今天是:2024年09月09日(星期一)
正在发生
2018年09月09日 | 基于51单片机SJA1000 CAN通讯实现
2018-09-09 来源:eefocus
经过一个星期的艰苦奋斗,终于将两个SJA1000通过51单片机成功通讯了!采用的是Pelican工作模式,扩展帧数据格式,验收滤波器是采用单滤波扩展帧模式。
发送和接收代码都全部相同样!
一 实物图
二 串口输出调试信息
三 以下是全部程序代码:包括1 main.c、2 uart.h、3 uart.c、4 sja1000.h、5 sja1000.c。
1main.c
#include "reg51.h"
#include "uart.h"
#include  "string.h"
#include  "sja1000.h"
sbit KEY=P2^5;
void main(void)
 unsigned char init,state,num,i=0;
 UART_Init();
    if(SJA_Interface_Test())
          UART_Send_String("\r\nSJA TO CPU Right!\r\n");
         else
          UART_Send_String("\r\nSJA TO CPU Error!\r\n");
         init=SJA_Init();
         if(init==0)
           UART_Send_String("\r\nSJA Init OK!\r\n");
        else
          UART_Send_String("\r\nSJA Init Error!\r\n");
          UART_Send_Byte(init);
    while(1)
     if(KEY==0)
             DelayMs(10);
             if(KEY==0)
              CAN_Send_Str("ILoveY\r\n");
              Display(num);
              if(num++==14) num=0;
             DelayMs(200);
      SJA_BCANAdr = REG_STATUS;
      state=*SJA_BCANAdr;
      if((state&0x40)==0x40) { UART_Send_String("\r\nSJA Error count overflow!!\r\n"); SJA_Init(); }
      if((state&0x20)==0x20)  UART_Send_String("SJA1000 CAN BUS is transmiting!\r\n");
2uart.h
#ifndef  __UART_H__
#define  __UART_H__
#include "stdio.h"
#include "reg51.h"
#define reclength 8
extern bit recfinish;
extern unsigned char recbuf[reclength];
void UART_Init(void);
void UART_Send_Byte(unsigned char ch);
void UART_Send_String(unsigned char *str);
void Display( char num);
void DelayMs(unsigned char t);
#endif
3uart.c
#include "uart.h"
unsigned char code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
unsigned char reccount=0;
bit recstart=0;
bit recfinish=0;
 SCON=0X50;
 TMOD|=0X20;
 TH1=0XFD;
 TL1=0XFD;
 TR1=1;
  EA=1;
  ES=1;
    SBUF=ch;
    while(!TI);//等到发送完成中断标志位置1
    TI=0;
 while(*str)
    UART_Send_Byte(*str);
     str++;
void UART_ISR(void)  interrupt 4
  //unsigned char temp;
 if(RI)
    if(recstart==0)
        recstart=1;
        reccount=0;
        recfinish=0;
    if(recstart)
        recbuf[reccount++]=SBUF;
        if((reccount==reclength)||(recbuf[reccount-1]=='z'))
            recfinish=1;
            reccount=0;
            recstart=0;
 RI=0;
 uS延时函数,含有输入参数 unsigned char t,无返回值
 unsigned char 是定义无符号字符变量,其值的范围是
 0~255 这里使用晶振12M,精确延时请使用汇编,大致延时
 长度如下 T=tx2+5 uS
void DelayUs2x(unsigned char t)
 while(--t);
 mS延时函数,含有输入参数 unsigned char t,无返回值
 while(t--)
     //大致延时1mS
     DelayUs2x(245);
DelayUs2x(245);
//共阳数码管显示 调试的时候用到 ,本程序最终没有用到。
    P1=table[num];
4sja1000.h
#ifndef  __SJA1000_H__
#define  __SJA1000_H__
#include  "string.h"
#include "uart.h"
#define  SJA_BaseAdr  0XFE00     //定义SJA RAM基址
                                 //P2口为地址线高八位 P0口为地址线低八位
                                 // CS接P2.0 地址线 1111 1110 0000 0000 即为0XFE00
                                 // CS接P2.7 地址线 0111 1111 0000 0000     0x7F00
#define         REG_CONTROL       SJA_BaseAdr+0x00       //内部控制寄存器
#define         REG_COMMAND       SJA_BaseAdr+0x01       //命令寄存器      只写
#define         REG_STATUS        SJA_BaseAdr+0x02       //状态寄存器      只读
#define         REG_INTERRUPT     SJA_BaseAdr+0x03       //中断寄存器      只读
#define         REG_INTENABLE     SJA_BaseAdr+0x04       //中断使能寄存器   可读可写
#define         REG_RESVER0       SJA_BaseAdr+0x05       //保留0
#define         REG_BTR0          SJA_BaseAdr+0x06       //总线定时寄存器0  复位模式读写
                                                         //定义了波特率预设值BRP 和同步跳转宽度SJW 的值
#define         REG_BTR1          SJA_BaseAdr+0x07       //总线定时寄存器1  复位模式读写
//总线定时寄存器1 定义了每个位周期的长度采样点的位置和在每个采样点的采样数目
#define         REG_OCR           SJA_BaseAdr+0x08       //输出控制寄存器  复位模式读写
//输出控制寄存器实现了由软件控制不同输出驱动配置的建立
#define         REG_TEST          SJA_BaseAdr+0x09       //测试寄存器
#define         REG_RESVER1       SJA_BaseAdr+0x0A       //保留1
#define         REG_ARBITRATE     SJA_BaseAdr+0x0B       //仲裁丢失捕捉    只读
#define         REG_ERRCATCH      SJA_BaseAdr+0x0C       //错误代码捕捉    只读
#define         REG_ERRLIMIT      SJA_BaseAdr+0x0D       //错误报警限额    工作模式只读 复位模式可读写
#define         REG_RXERR         SJA_BaseAdr+0x0E         //接收错误计数器工作模式只读 复位模式可读写
#define         REG_TXERR         SJA_BaseAdr+0x0F         //发送错误计数器工作模式只读 复位模式可读写
#define         REG_ACR0          SJA_BaseAdr+0x10       //验收代码寄存器
#define         REG_ACR1          SJA_BaseAdr+0x11       //验收代码寄存器
#define         REG_ACR2          SJA_BaseAdr+0x12       //验收代码寄存器
#define         REG_ACR3          SJA_BaseAdr+0x13       //验收代码寄存器
#define         REG_AMR0          SJA_BaseAdr+0x14       //验收屏蔽寄存器
#define         REG_AMR1          SJA_BaseAdr+0x15       //验收屏蔽寄存器
#define         REG_AMR2          SJA_BaseAdr+0x16       //验收屏蔽寄存器
#define         REG_AMR3          SJA_BaseAdr+0x17       //验收屏蔽寄存器
// 发送缓冲区寄存器  (发送缓冲区长13字节,在CAN地址是16-28即0x10-0x1c)
#define         REG_TXBuffer1     SJA_BaseAdr+0x10         //发送缓冲区1
#define         REG_TXBuffer2     SJA_BaseAdr+0x11         //发送缓冲区2
#define         REG_TXBuffer3     SJA_BaseAdr+0x12         //发送缓冲区3
#define         REG_TXBuffer4     SJA_BaseAdr+0x13         //发送缓冲区4
#define         REG_TXBuffer5     SJA_BaseAdr+0x14         //发送缓冲区5
#define         REG_TXBuffer6     SJA_BaseAdr+0x15         //发送缓冲区6
#define         REG_TXBuffer7     SJA_BaseAdr+0x16         //发送缓冲区7
#define         REG_TXBuffer8     SJA_BaseAdr+0x17         //发送缓冲区8
#define         REG_TXBuffer9     SJA_BaseAdr+0x18         //发送缓冲区9
#define         REG_TXBuffer10    SJA_BaseAdr+0x19         //发送缓冲区10
#define         REG_TXBuffer11    SJA_BaseAdr+0x1A         //发送缓冲区11
#define         REG_TXBuffer12    SJA_BaseAdr+0x1B         //发送缓冲区12
#define         REG_TXBuffer13    SJA_BaseAdr+0x1C         //发送缓冲区13
// 接收缓冲区寄存器   (接收缓冲区长13字节,在CAN地址是16-28即0x10-0x1c)
#define         REG_RXBuffer1     SJA_BaseAdr+0x10       //接收缓冲区1
#define         REG_RXBuffer2     SJA_BaseAdr+0x11       //接收缓冲区2
#define         REG_RXBuffer3     SJA_BaseAdr+0x12        //接收缓冲区3
#define         REG_RXBuffer4     SJA_BaseAdr+0x13       //接收缓冲区4
#define         REG_RXBuffer5     SJA_BaseAdr+0x14        //接收缓冲区5
#define         REG_RXBuffer6     SJA_BaseAdr+0x15         //接收缓冲区6
#define         REG_RXBuffer7     SJA_BaseAdr+0x16         //接收缓冲区7
#define         REG_RXBuffer8     SJA_BaseAdr+0x17         //接收缓冲区8
#define         REG_RXBuffer9     SJA_BaseAdr+0x18         //接收缓冲区9
#define         REG_RXBuffer10    SJA_BaseAdr+0x19        //接收缓冲区10
#define         REG_RXBuffer11    SJA_BaseAdr+0x1A        //接收缓冲区11
#define         REG_RXBuffer12    SJA_BaseAdr+0x1B        //接收缓冲区12
#define         REG_RXBuffer13    SJA_BaseAdr+0x1C        //接收缓冲区13
#define         REG_RXCOUNT       SJA_BaseAdr+0x1D         //RX报文计数器  只读 RX信息计数器(RMC)反应RXFIFO中可用的信息数目
#define         REG_RBSA          SJA_BaseAdr+0x1E         //RX缓冲器起始地址寄存器(RBSA)可读写 复位模式只写
                                                           //反映了当前可用来存储位于接收缓冲器窗口中的信息的内部RAM地址
#define         REG_CDR           SJA_BaseAdr+0x1F         //时钟分频寄存器
//时钟分频寄存器为微控制器控制CLKOUT 的频率以及屏蔽CLKOUT 引脚而且它还控制着TX1上
//的专用接收中断脉冲接收比较通道和BasicCAN 模式与PeliCAN 模式的选择
功能说明:   CAN控制器SJA1000通讯波特率.SJA1000的晶振为必须为16MHZ*/
#define         BTR0_Rate_20k      0x53          //20KBPS的预设值
#define         BTR1_Rate_20k      0x2F          //20KBPS的预设值
#define         BTR0_Rate_40k      0x87          //40KBPS的预设值
#define         BTR1_Rate_40k      0xFF          //40KBPS的预设值
#define         BTR0_Rate_50k      0x47          //50KBPS的预设值
#define         BTR1_Rate_50k      0x2F          //50KBPS的预设值
#define         BTR0_Rate_80k      0x83          //80KBPS的预设值
#define         BTR1_Rate_80k      0xFF          //80KBPS的预设值
#define         BTR0_Rate_100k     0x43          //100KBPS的预设值
#define         BTR1_Rate_100k     0x2f          //100KBPS的预设值
#define         BTR0_Rate_125k     0x03          //125KBPS的预设值
#define         BTR1_Rate_125k     0x1c          //125KBPS的预设值
#define         BTR0_Rate_200k     0x81          //200KBPS的预设值
#define         BTR1_Rate_200k     0xFA          //200KBPS的预设值
#define         BTR0_Rate_250k     0x01          //250KBPS的预设值
#define         BTR1_Rate_250k     0x1c          //250KBPS的预设值
#define         BTR0_Rate_400k     0x43          //400KBPS的预设值
#define         BTR1_Rate_400k     0x11          //400KBPS的预设值
#define         BTR0_Rate_500k     0x81          //500KBPS的预设值
#define         BTR1_Rate_500k     0x23          //500KBPS的预设值
#define         BTR0_Rate_666k     0x41          //666KBPS的预设值
#define         BTR1_Rate_666k     0x12          //666KBPS的预设值
#define         BTR0_Rate_800k     0x41          //800KBPS的预设值
#define         BTR1_Rate_800k     0x11          //800KBPS的预设值
#define         BTR0_Rate_1000k    0x40          //1000KBPS的预设值
#define         BTR1_Rate_1000k    0x23          //1000KBPS的预设值
//BPS
//功能说明:   CAN控制器SJA1000通讯波特率.SJA1000的晶振为必须为24MHZ*/
#define         BTR0_Rate_10k      0xEF          //20KBPS的预设值
#define         BTR1_Rate_10k      0xFF          //20KBPS的预设值
#define         ByteRate_10k       10
#define         ByteRate_20k       20
#define         ByteRate_40k       40
#define         ByteRate_50k       50
#define         ByteRate_80k       80
#define         ByteRate_100k      100
#define         ByteRate_125k      125
#define         ByteRate_200k      200
#define         ByteRate_250k      250
#define         ByteRate_400k      400
#define         ByteRate_500k      500
#define         ByteRate_800k      800
#define         ByteRate_1000k     1000
//命令字
#define    TR_CMD     0X01  //CMR.0发送请求位
#define    AT_CMD     0X02  //CMR.1中止发送位
#define    RRB_CMD    0X04  //CMR.2释放接收缓冲器
#define    COS_CMD    0X08  //CMR.3清除数据溢出
#define    SRR_CMD    0X10  //CMR.4自接收模式
#define    GTS_CMD    0X10  //????CMR.5.CMR7保留位
//错误字
#define CAN_INTERFACE_OK      0     //CAN总线接口OK
#define CAN_BUS_OK            0     //CAN总线OK
#define CAN_INTERFACE_ERR     0XFF  //CAN总线接口错误
#define CAN_ENTERSET_ERR      0XFE  //CAN总线初始化错误
#define CAN_QUITSET_ERR       0XFD  //CAN总线退出复位模式错误
#define CAN_INITOBJECT_ERR    0XFC  //CAN总线初始化对象错误
#define CAN_INITBTR_ERR       0XFB  //?
#define CAN_INITOUTCTL_ERR    0XFA  //??
#define CAN_INTCLKDIV_ERR     0XF9  //??
#define CAN_BUS_ERR           0XF8  //CAN总线错误
#define ID28_21    0X0A;
#define ID20_13    0X4A;
#define ID12_5     0X6B;
#define ID4_0      0XE8; //低三位不影响设为0
//定义扩展模式数据帧ID
//Basic CAN模式标准帧格式 :帧信息,TX识别码1-2,TX数据字节1-8
//Pelican模式扩展帧格式   :帧信息,TX识别码1-4,TX数据字节1-8
extern unsigned char xdata *SJA_BCANAdr;
bit SJA_Interface_Test(void);
bit Set_OutClock(unsigned char outclock);//只能用于复位模式
bit SET_ACR(unsigned char BCAN_ACR0,unsigned char BCAN_ACR1,unsigned char BCAN_ACR2,unsigned char BCAN_ACR3);
bit SET_AMR(unsigned char BCAN_AMR0,unsigned char BCAN_AMR1,unsigned char BCAN_AMR2,unsigned char BCAN_AMR3);
bit Set_Bandrate(unsigned char bandrate);//只能用于复位模式
bit Set_ContrREG(unsigned char CMD);//设置控制(模式)寄存器
bit Enter_RST_Mode(void);
bit Quit_RST_Mode(void);
bit CAN_CMD_PRG(unsigned char cmd);//命令请求
bit Set_IntEnable(unsigned char CMD);
unsigned char CAN_Write(unsigned char *SendDataBuf);
void CAN_Send_onebyte(unsigned char CAN_TX_data);
unsigned char SJA_Init(void);
void CAN_Send_Str(unsigned char *str);
#endif
5.sja1000.c
sbit LED=P1^0;
unsigned char RevceData[8];
//C语言指针说明以 * 为分隔符,
//“*” 前面的存储类型修饰—指针所指向的对象数据的存储位置;
//“*” 后面的存储类型修饰—指针本身所分配的存储位置。
//unsigned char xdata *P说明指针指向的对象是一个处于Xdata的元素,比如数组.
//xdata unsigned char *p表明指针本身位于Xdata,至于指向什么类型的地址,自由变换.
//所以unsigned char xdata *p; 和xdata unsigned char *p   不一样。说明的是2回事。
//而:xdata unsigned char *p; 和 unsigned char  * xdata p; 完全一样。
//因为C写法中允许“最前面的存储类型修饰符修饰最后面的对象。”
函数功能:检测SJA1000与CPU数据接口是否正确连接
入口参数:
返回参数:1正确 0错误
说明:
   SJA_BCANAdr=REG_TEST;
   *SJA_BCANAdr=0xAA;
   if(*SJA_BCANAdr==0XAA)
   return 1;
   else return 0;
函数功能:设置分频系数  工作模式
入口参数:
返回参数:1设置成功 0失败
说明:此处设置为PeliCAN模式,终止CAN输入比较器(复位模式),关闭时钟输出
   SJA_BCANAdr=REG_CDR ;
   *SJA_BCANAdr=outclock;
   if(*SJA_BCANAdr==outclock)
   return 1;
   else return 0;
函数功能:设置验收验收代码寄存器和接收屏蔽码寄存器 只有在复位模式下才能访问该寄存器
入口参数:各个寄存器的写入值
返回参数:1设置成功 0 设置失败
说明:设置CAN节点的通讯对象,允许接收的报文,是由AMR和ACR共同决定的.
PeliCAN工作模式下滤波模式分为:
1.单滤波器模式 模式寄存器(MOD.3=1)
    这种滤波模式可以定义一个4字节长虑波器 。虑波器字节和信息字节之位的对应关系取决于当前接收帧的格式。
标准帧:11位标识符、RTR位、数据场前连个字节参与滤波。对于参与滤波的数据,所有AMR为0的位所对应的ACR位
和参与滤波数据的对应位必须相同才算验收通过。如果由于置位RTR位而没有数据字节,或因为设置相应的数据长度代码
而没有或只有一个数据字节,报文也会被接收。ACR1和AMR1的低四位是不用的,此时可将AMR1.3-AMR1.0设为1,定为不影响
扩展帧:29位标识符和RTR位参与滤波。此时ACR3和AMR3的最低两位是不用的。将AMR3.1、AMR3.0置1,定为不影响。
2.双滤波器模式 模式寄存器(MOD.3=0)至少有一个滤波器验收通过,数据才能正常接收。
接收标准帧:第一个滤波器由ACR0、ACR1、AMR0、AMR1及ACR3、AMR3的低四位组成。11位标识符、RTR位和数据场的第一个字节参与滤波
在RTR位置位1或数据长度代码是0,表示没有数据字节存在时,只要从开始到RTR位的部分都表示接收。信息就可以通过滤波器1
第二个滤波器由ACR2、AMR2及ACR3、AMR3的高四位组成。11位标识符和RTR位参与滤波。
如果没有数据字节向滤波器请求过滤,AMR1和AMR3的低四位必须被置1,表示不影响。此时两个滤波器的识别工作都是验证
包括RTR在内的整个标准识别码。
接收扩展帧:定义的两个滤波器是相同的
第一个滤波器由ACR0、ACR1和AMR0、AMR1构成
第二个滤波器由ACR2、ACR3和AMR2、AMR3构成
两个滤波器都只比较扩展识别码的前两个字节即29位识别码中的搞16位
    SJA_BCANAdr=REG_ACR0;
   *SJA_BCANAdr=BCAN_ACR0;
    SJA_BCANAdr=REG_ACR1;
   *SJA_BCANAdr=BCAN_ACR1;
    SJA_BCANAdr=REG_ACR2;
   *SJA_BCANAdr=BCAN_ACR2;
    SJA_BCANAdr=REG_ACR3;
   *SJA_BCANAdr=BCAN_ACR3;
    if(*SJA_BCANAdr!=BCAN_ACR3)  return 0;
    return 1;
 SJA_BCANAdr=REG_AMR0;
   *SJA_BCANAdr=BCAN_AMR0;
    SJA_BCANAdr=REG_AMR1;
   *SJA_BCANAdr=BCAN_AMR1;
    SJA_BCANAdr=REG_AMR2;
   *SJA_BCANAdr=BCAN_AMR2;
    SJA_BCANAdr=REG_AMR3;
   *SJA_BCANAdr=BCAN_AMR3;
    if(*SJA_BCANAdr!=BCAN_AMR3) return 0;
    return 1;
函数功能:设置CAN总线通信波特率
入口参数:波特率
返回参数:1设置成功 0设置失败
说明:该子程序只能用于复位模式
      因为总线定时器BTRO-BTR1只有在复位模式下才能读写操作,工作模式只读
    unsigned char BR_Num= bandrate,BTR0_num,BTR1_num;
    switch (BR_Num)
        case ByteRate_10k:
             BTR0_num=BTR0_Rate_10k;
             BTR1_num=BTR0_Rate_10k;
             break;
        case ByteRate_20k:
             BTR0_num=BTR0_Rate_20k;
             BTR1_num=BTR0_Rate_20k;
             break;
        case ByteRate_40k:
             break;
        case ByteRate_50k:
             BTR0_num=BTR0_Rate_50k;
             BTR1_num=BTR0_Rate_50k;
             break;
        case ByteRate_80k:
             BTR0_num=BTR0_Rate_80k;
             BTR1_num=BTR0_Rate_80k;
             break;
        case ByteRate_100k:
             BTR0_num=BTR0_Rate_100k;
             BTR1_num=BTR0_Rate_100k;
             break;
        case ByteRate_125k:
             BTR0_num=BTR0_Rate_125k;
             BTR1_num=BTR0_Rate_125k;
             break;
        case ByteRate_200k:
             BTR0_num=BTR0_Rate_200k;
             BTR1_num=BTR0_Rate_200k;
             break;
        case ByteRate_250k:
             BTR0_num=BTR0_Rate_250k;
             BTR1_num=BTR0_Rate_250k;
             break;
        case ByteRate_400k:
             BTR0_num=BTR0_Rate_400k;
             BTR1_num=BTR0_Rate_400k;
             break;
        case ByteRate_500k:
             BTR0_num=BTR0_Rate_500k;
             BTR1_num=BTR0_Rate_500k;
             break;
        case ByteRate_1000k:
             BTR0_num=BTR0_Rate_1000k;
             BTR1_num=BTR0_Rate_1000k;
             break;
        default :return 0;break;
    SJA_BCANAdr=REG_BTR0;
    *SJA_BCANAdr=BTR0_num;
    if(*SJA_BCANAdr!=BTR0_num) return 0;
    SJA_BCANAdr=REG_BTR1;
    *SJA_BCANAdr=BTR1_num;
    if(*SJA_BCANAdr!=BTR1_num) return 0;
    return 1;
函数功能:设置控制(模式)寄存器
入口参数:写入的命令
返回参数:
说明:模式寄存器的内容是用来改变CAN 控制器的行为
    SJA_BCANAdr  = REG_CONTROL;//控制寄存器
    *SJA_BCANAdr=CMD;
    if(*SJA_BCANAdr==CMD) return 1;
    else return 0;
函数功能:设置复位请求和单滤波工作模式
入口参数:
返回参数:
说明:
    *SJA_BCANAdr=0x09;           //置位复位请求 和单滤波模式
    if((*SJA_BCANAdr&0x01) == 1)
     return   1;
    else
     return   0;
函数功能:
入口参数:
返回参数:
说明:
    SJA_BCANAdr=REG_CONTROL;            //退出 复位模式
    *SJA_BCANAdr=*SJA_BCANAdr&0xfe;
    if((*SJA_BCANAdr&0X01)==0)
        return 1;
    else return 0;
函数功能:发送命令请求,并返回请求结果
入口参数:
返回参数:0请求成功 1请求失败
说明:
   SJA_BCANAdr=REG_COMMAND;            //访问地址指向命令寄存器
   *SJA_BCANAdr=cmd;                   //启动命令字
   switch(cmd)
     case  TR_CMD:    //发送请求
           return    1;
           break;
     case  SRR_CMD:     //CMR.4自接收模式
           return 1;
           break;
     case  AT_CMD:      //CMR.1中止发送位
           SJA_BCANAdr = REG_STATUS;   //访问地址指向状态寄存器
           if((*SJA_BCANAdr & 0x20)==0) //判断是否正在发送 (0正在发送 1等待空闲)
             return  1;
           else
             return  0;
           break;
     case  RRB_CMD:   // CMR.2释放接收缓冲器
           if((*SJA_BCANAdr & 0x01)==1) //判断接收缓冲器是否为空 (0为空 1不为空)
              return  0;//若不为空 则释放接收缓冲器失败
           else
              return  1;
           break;
     case  COS_CMD:  //CMR.3清除数据溢出
           if((*SJA_BCANAdr & 0x02)==0)//判断清除溢出是否成功
             return  1;
           else
             return  0;
           break;
     default:
             return  0;
             break;
函数功能:设置中断使能寄存器
入口参数:
返回参数:
说明:
  SJA_BCANAdr=REG_INTENABLE;   //SJA_BaseAdr+0x00  控制寄存器
  *SJA_BCANAdr=CMD;
  if (*SJA_BCANAdr == CMD)
    return 1;
  else
    return 0;
    unsigned char temp;
    temp=*SJA_BCANAdr;
    if ((temp&0x08)==0) return  1;    //上次发送未完成
    if ((temp&0x04)==0) return  2;    //发送缓冲区是否锁定
    if ((temp&0x10)==0x10) return 3;  //判断是否正在接收
    SJA_BCANAdr = REG_RXBuffer1;      //访问地址指向发送缓冲区1,修改成头文件
    memcpy(SJA_BCANAdr,SendDataBuf,4); //将SendDataBuf起始地址的的4个字节数据拷贝到 SJA_BCANAdr 发送缓冲区中
    CAN_CMD_PRG(TR_CMD);             //请求发送
    return 0;
//CAN发送一个字节
unsigned char temptt;
loop:
         temptt=*SJA_BCANAdr;
//temptt=Read_SJA1000(REG_STATUS);
if((temptt&0x04)==0x00)  goto loop;//循环检测等待
//可以向发送缓冲器写数据
    *SJA_BCANAdr=0x01;
    SJA_BCANAdr = REG_RXBuffer2;
    *SJA_BCANAdr=0x28;
     SJA_BCANAdr = REG_RXBuffer3;
    *SJA_BCANAdr=0x00;
    SJA_BCANAdr = REG_RXBuffer4;
    *SJA_BCANAdr=CAN_TX_data;
//数据发送请求
    unsigned char temptt,length;
loop:
//可以向发送缓冲器写数据
    length=strlen(str);
    SJA_BCANAdr = REG_TXBuffer1;
    *SJA_BCANAdr=0x80|length; //设置发送信息帧位扩展数据帧 和发送的数据字节长度
    SJA_BCANAdr = REG_TXBuffer2;
    *SJA_BCANAdr=ID28_21;
     SJA_BCANAdr = REG_TXBuffer3;
    *SJA_BCANAdr=ID20_13;
    SJA_BCANAdr = REG_TXBuffer4;
    *SJA_BCANAdr=ID12_5;
    SJA_BCANAdr =REG_TXBuffer5;
    *SJA_BCANAdr=ID4_0;
    SJA_BCANAdr = REG_TXBuffer6;
    memcpy(SJA_BCANAdr,str,length);
//数据发送请求
函数功能:SJA1000初始化
入口参数:
返回参数:
说明:
    bit s;
    EA=0;//关总中断
    if (!Enter_RST_Mode()) return 1; //设置模式(控制)寄存器 置位复位请求位 和验收滤波模式位(单滤波模式)
    if (!SJA_Interface_Test()) return 2; //!!!!!我觉得此处逻辑上应先测试SJA1000再进行复位操作
    //0XC8=1100 0000 最高位CDR.7(CANmode位)=1=Pelican模式(=0=BasicCAN模式)
    //置位CDR.6 可以中止CAN 输入比较器 CDR.3置位关闭external CLKOUT CD2-CD0 设置时钟分频
    //设置为PeliCAN模式,终止CAN输入比较器(复位模式),关闭时钟输出
    if (!Set_OutClock(0XC8)) return 3;
    //设置滤波器滤波条件
    SET_ACR(0x0A,0x4A,0x6B,0x78);
    s=SET_AMR(0x00,0x00,0x00,0x03);
    if (s==0) return 4;
    if (!Set_Bandrate(ByteRate_1000k)) return 5;//设置通信波特率
    if (!Set_IntEnable(0x1D)) return 6;
    SJA_BCANAdr=REG_OCR ;               //输出控制寄存器
    *SJA_BCANAdr=0x1a;                  //设置为正常输出模式
     if(!Quit_RST_Mode()) return 7;
     EA=1;
     PX0=1;//外部中断0定义为高优先级中断
     EX0=1;//开启外部中断
     IT0=0;//外部中断0触发方式选择位 此处设置为低电平触发
     return 0;
void Int0_ISR() interrupt 0
 unsigned char tt,length;
 SJA_BCANAdr=REG_INTERRUPT;//中断寄存器
 if((*SJA_BCANAdr)&0x01)   //产生了接收中断
    UART_Send_String("SJA1000 Has recieved data!\r\n");
    SJA_BCANAdr=REG_RXBuffer1;//CAN地址16  TX帧信息 低四位DLC.3-DLC.0数据长度代码为
    tt=*SJA_BCANAdr;
    length=tt&0x0F;//获取数据长度代码
     if ((tt&0x40)!=0x40)                 //最高位为帧格式位=0数据帧   =1 为远程帧
     SJA_BCANAdr=REG_RXBuffer6;           //宏定义的变量不能memcpy(RevceData,REG_RXBuffer4,8);
     memcpy(RevceData,SJA_BCANAdr,length);//功能:由src所指内存区域复制count个字节到dest所指内存区域
                                          //测试用的主要是把接收到的数据在发出去,验证数据的正确
                                          //以下代码是发送到串
     UART_Send_String(RevceData);
     CAN_CMD_PRG(RRB_CMD);                //释放SJA1000接收缓冲区,****已经修改
Auris公司的发展小趣事
Auris公司在技术研发方面取得了显著成果。其中,一款名为Auris Robotic Endoscopy System(ARES)的医疗机器人尤为引人注目。这款机器人能够通过精准的操控,帮助医生在不切口的情况下发现早期肺癌,提高了诊断的精确性。20XX年,食品与药品监督管理局(FDA)正式批准了ARES机器人的使用,这是对Auris公司技术实力和产品质量的高度认可。
Benchmarq Microelectronics Inc公司的发展小趣事
在半导体行业中,供应链的稳定性和可靠性对企业的发展至关重要。Benchmarq Microelectronics Inc深知这一点,因此始终注重供应链管理和合作伙伴关系的建立。公司与多家知名供应商建立了长期稳定的合作关系,确保原材料的稳定供应和质量可控。同时,公司还加强库存管理和物流配送,确保产品能够及时、准确地送达客户手中。这些努力不仅提升了公司的运营效率和市场竞争力,还为客户提供了更加便捷、高效的服务。
Frequency Electronics Inc公司的发展小趣事
高频电子深知技术创新是企业持续发展的核心动力。因此,公司一直保持着对研发的持续投入,不断推出新产品、新技术和新服务。同时,高频电子还积极与高校、科研机构等合作,共同开展前沿技术的研发和应用。这些努力使得高频电子在技术创新方面始终保持着领先地位,为公司的长期发展奠定了坚实的基础。
综上所述,高频电子通过战略转型、技术创新、全球化布局、多元化业务布局以及持续投入研发等举措,实现了从一家小型国防合同制造商到全球领先的高科技供应商的华丽蜕变。这些故事不仅展现了高频电子的发展历程和成就,也为我们揭示了企业成功背后的关键因素。
Diode Laser Concepts公司的发展小趣事
随着技术的不断成熟,Diode Laser Concepts公司开始将产品推向市场。公司凭借其卓越的性能和稳定性,在电子制造、半导体加工等领域迅速获得了客户的认可。同时,公司不断投入研发,推出了一系列创新的二极管激光产品,如超短脉冲激光器和高精度定位系统等,进一步巩固了市场地位。
Eink公司的发展小趣事
进入21世纪,E-Ink继续推动电子纸技术的发展。2000年,E-Ink与美国朗讯科技公司合作,成功开发出第一张可卷曲的电子纸和电子墨。随后,在2001年,E-Ink与日本Toppan Printing公司合作,利用Toppan的滤镜技术生产出了彩色电子纸,这是电子纸技术的一大突破。
Chauvin Arnoux公司的发展小趣事
到了1960年,Chauvin Arnoux推出了Monoc测试仪,这是一种带有旋转开关和统一测量刻度的测量仪器。Monoc测试仪以其简洁、直观的操作界面和精确的测量能力,迅速成为电工行业的首选测量工具。这一产品的普及,进一步巩固了Chauvin Arnoux在电气测量领域的领导地位。
GPIO驱动中,IO口发生中断后, 读取数据的问题.
GPIO驱动中,IO口发生中断后, 读取数据的问题. GPIO驱动中,IO口发生中断后,驱动是读IO口寄存器的一位数据,还是将IO口上的数据全部读完? 三星6410 BSP中有这样的参考代码吗? …
SQLCE创建错误
    在一个PDA(WinCE5.0操作系统),依次安装了以下三个程序:     1)sqlce.wce5.armv4i.CAB     2)sqlce.repl.wce5.armv4i.CAB     3)sqlce.dev.CHS.wce5.armv4i.CAB     上述三个cab ...…
wince6.0 directshow例子编译问题
我编译DirectX\\Directshow\\ddxclmv项目,已经加入strmiids.lib strmbase.lib ddraw.lib了,但连接时依然报错, 无法解析的外部符号 \"void __cdecl DbgLogInfo(unsigned long,unsigned long,wchar_t const *,...) 无法解析的外部符号 \"public: ...…
关于wince、2410 com2,com3的问题
找了好多论坛、资料都解决不了 还有个位帮忙…
转行通信系统开发准备工作,希望给点指引.
有一亲戚在一大公司作副总,估计进去不成问题。可能就是自已是否能站住脚的问题 本人情况:C#.NET开发工程师 三年应用软件开发经验 现转通信系统开发,需要提前专握些什么技术? 职位介绍: ------------------------------------------------ ...…
Windows CE讨论群~ 群号49889190~欢迎高手们参加讨论给予帮助~也欢迎新手们增添人气
Windows CE讨论群~ 群号49889190~欢迎高手们参加讨论给予帮助~也欢迎新手们增添人气 新年快乐!…
基于智能传感的机动车动载荷监测系统软件设计
这是我的毕业设计,需要用到51单片机汇编程序,请问有人有资料吗???由于资料太少了,所以在这向大家求救啊!如果有就太感谢了 …
南华大学黄智伟系列--为竞赛准备好一些常用的电路模块
本帖最后由 paulhyde 于 2014-9-15 03:21 编辑 一. 需要准备的一些模块 1. 微控制器电路模块:单片机,FPGA,ARM,DSP 2. 微控制器外围电路模块:键盘及LED数码管显示器模块,LCD显示器模块,触摸屏显示器模块,RS-485总线通信模块,CAN总线通信 ...…
高级嵌入式软件测试,单片机开发人员(北京)
单片机开发工程师-1人岗位职责:1、负责数码电子雷管仿真校准平台软件代码编程; 2、负责延时控制电路测试; 3、负责延时控制电路测试平台的搭建与开发;4、负责研发文档的撰写。任职要求:1、电子工程、自动化、机电、计算机相关专业,本科或 ...…
关于用MATLAB画波特图时相角设置问题,急求大神指导!
这个图上画出的相频特性范围是360~90,但我希望设置为0~-270,请问程序上该如何改动? 下附程序: clear; s=tf(\'s\'); U1=35;R=2.45;L=38e-6;C=2820e-6;D=0.686; Gvd=-(U1/D)*(s*L/R-D*D)/(D*D+s*L/R+s*s*L*C); margin(Gvd); grid; …
