今天是:2024年10月17日(星期四)
正在发生
2018年10月17日 | STM32时钟RCC详解(三)
2018-10-17 来源:eefocus
RCC相关库函数解析
1、库中所涉及到的结构体
typedef struct
  uint32_t SYSCLK_Frequency;
  uint32_t HCLK_Frequency;
  uint32_t PCLK1_Frequency;
  uint32_t PCLK2_Frequency;
  uint32_t ADCCLK_Frequency;
}RCC_ClocksTypeDef;
2、库函数解析
void RCC_DeInit(void);  //将外设RCC寄存器设为缺省值;(除RCC_BDCR和RCC_CSR)
void RCC_HSEConfig(uint32_t RCC_HSE);  //设置外部高速晶振(HSE);
//输入:RCC_HSE_OFF,RCC_HSE_ON,RCC_HSE_Bypass(HSE旁路)
ErrorStatus RCC_WaitForHSEStartUp(void);   //等待HSE起振;
//返回值:SUCCESS,HSE晶振稳定且就绪;ERROR,HSE晶振未就绪
void RCC_AdjustHSICalibrationValue(uint8_t HSICalibrationValue);  //调整内部高速晶振(HSI)校准值
//输入:校准补偿值(该参数取值必须在0到0x1F之间)
void RCC_HSICmd(FunctionalState NewState);  //使能或者失能内部高速晶振(HSI)
//输入:ENABLE或者DISABLE(如果HSI被用于系统时钟,或者FLASH编写操作进行中,那么它不能被停                      振)
void RCC_PLLConfig(uint32_t RCC_PLLSource, uint32_t RCC_PLLMul);  //设置PLL时钟源及倍频系数
//输入:RCC_PLLSource_HSI_Div2,RCC_PLLSource_HSE_Div1,RCC_PLLSource_HSE_Div2
//输入:RCC_PLLMul_2到RCC_PLLMul_16
void RCC_PLLCmd(FunctionalState NewState);  // 使能或者失能PLL
#if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL) || defined (STM32F10X_CL)
 void RCC_PREDIV1Config(uint32_t RCC_PREDIV1_Source, uint32_t RCC_PREDIV1_Div);//
#endif
#ifdef  STM32F10X_CL
 void RCC_PREDIV2Config(uint32_t RCC_PREDIV2_Div);  //
 void RCC_PLL2Config(uint32_t RCC_PLL2Mul);  //
 void RCC_PLL2Cmd(FunctionalState NewState);  //
 void RCC_PLL3Config(uint32_t RCC_PLL3Mul);  //
 void RCC_PLL3Cmd(FunctionalState NewState);  //
#endif
void RCC_SYSCLKConfig(uint32_t RCC_SYSCLKSource);  //设置系统时钟(SYSCLK)源
// RCC_SYSCLKSource_HSI,RCC_SYSCLKSource_HSE,RCC_SYSCLKSource_PLLCLK
uint8_t RCC_GetSYSCLKSource(void);  // 返回用作系统时钟的时钟源
//返回值:0x00 HSI作为系统时钟,0x04 HSE作为系统时钟,0x08 PLL作为系统时钟
void RCC_HCLKConfig(uint32_t RCC_SYSCLK);  //设置AHB时钟(HCLK)
//输入:RCC_SYSCLK_Div1、RCC_SYSCLK_Div2、RCC_SYSCLK_Div4、RCC_SYSCLK_Div8、RCC_SYSCLK_Div16、RCC_SYSCLK_Div32、RCC_SYSCLK_Div64、RCC_SYSCLK_Div128、RCC_SYSCLK_Div256、RCC_SYSCLK_Div512
void RCC_PCLK1Config(uint32_t RCC_HCLK);  // 设置低速AHB时钟(PCLK1)
//输入:RCC_HCLK_Div1、RCC_HCLK_Div2、RCC_HCLK_Div4、RCC_HCLK_Div8、RCC_HCLK_Div16
void RCC_PCLK2Config(uint32_t RCC_HCLK);  // 设置高速AHB时钟(PCLK2)
void RCC_ITConfig(uint8_t RCC_IT, FunctionalState NewState);  // 使能或者失能指定的RCC中断
//输入:RCC_IT_LSIRDY  LSI就绪中断->ENABLE或者DISABLE
//RCC_IT_LSERDY  LSE就绪中断,RCC_IT_HSIRDY  HSI就绪中断
//RCC_IT_HSERDY  HSE就绪中断,RCC_IT_PLLRDY  PLL就绪中断
#ifndef STM32F10X_CL
 void RCC_USBCLKConfig(uint32_t RCC_USBCLKSource);  // 设置USB时钟(USBCLK)
//输入:RCC_USBCLKSource_PLLCLK_1Div5,USB时钟 = PLL时钟除以1.5
RCC_USBCLKSource_PLLCLK_Div1,USB时钟 = PLL时钟
#else
void RCC_OTGFSCLKConfig(uint32_t RCC_OTGFSCLKSource);  //
#endif
void RCC_ADCCLKConfig(uint32_t RCC_PCLK2);  // 设置ADC时钟(ADCCLK)
//RCC_PCLK2_Div2,ADC时钟 = PCLK / 2;RCC_PCLK2_Div4,ADC时钟 = PCLK / 4;
//RCC_PCLK2_Div6,ADC时钟 = PCLK / 6;RCC_PCLK2_Div8,ADC时钟 = PCLK / 8
#ifdef STM32F10X_CL
void RCC_I2S2CLKConfig(uint32_t RCC_I2S2CLKSource);   //
void RCC_I2S3CLKConfig(uint32_t RCC_I2S3CLKSource);  //
#endif
void RCC_LSEConfig(uint8_t RCC_LSE);  // 设置外部低速晶振(LSE)
//输入:RCC_LSE_OFF,LSE晶振OFF;RCC_LSE_ON,LSE晶振ON;
//RCC_LSE_Bypass,LSE晶振被外部时钟旁路
void RCC_LSICmd(FunctionalState NewState);  // 使能或者失能内部低速晶振(LSI)
//输入:ENABLE或者DISABLE   (IWDG运行的话,LSI不能被失能)
void RCC_RTCCLKConfig(uint32_t RCC_RTCCLKSource);  //设置RTC时钟(RTCCLK)源(RTC时钟一经选定即不能更改,除非复位后备域)
//输入:RCC_RTCCLKSource_LSE,选择LSE作为RTC时钟;RCC_RTCCLKSource_LSI,选择LSI作为RTC时钟;RCC_RTCCLKSource_HSE_Div128,选择HSE时钟频率除以128作为RTC时钟
void RCC_RTCCLKCmd(FunctionalState NewState);  // 使能或者失能RTC时钟
void RCC_GetClocksFreq(RCC_ClocksTypeDef* RCC_Clocks);  // 返回时钟的频率
//输入:指向结构RCC_ClocksTypeDef的指针,包含了各个时钟的频率(单位为Hz)
void RCC_AHBPeriphClockCmd(uint32_t RCC_AHBPeriph, FunctionalState NewState);// 使能或者失能AHB外设时钟
//输入:RCC_AHBPeriph_DMA,DMA时钟->ENABLE或者DISABLE;
//RCC_AHBPeriph_SRAM,SRAM时钟;RCC_AHBPeriph_FLITF,FLITF时钟
//RCC_AHBPeriph_DMA1,DMA1时钟;RCC_AHBPeriph_DMA2,DMA2时钟
//RCC_AHBPeriph_CRC,CRC时钟;RCC_AHBPeriph_FSMC,FSMC时钟
//RCC_AHBPeriph_SDIO,SDIO时钟
void RCC_APB2PeriphClockCmd(uint32_t RCC_APB2Periph, FunctionalState NewState);// 使能或者失能APB2外设时钟
//输入:RCC_APB2Periph_AFIO,功能复用IO时钟->ENABLE或者DISABLE;
//RCC_APB2Periph_GPIOA,GPIOA时钟;RCC_APB2Periph_GPIOB,GPIOB时钟;
//RCC_APB2Periph_GPIOC,GPIOC时钟;RCC_APB2Periph_GPIOD,GPIOD时钟;
//RCC_APB2Periph_GPIOE,GPIOE时钟;RCC_APB2Periph_ADC1,ADC1时钟;
//RCC_APB2Periph_ADC2,ADC2时钟;RCC_APB2Periph_TIM1,TIM1时钟;
//RCC_APB2Periph_SPI1,SPI1时钟;RCC_APB2Periph_USART1,USART1时钟;
//RCC_APB2Periph_ALL,全部APB2外设时钟
void RCC_APB1PeriphClockCmd(uint32_t RCC_APB1Periph, FunctionalState NewState);// 使能或者失能APB1外设时钟
//输入:RCC_APB1Periph_TIM2,TIM2时钟->ENABLE或者DISABLE;
//RCC_APB1Periph_TIM3,TIM3时钟;RCC_APB1Periph_TIM4,TIM4时钟
//RCC_APB1Periph_WWDG,WWDG时钟;RCC_APB1Periph_SPI2,SPI2时钟
//RCC_APB1Periph_USART2,USART2时钟;RCC_APB1Periph_USART3,USART3时钟
//RCC_APB1Periph_I2C1,I2C1时钟;RCC_APB1Periph_I2C2,I2C2时钟
//RCC_APB1Periph_USB,USB时钟;RCC_APB1Periph_CAN,CAN时钟
//RCC_APB1Periph_BKP,BKP时钟;RCC_APB1Periph_PWR,PWR时钟
//RCC_APB1Periph_ALL,全部APB1外设时钟
#ifdef STM32F10X_CL
void RCC_AHBPeriphResetCmd(uint32_t RCC_AHBPeriph, FunctionalState NewState);  //
#endif
void RCC_APB2PeriphResetCmd(uint32_t RCC_APB2Periph, FunctionalState NewState);  // 强制或者释放高速APB(APB2)外设复位
//输入:同void RCC_APB2PeriphClockCmd(uint32_t RCC_APB2Periph, FunctionalState NewState);函数的值
void RCC_APB1PeriphResetCmd(uint32_t RCC_APB1Periph, FunctionalState NewState);  // 强制或者释放低速APB(APB1)外设复位
//输入:同void RCC_APB1PeriphClockCmd(uint32_t RCC_APB1Periph, FunctionalState NewState);函数的值
//例:
//RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1, ENABLE);
//RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1, DISABLE);
void RCC_BackupResetCmd(FunctionalState NewState);  // 强制或者释放后备域复位
void RCC_ClockSecuritySystemCmd(FunctionalState NewState);  //使能或者失能时钟安全系统
void RCC_MCOConfig(uint8_t RCC_MCO);  // 选择在MCO管脚上输出的时钟源
//输入:RCC_MCO_NoClock 无时钟被选中 ;RCC_MCO_SYSCLK 选中系统时钟;
//RCC_MCO_HSI 选中HSI ;RCC_MCO_HSE 选中HSE ;
//RCC_MCO_PLLCLK_Div2 选中PLL时钟除以2
//警告:当选中系统时钟作为MCO管脚的输出时,注意它的时钟频率不超过50MHz(最大I/O速率)。
FlagStatus RCC_GetFlagStatus(uint8_t RCC_FLAG);  // 检查指定的RCC标志位设置与否
//输入:待检查的RCC标志位
//RCC_FLAG_HSIRDY ,HSI晶振就绪;RCC_FLAG_HSERDY ,HSE晶振就绪;
//RCC_FLAG_PLLRDY ,PLL就绪;RCC_FLAG_LSERDY ,LSI晶振就绪;
//RCC_FLAG_LSIRDY ,LSE晶振就绪;RCC_FLAG_PINRST ,管脚复位 ;
//RCC_FLAG_PORRST ,POR/PDR复位;RCC_FLAG_SFTRST ,软件复位 ;
//RCC_FLAG_IWDGRST ,IWDG复位;RCC_FLAG_WWDGRST ,WWDG复位;
//RCC_FLAG_LPWRRST ,低功耗复位
//返回值:RCC_FLAG的新状态(SET或者RESET)
//例:
//FlagStatus Status;
//Status = RCC_GetFlagStatus(RCC_FLAG_PLLRDY);
//if(Status == RESET)
//else
void RCC_ClearFlag(void);  // 清除RCC的复位标志位
//(可以清除的复位标志位有:RCC_FLAG_PINRST, RCC_FLAG_PORRST, //RCC_FLAG_SFTRST, RCC_FLAG_IWDGRST, RCC_FLAG_WWDGRST, RCC_FLAG_LPWRRST)
ITStatus RCC_GetITStatus(uint8_t RCC_IT);  // 检查指定的RCC中断发生与否
//输入:RCC_IT_LSIRDY,LSI晶振就绪中断;RCC_IT_LSERDY,LSE晶振就绪中断
//RCC_IT_HSIRDY,HSI晶振就绪中断;RCC_IT_HSERDY,HSE晶振就绪中断
//RCC_IT_PLLRDY,PLL就绪中断;RCC_IT_CSS,时钟安全系统中断
//返回值:RCC_IT的新状态
//例:
//ITStatus Status;
//Status = RCC_GetITStatus(RCC_IT_PLLRDY);
//else
void RCC_ClearITPendingBit(uint8_t RCC_IT);  // 清除RCC的中断待处理位
//RCC_IT_LSIRDY,LSI晶振就绪中断;RCC_IT_LSERDY,LSE晶振就绪中断
Advanced Energy公司的发展小趣事
AE公司一直将创新作为企业发展的核心动力。公司不断投入研发资源,推动电源技术的持续创新。同时,AE公司也积极与各大电子企业建立合作伙伴关系,共同推动电子行业的发展。通过与合作伙伴的紧密合作,AE公司不仅获得了更多的市场机会,也提升了自身的技术水平和创新能力。
Everbuild公司的发展小趣事
随着公司的逐步发展,Everbuild开始注重技术研发和品牌建设。公司投入大量资金引进先进的生产设备和技术人才,不断推出具有创新性的电子产品。其中,一款高性能的智能手机处理器在市场上引起了热烈反响,成为公司的明星产品。同时,Everbuild还加强了品牌宣传和推广,提高了品牌的知名度和美誉度。
迪一电子公司的发展小趣事
迪一电子公司成立于2006年,最初只是一家规模较小的半导体电子元器件制造企业。在创业初期,公司面临着资金紧张、技术落后和市场竞争激烈等多重困难。然而,创始人李政坚信半导体行业的发展潜力,带领团队不断研发新产品,提高产品质量,逐渐在市场上赢得了一席之地。
CSR plc(剑桥硅晶无线电)公司的发展小趣事
CSR plc的创始人们怀揣着对音频技术的热情与追求,在剑桥这个科技创新的摇篮中开始了他们的征程。初创时期,公司的主要业务集中在音频领域,他们研发出了一系列创新的音频技术,为当时的移动设备市场带来了前所未有的听觉体验。这些技术的成功应用,不仅让CSR plc在行业内崭露头角,也为公司的后续发展奠定了坚实的基础。
Alcatel-Lucent公司的发展小趣事
为了进一步拓展业务范围,CSR plc在2010年8月收购了专业音频压缩技术供应商APT。这次收购让CSR plc得以将APT-X的低延迟音频压缩编解码器与公司的下一代音频产品实现更紧密的集成,从而支持公司向前景更广阔的音频市场进军。这一举措不仅让CSR plc在音频领域取得了更大的市场份额,也为其未来的发展开辟了新的道路。
Gauthier Connectique公司的发展小趣事
了解供应商的技术支持和售后服务情况,以便在使用过程中获得及时帮助。
飞思卡尔智能汽车比赛
本来是要参加明天的飞思卡尔智能汽车比赛的,前段时间被老师叫去帮他完成一些东西,就退出来了。下面是一些飞思卡尔的资料,或许有用。 …
总线方式布线是怎样的方式!?
在pcb布线的过程中,总线方式布线是怎样的方式!?在县卡,主板上看到其布线很漂亮,经询问说是总线方式布线,不懂。请教。在protel中用shift+空格转换…
vxworks usrRoot任务起不来!
    各位vxworks的前辈们,小弟刚刚接触vxworks,目前使用一块MPC852的板子,自带了bootrom,无源码,无仿真器,板子启动后bootrom可以正常运行,现在我自己修改了一个MPC852的BSP,并基于此做了个vxworks镜像。       ...…
关于一个单片机串口接收FPGA配置文件的问题,希望大家不吝赐教
各位高手,小弟有疑问相求,最近被安排做个小东西,目的是把几个FPGA的配置文件利用串口发给单片机,单片机接收后将其存入几片EEPROM里,再根据需求选择用哪个文件来配置FPGA,感觉上位机程序的功能和串口调试助手有点像。疑问就在于: 1.是否可以 ...…
网络综合布线系统概述
综合布线是一种模块化的、灵活性极高的建筑物内或建筑群之间的信息传输通道。它既能使语音、数据、图像设备和交换设备与其它信息管理系统彼此相连, 也能使这些设备与外部相连接。它还包括建筑物外部网络或电信线路的连接点与应用系统设备之间的所有 ...…
新手求助啊 ccs5.1延时程序中asm("nop")
当加一个asm(\"nop\")到延时程序中,无任何问题,当有2个以上延时程序时则会出现错误,如何解决啊?  附图 …
FL2440屏幕初始化
我看了FL2440屏幕初始化的代码,在bootloader,eboot还有wince驱动中都有,但是只有bootloader中的初始化调用了,eboot还有wince驱动中都没有调用初始化函数。。但是我现在用spi接口的屏幕照样做,bootloader中可以点亮,但是到了wince中就会熄灭, ...…
430仿真器的驱动装不上去win7 32位的,指点一下吧
430仿真器的驱动装不上去win7 32位的,每次都安装不成功,出现下面这种情况…
BB-Black到货啦!
BB-Black 到货啦!上图 接下来就是arm linux移植以及交叉编译的问题了,之前在OK6410板子上做过。也是一番痛苦的经历。再来一次吧!…
