今天是:2025年04月19日(星期六)
2019年04月19日 | 基于MSP430G2253的OLED驱动(SPI)
2019-04-19 来源:eefocus
本例OLED通过SPI与开发板建立连接(编辑器是IAR FOR MSP):
这个是OLED驱动:
//12864.c
#include"MSP430G2553.h"
#include"12864.h"
#include"qumo.h"
#include"stdio.h"
void delay(int ms)//延时
int ii,jj;
if (ms<1) ms=1;
for(ii=0;ii } //向LCD写入地址 void LCD_WrDat(unsigned char dat) { unsigned char i=8; DC_SET; SCL_CLR; while(i--) { if(dat&0x80) {SDA_SET;} else {SDA_CLR;} SCL_SET ; SCL_CLR; dat<<=1; } } //向LCD屏中写入命令 void LCD_WrCmd(unsigned char cmd) { unsigned char i=8; DC_CLR; SCL_CLR; while(i--) { if(cmd&0x80) {SDA_SET;} else{SDA_CLR;} SCL_SET; SCL_CLR; cmd<<=1; } } //延时函数 void LCD_DLY_ms(unsigned int ms) { unsigned int a; while(ms) { a=1335; while(a--); ms--; } return; } //LCD屏清屏 void LCD_CLS(void) { unsigned char y,x; for(y=0;y<8;y++) { LCD_WrCmd(0xb0+y); LCD_WrCmd(0x01); LCD_WrCmd(0x10); for(x=0;x } } //清屏操作 void LCD_Fill(unsigned char bmp_dat) { unsigned char y,x; for(y=0;y<8;y++) { LCD_WrCmd(0xb0+y); LCD_WrCmd(0x01); LCD_WrCmd(0x10); for(x=0;x } } void LCD_Set_Pos(unsigned char x, unsigned char y)//设置坐标 { LCD_WrCmd(0xb0+y); LCD_WrCmd(((x&0xf0)>>4)|0x10); LCD_WrCmd((x&0x0f)|0x00); } //LCD液晶屏初始化 void LCD_Init(void) { SCL_SET; RST_CLR; LCD_DLY_ms(50); RST_SET; //从上电到下面开始初始化要有足够的时间,即等待RC复位完毕 LCD_WrCmd(0xae);//--turn off oled panel LCD_WrCmd(0x00);//---set low column address LCD_WrCmd(0x10);//---set high column address LCD_WrCmd(0x40);//--set start line address Set Mapping RAM Display Start Line (0x00~0x3F) LCD_WrCmd(0x81);//--set contrast control register LCD_WrCmd(0xcf); // Set SEG Output Current Brightness LCD_WrCmd(0xa1);//--Set SEG/Column Mapping 0xa0左右反置 0xa1正常 LCD_WrCmd(0xc8);//Set COM/Row Scan Direction 0xc0上下反置 0xc8正常 LCD_WrCmd(0xa6);//--set normal display LCD_WrCmd(0xa8);//--set multiplex ratio(1 to 64) LCD_WrCmd(0x3f);//--1/64 duty LCD_WrCmd(0xd3);//-set display offset Shift Mapping RAM Counter (0x00~0x3F) LCD_WrCmd(0x00);//-not offset LCD_WrCmd(0xd5);//--set display clock divide ratio/oscillator frequency LCD_WrCmd(0x80);//--set divide ratio, Set Clock as 100 Frames/Sec LCD_WrCmd(0xd9);//--set pre-charge period LCD_WrCmd(0xf1);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock LCD_WrCmd(0xda);//--set com pins hardware configuration LCD_WrCmd(0x12); LCD_WrCmd(0xdb);//--set vcomh LCD_WrCmd(0x40);//Set VCOM Deselect Level LCD_WrCmd(0x20);//-Set Page Addressing Mode (0x00/0x01/0x02) LCD_WrCmd(0x02);// LCD_WrCmd(0x8d);//--set Charge Pump enable/disable LCD_WrCmd(0x14);//--set(0x10) disable LCD_WrCmd(0xa4);// Disable Entire Display On (0xa4/0xa5) LCD_WrCmd(0xa6);// Disable Inverse Display On (0xa6/a7) LCD_WrCmd(0xaf);//--turn on oled panel LCD_Fill(0x00); //初始清屏 LCD_Set_Pos(0,0); } //============================================================== //函数名:LCD_P6x8Str(unsigned char x,unsigned char y,unsigned char *p) //功能描述:写入一组标准ASCII字符串 //参数:显示的位置(x,y),y为页范围0~7,要显示的字符串 //返回:无 //============================================================== void LCD_P6x8Str(unsigned char x,unsigned char y,unsigned char ch[]) { unsigned char c=0,i=0,j=0; while (ch[j]!='
