今天是:2024年12月26日(星期四)
2018年12月26日 | STM32F4XX中断号定义
2018-12-26 来源:eefocus
typedef enum IRQn
/****** Cortex-M4 Processor Exceptions Numbers ****************************************************************/
NonMaskableInt_IRQn = -14, /*!< 2 Non Maskable Interrupt */
MemoryManagement_IRQn = -12, /*!< 4 Cortex-M4 Memory Management Interrupt */
BusFault_IRQn = -11, /*!< 5 Cortex-M4 Bus Fault Interrupt */
UsageFault_IRQn = -10, /*!< 6 Cortex-M4 Usage Fault Interrupt */
SVCall_IRQn = -5, /*!< 11 Cortex-M4 SV Call Interrupt */
DebugMonitor_IRQn = -4, /*!< 12 Cortex-M4 Debug Monitor Interrupt */
PendSV_IRQn = -2, /*!< 14 Cortex-M4 Pend SV Interrupt */
SysTick_IRQn = -1, /*!< 15 Cortex-M4 System Tick Interrupt */
/****** STM32 specific Interrupt Numbers **********************************************************************/
WWDG_IRQn = 0, /*!< Window WatchDog Interrupt */
PVD_IRQn = 1, /*!< PVD through EXTI Line detection Interrupt */
TAMP_STAMP_IRQn = 2, /*!< Tamper and TimeStamp interrupts through the EXTI line */
RTC_WKUP_IRQn = 3, /*!< RTC Wakeup interrupt through the EXTI line */
FLASH_IRQn = 4, /*!< FLASH global Interrupt */
RCC_IRQn = 5, /*!< RCC global Interrupt */
EXTI0_IRQn = 6, /*!< EXTI Line0 Interrupt */
EXTI1_IRQn = 7, /*!< EXTI Line1 Interrupt */
EXTI2_IRQn = 8, /*!< EXTI Line2 Interrupt */
EXTI3_IRQn = 9, /*!< EXTI Line3 Interrupt */
EXTI4_IRQn = 10, /*!< EXTI Line4 Interrupt */
DMA1_Stream0_IRQn = 11, /*!< DMA1 Stream 0 global Interrupt */
DMA1_Stream1_IRQn = 12, /*!< DMA1 Stream 1 global Interrupt */
DMA1_Stream2_IRQn = 13, /*!< DMA1 Stream 2 global Interrupt */
DMA1_Stream3_IRQn = 14, /*!< DMA1 Stream 3 global Interrupt */
DMA1_Stream4_IRQn = 15, /*!< DMA1 Stream 4 global Interrupt */
DMA1_Stream5_IRQn = 16, /*!< DMA1 Stream 5 global Interrupt */
DMA1_Stream6_IRQn = 17, /*!< DMA1 Stream 6 global Interrupt */
ADC_IRQn = 18, /*!< ADC1, ADC2 and ADC3 global Interrupts */
#if defined(STM32F40_41xxx)
CAN1_TX_IRQn = 19, /*!< CAN1 TX Interrupt */
CAN1_RX0_IRQn = 20, /*!< CAN1 RX0 Interrupt */
CAN1_RX1_IRQn = 21, /*!< CAN1 RX1 Interrupt */
CAN1_SCE_IRQn = 22, /*!< CAN1 SCE Interrupt */
EXTI9_5_IRQn = 23, /*!< External Line[9:5] Interrupts */
TIM1_BRK_TIM9_IRQn = 24, /*!< TIM1 Break interrupt and TIM9 global interrupt */
TIM1_UP_TIM10_IRQn = 25, /*!< TIM1 Update Interrupt and TIM10 global interrupt */
TIM1_TRG_COM_TIM11_IRQn = 26, /*!< TIM1 Trigger and Commutation Interrupt and TIM11 global interrupt */
TIM1_CC_IRQn = 27, /*!< TIM1 Capture Compare Interrupt */
TIM2_IRQn = 28, /*!< TIM2 global Interrupt */
TIM3_IRQn = 29, /*!< TIM3 global Interrupt */
TIM4_IRQn = 30, /*!< TIM4 global Interrupt */
I2C1_EV_IRQn = 31, /*!< I2C1 Event Interrupt */
I2C1_ER_IRQn = 32, /*!< I2C1 Error Interrupt */
I2C2_EV_IRQn = 33, /*!< I2C2 Event Interrupt */
I2C2_ER_IRQn = 34, /*!< I2C2 Error Interrupt */
SPI1_IRQn = 35, /*!< SPI1 global Interrupt */
SPI2_IRQn = 36, /*!< SPI2 global Interrupt */
USART1_IRQn = 37, /*!< USART1 global Interrupt */
USART2_IRQn = 38, /*!< USART2 global Interrupt */
USART3_IRQn = 39, /*!< USART3 global Interrupt */
EXTI15_10_IRQn = 40, /*!< External Line[15:10] Interrupts */
RTC_Alarm_IRQn = 41, /*!< RTC Alarm (A and B) through EXTI Line Interrupt */
OTG_FS_WKUP_IRQn = 42, /*!< USB OTG FS Wakeup through EXTI line interrupt */
TIM8_BRK_TIM12_IRQn = 43, /*!< TIM8 Break Interrupt and TIM12 global interrupt */
TIM8_UP_TIM13_IRQn = 44, /*!< TIM8 Update Interrupt and TIM13 global interrupt */
TIM8_TRG_COM_TIM14_IRQn = 45, /*!< TIM8 Trigger and Commutation Interrupt and TIM14 global interrupt */
TIM8_CC_IRQn = 46, /*!< TIM8 Capture Compare Interrupt */
DMA1_Stream7_IRQn = 47, /*!< DMA1 Stream7 Interrupt */
FSMC_IRQn = 48, /*!< FSMC global Interrupt */
SDIO_IRQn = 49, /*!< SDIO global Interrupt */
TIM5_IRQn = 50, /*!< TIM5 global Interrupt */
SPI3_IRQn = 51, /*!< SPI3 global Interrupt */
UART4_IRQn = 52, /*!< UART4 global Interrupt */
UART5_IRQn = 53, /*!< UART5 global Interrupt */
TIM6_DAC_IRQn = 54, /*!< TIM6 global and DAC1&2 underrun error interrupts */
TIM7_IRQn = 55, /*!< TIM7 global interrupt */
DMA2_Stream0_IRQn = 56, /*!< DMA2 Stream 0 global Interrupt */
DMA2_Stream1_IRQn = 57, /*!< DMA2 Stream 1 global Interrupt */
DMA2_Stream2_IRQn = 58, /*!< DMA2 Stream 2 global Interrupt */
DMA2_Stream3_IRQn = 59, /*!< DMA2 Stream 3 global Interrupt */
DMA2_Stream4_IRQn = 60, /*!< DMA2 Stream 4 global Interrupt */
ETH_IRQn = 61, /*!< Ethernet global Interrupt */
ETH_WKUP_IRQn = 62, /*!< Ethernet Wakeup through EXTI line Interrupt */
CAN2_TX_IRQn = 63, /*!< CAN2 TX Interrupt */
CAN2_RX0_IRQn = 64, /*!< CAN2 RX0 Interrupt */
CAN2_RX1_IRQn = 65, /*!< CAN2 RX1 Interrupt */
CAN2_SCE_IRQn = 66, /*!< CAN2 SCE Interrupt */
OTG_FS_IRQn = 67, /*!< USB OTG FS global Interrupt */
DMA2_Stream5_IRQn = 68, /*!< DMA2 Stream 5 global interrupt */
DMA2_Stream6_IRQn = 69, /*!< DMA2 Stream 6 global interrupt */
DMA2_Stream7_IRQn = 70, /*!< DMA2 Stream 7 global interrupt */
USART6_IRQn = 71, /*!< USART6 global interrupt */
I2C3_EV_IRQn = 72, /*!< I2C3 event interrupt */
I2C3_ER_IRQn = 73, /*!< I2C3 error interrupt */
OTG_HS_EP1_OUT_IRQn = 74, /*!< USB OTG HS End Point 1 Out global interrupt */
OTG_HS_EP1_IN_IRQn = 75, /*!< USB OTG HS End Point 1 In global interrupt */
OTG_HS_WKUP_IRQn = 76, /*!< USB OTG HS Wakeup through EXTI interrupt */
OTG_HS_IRQn = 77, /*!< USB OTG HS global interrupt */
DCMI_IRQn = 78, /*!< DCMI global interrupt */
CRYP_IRQn = 79, /*!< CRYP crypto global interrupt */
HASH_RNG_IRQn = 80, /*!< Hash and Rng global interrupt */
FPU_IRQn = 81 /*!< FPU global interrupt */
#endif /* STM32F40_41xxx */
#if defined(STM32F427_437xx)
FMC_IRQn = 48, /*!< FMC global Interrupt */
FPU_IRQn = 81, /*!< FPU global interrupt */
UART7_IRQn = 82, /*!< UART7 global interrupt */
UART8_IRQn = 83, /*!< UART8 global interrupt */
SPI4_IRQn = 84, /*!< SPI4 global Interrupt */
SPI5_IRQn = 85, /*!< SPI5 global Interrupt */
SPI6_IRQn = 86, /*!< SPI6 global Interrupt */
SAI1_IRQn = 87, /*!< SAI1 global Interrupt */
DMA2D_IRQn = 90 /*!< DMA2D global Interrupt */
#endif /* STM32F427_437xx */
#if defined(STM32F429_439xx)
LTDC_IRQn = 88, /*!< LTDC global Interrupt */
LTDC_ER_IRQn = 89, /*!< LTDC Error global Interrupt */
#endif /* STM32F429_439xx */
#if defined(STM32F401xx) || defined(STM32F411xE)
SPI4_IRQn = 84 /*!< SPI4 global Interrupt */
#endif /* STM32F411xE */
#if defined(STM32F411xE)
SPI5_IRQn = 85 /*!< SPI5 global Interrupt */
#endif /* STM32F401xx || STM32F411xE */
#if defined(STM32F446xx)
TIM8_BRK_IRQn = 43, /*!< TIM8 Break Interrupt */
SAI2_IRQn = 91, /*!< SAI2 global Interrupt */
QUADSPI_IRQn = 92, /*!< QuadSPI global Interrupt */
CEC_IRQn = 93, /*!< QuadSPI global Interrupt */
SPDIF_RX_IRQn = 94, /*!< QuadSPI global Interrupt */
FMPI2C1_EV_IRQn = 95, /*!< FMPI2C Event Interrupt */
FMPI2C1_ER_IRQn = 96 /*!< FMPCI2C Error Interrupt */
#endif /* STM32F446xx */
} IRQn_Type;
上一篇:STM32F429之定时器
下一篇:STM32F429之外部中断
vs2005 + windows Mobile 5 SDK 中关于 Media Player的加入到窗体中的问题 遇到问题,第一次开WM5程序,在MFC中 加入 ActiveX for Media Player 这段代码如下,帮忙看看! CAxWindow m_wndView; CComPtr m_spWMPPlayer; &nbs ...… 查看全部问答> |
项目开发遇到的问题急,请有用PB5.0定制过系统的帮忙下,谢谢 由于项目用adoce组件进行开发,从网上下载adoce组件包后,由于一直用EVC开发阶段都是拷进去来调试。现在要用PB5.0定制系统,不知道怎么打包adoce组件,添加原先的cec文件好像不行。只能定制一个cec文件,但网上大多数都为PB4.2步骤和PB5.0差好多。 ...… 查看全部问答> |
d:\\question.jpg 以上是一个发射地址码和数据码的电路。在数据码编辑的时,原先的电路是使用开关控制数据位D0-D3的高低电平,进而对数据位D0-D3进行编辑。 我的问题是,这部分开关控制的电路(图上红色长方形框所示),是否能通过一块芯片控制 ...… 查看全部问答> |
有网友询问MCU应用系统中上电暂态时输出失控的方法,在此解答入下: 问:怎么解决系统上电时继电器乱动作的问题? 解答: 可以采用负逻辑甚至互补逻辑、翻转逻辑设计等。 负逻辑设计指低电平有效。多数MCU的常规IO在上电暂态过程中是弱上拉输出 ...… 查看全部问答> |
