今天是:2024年10月30日(星期三)
正在发生
2019年10月30日 | 51单片机阳历转农历(仅仅是阳历转阴历例程)
2019-10-30 来源:51hei
之前要做一个万年历,从论坛上辗转多处,最终发现以下这个阳历转换阴历的程序比较简单,数据带入可以直接使用,不过测试发现转换有问题,后面进行仿真调试找到问题所在,从而进而修改。不知道是我复制出错,还是自己不经意间修改才导致问题出现,已经修复,需要阳历转阴历的可以拿去。找不到具体来源,因此无法标志引用链接地址,如有侵权,联系删除。
问题所在:在SPDATE GetSpringDay(uchar GreYear,uchar GreMon,uchar GreDay)函数里面的参数定义,把Offset1定义为uchar类型,后面计算时Offset1数值溢出,将uchar改为uint后,数据不在溢出,进行上机测试,转换成功。
//公曆轉農曆(1901-2100)
//亦木明 2008.1.11
//2018.12.30清枫城主测试,发现存在问题,通过仿真一步步走找出问题所在,并作出修正
//原文在哪忘了,只知道作者有“亦木明”的标注,如有侵权联系删除
#include "12c5a60s2.h"//可修改为51的头文件
#define TRUE  1
//公历年对应的农历数据,每年三字节,
//格式第一字节BIT7-4 位表示闰月月份,值为0 为无闰月,BIT3-0 对应农历第1-4 月的大小
//第二字节BIT7-0 对应农历第5-12 月大小,第三字节BIT7 表示农历第13 个月大小
//月份对应的位为1 表示本农历月大(30 天),为0 表示小(29 天).
//第三字节BIT6-5 表示春节的公历月份,BIT4-0 表示春节的公历日期
//每年的數據對應在數組中的位置庫 (200-(2100-year)-1)*3+Offset1
//0x09,0x2d,0x47, //2008  0x47 01000111
//0x4d,0x4A,0xB8, //2001
typedef struct spdate
        char         cYear;
        char        cMon;
        char        cDay;
}SPDATE;
uchar code Data[]={
0x04,0xAe,0x53, //1901  0        (200-(2100-1901)-1)*3=0
0x0A,0x57,0x48, //1902        3   (200-(2100-1902)-1)*3=3
0x55,0x26,0xBd, //1903        6        (200-(2100-1903)-1)*3=3
0x0d,0x26,0x50, //1904        9   (200-(2100-year)-1)*3
0x0d,0x95,0x44, //1905        12
0x46,0xAA,0xB9, //1906        15
0x05,0x6A,0x4d, //1907
0x09,0xAd,0x42, //1908
0x24,0xAe,0xB6, //1909
0x04,0xAe,0x4A, //1910
0x6A,0x4d,0xBe, //1911
0x0A,0x4d,0x52, //1912
0x0d,0x25,0x46, //1913
0x5d,0x52,0xBA, //1914
0x0B,0x54,0x4e, //1915
0x0d,0x6A,0x43, //1916
0x29,0x6d,0x37, //1917
0x09,0x5B,0x4B, //1918
0x74,0x9B,0xC1, //1919
0x04,0x97,0x54, //1920
0x0A,0x4B,0x48, //1921
0x5B,0x25,0xBC, //1922
0x06,0xA5,0x50, //1923
0x06,0xd4,0x45, //1924
0x4A,0xdA,0xB8, //1925
0x02,0xB6,0x4d, //1926
0x09,0x57,0x42, //1927
0x24,0x97,0xB7, //1928
0x04,0x97,0x4A, //1929
0x66,0x4B,0x3e, //1930
0x0d,0x4A,0x51, //1931
0x0e,0xA5,0x46, //1932
0x56,0xd4,0xBA, //1933
0x05,0xAd,0x4e, //1934
0x02,0xB6,0x44, //1935
0x39,0x37,0x38, //1936
0x09,0x2e,0x4B, //1937
0x7C,0x96,0xBf, //1938
0x0C,0x95,0x53, //1939
0x0d,0x4A,0x48, //1940
0x6d,0xA5,0x3B, //1941
0x0B,0x55,0x4f, //1942
0x05,0x6A,0x45, //1943
0x4A,0xAd,0xB9, //1944
0x02,0x5d,0x4d, //1945
0x09,0x2d,0x42, //1946
0x2C,0x95,0xB6, //1947
0x0A,0x95,0x4A, //1948
0x7B,0x4A,0xBd, //1949
0x06,0xCA,0x51, //1950
0x0B,0x55,0x46, //1951
0x55,0x5A,0xBB, //1952
0x04,0xdA,0x4e, //1953
0x0A,0x5B,0x43, //1954
0x35,0x2B,0xB8, //1955
0x05,0x2B,0x4C, //1956
0x8A,0x95,0x3f, //1957
0x0e,0x95,0x52, //1958
0x06,0xAA,0x48, //1959
0x7A,0xd5,0x3C, //1960
0x0A,0xB5,0x4f, //1961
0x04,0xB6,0x45, //1962
0x4A,0x57,0x39, //1963
0x0A,0x57,0x4d, //1964
0x05,0x26,0x42, //1965
0x3e,0x93,0x35, //1966
0x0d,0x95,0x49, //1967
0x75,0xAA,0xBe, //1968
0x05,0x6A,0x51, //1969
0x09,0x6d,0x46, //1970
0x54,0xAe,0xBB, //1971
0x04,0xAd,0x4f, //1972
0x0A,0x4d,0x43, //1973
0x4d,0x26,0xB7, //1974
0x0d,0x25,0x4B, //1975
0x8d,0x52,0xBf, //1976
0x0B,0x54,0x52, //1977
0x0B,0x6A,0x47, //1978
0x69,0x6d,0x3C, //1979
0x09,0x5B,0x50, //1980
0x04,0x9B,0x45, //1981
0x4A,0x4B,0xB9, //1982
0x0A,0x4B,0x4d, //1983
0xAB,0x25,0xC2, //1984
0x06,0xA5,0x54, //1985
0x06,0xd4,0x49, //1986
0x6A,0xdA,0x3d, //1987
0x0A,0xB6,0x51, //1988
0x09,0x37,0x46, //1989
0x54,0x97,0xBB, //1990
0x04,0x97,0x4f, //1991
0x06,0x4B,0x44, //1992
0x36,0xA5,0x37, //1993
0x0e,0xA5,0x4A, //1994
0x86,0xB2,0xBf, //1995
0x05,0xAC,0x53, //1996
0x0A,0xB6,0x47, //1997
0x59,0x36,0xBC, //1998
0x09,0x2e,0x50, //1999
0x0C,0x96,0x45, //2000
0x0d,0x4A,0x4C, //2002
0x0d,0xA5,0x41, //2003
0x25,0xAA,0xB6, //2004
0x05,0x6A,0x49, //2005
0x7A,0xAd,0xBd, //2006
0x02,0x5d,0x52, //2007
0x5C,0x95,0xBA, //2009
0x0A,0x95,0x4e, //2010
0x0B,0x4A,0x43, //2011
0x4B,0x55,0x37, //2012
0x0A,0xd5,0x4A, //2013
0x95,0x5A,0xBf, //2014
0x04,0xBA,0x53, //2015
0x0A,0x5B,0x48, //2016
0x65,0x2B,0xBC, //2017
0x05,0x2B,0x50, //2018
0x0A,0x93,0x45, //2019
0x47,0x4A,0xB9, //2020
0x06,0xAA,0x4C, //2021
0x0A,0xd5,0x41, //2022
0x24,0xdA,0xB6, //2023
0x04,0xB6,0x4A, //2024
0x69,0x57,0x3d, //2025
0x0A,0x4e,0x51, //2026
0x0d,0x26,0x46, //2027
0x5e,0x93,0x3A, //2028
0x0d,0x53,0x4d, //2029
0x05,0xAA,0x43, //2030
0x36,0xB5,0x37, //2031
0x09,0x6d,0x4B, //2032
0xB4,0xAe,0xBf, //2033
0x04,0xAd,0x53, //2034
0x0A,0x4d,0x48, //2035
0x6d,0x25,0xBC, //2036
0x0d,0x25,0x4f, //2037
0x0d,0x52,0x44, //2038
0x5d,0xAA,0x38, //2039
0x0B,0x5A,0x4C, //2040
0x05,0x6d,0x41, //2041
0x24,0xAd,0xB6, //2042
0x04,0x9B,0x4A, //2043
0x7A,0x4B,0xBe, //2044
0x0A,0x4B,0x51, //2045
0x0A,0xA5,0x46, //2046
0x5B,0x52,0xBA, //2047
0x06,0xd2,0x4e, //2048
0x0A,0xdA,0x42, //2049
0x35,0x5B,0x37, //2050
0x09,0x37,0x4B, //2051
0x84,0x97,0xC1, //2052
0x04,0x97,0x53, //2053
0x06,0x4B,0x48, //2054
0x66,0xA5,0x3C, //2055
0x0e,0xA5,0x4f, //2056
0x06,0xB2,0x44, //2057
0x4A,0xB6,0x38, //2058
0x0A,0xAe,0x4C, //2059
0x09,0x2e,0x42, //2060
0x3C,0x97,0x35, //2061
0x0C,0x96,0x49, //2062
0x7d,0x4A,0xBd, //2063
0x0d,0x4A,0x51, //2064
0x0d,0xA5,0x45, //2065
0x55,0xAA,0xBA, //2066
0x05,0x6A,0x4e, //2067
0x0A,0x6d,0x43, //2068
0x45,0x2e,0xB7, //2069
0x05,0x2d,0x4B, //2070
0x8A,0x95,0xBf, //2071
0x0A,0x95,0x53, //2072
0x0B,0x4A,0x47, //2073
0x6B,0x55,0x3B, //2074
0x0A,0xd5,0x4f, //2075
0x05,0x5A,0x45, //2076
0x4A,0x5d,0x38, //2077
0x0A,0x5B,0x4C, //2078
0x05,0x2B,0x42, //2079
0x3A,0x93,0xB6, //2080
0x06,0x93,0x49, //2081
0x77,0x29,0xBd, //2082
0x06,0xAA,0x51, //2083
0x0A,0xd5,0x46, //2084
0x54,0xdA,0xBA, //2085
0x04,0xB6,0x4e, //2086
0x0A,0x57,0x43, //2087
0x45,0x27,0x38, //2088
0x0d,0x26,0x4A, //2089
0x8e,0x93,0x3e, //2090
0x0d,0x52,0x52, //2091
0x0d,0xAA,0x47, //2092
0x66,0xB5,0x3B, //2093
0x05,0x6d,0x4f, //2094
0x04,0xAe,0x45, //2095
0x4A,0x4e,0xB9, //2096
0x0A,0x4d,0x4C, //2097
0x0d,0x15,0x41, //2098
0x2d,0x92,0xB5, //2099
0x0d,0x53,0x49, //2100
uchar code Mon1[2][13]={0,31,28,31,30,31,30,31,31,30,31,30,31,
                                  0,31,29,31,30,31,30,31,31,30,31,30,31};
SPDATE Spdate;
//獲得當年春節的公曆日期
        int day;
    uchar i,Flag,F;
        uint Offset1;//出现问题在这里,原本定义为uchar类型,下面计算时超出范围导致错误,进行修改为uint类型后,验证正常
        unsigned char L=0x01,Flag1=1;
        unsigned int  Temp16,L1=0x0800;
        Spdate.cYear=GreYear ;
        Spdate.cMon=(Data[(200-(100-GreYear)-1)*3+2]&0x60)>>5; //计算春节公历月份
        Spdate.cDay=(Data[(200-(100-GreYear)-1)*3+2])&0x1f;    //计算春节公历日期
        //判断平年,闰年
        if( (!(GreYear%4) && (GreYear%100)) || !(GreYear%400) ) Flag=1;
        else Flag=0;
        if(Spdate.cMon>GreMon)        //春节离公历日期的天数
           day=Mon1[Flag][GreMon]-GreDay;
           for(i=GreMon+1;i<=Spdate.cMon-1;i++)
                        day+=Mon1[Flag][i];
           day+=Spdate.cDay;
           F=1;
        else if(Spdate.cMon        {
                day=Mon1[Flag][Spdate.cMon]-Spdate.cDay;
                for(i=Spdate.cMon+1;i<=GreMon-1;i++)
                        day+=Mon1[Flag][i];
                day+=GreDay;                                //          000000000000000000000000000000000000000000000000000000000000000000
                F=0;
        else
                if(Spdate.cDay>GreDay)
                        day=Spdate.cDay-GreDay;
                        F=1;
                else if(Spdate.cDay                {
                        day=GreDay-Spdate.cDay;
                        F=0;
                else day=0;
        Spdate.cYear=Spdate.cYear;
        Spdate.cMon=1;
        Spdate.cDay=1;
        if(!day) return Spdate ;
        if(F)    //春节在公历日期后
                Spdate.cYear--;
                Spdate.cMon=12;
                //这边Offset1计算会出现超范围,因此把uchar类型改为uint后正常
Hong Kong X'Tals Ltd公司的发展小趣事
在必要时,可以加入保护电路(如过流保护、过压保护等),以提高电路的可靠性和安全性。
Anderson Electronics Inc公司的发展小趣事
面对电子行业的快速变革和市场竞争的加剧,Anderson Electronics Inc公司积极进行产业升级和智能制造的转型。公司引进了先进的生产设备和技术,实现了生产过程的自动化和智能化。同时,公司还加大了对研发人员的培养和引进力度,建立了一支高素质的研发团队。通过产业升级和智能制造的转型,公司成功提升了生产效率和产品质量,进一步巩固了市场地位。
芯邦(Chipsbank)公司的发展小趣事
在全球半导体市场竞争日益激烈的背景下,芯邦科技面临着来自国际巨头的挑战。然而,公司凭借在半导体设计领域的深厚积累和不断创新的精神,逐步形成了自己的核心竞争力。同时,芯邦也积极寻求与国际合作伙伴的合作机会,共同推动半导体产业的发展。
以上五个故事简要概述了芯邦科技在电子行业中的发展起来的关键节点和里程碑事件。这些故事不仅展现了芯邦科技在技术创新、产品线拓展、资本运作、市场表现和国际竞争等方面的努力和成就,也预示着公司未来发展的广阔前景和无限可能。
汇科公司的发展小趣事
作为一家有社会责任感的企业,汇科公司始终关注环境保护和可持续发展。公司积极推广绿色生产技术和资源循环利用方案,减少生产过程中的能源消耗和废弃物排放。同时,汇科公司还积极参与社会公益活动,为社区和环境贡献自己的力量。这些举措不仅体现了公司的社会责任担当,也为其赢得了更多客户和合作伙伴的信任和支持。
Elpaq公司的发展小趣事
Alcatel-Lucent公司的发展小趣事
变压器的输出电压比需要的偏高,请教!
大虾们,我有一个输入220V,输出53V的变压器, 但是,我只需要上限不超过28~36伏的可调直流电源 下限当然是。。。。取可调范围大的 请各位多多指教…
M/B、N/B
哪位大虾能为我解答一下什么是M/B、N/B 设计?谢谢了…
我学习单片机时写的一些简单的程序
这是我刚学C语言时写的一些程序,比较简单,希望对刚接触单片机的同胞们有所帮助吧 我使用的主控是89c51,晶振频率是11.0592m的 [ 本帖最后由 open82977352 于 2010-2-3 14:44 编辑 ]…
问个FatFS的问题
读文件, 循环第一次读取 正常, 第二次,就退出循环了,我的文件大, 这个文件 就只读了一次 512个数组, 我看FatFS copy文件的例子,人家是一直读,知道读没了才退出的, 读第二次 那个提示是说  目录对象是无效的。      ...…
新成立Linux开发-4号群68906481,欢迎做嵌入式Linux方面的相关人员加入。共同交流与提高
新成立Linux开发-4号群68906481,欢迎做嵌入式Linux方面的相关人员加入。共同交流与提高…
Φ5光敏二极管的Φ5是什么意思?
Φ5光敏二极管的Φ5是什么意思?…
Intel Xscale WinCE 5.0操作系统基础及实验教程
我的资源下载分用完了,需要10分下载一个文件,请大家帮忙。 上传了“Intel Xscale WinCE 5.0操作系统基础及实验教程”基于PXA270的实验配套教程包括基础篇、实战篇、实验篇。 下载地址:http://download.eeworld.net/source/580934 好心的人帮 ...…
[求助]谁有Loadauth.lib文件以及相关的.h文件?
能上传上给我么?急需,收到后再追加分。…
交通灯程序加仿真图!
小弟刚学51不久!写的交通灯程序!好的话顶下!不好的话鼓励下哈!继续努力!…
2010年12月9日 TI有研讨会哦
hank you for registering for Texas Instruments’ eTech Day.Get ready for a day packed with problem solving and interactivity!Presented by: Texas InstrumentsLive show date: December 9, 2010Live show hours: 10:00 a.m. CT – 4:00 p.m ...…
