今天是:2024年10月12日(星期六)
2018年10月12日 | Tiny210触摸屏之触摸屏控制器驱动
2018-10-12 来源:eefocus
tiny_ts.c驱动源码:
#include "linux/errno.h"
#include "linux/kernel.h"
#include "linux/module.h"
#include "linux/slab.h"
#include "linux/input.h"
#include "linux/init.h"
#include "linux/serio.h"
#include "linux/delay.h"
#include "linux/platform_device.h"
#include "linux/clk.h"
#include "asm/io.h"
#include "asm/irq.h"
#include "asm/plat-s3c24xx/ts.h"
#include "asm/arch/regs-adc.h"
#include "asm/arch/regs-gpio.h"
#define MHZ (1000*1000)
#define PRINT_MHZ(m) ((m) / MHZ), ((m / 1000) % 1000)
struct tiny_ts_regs {
unsigned long tsadccon1;
unsigned long tscon1;
unsigned long tsdly1;
unsigned long tsdatx1;
unsigned long tsdaty1;
unsigned long tspenstat1;
unsigned long clrintadc1;
unsigned long reserved;
unsigned long clrintpen1;
static struct input_dev *tiny_ts_dev;
static volatile struct tiny_ts_regs *tiny_ts_regs;
static unsigned long *tsadccon0;
static struct timer_list ts_timer;
static void enter_wait_pen_down_mode(void)
tiny_ts_regs->tscon1 = 0xd3;
static void enter_wait_pen_up_mode(void)
tiny_ts_regs->tscon1 = 0x1d3;
static void enter_measure_xy_mode(void)
tiny_ts_regs->tscon1 = (1<<3)|(1<<2);
static void start_adc(void)
tiny_ts_regs->tsadccon1 |= (1<<0);
static int tiny_filter_ts(int x[], int y[])
#define ERR_LIMIT 10
int avr_x, avr_y;
int det_x, det_y;
avr_x = (x[0] + x[1])/2;
avr_y = (y[0] + y[1])/2;
det_x = (x[2] > avr_x) ? (x[2] - avr_x) : (avr_x - x[2]);
det_y = (y[2] > avr_y) ? (y[2] - avr_y) : (avr_y - y[2]);
if ((det_x > ERR_LIMIT) || (det_y > ERR_LIMIT))
return 0;
avr_x = (x[1] + x[2])/2;
avr_y = (y[1] + y[2])/2;
det_x = (x[3] > avr_x) ? (x[3] - avr_x) : (avr_x - x[3]);
det_y = (y[3] > avr_y) ? (y[3] - avr_y) : (avr_y - y[3]);
return 0;
return 1;
static void tiny_ts_timer_function(unsigned long data)
if (tiny_ts_regs->tsdatx1 & (1<<15))
// 已经松开
input_report_abs(s3c_ts_dev, ABS_PRESSURE, 0);
input_report_key(s3c_ts_dev, BTN_TOUCH, 0);
input_sync(s3c_ts_dev);
enter_wait_pen_down_mode();
else
// 测量X/Y坐标
enter_measure_xy_mode();
start_adc();
static irqreturn_t pen_down_up_irq(int irq, void *dev_id)
//printk("pen up\n");
else
//printk("pen down\n");
//enter_wait_pen_up_mode();
start_adc();
return IRQ_HANDLED;
static irqreturn_t adc_irq(int irq, void *dev_id)
static int cnt = 0;
static int x[4], y[4];
int adcdat0, adcdat1;
// 优化措施2: 如果ADC完成时, 发现触摸笔已经松开, 则丢弃此次结果
adcdat0 = tiny_ts_regs->tsdatx1;
adcdat1 = tiny_ts_regs->tsdaty1;
// 已经松开
cnt = 0;
else
// printk("adc_irq cnt = %d, x = %d, y = %d\n", ++cnt, adcdat0 & 0x3ff, adcdat1 & 0x3ff);
// 优化措施3: 多次测量求平均值
x[cnt] = adcdat0 & 0x3ff;
y[cnt] = adcdat1 & 0x3ff;
++cnt;
if (cnt == 4)
// 优化措施4: 软件过滤
if (tiny_filter_ts(x, y))
//printk("x = %d, y = %d\n", (x[0]+x[1]+x[2]+x[3])/4, (y[0]+y[1]+y[2]+y[3])/4);
input_report_abs(s3c_ts_dev, ABS_X, (x[0]+x[1]+x[2]+x[3])/4);
input_report_abs(s3c_ts_dev, ABS_Y, (y[0]+y[1]+y[2]+y[3])/4);
input_report_abs(s3c_ts_dev, ABS_PRESSURE, 1);
input_report_key(s3c_ts_dev, BTN_TOUCH, 1);
cnt = 0;
// 启动定时器处理长按/滑动的情况
mod_timer(&ts_timer, jiffies + HZ/100);
else
start_adc();
return IRQ_HANDLED;
static int s3c_ts_init(void)
struct clk* clk;
// 1. 分配一个input_dev结构体
tiny_ts_dev = input_allocate_device();
// 2. 设置
// 2.1 能产生哪类事件
set_bit(EV_KEY, tiny_ts_dev->evbit);
set_bit(EV_ABS, tiny_ts_dev->evbit);
// 2.2 能产生这类事件里的哪些事件
set_bit(BTN_TOUCH, tiny_ts_dev->keybit);
input_set_abs_params(tiny_ts_dev, ABS_X, 0, 0x3FF, 0, 0);
input_set_abs_params(tiny_ts_dev, ABS_Y, 0, 0x3FF, 0, 0);
input_set_abs_params(tiny_ts_dev, ABS_PRESSURE, 0, 1, 0, 0);
// 3. 注册
input_register_device(tiny_ts_dev);
// 4. 硬件相关的操作
// 4.1 使能时钟(CLKCON[15])
clk = clk_get(NULL, "adc");
if (!clk || IS_ERR(clk)) {
printk(KERN_INFO "failed to get adc clock source\n");
clk_enable(clk);
printk("Tiny_TS clock got enabled :: %ld.ld Mhz\n", PRINT_MHZ(clk_get_rate(tiny_clk)));
// 4.2 设置S3C2440的ADC/TS寄存器
tsadccon0 = ioremap(0xE1700000, 4);
tiny_ts_regs = ioremap(0xE1701000, sizeof(struct tiny_ts_regs));
// s5pv210有触摸屏接口0,1
// Tiny210开发板向外提供接口1
// 所以这里选择接口1
tsadccon0 |= 1<<17;
// bit[14] : 1-A/D converter prescaler enable
// bit[13:6]: A/D converter prescaler value,
// 65, ADCCLK=PCLKP/(65+1)=66.7MHz/(65+1)=1MHz
// bit[2]: 默认为1,即Standby mode,我们要设置为0,正常模式
// bit[0]: A/D conversion starts by enable. 先设为0
tiny_ts_regs->tsadccon1 &= ~(1<<2);
tiny_ts_regs->tsadccon1 |= (1<<14)|(65<<6);
request_irq(IRQ_TC, pen_down_up_irq, IRQF_SAMPLE_RANDOM, "ts_pen", NULL);
request_irq(IRQ_ADC, adc_irq, IRQF_SAMPLE_RANDOM, "adc", NULL);
// 优化措施1:
// 设置ADCDLY为最大值, 这使得电压稳定后再发出IRQ_TC中断
tiny_ts_regs->tsdaty1 = 0xffff;
// 优化措施5: 使用定时器处理长按,滑动的情况
init_timer(&ts_timer);
ts_timer.function = tiny_ts_timer_function;
add_timer(&ts_timer);
return 0;
static void s3c_ts_exit(void)
free_irq(IRQ_TC, NULL);
free_irq(IRQ_ADC, NULL);
iounmap(tiny_ts_regs);
iounmap(tsadccon0);
input_unregister_device(tiny_ts_dev);
input_free_device(tiny_ts_dev);
del_timer(&ts_timer);
module_init(s3c_ts_init);
module_exit(s3c_ts_exit);
MODULE_LICENSE("GPL");
测试以及tslib-1.4.tar.gz安装编译方法参考:“触摸屏驱动程序(输入子系统)”
由于各种原因,电信行业运营商网上运行的动力环境集中监控系统(以下简称:监控系统)常常不只一个厂家的系统,而且一般各厂家的系统都根据自己的硬件系统,开发了不同的应用软件。不同厂家的系统不能简单的共享数据与操作、管理平台,不便于集中维 ...… 查看全部问答> |
SD卡的动态插入与拔出,在AP层怎么检测?必须自己写个小的驱动?还是只能用定时器不断查询其状态? SD卡的动态插入与拔出,在AP层怎么检测?必须自己写个小的驱动?还是只能用定时器不断查询其状态?… 查看全部问答> |
arms3c2410 急…… 大家给看看吧,初学遇到了点问题 我现在在编写一个按键驱动程序,我已经实现了两个按键的驱动程序,可我的问题是,首先是板子给的中断口不多(4个左右),我想编写一个8个左右的按键驱动,但必须知道是哪个按键有请求,我想只用一个中断口来实现,我想了想用矩阵按键 ...… 查看全部问答> |
之前在WinCE6.0下的音频驱动程序中(内核模式下),申请了32B的空间,直接使用,不做映射和检查嵌入指针。应用程序写32B进来,驱动程序写32B到音频解码芯片中,可以播放音乐。只是这样采用单线程,播放时会有一点“毛刺” ...… 查看全部问答> |
请问如何用evc控制explore打开一个指定路径的文件夹浏览? 我要写个evc程序控制打开一个指定路径的文件夹浏览窗 比如触发某个事件,程序能让wince打开存储卡\\\\sd\\\\test\\\\文件夹进行浏览和操作, SHBrowseForFolder行不行?还是有更简单的办法? 平台:evc4.0+ wince5.0+arm… 查看全部问答> |
最近读书生活费存了点,准备买几本书,首先我准备 看点板级开发/嵌入式方面的。 我自己要买的书有2本 《c++ primer 4》 (看了2遍了,还是准备买本)和《代码大全 2》。 SO 再推荐基本 板级开发/嵌入式方面 的 ...… 查看全部问答> |
天津电子口岸发展有限公司 天津电子口岸发展有限公司是在天津市政府与海关总署等有关部委的支持下创立的,注册资金3000万元。公司承担 “天津国际航运中心和物流中心暨天津电子口岸信息系统”的建设和运营工作,根据公司发展需要,现诚聘如下职 ...… 查看全部问答> |
虽然LM3S6892的名头已经很响了,看到坛子里还有一些人习惯说流明,这应该是原来Luminary那带过来的,当时还没被TI收购前的名字。习惯叫流明的人,说明在TI M3上,真的是很资深啊,因为那时只有很少的一部分人接触过。… 查看全部问答> |
那各位在调试ARM STM32 的时候是仿真着跑找问题,还是直接DOWNLOAD跑,然后看串口输出?有区别吗? 之前好像看过论坛一个哥们说,不太一样。… 查看全部问答> |
