今天是:2024年09月30日(星期一)
2019年09月30日 | stm32 can中断通信
2019-09-30 来源:eefocus
1、初始化can时钟
void canRCCInit()
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
2、配置can的GPIO引脚
void canGPIOConfigure()
GPIO_PinRemapConfig(GPIO_Remap1_CAN1, ENABLE);
GPIO_InitTypeDef gpioInit;
gpioInit.GPIO_Pin = GPIO_Pin_8;
gpioInit.GPIO_Mode = GPIO_Mode_IPU;
gpioInit.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOB, &gpioInit);
gpioInit.GPIO_Pin = GPIO_Pin_9;
gpioInit.GPIO_Mode = GPIO_Mode_AF_PP;
3、配置并使能can
void canConfigure()
CAN_InitTypeDef can_init;
CAN_DeInit(CAN1);
CAN_StructInit(&can_init);
//关闭时间触发模式
can_init.CAN_TTCM = DISABLE;
//关闭自动离线管理
can_init.CAN_ABOM = DISABLE;
//关闭自动唤醒模式
can_init.CAN_AWUM = DISABLE;
//禁止报文自动重发
can_init.CAN_NART = DISABLE;
//FIFO 溢出时报文覆盖原文件
can_init.CAN_RFLM = DISABLE;
//报文发送优先级取决于ID号
can_init.CAN_TXFP = DISABLE;
//回环模式
can_init.CAN_Mode = CAN_Mode_LoopBack;
//配置时钟频率
can_init.CAN_SJW = CAN_SJW_1tq;
can_init.CAN_BS1 = CAN_BS1_3tq;
can_init.CAN_BS2 = CAN_BS2_2tq;
can_init.CAN_Prescaler = 48;
CAN_Init(CAN1, &can_init);
CAN_FilterInitTypeDef can_filter;
//屏蔽滤波
can_filter.CAN_FilterNumber = 0;
//屏蔽模式
can_filter.CAN_FilterMode = CAN_FilterMode_IdMask;
//32位寄存器
can_filter.CAN_FilterScale = CAN_FilterScale_32bit;
//高16位
can_filter.CAN_FilterIdHigh = 0x0000;
//低16位
can_filter.CAN_FilterIdLow = 0;
//屏蔽位高16位
can_filter.CAN_FilterMaskIdHigh = 0;
//屏蔽位低16位
can_filter.CAN_FilterMaskIdLow = 0;
//过滤器0关联到FIFO0
can_filter.CAN_FilterFIFOAssignment = CAN_FilterFIFO0;
//使能过滤器
can_filter.CAN_FilterActivation = ENABLE;
//初始化过滤器
CAN_FilterInit(&can_filter);
//使能接收中断
CAN_ITConfig(CAN1, CAN_IT_FMP0, ENABLE);
4、配置中断源
void canNvicConfigure()
NVIC_InitTypeDef nvic_init;
nvic_init.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
nvic_init.NVIC_IRQChannelPreemptionPriority = 0;
nvic_init.NVIC_IRQChannelSubPriority = 0;
nvic_init.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&nvic_init);
nvic_init.NVIC_IRQChannel = USB_HP_CAN1_TX_IRQn;
nvic_init.NVIC_IRQChannelSubPriority = 1;
5、实现中断处理函数
void USB_LP_CAN1_RX0_IRQHandler(void)
CanRxMsg rx;
CAN_Receive(CAN1, CAN_FIFO0, &rx);
for(int i = 0; i < rx.DLC; i++){
printf("recv data: %crn",rx.Data[i]);
void USB_HP_CAN1_TX_IRQHandler(void)
if(count < len){
txMessage.Data[0] = txBuf[count++];
CAN_Transmit(CAN1, &txMessage);
else {
CAN_ITConfig(CAN1, CAN_IT_TME, DISABLE);
6、实现发送函数
void canWrite(const char *p)
strcpy(txBuf, p);
len = strlen(p);
count = 0;
txMessage.StdId = 0xFE00 >> 5;
txMessage.ExtId = 0;
txMessage.IDE = CAN_ID_STD;
txMessage.RTR = CAN_RTR_DATA;
txMessage.DLC = 1; //此处最多可传输8个字节
CAN_ITConfig(CAN1, CAN_IT_TME, ENABLE);
7、总结:在写can总线协议时,需要自己仔细阅读stm32的官方手册,can总线有多种模式及标识符列表模式、标识符屏蔽模式等,需要自己仔细琢磨。
上一篇: stm32内部的CAN总线
遥控器用的红外LED,因为红外LED发出的光不完全是红外光,也包含部分的可见光(红色)成分,所以肉眼能看到少许光。遥控器使用的LED,一般发射角度是30度左右,用户即使没有完全对准目标,也能有效操作。在没有外界红外线干扰的时候,遥控距离可以 ...… 查看全部问答> |
最近我刚买一块2440的开发板,跑wince5.0,按照PC机设置wince,连上网线后不能上网!不知道是什么原因。PC机可以通过网线与ARM板通信。ftp和fttp都正常。那我应该怎么样设置或还需要哪些工作才能实现我这块开发板与网络的连接呢。… 查看全部问答> |
在wince 6.0中我有一个客户端程序,先后两次调用InitializeSecurityContext用于和google服务器端进行安全认证,第一次调用返回的是SEC_I_CONTINUE_NEEDED,第二次返回的是SEC_E_WRONG_PRINCIPAL,请问怎么解决啊?是不是和证书有关系?相同程序在wi ...… 查看全部问答> |
【招聘】汇编语言入门图书兼职作者 本公司是业内知名IT图书策划出版公司,正在运作一本汇编语言入门相关图书。想征求关于汇编语言的设计高手参与编写。有意者请将个人介绍和联系方式(QQ或MSN)发到本人邮箱macuilhy@sina.cn。… 查看全部问答> |
u8 sd_raw_get_info(struct sd_raw_info* info)中struct怎么理解 u8 sd_raw_get_info(struct sd_raw_info* info) { …… } 这个子程序怎么用啊,像u8 mmcWrite(u32 sector, u8* buffer)这种,我在主程序中只要定义unsigned char SD_Write1[]={\"0123456789\"}; 就可以用了mmcWrite(SD_Write1); 但是这个定义 ...… 查看全部问答> |
欢迎来到电源设计小贴士!随着现在对更高效、更低成本电源解决方案需求的强调,我们创建了该专栏,就各种电源管理课题提出一些对您有帮助的小技巧。该专栏面向各级设计工程师。无论您是从事电源业务多年还是刚刚步入电源领域,您都可以在这里找到一 ...… 查看全部问答> |
