今天是:2024年10月13日(星期日)
2018年10月13日 | Tiny210裸机简单命令的实现
2018-10-13 来源:eefocus
start.S源码:
.global _start
_start:
ldr sp, =0xD0030000 @初始化堆栈
b main
main.c源码:
#include "command.h"
#include "clock.h"
#include "led.h"
#include "uart.h"
#include "lib.h"
#define CFG_PROMPT "WY_BOOT # " // Monitor Command Prompt
#define CFG_CBSIZE 256 // Console I/O Buffer Size
char *argv[10];
int readline (const char *const prompt)
char console_buffer[CFG_CBSIZE]; // console I/O buffer
char *buf = console_buffer;
int argc = 0;
int state = 0;
puts(prompt);
gets(console_buffer);
while (*buf)
if (*buf != ' ' && state == 0)
argv[argc++] = buf;
state = 1;
if (*buf == ' ' && state == 1)
*buf = '\0';
state = 0;
buf++;
return argc;
void message(void)
wy_printf("This bootloader support some command to test peripheral:\n");
wy_printf("Such as: LCD, IIS, BUZZER \n");
wy_printf("Try 'help' to learn them \n");
int main(void)
int argc = 0;
int i = 0;
led_init(); // 设置对应管脚为输出
clock_init(); // 初始化时钟
uart_init(); // 初始化UART0
wy_printf("\n************************************************\n");
wy_printf(" wy_bootloader\n");
wy_printf(" vars: %d \n",2012);
wy_printf("************************************************\n");
while (1)
argc = readline (CFG_PROMPT);
if(argc == 0 && i ==0)
message();
i=1;
run_command(argc, argv);
return 0;
clock.S源码:
#define APLL_CON (*(volatile unsigned int *)0xe0100100)
#define CLK_SRC0 (*(volatile unsigned int *)0xe0100200)
#define CLK_DIV0 (*(volatile unsigned int *)0xe0100300)
#define MPLL_CON (*(volatile unsigned int *)0xe0100108)
void clock_init(void)
// 设置时钟为:
// ARMCLK=1000MHz, HCLKM=200MHz, HCLKD=166.75MHz
// HCLKP =133.44MHz, PCLKM=100MHz, PCLKD=83.375MHz,
// PCLKP =66.7MHz
// SDIV[2:0] : S = 1
// PDIV[13:8] : P = 0x3
// MDIV[25:16]: M = 0x7d
// LOCKED [29]: 1 = 使能锁
// ENABLE [31]: 1 = 使能APLL控制器
// 得出FoutAPLL = 500MHz
APLL_CON = (1<<31)|(1<<29)|(0x7d<<16)|(0x3<<8)|(1<<0);
// 时钟源的设置
// APLL_SEL[0] :1 = FOUTAPLL
// MPLL_SEL[4] :1 = FOUTMPLL
// EPLL_SEL[8] :1 = FOUTEPLL
// VPLL_SEL[12]:1 = FOUTVPLL
// MUX_MSYS_SEL[16]:0 = SCLKAPLL
// MUX_DSYS_SEL[20]:0 = SCLKMPLL
// MUX_PSYS_SEL[24]:0 = SCLKMPLL
// ONENAND_SEL [28]:1 = HCLK_DSYS
CLK_SRC0 = (1<<28)|(1<<12)|(1<<8)|(1<<4)|(1<<0);
// 设置分频系数
// APLL_RATIO[2:0]: APLL_RATIO = 0x0
// A2M_RATIO [6:4]: A2M_RATIO = 0x4
// HCLK_MSYS_RATIO[10:8]: HCLK_MSYS_RATIO = 0x4
// PCLK_MSYS_RATIO[14:12]:PCLK_MSYS_RATIO = 0x1
// HCLK_DSYS_RATIO[19:16]:HCLK_DSYS_RATIO = 0x3
// PCLK_DSYS_RATIO[22:20]:PCLK_DSYS_RATIO = 0x1
// HCLK_PSYS_RATIO[27:24]:HCLK_PSYS_RATIO = 0x4
// PCLK_PSYS_RATIO[30:28]:PCLK_PSYS_RATIO = 0x1
CLK_DIV0 = (0x1<<28)|(0x4<<24)|(0x1<<20)|(0x3<<16)|(0x1<<12)|(0x4<<8)|(0x4<<4);
// PDIV[13:8] : P = 0xc
// MDIV[25:16]: M = 0x29b
// VSEL [27]: 0
// ENABLE [31]: 1 = 使能MPLL控制器
// 得出FoutAPLL = 667MHz
APLL_CON = (1<<31)|(1<<29)|(0x29d<<16)|(0xc<<8)|(1<<0);
uart.c源码:
#define GPA0CON (*(volatile unsigned int *)0xE0200000)
#define ULCON0 (*(volatile unsigned int *)0xE2900000)
#define UCON0 (*(volatile unsigned int *)0xE2900004)
#define UTRSTAT0 (*(volatile unsigned int *)0xE2900010)
#define UTXH0 (*(volatile unsigned char *)0xE2900020)
#define URXH0 (*(volatile unsigned char *)0xE2900024)
#define UBRDIV0 (*(volatile unsigned int *)0xE2900028)
#define UDIVSLOT0 (*(volatile unsigned int *)0xE290002C)
void uart_init(void)
// 设置对应GPIO用于UART0
GPA0CON |= 0x22;
// 设置UART0寄存器
// bit[1:0]:0x3 = 8位数据位
// 其他位默认,即1位停止位,无校验,正常模式
ULCON0 |= (0x3<<0);
// Receive Mode [1:0]:1 = 接收采用查询或者中断模式
// Transmit Mode[3:2]:1 = 发送采用查询或者中断模式
// bit[6]:1 = 产生错误中断
// bit[10]:0 = 时钟源为PCLK
UCON0 = (1<<6)|(1<<2)|(1<<0);
// 设置波特率(详细信息请参考手册或者学习日记)
// DIV_VAL = UBRDIVn + (num of 1's in UDIVSLOTn)/16
// DIV_VAL = (PCLK / (bps x 16)) - 1
UBRDIV0 = 0x23;
UDIVSLOT0 = 0x808;
return;
char uart_getchar(void)
char c;
// 查询状态寄存器,直到有有效数据
while (!(UTRSTAT0 & (1<<0)));
c = URXH0; // 读取接收寄存器的值
return c;
void uart_putchar(char c)
// 查询状态寄存器,直到发送缓存为空
while (!(UTRSTAT0 & (1<<2)));
UTXH0 = c; // 写入发送寄存器
return;
lib.c源码:
#include "uart.h"
void delay(void)
volatile int i = 0x100000;
while (i--);
void putchar_hex(char c)
char * hex = "0123456789ABCDEF";
uart_putchar(hex[(c>>4) & 0x0F]);
uart_putchar(hex[(c>>0) & 0x0F]);
return;
int putchar(int c)
if(c == '\r')
while(!(UTRSTAT0&(1<<1)));
UTXH0 = '\n';
if(c == '\n')
UTXH0 = '\r';
UTXH0 = c;
int getchar(void)
int c;
c = (int)uart_getchar();
if (c == '\r')
return '\n';
return c;
int puts(const char * s)
while (*s)
putchar(*s++);
return 0;
char * gets(char * s)
char * p = s;
while ((*p = getchar()) != '\n')
if (*p != '\b')
putchar(*p++);
else
if (p > s)
puts ("\b \b");
p--;
*p = '\0';
putchar('\n');
return s;
void putint_hex(int a)
putchar_hex( (a>>24) & 0xFF );
putchar_hex( (a>>16) & 0xFF );
putchar_hex( (a>>8) & 0xFF );
putchar_hex( (a>>0) & 0xFF );
char *itoa(int a, char * buf)
int num = a;
int i = 0;
int len = 0;
do
buf[i++] = num % 10 + '0';
num /= 10;
}while (num);
buf[i] = '\0';
len = i;
for (i = 0; i < len/2; i++)
char tmp;
tmp = buf[i];
buf[i] = buf[len-i-1];
buf[len-i-1] = tmp;
return buf;
int strcmp(const char * s1, const char * s2)
while (*s1 == *s2)
if (*s1 == '\0')
return 0;
s1++;
s2++;
return *s1 - *s2;
int atoi(char * buf)
int value = 0;
int base = 10;
int i = 0;
if (buf[0] == '0' && buf[1] == 'x')
base = 16;
i = 2;
// 123 = (1 * 10 + 2) * 10 + 3
// 0x1F = 1 * 16 + F(15)
while (buf[i])
int tmp;
if (buf[i] <= '9' && buf[i] >= '0')
tmp = buf[i] - '0';
else
tmp = buf[i] - 'a' + 10;
value = value * base + tmp;
i++;
return value;
typedef int * va_list;
#define va_start(ap, A) (ap = (int *)&(A) + 1)
#define va_arg(ap, T) (*(T *)ap++)
#define va_end(ap) ((void)0)
int wy_printf(const char * format, ...)
char c;
va_list ap;
va_start(ap, format);
while ((c = *format++) != '\0')
switch (c)
case '%':
c = *format++;
switch (c)
char ch;
char * p;
int a;
char buf[100];
case 'c':
ch = va_arg(ap, int);
putchar(ch);
break;
case 's':
p = va_arg(ap, char *);
puts(p);
break;
case 'x':
a = va_arg(ap, int);
putint_hex(a);
break;
case 'd':
itoa(a, buf);
puts(buf);
break;
default:
break;
break;
default:
putchar(c);
break;
return 0;
command.c源码:
#include "lib.h"
int help(int argc, char * argv[])
wy_printf("do_command 《$s》 \n", argv[0]); //"《"实际为“<”,"$"实际为"%",避免格式冲突
wy_printf("help message: \n");
wy_printf("md - memory dispaly\n");
wy_printf("mw - memory write\n");
return 0;
int md(int argc, char * argv[])
unsigned long *p = (unsigned long *)0;
int i, j;
if (argc <= 1) {
wy_printf ("Usage:\n%s\n", "md address");
return 1;
if (argc >= 2)
p = (unsigned long *)atoi(argv[1]);
for (j = 0; j < 16; j++)
wy_printf("%x: ", p);
for (i = 0; i < 4; i++)
wy_printf("%x ", *p++);
wy_printf("\n");
return 0;
int mw(int argc, char * argv[])
int v = 0;
if (argc <= 2) {
wy_printf ("Usage:\n%s\n", "md address data");
return 1;
if (argc >= 2)
if (argc >= 3)
v = atoi(argv[2]);
*p = v;
return 0;
void run_command(int argc, char * argv[])
if (strcmp(argv[0], "help") == 0)
help(argc, argv);
return;
if (strcmp(argv[0], "md") == 0)
md(argc, argv);
return;
if (strcmp(argv[0], "mw") == 0)
mw(argc, argv);
return;
if(argc >= 1)
wy_printf("Unknown command '%s' - try 'help' \n",argv[0]);
return;
Makefile文件:
uart.bin:start.s main.c uart.c clock.c led.c lib.c command.c
arm-linux-gcc -nostdlib -c start.s -o start.o
arm-linux-gcc -nostdlib -c main.c -o main.o
arm-linux-gcc -nostdlib -c uart.c -o uart.o
arm-linux-gcc -nostdlib -c lib.c -o lib.o
arm-linux-gcc -nostdlib -c clock.c -o clock.o
arm-linux-gcc -nostdlib -c led.c -o led.o
arm-linux-gcc -nostdlib -c command.c -o command.o
arm-linux-ld -Ttext 0xD0020010 start.o main.o uart.o lib.o clock.o led.o command.o -o uart_elf
arm-linux-objcopy -O binary -S uart_elf uart.bin
clean:
rm -rf *.o *.bin uart_elf *.dis
源码解析:
分析过u-boot的朋友们,应该对readline()函数不陌生吧,我这里将实现一个简化的readline()函数,实现在终端显示输入提示符,并从终端获取命令,实现过程如下:
char console_buffer[CFG_CBSIZE]; // 定义一个缓存数组,用于接收终端输入的字符串
char *buf = console_buffer; // 定义个指针,指向上面的数组
int argc = 0; // 用于指明命令参数的个数
int state = 0; // 状态标志
puts(prompt); // 显示输入提示符:WY_BOOT #
gets(console_buffer); // 从终端获取字符串,并存入缓存数组
while (*buf)//该while实现对终端输入的命令的解析,将命令,参数拆分,分别存入argv[n]
argv[argc++] = buf;
state = 1;
*buf = '\0';
state = 0;
buf++;
return argc; // 返回参数的个数
//一下是大家更加熟悉的u-boot中的run_command函数的简化版本,实现过程如下,只是将argv[0]指向的数组和另外一个数组进行比较,如果相等,则执行该if分支里面的函数。strcmp()函数的实现也非常简单,我已经在共享的代码中给出,请大家自行分析之。
do_help(argc, argv);
return;
do_md(argc, argv);
return;
do_mw(argc, argv);
return;
if(argc >= 1)
return;
注意:
本章实现的命令几乎算是和硬件无关的了,以后每当写完一个具体外设的裸板程序的时候,会添加相应命令的支持,比如nand read,nand write等等函数。添加的过程其实就是在run_command()函数里面多添加一个strcmp()函数的调用,然后用if判断其返回值,若相等,则调用具体的命令执行函数do_XXX
最近在看汇编,但是很是困惑: 1.我们一般在高级语言里碰到的int\\float,与我们在讲解二进制加法时用的8位有什么关系? 2.若汇编老师在讲解完计算机内的数字存储后,发问7+251=?那到底怎么做呢? 251=11111011已经八位了啊!!? ...… 查看全部问答> |
wince writefile 总是发送不了数据,但不报错! 问题如下: 我现在接手别人的工作,驱动别人是用evc4.2写dll,驱动经测试可用。 我现在用C#开发应用程序。 现在的问题是,驱动writefile第二个参数他传的是 ...… 查看全部问答> |
想学WINCE的驱动,但书籍好少,于是我想先看WINDOWS的驱动,从这里入门,下面这三种那种更接近WINCE的驱动编程呢?区别又在那呢? 1)WIN9X虚拟设备驱动VxD 2)WIN NT驱动 3)WIN 2000 WDM驱动 … 查看全部问答> |
在C51中,char xdata doc[19]=\"AT+CMGF=0\"; 我想请教一下各位大虾,在ATmega128中,这个语句应该怎样写呢? … 查看全部问答> |
1、89S52的波特率发生器是T2还是T1,还是两个都可以? 2、多机通信的时候SCON是设置成方式1还是方式3?(我要通过SM2来控制发送的是地址还是数据) 3、S52用KEIL在线仿真是接在COM口还是打印机口?… 查看全部问答> |
今天,用protues搭了一个电路,写了一个相应的程序,调试运行了一下,竟然无效, 于是乎,我就把原本庞大的电路删减一部分剩下基本的显示数码管,可是竟然还是不 对,那么,我首先怀疑是不是我的程序有问题 ...… 查看全部问答> |
