今天是:2024年09月22日(星期日)
2018年09月22日 | STM32 ADC单次转换实例
2018-09-22 来源:eefocus
ADC的初始化步骤:
1.初始化ADC所用的通道IO
2.开启ADC的时钟并初始化ADC的结构体
3.调用ADC_Cmd函数进行使能ADC,目的是可以进行读写ADC的寄存器
4.校准ADC(这一步不是必须的,校准ADC时ADC硬件会生成一个校准码,来减小测量误差,校准过的ADC比不校准的准确)
5.调用ADC_RegularChannelConfig写入规则通道的信息(包括写入SQR寄存器的值,采样时间等)
6.调用ADC_SoftwareStartConvCmd函数开启ADC采样
7.等待采样完成,并读取ADC数据
ADC部分代码如下:
#include "adc.h"
static void ADC_GPIO_Config(void)
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //ʹÄÜPB,PE¶Ë¿ÚʱÖÓ
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AIN;
GPIO_Init(GPIOA, &GPIO_InitStructure);
void ADC_Mode_Config(void)
ADC_InitTypeDef ADC_InitStructure;
ADC_GPIO_Config();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
ADC_DeInit(ADC1);
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
ADC_InitStructure.ADC_ScanConvMode=DISABLE;
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfChannel=ADC_Channel_1;
ADC_Init(ADC1,&ADC_InitStructure);
ADC_Cmd(ADC1,ENABLE);
ADC_ResetCalibration(ADC1);
while(ADC_GetResetCalibrationStatus(ADC1)==SET);
ADC_StartCalibration(ADC1);
while(ADC_GetCalibrationStatus(ADC1)==SET);
u16 ADC_STARTConver(void)
u16 adcconverdata;
ADC_RegularChannelConfig(ADC1,ADC_Channel_1,1,ADC_SampleTime_239Cycles5);
ADC_SoftwareStartConvCmd(ADC1,ENABLE);
while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));
adcconverdata=ADC_GetConversionValue(ADC1);
return adcconverdata;
main函数中执行如下循环
AdcConverValue=ADC_STARTConver();
printf("AdcConverValue=%d \r\n",AdcConverValue);
接下来就是执行结果了:
上面是我引脚悬空时候的结果,下图是测量0V时的图片:
值得注意的是ADC_Cmd这个命令,当把上面程序的ADC_SoftwareStartConvCmd(ADC1,ENABLE);命令更换为ADC_Cmd(ADC1,ENABLE);命令时程序仍然正常运行,原因如下:
void ADC_Cmd(ADC_TypeDef* ADCx, FunctionalState NewState)
assert_param(IS_ADC_ALL_PERIPH(ADCx));
assert_param(IS_FUNCTIONAL_STATE(NewState));
if (NewState != DISABLE)
ADCx->CR2 |= CR2_ADON_Set;
else
ADCx->CR2 &= CR2_ADON_Reset;
从上面的函数原型可以看出ADC_CMD函数设置的是CR2寄存器的ADON位
打开参考手册,找到这个位,解释如下:
从上图中我们可以看到,当该位为1时,再写入1的话则是启动ADC转换,而不是无效命令,我们程序在ADC初始化的时候已经调用过一次ADC_CMD函数,所以该位为1,所以当我们将ADC_SoftwareStartConvCmd(ADC1,ENABLE);函数更换为ADC_Cmd(ADC1,ENABLE)时,程序一点影响都没有,照常运行。
上一篇:STM32 ADC转换中断读取
下一篇:stm32标准库dma初始化详解
来源:窗户纸 http://www.getproject.com.cn/post/98.html 机器人,听起来挺神秘的,在大多数科幻电影和文学作品中,机器人通常无所不知,无所不能,跟人类相比起来,简直就是完美无瑕了。因此,作品中的机器人,要么是人类的好朋友, ...… 查看全部问答> |
本帖最后由 paulhyde 于 2014-9-15 09:23 编辑 我产生的调制信号频率150K,在不混频的情况下可以直接通过功率放大器进行电感耦合吗???两个电感线圈的距离为5CM 具体功率放大器怎样设计??? … 查看全部问答> |
virtual BOOL ExtTextOut ( int x, int y, UINT nOptions, LPCRECT lpRect, LPCTSTR lpszString, UINT nCount, LPINT lpDxWidths ); 想请教一下参数nOptions是否有效?本人通过测试,觉得ETO-CLIPPED、ETO-OPAQUE、NULL三者之间没有 ...… 查看全部问答> |
VC++关于directshow图像旋转90度输出花屏的问题 VC++关于directshow图像旋转90度输出花屏的问题 我在transfilter对图像做了一个90度的旋转,再传给第三个filter,发现图像是花屏,解析度为176x144 如果解析度为高,宽相等就是正常的(如:240x240) 请问是什么原因?… 查看全部问答> |
我问ST工程师的邮件:~~: 你好! 我需要用到BEEP功能,可是设定寄存器后跑程序,发现BEEP寄存器并没有改变.OPTION里面我有把PD4设成BEEP功能,OPTION里的PRSC设成(16MHZ TO 128KHZ P ...… 查看全部问答> |
我在用LPC11C14写IAP在线升级程序时,将用户程序的向量表复制到RAM的0地址,再通过重映射寄存器重映射到FLASH的0地址,实现了用户程序调用中断,但现在要把CAN API的程序加上去,而CAN API要占用RAM的0x1000 0050-0x1000 00B8 ...… 查看全部问答> |
现在刚开始接触FPGA不久,看了很长时间论坛了,也学习了Verilog,试着学习应用quartusii和modelsim,现在依旧感觉没有多大进步,好像根本还没有入门,简单的仿真还能进行,遇到复杂点的,比如几个模块联合编译仿真就总是仿真失败,也没有找到原因! ...… 查看全部问答> |
