今天是:2025年03月07日(星期五)
2019年03月07日 | 基于S3C2440的Linux内核移植和yaffs2文件系统制作--启动系统
2019-03-07 来源:eefocus
第三章 启动系统
将前面两章生成的内核映像文件和根文件系统映像文件下载到mini2440开发板,查看启动信息。我成功移植启动信息如下:
VIVI version 0.1.4 (root@capcross) (gcc version 2.95.3 20010315 (release)) #0.1.4 Mon Oct 27 10:18:15 CST 2008
MMU table base address = 0x33DFC000
Succeed memory mapping.
DIVN_UPLL0
MPLLVal [M:7fh,P:2h,S:1h]
CLKDIVN:5h
| S3C2440A USB Downloader ver R0.03 2004 Jan |
USB: IN_ENDPOINT:1 OUT_ENDPOINT:3
FORMAT:
NOTE: Power off/on or press the reset button for 1 sec
in order to get a valid USB device address.
NAND device: Manufacture ID: 0xec, Chip ID: 0x76 (Samsung K9D1208V0M)
Found saved vivi parameters.
Press Return to start the LINUX/Wince now, any other key for vivi
Copy linux kernel from 0x00050000 to 0x30008000, size = 0x00200000 ... done
zImage magic = 0x016f2818
Setup linux parameters at 0x30000100
linux command line is: "noinitrd root="/dev/mtdblock2" init="/linuxrc" console="ttySAC0""
MACH_TYPE = 362
NOW, Booting Linux......
Uncompressing Linux.......................................................................................................................... done, booting the kernel.
Linux version 2.6.29.1 (root@localhost.localdomain) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #8 Sat Jul 18 10:37:22 CST 2009
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr="c0007177"
CPU: VIVT data cache, VIVT instruction cache
Machine: Study-S3C2440
ATAG_INITRD is deprecated; please update your bootloader.
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C24XX Clocks, (c) 2004 Simtec Electronics
S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: noinitrd root="/dev/mtdblock2" init="/linuxrc" console="ttySAC0"
irq: clearing pending status 02000000
irq: clearing subpending status 00000002
PID hash table entries: 256 (order: 8, 1024 bytes)
Console: colour dummy device 80x30
console [ttySAC0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 60876KB available (3536K code, 293K data, 136K init)
Calibrating delay loop... 201.93 BogoMIPS (lpj=504832)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 296 bytes
NET: Registered protocol family 16
S3C2410 Power Management, (c) 2004 Simtec Electronics
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
S3C244X: Clock Support, DVS off
bio: create slab
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
NTFS driver 2.1.29 [Flags: R/O].
yaffs Jul 18 2009 10:31:41 Installing.
msgmni has been set to 119
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Console: switching to colour frame buffer device 30x40
fb0: s3c2410fb frame buffer device
lp: driver loaded but no devices found
ppdev: user-space parallel port driver
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
brd: module loaded
loop: module loaded
dm9000 Ethernet Driver, V1.31
Uniform Multi-Platform E-IDE driver
ide-gd driver 1.18
ide-cd driver 5.00
Driver 'sd' needs updating - please use bus_type methods
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2440-nand s3c2440-nand: Tacls="1", 9ns Twrph0=4 39ns, Twrph1=1 9ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
Scanning device for bad blocks
Creating 3 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x000000000000-0x000000030000 : "boot"
0x000000050000-0x000000250000 : "kernel"
0x000000250000-0x000003ffc000 : "kernel"
usbmon: debugfs is not available
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: New USB device found, idVendor="1d6b", idProduct="0001"
usb usb1: New USB device strings: Mfr="3", Product="2", SerialNumber="1"
usb usb1: Product: S3C24XX OHCI
usb usb1: Manufacturer: Linux 2.6.29.1 ohci_hcd
usb usb1: SerialNumber: s3c24xx
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new interface driver libusual
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver ftdi_sio
ftdi_sio: v1.4.3:USB FTDI Serial Converters Driver
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
s3c2410_udc: debugfs dir creation failed -19
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 98 KHz
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
TCP cubic registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
yaffs: dev is 32505858 name is "mtdblock2"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.2, "mtdblock2"
yaffs_read_super: isCheckpointed 0
VFS: Mounted root (yaffs filesystem) on device 31:2.
Freeing init memory: 136K
----------munt all----------------
****************Studying ARM*********************
Kernel version:linux-2.6.29.1
Student:Feng dong rui
Date:2009.07.15
Please press Enter to activate this console.
[@MrFeng=W]#ls
bin etc linuxrc proc sys var
boot home lost+found root tmp www
dev lib mnt sbin usr
[@MrFeng=W]#
这期间可能会遇到这样或那样启动失败的错误,要么是内核移植有问题,要么是根文件系统没制作好,只有到google上搜索解决问题了。我就是重复的配置和编译、google,甚至虚拟机上的Linux系统都重新装过,经过许多重复的劳动和思考终于移植成功了。
【EEWORLD】“简简单单DSP”系列学习活动(11月07日已更新第七期) 【EEWORLD】“简简单单DSP”系列学习活动 欢迎加入“简简单单DSP”系列学习活动,AQUA学习小组将和您一起学DSP281x。 活动目的: 数字信号处理器(DSP)是广大电子工程师几乎必备的利器,从运动控制到图像处理的诸多领域,DSP已 ...… 查看全部问答> |
一个LED的N种玩法 (二)---渐变 Author: chenzhufly Email: chenzhufly@126.com 2010-4-28 在第一篇中我已经能够上LED闪烁起来了,还可以怎么玩呢?想到网络上曾经讨论过LED亮度渐变的程序,实现的方式很多,我这里挑个最简单的—用延时 ...… 查看全部问答> |
ARM92440芯片IIC接口,驱动光强传感器TSL2561。 根据TSL2561手册中的描述,The TIMING register defaults to 02h at power on,现在我的代码可以读出这个02h;读ID Register (Ah),也能读到正确的值。 用示波器观察,能很清楚地观察到START、STOP ...… 查看全部问答> |
CE6.0下的Cellcore是不是已经帮我们实现了GSM协议栈?很多公司找人去设计GSM协议栈是什么意思? CE6.0下的Cellcore是不是已经帮我们实现了GSM协议栈?很多公司找人去设计GSM协议栈是什么意思?… 查看全部问答> |
关于16为data width如何在pSRM里面申请一个unsignd char CPU与SRAM的访问方式为WORD访问,也就是说,CPU能一次从SRAM里面读出16BIT的数据,这样现在有一个问题想不通: unsigned char testTemp; 请问,CPU如何在SRAM里面定位一个BYTE,并申请了这个空间的?… 查看全部问答> |
想要在TI送的8962板子上用计时器中断实现LED闪烁,代码是网上找的,但是下载到板子后没有实现功能,我看不出问题,请大家指教 #include \"hw_ints.h\" #include \"hw_memmap.h\" #include \"hw_types.h\" #include \"debug.h\" #include \"gpi ...… 查看全部问答> |
最近看了一下linux下面的防火墙的实现过程有些资料上传与大家分享Linux安全体系的防火墙实现linuxnetfilter&iptables实现机制的分析与应用 [ 本帖最后由 daicheng 于 2010-12-20 14:35 编辑 ]… 查看全部问答> |
