今天是:2025年03月07日(星期五)
2019年03月07日 | 基于STM32的智能学习空调项目的定时器捕获驱动
2019-03-07 来源:eefocus
* 函数 : TIM3.C
* 功能 : 红外信号捕获和发射
* 参数 : 无
* 返回 : 无
* 依赖 : 底层读写函数
voidIRDA_GPIO_Init(void)
GPIO_InitTypeDef GPIO_InitStructure;
//LED1 LED2
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //使能PA,PD端口时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //使能PA,PD端口时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11|GPIO_Pin_12; //
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz
GPIO_Init(GPIOA, &GPIO_InitStructure); //根据设定参数初始化GPIOA.8
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; //PA6 清除之前设置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //PA6 清除之前设置
GPIO_SetBits(GPIOA,GPIO_Pin_5); //PA.8 输出高
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11; //PA6 清除之前设置
GPIO_Init(GPIOB, &GPIO_InitStructure);
// 看门狗SP706 输入脚PA7
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; //PA7 清除之前设置
void TIM3_Int_Init(u16 arr,u16 psc)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_ICInitTypeDef TIM_ICInitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); //时钟使能
TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值计数到5000为500ms
TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置用来作为TIMx时钟频率除数的预分频值 10Khz的计数频率
TIM_TimeBaseStructure.TIM_ClockDivision = 0; //设置时钟分割:TDTS = Tck_tim
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
TIM_ICInitStructure.TIM_Channel = TIM_Channel_1;
TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Falling;
TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
TIM_ICInitStructure.TIM_ICFilter = 0x0;
TIM_ICInit(TIM3, &TIM_ICInitStructure);
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; //TIM3中断
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; //先占优先级0级
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //从优先级3级
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
NVIC_Init(&NVIC_InitStructure); //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器
TIM_ITConfig(TIM3,TIM_IT_CC1,DISABLE);//不允许CC1IE捕获中断
TIM_ITConfig(TIM3,TIM_IT_Update,DISABLE);//不允许更新中断
TIM_Cmd(TIM3,DISABLE); //使能定时器3
void TIM_Polarityset(u8 Polarity)
if(Polarity == 0) TIM3->CCER &= ~(1<<1); //上升
else TIM3->CCER |= 1<<1; //下降
void TIM3_IRQHandler(void) //TIM3中断
if(TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) //检查指定的TIM中断发生与否:TIM 中断源
TIM_ClearITPendingBit(TIM3,TIM_IT_Update ); //清除TIMx的中断待处理位:TIM 中断源
switch(Timer3)
case 0:
Timer3++;
if(u8Lev == 0x0) GPIO_SetBits(GPIOA,GPIO_Pin_5);
else GPIO_ResetBits(GPIOA,GPIO_Pin_5);
break;
case 1:
Timer3++;
break;
case 2:
Timer3 = 0;
Timer_PWM++;
if(Timer_PWM >= Capture)
Capture = u16P[u16Pcn++];
if(Capture == 0xffff) //输出结束
irad_launch = 1;
u8FSMirda = IRDA_FSM_DILE;
else
u8Lev = ~u8Lev;
Timer_PWM = 0;
break;
default:
Timer3 = 0;
if(TIM_GetITStatus(TIM3, TIM_IT_CC1) == SET)
//TIM_ICInitTypeDef TIM_ICInitStructure;
/* Clear TIM3 Capture compare interrupt pending bit */
TIM_ClearITPendingBit(TIM3, TIM_IT_CC1);
u8Timerirda = 0;
if(CaptureNumber == 0)
/* Get the Input Capture value */
IC3ReadValue1 = TIM_GetCapture1(TIM3);
CaptureNumber = 1;
u8Lev = 0xff;
else if(CaptureNumber == 1)
IC3ReadValue2 = TIM_GetCapture1(TIM3);
/* Capture computation */
if (IC3ReadValue2 > IC3ReadValue1)
Capture = (IC3ReadValue2 - IC3ReadValue1);
else
Capture = ((0xFFFF - IC3ReadValue1) + IC3ReadValue2);
u16P[u16Pcn++] = Capture;
IC3ReadValue1 = IC3ReadValue2;
/* Frequency computation */
//TIM3Freq = (uint32_t) SystemCoreClock / Capture;
//CaptureNumber = 0;
u8Lev = ~u8Lev;
TIM_Polarityset(u8Lev);
我在原来的公司做的时候,就注意观察公司在管理上的成功和失败的经验教训,并在网络上找很多关于管理的文章。 管理上有很多故事,让我领悟到管理就是设计一个合理的机制。 故事之一:分粥 分粥的故 ...… 查看全部问答> |
s3c2440 for wince4.2 的 eboot启动时出现的网络端口问题,高手请进给解答一下。 启动后,DNW出现下列打印信息: WinCE NAND Boot v1.00 Jun 11 2007 11:50:13 Start Eboot... Start Launch...0 Microsoft Windows CE Ethernet Bootloader Common Library Version 1.0 Built Mar 13 2003 23:05:42 Microsoft Windows CE SMD ...… 查看全部问答> |
拿到STM32开发板三天了!写了几个程序!程序简单但对入门还是有点帮助的!我自己下次调试成功了的! 上传供一起刚入门的朋友分享下! 第一天学习:MDK工程建立和GPIO 第二天学习:RCC和按键程序 第三天学习:EXTI程序(一个中断按键程序) 每 ...… 查看全部问答> |
我用2407做一个液晶显示,因为有存放大量字符数据的常量数组,我把这些数组定义为const unsigned char 类型。cmd文件如下: -o LCD.out - stack 60 MEMORY { PAGE 0: /* Program Memory */ & ...… 查看全部问答> |
电风扇模拟控制系统设计1.用4个LED显示电风扇的工作状态(1,2,3,4四档风力),显示风类:“自然风”、 “常风”和“睡眠风”。2.设计 “自然风”、 “常风”和“睡眠风” 三个风类键用于设置风类; 设计一个“摇头” 键用于控制电机摇头。 &nb ...… 查看全部问答> |
我们知道, MOS管最常见的应用可能是电源中的开关元件,此外,它们对电源输出也大有裨益。服务器和通信设备等应用一般都配置有多个并行电源,以支持N+1 冗余与持续工作 (图1)。各并行电源平均分担负载,确保 ...… 查看全部问答> |
