今天是:2024年11月06日(星期三)
2019年11月06日 | 基于PIC单片机的24c02调试完成
2019-11-06 来源:51hei
适用于PIC系列,汇编、内存紧张的朋友用
SDA EQU 5 ;'OC'
SCL EQU 4
ACKF EQU 0
EE_VCC EQU 2
EE_WP EQU 1 ;'H' DISABLE 'L'ENABLE
DO EQU 7
TX_BUF EQU 0X30
BUF_IN EQU 0X31
EEPROM EQU 0X32
BIT_COUNT EQU 0X33
byte_count equ 0x34
ACK EQU 0X35
rom_buf1 equ 0x36
rom_buf2 equ 0x37
rom_buf3 equ 0x38
rom_buf4 equ 0x39
rom_buf5 equ 0x3a
;**********************启动信号***************************************
BSTART:
BSF PORTA,SDA
NOP
NOP
NOP
NOP
NOP
NOP
BSF PORTA,SCL
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
BCF PORTA,SDA
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
BCF PORTA,SCL
NOP
NOP
RETLW 0
;***********************停止信号********************************
BSTOP:
BCF PORTA,SDA
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
BSF PORTA,SCL
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
BSF PORTA,SDA
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
BCF PORTA,SCL
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
RETLW 0
;**********************发送N_ACK**************************
SEND_ACK:
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
BCF PORTA,SDA
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
BSF PORTA,SCL
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
BCF PORTA,SCL
NOP
NOP
NOP
NOP
NOP
NOP
RETLW 0
READ_ACK:
BSF TRISA,SDA ;SET SDA IN
CLRF ACK
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
BSF PORTA,SCL
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
BTFSS PORTA,SDA
INCF ACK,F
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
BCF PORTA,SCL
BCF TRISA,SDA ;SET SDA OUT
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
RETLW ACK;0
;**********************发送一个字节**************************
BYTEOUT:
MOVLW D'8'
MOVWF BIT_COUNT
TXLP
nop
nop
CALL BITOUT
RLF TX_BUF,F
DECFSZ BIT_COUNT,F
GOTO TXLP
CALL READ_ACK
;CALL BITIN ;ACK
;BTFSC EEPROM,DI
; BSF PORTC,ACKF
RETLW 0
;************************接收一个字节*****************************
BYTEIN:
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
CLRF BUF_IN
MOVLW D'8'
关于直插LED与SMDLED和大功率LED的投资分析 因近段时间有很多朋友问关于投资以上三类型的LED,个人仅发表一些看法: 1.直插LED投资发展最快的几年是在02年至05年(相信这时候开厂的已经赚的盆满钵满了);凡有钱的都做直插的LED了,并且现在有很 ...… 查看全部问答> |
windowsXP DDK 如何连接一个中断?(KInterrupt?) 我只找到了KInterrupt这个类:但是问题出现如下 KInterrupt::Initialize 两种 格式 FORM 2: (WDM) VOID Initialize( KIRQL irql, ULONG vector, KINTERRUPT_MODE Mode, ...… 查看全部问答> |
marvell的cpu智能机板子,要做一个自己的下载工具 email:killbug2004@gmail.com 另外麻烦讲一下基于usb下载的流程 中间有个VerifyImage不懂,文件下载id设置也不太清楚 谢谢达人… 查看全部问答> |
1。在仿真中,有些非端口信号,例如SIGNAL ,VARIABLE,在node finder的 all list中 还是没有,没法建立它们的仿真波形,该怎么办,而且有的SIGNAL可以看到,有的看不到,这是为什么?(QUARTUSII) 2。在PROCESS中,这个PROCESS是 TYPE state IS ...… 查看全部问答> |
我正要做一个项目,输入信号是±4V,显示范围是0---99999,要求输入信号变化时,显示数据的最后一个位的最小变化是一个字。 即00001-00002---00003向这样的趋势变化,请问我要选择几位的A/D芯片呢,是怎样计算出来的呢? 还请指教!!!… 查看全部问答> |
在网上有下了《51+sl811读写U盘的源程序+原理图》的原代码,但找不到原理图,请问哪位大哥有可以寄一份给我,或告知下载地址。谢谢! 我邮箱是: power_wjc@163.com… 查看全部问答> |
我用1394转接卡接一个摄像头,然后在屏幕上实时的显示摄像头拍得图像,但是在启动初始化的时候(大概10次中有1次),显示在屏幕上的图像错位了,图像的1/3跑到下面去了,而且一直保持这样,要让图像正常只能重启,有人说是同步问题,但我觉得不像, ...… 查看全部问答> |
我编译binutils到ARM上用,可是没有make过,请帮忙看一下!! 我先是 ./configure -target=arm-linux生成 Makefile 然后执行 make ,提示如下: // 我查了一下 regex.c中定义了个 char *malloc(); 在stdlib.h中void *malloc (size_t __size),我用的是gcc编译器,如果函数重载c++也可以通过 make[1]: Leav ...… 查看全部问答> |
STLINK 与STM8连接不成功。附图:硬件连接有问题吗?或者是STVP的配置有问题。 现在不是下载或者调试问题,而是STLINK识别不到有STM8S的存在:can not connect the device (当时的消息栏忘记抓图了) 初次使用STM8S(具体型号是STM8S103F3P ...… 查看全部问答> |
