今天是:2024年10月18日(星期五)
正在发生
2019年10月18日 | AVR M16单片机NRF2401无线通信开发包
2019-10-18 来源:51hei
单片机源程序如下:
//ICC-AVR application builder :
// Target : M16
// Crystal: 8.0000Mhz
#include
#include
//--------------------------------NRF24L01接口定义--------------------------------
//#define NRF24L01_MISO          PB4                //输入0
#define   Hign_24L01_MISO    PORTB |= (1 << PB4)
#define   Low_24L01_MISO     PORTB &= ~(1 << PB4)
#define   Read_24L01_MISO    PINB & (1 << PB4)
//#define NRF24L01_MOSI         PB2              //输出1
#define   Hign_24L01_MOSI    PORTB |= (1 << PB2)
#define   Low_24L01_MOSI     PORTB &= ~(1 << PB2)
#define   Read_24L01_MOSI    PINB & (1 << PB2)
//#define NRF24L01_CSN                     PB7              //输出1
#define   Low_24L01_CSN     PORTB &= ~(1 << PB7)
#define   Hign_24L01_CSN           PORTB |= (1 << PB7)
//#define NRF24L01_SCK                  PB6             //输出1
#define   Hign_24L01_SCK    PORTB |= (1 << PB6)
#define   Low_24L01_SCK     PORTB &= ~(1 << PB6)
#define   Read_24L01_SCK    PINB & (1 << PB6);
//#define NRF24L01_CE                PB5              //输出1
#define   Hign_24L01_CE    PORTB |= (1 << PB5)
#define   Low_24L01_CE     PORTB &= ~(1 << PB5)
#define   Read_24L01_CE    PINB & (1 << PB5)
//#define  NRF24L01_IRQ     PB3               //输入
#define   Hign_NRF24L01_IRQ    PORTB |= (1 << PB3)
#define   Low_NRF24L01_IRQ     PORTB &= ~(1 << PB3)
#define   Read_NRF24L01_IRQ    PINB & (1 << PB3)
//------------------------------数码管位选--------------------------------------
//#define Display1   PA1                      //输出1
#define   Hign_Display1     PORTA |= (1 << PA1);
#define   Low_Display1            PORTA &= ~(1 << PA1);
//#define Display2      PA2                  //输出1
#define   Hign_Display2     PORTA |= (1 << PA2);
#define   Low_Display2            PORTA &= ~(1 << PA2);
//#define Display3     PA3                  //输出1
#define   Hign_Display3     PORTA |= (1 << PA3);
#define   Low_Display3             PORTA &= ~(1 << PA3);
//#define Display4      PA4                 //输出1
#define   Hign_Display4     PORTA |= (1 << PA4);
#define   Low_Display4             PORTA &= ~(1 << PA4);
//-------------------------------BELL蜂明器-------------------------------------
#define   Hign_BELL                 PORTD |= (1 << PD5)
#define   Low_BELL                 PORTD &= ~(1 << PD5)
//-------------------------------JDQ继电器--------------------------------------
#define   Hign_JDQ                  PORTD |= (1 << PD7)
#define   Low_JDQ                    PORTD &= ~(1 << PD7)
//***********************************数码管0-9编码*******************************************
char seg[10]={0xC0,0xCF,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};         //0~~9段码
char TxBuf[32]=
0x01,0x02,0x03,0x4,0x05,0x06,0x07,0x08,
0x09,0x10,0x11,0x12,0x13,0x14,0x15,0x16,
0x17,0x18,0x19,0x20,0x21,0x22,0x23,0x24,
0x25,0x26,0x27,0x28,0x29,0x30,0x31,0x32,
char sta,tf,KEY0;
//*********************************************NRF24L01*************************************
#define TX_ADR_WIDTH    5           // 5 uints TX address width
#define RX_ADR_WIDTH    5           // 5 uints RX address width
#define TX_PLOAD_WIDTH  32          // 20 uints TX payload
#define RX_PLOAD_WIDTH  32          // 20 uints TX payload
char  TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01};        //本地地址
char  RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01};        //接收地址
//***************************************NRF24L01寄存器指令*******************************************************
#define READ_REG        0x00          // 读寄存器指令
#define WRITE_REG       0x20         // 写寄存器指令
#define RD_RX_PLOAD     0x61          // 读取接收数据指令
#define WR_TX_PLOAD     0xA0          // 写待发数据指令
#define FLUSH_TX        0xE1         // 冲洗发送 FIFO指令
#define FLUSH_RX        0xE2          // 冲洗接收 FIFO指令
#define REUSE_TX_PL     0xE3          // 定义重复装载数据指令
#define NOP1             0xFF          // 保留
//*************************************SPI(nRF24L01)寄存器地址****************************************************
#define CONFIG          0x00  // 配置收发状态,CRC校验模式以及收发状态响应方式
#define EN_AA           0x01  // 自动应答功能设置
#define EN_RXADDR       0x02  // 可用信道设置
#define SETUP_AW        0x03  // 收发地址宽度设置
#define SETUP_RETR      0x04  // 自动重发功能设置
#define RF_CH           0x05  // 工作频率设置
#define RF_SETUP        0x06  // 发射速率、功耗功能设置
#define STATUS          0x07  // 状态寄存器
#define OBSERVE_TX      0x08  // 发送监测功能
#define CD              0x09  // 地址检测
#define RX_ADDR_P0      0x0A  // 频道0接收数据地址
#define RX_ADDR_P1      0x0B  // 频道1接收数据地址
#define RX_ADDR_P2      0x0C  // 频道2接收数据地址
#define RX_ADDR_P3      0x0D  // 频道3接收数据地址
#define RX_ADDR_P4      0x0E  // 频道4接收数据地址
#define RX_ADDR_P5      0x0F  // 频道5接收数据地址
#define TX_ADDR         0x10  // 发送地址寄存器
#define RX_PW_P0        0x11  // 接收频道0接收数据长度
#define RX_PW_P1        0x12  // 接收频道0接收数据长度
#define RX_PW_P2        0x13  // 接收频道0接收数据长度
#define RX_PW_P3        0x14  // 接收频道0接收数据长度
#define RX_PW_P4        0x15  // 接收频道0接收数据长度
#define RX_PW_P5        0x16  // 接收频道0接收数据长度
#define FIFO_STATUS     0x17  // FIFO栈入栈出状态寄存器设置
void Delay(int s);
void inerDelay_us(char n);
void init_NRF24L01(void);
char SPI_RW(char data);
char SPI_Read(char reg);
char SPI_RW_Reg(char reg, char value);
char SPI_Read_Buf(char reg, char *pBuf, char uchars);
char SPI_Write_Buf(char reg, char *pBuf, char uchars);
void SetRX_Mode(void);
char nRF24L01_RxPacket(char* rx_buf);
void nRF24L01_TxPacket(char * tx_buf);
//*****************************************长延时*****************************************
void Delay(int s)
        unsigned int i;
        for(i=0; i        for(i=0; i}
/*延时函数
        for(;n>0;n--);
//------------------------------串口初始化--------------------------------------
void uart0_init(void)
CLI(); //关闭中断
UCSRB =0x98;    //disable while setting baud rate
UCSRA =0x20;
UCSRC = 0x86;
UBRRL =51; //set baud rate lo
TIMSK = 0x00; //timer interrupt sources
SEI(); //开中断
//----------------------------接收中断处理函数----------------------------------
#pragma interrupt_handler uart0_rx_isr:12
void uart0_rx_isr(void)
  KEY0=UDR;
  UDR=KEY0;
Applied Engineering Products (AEP)公司的发展小趣事
在环保意识日益增强的今天,AEP公司积极响应国家号召,致力于绿色环保和可持续发展。公司投入大量资金研发环保型电子元器件,减少生产过程中的废弃物排放。同时,公司还建立了完善的废旧产品回收机制,对废旧产品进行环保处理,实现资源的循环利用。这一举措不仅提升了AEP公司的社会形象,也为公司的可持续发展注入了新的动力。
CET Technology公司的发展小趣事
随着数字化转型的深入,CET Technology紧跟时代步伐,成功研发出数字化安全生产管控平台。该平台通过整合配电、给水、电梯、消防、空调、安防等各系统,建立统一的安全物联感知平台,实现对安全生产各要素的在线监测。利用3D可视化技术,关键信息得以直观呈现,为企业的安全生产管理提供了有力支持。此外,CET还引入了AI技术,对安全风险进行精准预测,助力企业防范和应对各类安全事件。
Heatron LED Integration公司的发展小趣事
Heatron LED Integration始终将客户需求放在首位,提供全方位的服务支持。公司建立了完善的售前咨询、售中指导和售后服务体系,确保客户在使用过程中能够得到及时、专业的帮助。此外,公司还根据客户需求提供定制化解决方案,满足不同场景下的照明需求。这种客户至上的服务理念,赢得了广大客户的信赖和好评。
Ememory Technology Inc公司的发展小趣事
除了自主研发外,eMemory还积极寻求与外部合作伙伴的联合研发。在2016年,eMemory与马来西亚的半导体晶圆代工厂Silterra联合宣布,基于Silterra 0.18微米CMOS制程技术的一次性可编程(OTP)存储器已经通过了验证。这一合作不仅证明了eMemory技术的先进性和可靠性,还为双方带来了新的市场机遇。
Einfochips公司的发展小趣事
为了满足不断增长的ASIC和嵌入式服务需求,Einfochips公司决定在印度孟买附近的Pune设立一家新的设计中心。该设计中心将为亚洲和北美客户提供服务,主要涉及存储网络、无线通信和消费多媒体等领域。这一举措不仅加强了Einfochips在亚洲和北美市场的地位,还为其未来的发展奠定了坚实基础。
长运通(CYT)公司的发展小趣事
深圳市长运通光电技术有限公司(简称长运通或CYT)成立于2003年11月,总部设在深圳这座充满创新活力的城市。公司从最初只有几名员工的初创团队,逐步发展成为在电源管理IC和LED光源领域具有影响力的企业。长运通在初创阶段就明确了自身的市场定位,致力于为客户提供高品质的电源解决方案和LED照明产品。通过不断努力,公司逐渐在市场上建立了良好的口碑。
新建楼宇防雷电设计
根据5月16日颁布实施的《厦门市建设项目防雷工程设计审核规定(试行)》(以下简称《规定》(试行)),今后所有新建、改建、扩建建设项目在设计审核和竣工验收时,建设方都必须向审核、验收部门提供单独列出的防雷设计专篇。昨日上午,市气象局召 ...…
成批量的买件,你习惯去哪里
设计好一套电路板,需要购买器件,大家一般都去哪里买啊,网上还是当地电子市场。派睿,艾睿还是其他的,大家说说啊…
nrf905在凌阳61上的问题!!大家帮帮忙!急啊
#include \"SPCE061A.H\" #include \"math.h\" #include \"bit.h\"   //位操作            1.8.4版 #define  uchar  unsigned char #define LED     & ...…
SMbus 总线与 I2C总线有什么区别?
同一个设备EEPROM,接在I2C总线上,和连在SM bus上,写驱动时有什么差别吗? 以前写过I2C主控制器的驱动, 现在要写一个SM bus控制器的驱动,二者有什么差别啊? …
MMU地址映射问题
各位大侠好! 小弟最近在调试wince5.0的bootloader时遇到了问题,是这样的:cpu是ATMEL9261(926ej-s),在startup.s中没有启用MMU之前程序运行很好!但是当执行完mcr      p15, 0, r1, c1, c0, 0 后,灯也没亮,程序就飞了,请大家赐教 ...…
晶振的问题
我用了一个有源的晶阵 是5v电压供电的那一种 输出是ttl电平 可是我下面接了一个非门 可是没有输出啊 是不是驱动能力不构 如何提高呢 感谢啊…
关于CCS的限制问题
我的仿真器附带光盘上有一个CCSv4,上面说是32K限制版,这个32K指的是存储器的大小吗?假如我想使用TMS320F28035中的128K的Flash,能用吗?…
单电源边双电源?
单电源变双电源的原理是什么?能给个电路吗 6v电池到正负5v的? 谢谢…
用51单片机进行控制射进简易计算器
通过Proteus与keil C的方针联调设计一个简易计算器,计算器可实现6位整数的四则运算,由LED数码显示运算数据以及结果,其中出发运算无需实现小数部分。   QQ 261246707欢迎交流 现在编程方面有一些问题 希望大家给点帮助…
日企PCB专业LAYOUT工作经验6年,求兼职
本人日企PCB专业LAYOUT工作经验6年,有2-10层基板级设计经验,有丰富EMC、SI,EMI,ESD,PI设计经验,现求兼职PCB LAYOUT,有意请:ximigac@163.com…
