今天是:2025年04月23日(星期三)
正在发生
2018年04月23日 | ARM CMSIS Driver 学习 之 USART
2018-04-23 来源:eefocus
 最近把 MDK 升级到了 V5.25 ,发现 Managing Run-Time Environment 中已经有好多好多的库。相比之前已经好了太多太多,从底层驱动,到上层协议栈,常用的有不常用的也有。发现 ARM 对这套系统的更新速度加快了一些,觉得有必要学习一下。从驱动开始学起,先学 USART API 详细介绍见 CMSIS Driver USART API
USART 把收到的数据再发出去程序
  * @file    main.c
  * @author  XinLi
  * @version v1.0
  * @date    20-March-2018
  * @brief   Main program body.
  * @attention
Copyright © 2018 XinLi
  * This program is free software: you can redistribute it and/or modify
  * it under the terms of the GNU General Public License as published by
  * the Free Software Foundation, either version 3 of the License, or
  * (at your option) any later version.
  * This program is distributed in the hope that it will be useful,
  * but WITHOUT ANY WARRANTY; without even the implied warranty of
  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  * GNU General Public License for more details.
  * You should have received a copy of the GNU General Public License
  * along with this program.  If not, see
/* Header includes -----------------------------------------------------------*/
#include "stm32f4xx.h"
#include "Driver_USART.h"
#include
/* Macro definitions ---------------------------------------------------------*/
/* Type definitions ----------------------------------------------------------*/
/* Variable declarations -----------------------------------------------------*/
extern ARM_DRIVER_USART Driver_USART1;
/* Variable definitions ------------------------------------------------------*/
static uint8_t rxBuffer[1024] = {0};
static uint8_t txBuffer[1024] = {0};
/* Function declarations -----------------------------------------------------*/
static void USART1_Callback(uint32_t event);
static void SystemClock_Config(void);
/* Function definitions ------------------------------------------------------*/
  * @brief  Main program.
  * @param  None.
  * @return None.
int main(void)
  /* STM32F4xx HAL library initialization:
       - Configure the Flash prefetch, instruction and Data caches
       - Configure the Systick to generate an interrupt each 1 msec
       - Set NVIC Group Priority to 4
       - Global MSP (MCU Support Package) initialization
  HAL_Init();
  /* Configure the system clock to 168 MHz */
  SystemClock_Config();
  Driver_USART1.Initialize(USART1_Callback);
  Driver_USART1.PowerControl(ARM_POWER_FULL);
  Driver_USART1.Control(ARM_USART_MODE_ASYNCHRONOUS |
                        ARM_USART_DATA_BITS_8 |
                        ARM_USART_PARITY_NONE |
                        ARM_USART_STOP_BITS_1 |
                        ARM_USART_FLOW_CONTROL_NONE, 115200);
  Driver_USART1.Control(ARM_USART_CONTROL_TX, 1);
  Driver_USART1.Control(ARM_USART_CONTROL_RX, 1);
  Driver_USART1.Receive(rxBuffer, sizeof(rxBuffer));
  for(;;)
  * @brief  USART1 callback function.
  * @param  event: USART events notification mask.
  * @return None.
  if(event & ARM_USART_EVENT_RX_TIMEOUT)
    Driver_USART1.Control(ARM_USART_ABORT_RECEIVE, 1);
    uint32_t length = Driver_USART1.GetRxCount();
    memcpy(txBuffer, rxBuffer, length);
    Driver_USART1.Send(txBuffer, length);
  * @brief  System Clock Configuration
  *         The system Clock is configured as follow :
  *            System Clock source            = PLL (HSE)
  *            SYSCLK(Hz)                     = 168000000
  *            HCLK(Hz)                       = 168000000
  *            AHB Prescaler                  = 1
  *            APB1 Prescaler                 = 4
  *            APB2 Prescaler                 = 2
  *            HSE Frequency(Hz)              = 8000000
  *            PLL_M                          = 8
  *            PLL_N                          = 336
  *            PLL_P                          = 2
  *            PLL_Q                          = 7
  *            VDD(V)                         = 3.3
  *            Main regulator output voltage  = Scale1 mode
  *            Flash Latency(WS)              = 5
  * @param  None
  * @retval None
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_OscInitTypeDef RCC_OscInitStruct;
  /* Enable Power Control clock */
  __HAL_RCC_PWR_CLK_ENABLE();
  /* The voltage scaling allows optimizing the power consumption when the device is
     clocked below the maximum system frequency, to update the voltage scaling value
     regarding system frequency refer to product datasheet.  */
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  /* Enable HSE Oscillator and activate PLL with HSE as source */
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 336;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 7;
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
     clocks dividers */
  RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5);
  /* STM32F405x/407x/415x/417x Revision Z devices: prefetch is supported  */
  if (HAL_GetREVID() == 0x1001)
    /* Enable the Flash prefetch */
    __HAL_FLASH_PREFETCH_BUFFER_ENABLE();
Electro Adapter Inc公司的发展小趣事
Electro Adapter Inc公司(以下简称EA公司)的成立源于创始人对电子行业未来发展的深刻洞察。在创立初期,EA公司主要生产一些基本的电源适配器,面临着激烈的市场竞争和资金短缺的双重压力。然而,创始人凭借其深厚的技术背景和敏锐的市场洞察力,不断研发新产品,提升产品质量,逐渐在市场上站稳了脚跟。特别是在一次技术革新中,EA公司率先推出了一款高效能、低成本的适配器,赢得了客户的青睐,也为公司的发展奠定了坚实的基础。
Chipcera Technology Co Ltd公司的发展小趣事
在电子行业的激烈竞争中,Chipcera Technology Co Ltd始终坚持以技术为核心的发展策略。某年,公司研发团队成功研发出一款具有更高耐压、更低损耗的陶瓷电容器。这款产品不仅满足了市场对高性能电容器的迫切需求,还为公司赢得了大量订单。随着该产品的广泛应用,Chipcera在行业内的影响力逐渐提升,为后续的发展奠定了坚实基础。
AiT Semiconductor Inc公司的发展小趣事
对于半导体行业来说,产品质量是企业的生命线。AiT公司一直注重质量管理,从原材料采购到产品生产、检测等各个环节都严格把关。他们引进了先进的质量管理体系和检测设备,确保每一件产品都符合高标准的质量要求。同时,公司还建立了完善的客户服务体系,及时解决客户在使用过程中遇到的问题。这些举措使得AiT公司的产品在市场上赢得了良好的口碑和客户信任。
高通(GENITOP)公司的发展小趣事
随着全球市场的不断拓展,超霸电池的销售网络遍布亚洲、欧洲和北美等多个国家和地区。公司始终坚持绿色环保的生产理念,研发出无汞无镉的电池产品,可随生活垃圾丢弃而不会对环境造成影响。此外,超霸电池还积极参与环保事业,旗下多家工厂获得了UL美国安全试验所废弃物零填埋认证。这些举措不仅彰显了超霸电池的社会责任感,也为其在国际市场上树立了良好的品牌形象。
Aptiv公司的发展小趣事
Aptiv公司在电子行业中以其领先的技术实力著称。早在1995年,公司便成立了自动驾驶研究实验室,开始探索自动驾驶技术的可能性。经过多年的研发与试验,Aptiv在自动驾驶领域取得了显著的突破。2004年,公司首次在内华达州成功测试了自动驾驶汽车,获得了州政府的批准,这标志着Aptiv在自动驾驶技术上迈出了坚实的步伐。此后,Aptiv不断推动自动驾驶技术的商业化进程,为全球汽车行业带来了新的发展机遇。
GS Technology公司的发展小趣事
在工业自动化和监测系统中,用于显示各种物理量的峰值。
语音单片机WT588D
Ü 外挂2M~32M的Flash,时间从32—1054秒。掩膜为内置ROM,最长支持400秒(@6K采样)。采样率支持6K~22K Ü DAC输出:13Bit,PWM输出:12Bit Ü 内置0.5W功放,可直接推动0.5W/8Ω扬声器 Ü 支持加载MP3/WAV/WMA三种音频 ...…
刚从京东订的主机就出问题了~
每次重启电源后开机,cpu、显卡风扇转一下就停了,主板无法上电,主板上的LED灯不亮,再按开机键就没有任何反应了,只能再次重启电源才能复现上述情况。 请问这是怎么回事啊?电源供电不足?还是主板烧了(为什么每次重启电源后风扇都能转一下呢) ...…
要做电源管理,有什么好的建议没?
功能一、    检测充电器的插拔         【我的想法:】可以用中断来做,这个好做 功能二、检测电池的电量:         只能用AD,将电压转成数字信号了, 就不知道怎么实 ...…
求教高手解决vxworks 启动盘制作问题
我在制作启动盘时如果选择bootrom_uncmp image则使用mkboot a: bootrom_uncmp指令时,弹出如下的对话框 D:\\Tornado2.2\\target\\config\\PCPENT~4>mkboot a: bootrom_uncmp VxSys 1.6 (c) Wind River 1993-2002 Boot sector installed OK. obj ...…
怎样用residentFlash保存用户数据
我用的是2410+wince4.2,flash用的是K9F1208UOM.在wince系统运行时,我能够看到ResidentFlash文件夹,而且好像用属性查看剩于空间也就是出去os镜像的大小.但是好像因为没有指定flash剩于空间的起始位置的原因吧,只要拷东西进这个文件夹,下次wince就别 ...…
早晨浏览见到个地铁应急灯大家看下,我看老好了
  这款地铁应急灯是为应付地铁突发状况准备的。当地铁突然停运,电源切断的时候,乘客们可以将把手取下,充当应急电筒使用。通过挤按把手上的按钮,就能够轻松将把手与带子分离。当然,只有在地铁熄灯之后才能启动这一按钮。   &n ...…
VHDL类属参数在verilog中怎么对应?
在VHDL中,类属参数可以在不同层次的模块间传递。可以在顶层修改这些参数,下面各层随之改变。 verilog中怎么实现这一功能? 谢谢!…
信号链基础知识合集2
  自《电源开关设计秘笈30例》推出以来,得到广大工程师的热烈反响, 已推出的由德仪资深工程师William P. (Bill) Klein 主笔的《信号链基础知识合辑》反响也非常好,   应大家的强烈要求,现隆重推出《信号链基础知识合辑2》   ...…
