今天是:2024年11月06日(星期三)
正在发生
2019年11月06日 | MSP432E401Y-PWM的生成和占空比的调整
2019-11-06 来源:eefocus
 * MSP432E4 Empty Project
 * Description: An empty project that uses DriverLib
 *                MSP432E401Y
 *          --|RST               |
 *            |             PF2  |--->25%PWM
 *            |             PF3  |--->75%PWM
 * Author:
/* DriverLib Includes */
#include
/* Standard Includes */
#include
#include
/* Global variable for system clock */
uint32_t getSystemClock;
/* PWM ISR */
void PWM0_0_IRQHandler(void)
    uint32_t getIntStatus;
    getIntStatus = MAP_PWMGenIntStatus(PWM0_BASE, PWM_GEN_1, true);
    MAP_PWMGenIntClear(PWM0_BASE, PWM_GEN_1, getIntStatus);
int main(void)
   /* Configure the system clock for 16 MHz internal oscillator */
    getSystemClock = MAP_SysCtlClockFreqSet((SYSCTL_OSC_INT |
                                             SYSCTL_USE_OSC), 16000000);
    /* The PWM peripheral must be enabled for use. */
    MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM0);
    while(!(MAP_SysCtlPeripheralReady(SYSCTL_PERIPH_PWM0)));
    /* Set the PWM clock to the system clock. */
    MAP_PWMClockSet(PWM0_BASE,PWM_SYSCLK_DIV_1);
    /* Enable the clock to the GPIO Port F for PWM pins */
    MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
    while(!MAP_SysCtlPeripheralReady(SYSCTL_PERIPH_GPIOF));
    MAP_GPIOPinConfigure(GPIO_PF2_M0PWM2);
    MAP_GPIOPinConfigure(GPIO_PF3_M0PWM3);
    MAP_GPIOPinTypePWM(GPIO_PORTF_BASE, (GPIO_PIN_2 | GPIO_PIN_3));
    /* Configure the PWM0 to count up/down without synchronization. */
    MAP_PWMGenConfigure(PWM0_BASE, PWM_GEN_1, PWM_GEN_MODE_UP_DOWN |
                        PWM_GEN_MODE_NO_SYNC);
    /* Set the PWM period to 250Hz.  To calculate the appropriate parameter
     * use the following equation: N = (1 / f) * SysClk.  Where N is the
     * function parameter, f is the desired frequency, and SysClk is the
     * system clock frequency.
     * In this case you get: (1 / 250Hz) * 16MHz = 64000 cycles.  Note that
     * the maximum period you can set is 2^16 - 1. */
    MAP_PWMGenPeriodSet(PWM0_BASE, PWM_GEN_1, 64000);
    /* Set PWM0 PF0 to a duty cycle of 25%.  You set the duty cycle as a
     * function of the period.  Since the period was set above, you can use the
     * PWMGenPeriodGet() function.  For this example the PWM will be high for
     * 25% of the time or 16000 clock cycles (64000 / 4). */
    MAP_PWMPulseWidthSet(PWM0_BASE, PWM_OUT_2,
                     MAP_PWMGenPeriodGet(PWM0_BASE, PWM_GEN_1) / 4);
    /* Set PWM0 PF1 to a duty cycle of 75%.  You set the duty cycle as a
     * 7% of the time or 16000 clock cycles 3*(64000 / 4). */
    MAP_PWMPulseWidthSet(PWM0_BASE, PWM_OUT_3,
    MAP_IntMasterEnable();
    /* This timer is in up-down mode.  Interrupts will occur when the
     * counter for this PWM counts to the load value (64000), when the
     * counter counts up to 64000/4 (PWM A Up), counts down to 64000/4
     * (PWM A Down), and counts to 0. */
    MAP_PWMGenIntTrigEnable(PWM0_BASE, PWM_GEN_1,
                            PWM_INT_CNT_ZERO | PWM_INT_CNT_LOAD |
                            PWM_INT_CNT_AU | PWM_INT_CNT_AD);
    MAP_IntEnable(INT_PWM0_1);
    MAP_PWMIntEnable(PWM0_BASE, PWM_INT_GEN_1);
    /* Enable the PWM0 Bit 0 (PF0) and Bit 1 (PF1) output signals. */
    MAP_PWMOutputState(PWM0_BASE, PWM_OUT_2_BIT | PWM_OUT_3_BIT, true);
    /* Enables the counter for a PWM generator block. */
    MAP_PWMGenEnable(PWM0_BASE, PWM_GEN_1);
    /* Loop forever while the PWM signals are generated. */
    while(1)
单片机控制 3个220V电动机
我现在想用单片机来控制 3个220V电动机  或是 5个电动机     而一般的电路设计是 光偶 加 可控硅 实现关与开  或是继电器实现     但是电动机开与关 到底有没有执行单片机没有得到 ...…
用万用表能测到晶振起振电压,而用示波器测不到,请教原因?
我用万用表可以测到晶振的起振电压,接上示波器,测不到电压和频率,请教各位大哥这个是不是示波器探针电容的影响? 示波器的设置:探针 为  *10  挡,交直流都试过了 …
MC35i 中文资料
谁有MC35i的datesheet啊,发我一份。 邮箱 wyz1986111@163.com 收到立即给分 …
SEGA MD5的开发包
SEGA MD是很久以前的TV游戏机, 前些时候整理了一下, 找到完整的开发包: 1)C,汇编开发工具和库; 2)调试工具(免ICE开发); 3)MIDI音乐转换工具; 工具虽老了些,但当初用这个工具开发过很多的商业SEGA游戏, 包括为日本著名游戏厂家BANDAI开发的SEGA ...…
高可靠性心电采集电路
按国内医学会制定的心电图标准,心电信息数字化精度不小于12bit,(信号输入范围+/-5mV的情况下,心电信号最小分辨率2.44uV)心电采样率不低于500Hz 我们想做一款心电图的分析软件,想找一个可靠心电电路,当然比上面标准更高的更好 最好有实际使用过 ...…
请教高手:应用层关闭后,winlogon占用cpu过高。
一个can卡驱动,通讯时运行良好,可是应用层程序关闭后,winlogon占用cpu过高。请教高手这是什么原因?…
求教用SYSTEMVIEW做PN码相应同步系统.
求教用SYSTEMVIEW做PN码相应同步系统. 1、判决器用哪个控件? 2、VCO所连接的时钟用什么控制? 最好能有解决电路图。谢谢~~…
谁知道三星 s3c6400 处理器的报价啊
谁知道三星 s3c6400 处理器的具体报价啊?ARM11的那个,iphone用的那个。…
请教ST_ARM
  我用STR710的Bank1扩展了16M的外部Flash存储器。连接时STR710的地址线、数据线、读、写控制线与外连的Flash进行了相应的连接。   我想请教的是:在IAR EWARM环境下对外部Falsh写数据时,我除了要使能BANK1, ...…
问用仿真器仿真的运行速度问题
用仿真器进行仿真运行,速度是不是比实际在板子上运行要慢阿? 如果是的话,怎样设置能使其速度快点阿? 我用的是2812板…
