今天是:2025年03月24日(星期一)
正在发生
2019年03月24日 | 中容量STM32处理器启动代码的理解
2019-03-24 来源:eefocus
今天要介绍一下STM32的启动代码,我这里使用的是中容量的STM32f103c8t6,对应的启动文件就是startup_stm32f10x_md.s,我这里启动文件版本是V3.6.2
不多说废话,先上我注释过的源码:
  * @file      startup_stm32f10x_md.s
  * @author    MCD Application Team
  * @version   V3.6.2
  * @date      28-February-2013
  * @brief     STM32F10x Medium Density Devices vector table for RIDE7 toolchain.
  *            This module performs:
  *                - Set the initial SP                                              -设置最初的SP寄存器值
  *                - Set the initial PC == Reset_Handler, -设置最初的PC寄存器值 == Reset_Handler
  *                - Set the vector table entries with the exceptions ISR address    -在有特殊的ISR(中断服务程序)地址的情况下设置向量表入口
  *                - Configure the clock system -设置时钟系统
  *                - Branches to main in the C library (which eventually -C库文件中由分支到主函数(最后调用了主函数)
  *                  calls main()).
  *            After Reset the Cortex-M3 processor is in Thread mode, 在线程模式下复位了CM3处理器后,此时优先级特权化,栈顶设置为主函数
  *            priority is Privileged, and the Stack is set to Main.
  * @attention
© COPYRIGHT 2013 STMicroelectronics
  * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
  * You may not use this file except in compliance with the License.
  * You may obtain a copy of the License at:
  *        http://www.st.com/software_license_agreement_liberty_v2
  * Unless required by applicable law or agreed to in writing, software
  * distributed under the License is distributed on an "AS IS" BASIS,
  * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  * See the License for the specific language governing permissions and
  * limitations under the License.
  .syntax unified        ;表示使用了统一汇编语言语法
.cpu cortex-m3        ;MCU为CM3
.fpu softvfp
.thumb        ;指令集
.global g_pfnVectors        ;global使得g_pfnVectors可以被其他目标文件使用
.global Default_Handler
/* start address for the initialization values of the .data section.                初始化.data 块的起始地址,这个地址在链接脚本中被定义
defined in linker script */
.word _sidata
/* start address for the .data section. defined in linker script                    .data块的起始地址,这个地址在链接脚本中被定义*/
.word _sdata
/* end address for the .data section. defined in linker script                      .data块的结束地址,这个地址在链接脚本中被定义*/
.word _edata
/* start address for the .bss section. defined in linker script                     .bss块的起始地址,这个地址在链接脚本中被定义*/
.word _sbss
/* end address for the .bss section. defined in linker script                       .bss块的结束地址,这个地址在链接脚本中被定义*/
.word _ebss
.equ  BootRAM, 0xF108F85F                                                           /*这里跟c中的宏定义类似,即BootRAM = 0xF108F85F,不参与编译*/
 * @brief  This is the code that gets called when the processor first
 *          starts execution following a reset event. Only the absolutely
 *          necessary set is performed, after which the application
 *          supplied main() routine is called.
 * @param  None
 * @retval : None
    .section .text.Reset_Handler
.weak Reset_Handler
.type Reset_Handler, %function
Reset_Handler:
/* Copy the data segment initializers from flash to SRAM                             将初始化了的数据段从flash复制到SRAM*/
  movs r1, #0        ;将立即数0赋值给r1寄存器
  b LoopCopyDataInit        ;程序转移到LoopCopyDataInit处
CopyDataInit:        ;从FLASH中拷贝地址在sdata和edata之间的代码到SRAM中
ldr r3, =_sidata        ;从存储器中将_sidata加载到寄存器r3中
ldr r3, [r3, r1]        ;从地址r3+r1处读取一个字(32bit)到r3中
str r3, [r0, r1]        ;把寄存器r3的值存储到存储器中地址为r0+r1地址处
adds r1, r1, #4                                                               ;r1 = r1 + 4
LoopCopyDataInit:
ldr r0, =_sdata        ;从存储器中将_sidata加载到寄存器r0中
ldr r3, =_edata        ;从存储器中将_edata加载到寄存器r3中
adds r2, r0, r1                                                               ;r2=r0+r1
cmp r2, r3        ;计算r2 - r3,若小于0,标志位为0,反之为1
bcc CopyDataInit        ;如果标志位为0(无借位)即r2
ldr r2, =_sbss        ;从存储器中将_sbss加载到寄存器r2中
b LoopFillZerobss                                                              ;无条件跳转到LoopFillZerobss
/* Zero fill the bss segment. */
FillZerobss:
movs r3, #0        ;将立即数0存入寄存器r3
str r3, [r2], #4        ;将寄存器r3的值存储到地址为r2寄存器值得地址处后,r2 = r2 + 4
LoopFillZerobss:
ldr r3, = _ebss        ;从存储器中将_ebss加载到寄存器r3中
cmp r2, r3        ;比较r2,r3,然后更新标志位
bcc FillZerobss        ;如果标志位为0(无借位),则跳转到FillZerobss处
/* Call the clock system intitialization function.*/
/* bl  SystemInit */
/* Call the application's entry point.*/
bl main        ;转移到main函数起始处
bx lr        ;转移到地址lr处
.size Reset_Handler, .-Reset_Handler                                               ;相当于mov pc lr    lr即寄存器r14
 * @brief  This is the code that gets called when the processor receives an
 *         unexpected interrupt. This simply enters an infinite loop, preserving
 *         the system state for examination by a debugger.
 * @param  None
 * @retval None
    .section .text.Default_Handler,"ax",%progbits
Default_Handler:
Infinite_Loop:
b Infinite_Loop        ;无条件跳转到Infinite_Loop
.size Default_Handler, .-Default_Handler
* The minimal vector table for a Cortex M3.  Note that the proper constructs         Cortex M3的最小向量表
* must be placed on this to ensure that it ends up at physical address
* 0x0000.0000.
  .section .isr_vector,"a",%progbits                                            ;定义中断向量表的数据段
.type g_pfnVectors, %object
.size g_pfnVectors, .-g_pfnVectors
g_pfnVectors:
.word _estack        ;在当前位置放置一个word型的值,这个值为_estack;后面同理
.word Reset_Handler                                                            ;这一块程序的意思就是说以g_pfnVectors为初始地址,然后依次
.word NMI_Handler                                                              ;以字为单位写入相应的数据
.word HardFault_Handler
.word MemManage_Handler
.word BusFault_Handler
.word UsageFault_Handler
.word 0
.word 0
.word 0
.word 0
.word SVC_Handler
.word DebugMon_Handler
.word 0
.word PendSV_Handler
.word SysTick_Handler
.word WWDG_IRQHandler
.word PVD_IRQHandler
.word TAMPER_IRQHandler
.word RTC_IRQHandler
.word FLASH_IRQHandler
.word RCC_IRQHandler
.word EXTI0_IRQHandler
.word EXTI1_IRQHandler
.word EXTI2_IRQHandler
.word EXTI3_IRQHandler
.word EXTI4_IRQHandler
.word DMA1_Channel1_IRQHandler
.word DMA1_Channel2_IRQHandler
.word DMA1_Channel3_IRQHandler
.word DMA1_Channel4_IRQHandler
.word DMA1_Channel5_IRQHandler
.word DMA1_Channel6_IRQHandler
.word DMA1_Channel7_IRQHandler
.word ADC1_2_IRQHandler
.word USB_HP_CAN1_TX_IRQHandler
.word USB_LP_CAN1_RX0_IRQHandler
.word CAN1_RX1_IRQHandler
.word CAN1_SCE_IRQHandler
.word EXTI9_5_IRQHandler
.word TIM1_BRK_IRQHandler
.word TIM1_UP_IRQHandler
.word TIM1_TRG_COM_IRQHandler
.word TIM1_CC_IRQHandler
.word TIM2_IRQHandler
.word TIM3_IRQHandler
.word TIM4_IRQHandler
.word I2C1_EV_IRQHandler
.word I2C1_ER_IRQHandler
.word I2C2_EV_IRQHandler
.word I2C2_ER_IRQHandler
.word SPI1_IRQHandler
.word SPI2_IRQHandler
.word USART1_IRQHandler
.word USART2_IRQHandler
.word USART3_IRQHandler
.word EXTI15_10_IRQHandler
.word RTCAlarm_IRQHandler
.word USBWakeUp_IRQHandler
  .word 0
.word 0
.word 0
.word 0
.word 0
.word 0
.word 0
.word BootRAM          /* @0x108. This is for boot in RAM mode for             这个是为stm32f10系列中容量系列设备的boot中的RAM模式准备的
                            STM32F10x Medium Density devices. */
* Provide weak aliases for each Exception handler to the Default_Handler.
* As they are weak aliases, any function with the same name will override
* this definition.
  .weak NMI_Handler        ;定义一个弱别名NMI_Handler
.thumb_set NMI_Handler,Default_Handler                                          ;如果这个不重写这个弱别名,那么默认执行Default_Handler,反之这执行重写过的NMI_Handler
  .weak HardFault_Handler
.thumb_set HardFault_Handler,Default_Handler
  .weak MemManage_Handler
.thumb_set MemManage_Handler,Default_Handler
  .weak BusFault_Handler
.thumb_set BusFault_Handler,Default_Handler
.weak UsageFault_Handler
.thumb_set UsageFault_Handler,Default_Handler
.weak SVC_Handler
.thumb_set SVC_Handler,Default_Handler
.weak DebugMon_Handler
.thumb_set DebugMon_Handler,Default_Handler
.weak PendSV_Handler
.thumb_set PendSV_Handler,Default_Handler
.weak SysTick_Handler
.thumb_set SysTick_Handler,Default_Handler
.weak WWDG_IRQHandler
.thumb_set WWDG_IRQHandler,Default_Handler
.weak PVD_IRQHandler
.thumb_set PVD_IRQHandler,Default_Handler
.weak TAMPER_IRQHandler
.thumb_set TAMPER_IRQHandler,Default_Handler
.weak RTC_IRQHandler
.thumb_set RTC_IRQHandler,Default_Handler
.weak FLASH_IRQHandler
.thumb_set FLASH_IRQHandler,Default_Handler
.weak RCC_IRQHandler
.thumb_set RCC_IRQHandler,Default_Handler
.weak EXTI0_IRQHandler
.thumb_set EXTI0_IRQHandler,Default_Handler
.weak EXTI1_IRQHandler
.thumb_set EXTI1_IRQHandler,Default_Handler
.weak EXTI2_IRQHandler
.thumb_set EXTI2_IRQHandler,Default_Handler
.weak EXTI3_IRQHandler
.thumb_set EXTI3_IRQHandler,Default_Handler
.weak EXTI4_IRQHandler
.thumb_set EXTI4_IRQHandler,Default_Handler
.weak DMA1_Channel1_IRQHandler
.thumb_set DMA1_Channel1_IRQHandler,Default_Handler
.weak DMA1_Channel2_IRQHandler
.thumb_set DMA1_Channel2_IRQHandler,Default_Handler
.weak DMA1_Channel3_IRQHandler
.thumb_set DMA1_Channel3_IRQHandler,Default_Handler
.weak DMA1_Channel4_IRQHandler
.thumb_set DMA1_Channel4_IRQHandler,Default_Handler
.weak DMA1_Channel5_IRQHandler
.thumb_set DMA1_Channel5_IRQHandler,Default_Handler
.weak DMA1_Channel6_IRQHandler
.thumb_set DMA1_Channel6_IRQHandler,Default_Handler
.weak DMA1_Channel7_IRQHandler
.thumb_set DMA1_Channel7_IRQHandler,Default_Handler
.weak ADC1_2_IRQHandler
.thumb_set ADC1_2_IRQHandler,Default_Handler
.weak USB_HP_CAN1_TX_IRQHandler
.thumb_set USB_HP_CAN1_TX_IRQHandler,Default_Handler
.weak USB_LP_CAN1_RX0_IRQHandler
.thumb_set USB_LP_CAN1_RX0_IRQHandler,Default_Handler
.weak CAN1_RX1_IRQHandler
.thumb_set CAN1_RX1_IRQHandler,Default_Handler
.weak CAN1_SCE_IRQHandler
.thumb_set CAN1_SCE_IRQHandler,Default_Handler
.weak EXTI9_5_IRQHandler
.thumb_set EXTI9_5_IRQHandler,Default_Handler
.weak TIM1_BRK_IRQHandler
.thumb_set TIM1_BRK_IRQHandler,Default_Handler
.weak TIM1_UP_IRQHandler
.thumb_set TIM1_UP_IRQHandler,Default_Handler
.weak TIM1_TRG_COM_IRQHandler
.thumb_set TIM1_TRG_COM_IRQHandler,Default_Handler
.weak TIM1_CC_IRQHandler
.thumb_set TIM1_CC_IRQHandler,Default_Handler
.weak TIM2_IRQHandler
.thumb_set TIM2_IRQHandler,Default_Handler
.weak TIM3_IRQHandler
.thumb_set TIM3_IRQHandler,Default_Handler
.weak TIM4_IRQHandler
.thumb_set TIM4_IRQHandler,Default_Handler
.weak I2C1_EV_IRQHandler
.thumb_set I2C1_EV_IRQHandler,Default_Handler
.weak I2C1_ER_IRQHandler
.thumb_set I2C1_ER_IRQHandler,Default_Handler
.weak I2C2_EV_IRQHandler
.thumb_set I2C2_EV_IRQHandler,Default_Handler
.weak I2C2_ER_IRQHandler
.thumb_set I2C2_ER_IRQHandler,Default_Handler
.weak SPI1_IRQHandler
.thumb_set SPI1_IRQHandler,Default_Handler
.weak SPI2_IRQHandler
.thumb_set SPI2_IRQHandler,Default_Handler
.weak USART1_IRQHandler
.thumb_set USART1_IRQHandler,Default_Handler
.weak USART2_IRQHandler
.thumb_set USART2_IRQHandler,Default_Handler
.weak USART3_IRQHandler
.thumb_set USART3_IRQHandler,Default_Handler
.weak EXTI15_10_IRQHandler
.thumb_set EXTI15_10_IRQHandler,Default_Handler
.weak RTCAlarm_IRQHandler
.thumb_set RTCAlarm_IRQHandler,Default_Handler
.weak USBWakeUp_IRQHandler
.thumb_set USBWakeUp_IRQHandler,Default_Handler
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
如果有注释不准确的地方还希望能够给我指出,感谢感谢~~
这里以STM32程序运行过程为轴线,依次介绍单片机启动过程中的流程。
  在给单片机上电前,先通过给BOOT0和BOOT1连接高低电平来设置程序启动的初始位置。STM32程序启动的位置有三种:
  1:Main Flash memory
  是STM32内置的Flash,一般我们使用JTAG或者SWD模式下载程序时,就是下载到这个里面,重启后也直接从这启动程序。
  2:System memory
  从系统存储器启动,这种模式启动的程序功能是由厂家设置的。一般来说,这种启动方式用的比较少。
  3:Embedded Memory
  内置SRAM,既然是SRAM,自然也就没有程序存储的能力了,这个模式一般用于程序调试。
  在这三种方式里面用的最多的是第一种,下面以第一种启动方式为例进行介绍:
  在重启芯片时,SYSCLK的第4个上升沿,BOOT引脚的值将被锁存。然后进入启动文件,具体的启动文件为startup_stm32f10x_md.s。
  首先启动文件中有一个Reset_Handler,这个汇编函数的作用有两个:
   a.将FLASH中的程序代码拷贝到SRAM中
   b.将系统堆栈初始化(清0)
  然后进入main,从而进入c的世界。
但是启动文件到这里还没有结束,后面还有一个部分。
这个部分的作用是定义了一个段来存放中断向量表,然后以字的形式分别填入了中断的指针。
在这以后还有一个部分,后面这个部分的作用是给中断服务定义了一个弱别名,这个弱别名的作用就是在有中断被触发后,如果没有重写对应的弱别名,那么程序就默认执行默认的中断处理函数(Default_Handler),反之则执行重写了的中断处理函数
ACI [Applied Concepts, Inc.]公司的发展小趣事
随着全球电子市场的不断扩大,ACI公司开始将目光投向海外市场。公司积极实施国际化战略,通过设立海外分支机构、参加国际展会等方式拓展市场。同时,ACI还加强了与国际同行的交流与合作,共同推动电子行业的发展。通过国际化布局,ACI成功打开了海外市场的大门,为公司的发展注入了新的动力。
Hoffman_Enclosures__Inc.公司的发展小趣事
Hoffman在追求企业发展的同时,也积极履行社会责任,致力于实现可持续发展。公司注重环保和节能,不断推出绿色、低碳的产品和技术。同时,Hoffman还积极参与公益事业,通过捐款、志愿服务等多种方式回馈社会。这些举措不仅提升了公司的社会形象,也促进了企业与社会的和谐共生。
以上五个故事展示了Hoffman Enclosures, Inc.在电子行业中的发展历程和关键节点,每个故事都体现了公司在技术创新、市场拓展、产品定制、标准制定以及社会责任等方面的努力和成就。
EMBEST公司的发展小趣事
EMBEST公司成立于XXXX年,早期便专注于ARM嵌入式软件的开发。在XXXX年,EMBEST发布了国内首个具有自主知识产权的ARM嵌入式软件开发工具Embest IDE For ARM,这一里程碑式的产品不仅填补了国内市场的空白,也为EMBEST在嵌入式领域的地位奠定了基础。通过持续的创新和研发,EMBEST逐步建立了自己的技术壁垒,为公司的长远发展奠定了坚实基础。
岑科(CENKER)公司的发展小趣事
为了实现更高效的生产和更优质的产品,岑科在2011年成立了自动化设备研发团队。通过自主研发生产设备,岑科实现了对生产技术的全面掌控,并加强了技术创新和改进。这一举措不仅提高了生产效率,还为岑科带来了更多的技术积累和知识产权。随着自动化设备的广泛应用,岑科的生产能力得到了大幅提升,同时也推动了整个产业的升级和可持续发展。
Henkel公司的发展小趣事
为了实现更长远的发展,岑科在2004年决定进军生产制造领域。公司在深圳和广西设立了工厂,开始了自主生产制造之路。在这一过程中,岑科严格控制生产流程,灵活配置资源,并建立了严格的质量管理体系,以确保产品的高水平交付。通过自主研发和创新,岑科逐渐在生产制造领域取得了显著的成果,产品线不断扩展,市场份额也逐渐增加。
Esterline Technologies Corporation公司的发展小趣事
随着生产规模的扩大,岑科在2010年将制造板块迁移至广西,以进一步优化企业资源配置。这一举措不仅降低了生产成本,还提高了生产效率。同时,岑科加速了自主创新和技术进步的步伐,不断推出更具竞争力的电子产品。在这一阶段,岑科的产品质量和性能得到了市场的广泛认可,客户满意度也持续提升。
电子元器件识别
请教高手:两个稳压二极管头对头连接是什么元件?有什么作用?如何测试?谢谢!…
选择D题加入QQ群,一起讨论吧~
本帖最后由 paulhyde 于 2014-9-15 09:01 编辑 选择D题的请进我们的群22373240  …
求救高手,一个通信耦合问题!
问题是这样的:我现在要把一个“密室”里的音视频信号采集以后传输出来,信号采集传感器装在一个小车上,平时小车在“密室”预装的轨道上来回移动,轨道铺到密道口,密道是“S”形的,周围是1.8m厚的水泥墙,不能用有线通信,但是用无线的话信号也 ...…
为什么6410的串口数据都要走USB呢。。。小弟不才。。不知道怎么了不让他走USB。。。…
关于movx指令向外部器件端口地址送数据问题,急盼高手指点!
#define DIGPORT  XBYTE[0x0200]               //定义字位口 #define WORDPORT XBYTE[0x0100]               //定义字型口 #d ...…
印刷的参考手册哪里能买到?680多页
                                 电子版的不方便,需要反复看,英文的最好…
求助TDA7419设置问题
各位高手大侠,我目前用TDA7419做音频处理,结果是MCU与TDA7419的I2C通信正常了,TDA7419都能正常ACK。但是就是没有声音出来。 请求各位高手帮帮忙指点小弟。 我的外部硬件设置是,外部MUTE脚悬空,其他的是SE2先做一路输入,输入信号为1V  ...…
变压器发热严重的问题
我最近遇到了一个问题,需要大家帮我解答一下,在逆变器件正常的情况下,变压器发热严重的问题应该怎么调整?…
