今天是:2024年11月16日(星期六)
2019年11月16日 | AVR单片机8路AD如何采样
2019-11-16 来源:51hei
//*********ATmega128,8channel ADC sampling + LED display + USART*******
#include
#include
#define uchar unsigned char
#define uint unsigned int
#define ulong unsigned long
#define FOSC 1843200
#define baud 9600
#define MyUBBR (uint)((ulong)FOSC/(16*(ulong)baud)-1)
const uchar table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar Data[4]={0};
uchar adcon0_table[]={0x40,0x41,0x42,0x43,0x44,0x45,0x46,0x47};
uchar num1,num2;
uint data_buf[10]={0};
void delay_ms(uint x);
void PORT_init();
void USART_Init(uint ubbr);
void USART_Transmit(uchar data);
uchar USART_Receive(void);
void NumericalLED_display(void);
uint data_average(uint buffer[30]);
void get_AD(void);
void main()
uchar i;
PORT_init();
USART_Init(MyUBBR);
while(1)
NumericalLED_display();
get_AD();
if(USART_Receive()==0x01)
num1=PORTD;
num2=PORTB&0X03;
if((num1==0xff)&&(num2==0x03))
USART_Transmit(num1);
USART_Transmit(num2);
for(i=0;i<8;i++)
num1=data_buf[i]/255;
num2=data_buf[i]%255;
delay_ms(1000);
uint y,z;
for(y=x;y>0;y--)
for(z=110;z>0;z--);
void PORT_init()
DDRA=0x00;
DDRB=0xFF;
PORTB=0xFF;
DDRC=0xFF;
PORTC=0xFF;
PORTD=0xFF;
DDRD=0xFF;
UBRR1H= (uchar)(ubbr>>8);
UBRR1L= (uchar)ubbr;
UCSR1A= 0x00;
UCSR1B|=(1<
while(!(UCSR1A&(UDRE1)));
UDR1=data;
while(!(UCSR1A&(1<
static uchar i,temp=0x01;//temp=0x7f;
for (i=0; i<4; i++)
PORTC=table[Data[i]];
temp=1< PORTB&=~temp;
delay_ms(10);
//PORTC=table[Data[i]];
//PORTB=temp;
//temp=(temp>>1)|0x80;
//__delay_cycles(100);
uchar i,j;
uint temp;
float temp1;
for(i=1; i<30; i++)
for(j=29; j>=i; --j)
if(buffer[j-1] > buffer[j])
temp = buffer[j-1];
buffer[j-1] = buffer[j];
buffer[j] = temp;
temp1 = 0;
for(i=5; i<25; i++)
temp1 += buffer[i];
temp = (uint)(((float)temp1) / 20 + 0.5);
return(temp);
void get_AD(void)
uchar i,j;
uint adcbuf[30]={0};
static uchar ADC_channel=0;
//ADMUX=0x40;
ADCSRA=0x83;
SFIOR=0x00;
delay_ms(1);
for (i=0; i<8; i++)
ADMUX=adcon0_table[ADC_channel];
for(j=0; j<30; j++)
asm("NOP");
asm("NOP");
ADCSRA|=BIT(6);
while(((1<
adcbuf[j]=(ADCH<<8)|ADCL;
data_buf[i]=data_average(adcbuf);
Data[3]=data_buf[i]/1000;
Data[2]=data_buf[i]%1000/100;
Data[1]=data_buf[i]%100/10;
Data[0]=data_buf[i]%10;
if (++ADC_channel>8)ADC_channel=0;
delay_ms(1);
//PIC Multi_CD channel source code,
//******Multi_ADChannel converter**********//
#include
__PROG_CONFIG(1,0xc200);
__PROG_CONFIG(2,0x0a16);
__PROG_CONFIG(3,0x8100);
__PROG_CONFIG(4,0x0081);
__PROG_CONFIG(5,0xc00f);
__PROG_CONFIG(6,0xe00f);
__PROG_CONFIG(7,0x400f);
uchar temp;
void multi_convertor(void);
void port_check(void);
uint ADbuf[10];
void delay_ms(uint t)
uint m,n;
for (m=0;m
void GPIO_Init(void)
TRISA=0xff;
TRISB=0xff;
TRISC=0xff;
TRISD=0xff;
TRISE=0xff;
PSPMODE=0;
PSPIE=0;
PSPIP=0;
TRISBbits.RB2 =1; //set direction of RB2 to be An input;
TRISBbits.RB3 =1; //set direction of RB3 to be An input;
void ADC_Init(void)
ADCON1 = 0x05; //seting AN0~AN9 to be analog input;
ADCON2 = 0xBE; //20TAD,FOSC/64 and right justified;
void timer0_init(void)
INTCON =0xE0;//GIE,PEIE,TMR0IE to set;
T0CON = 0x1F;// timer0 to be 16-bit;
TMR0H = (65536-1000)/256;
TMR0L = (65536-1000)%256;
T0CON |=0x80;
TMR0ON=1;
void EUART_init(void)
TRISC7=1;
TRISC6=1;
SPBRG=0x40;
TXSTA=0x24;
RCSTA=0x90;
RCIE=0;
TXIE=0;
PEIE=1;
GIE=1;
void transmit_udata(uchar udata)
TXREG=udata;
while(!TRMT);
uchar receive_udata(void)
uchar temp;
if (RCIF==1)
temp=RCREG;
return temp;
uchar i,j;
uint temp;
float temp1;
for(i=1; i<30; i++)
temp = buffer[j-1];
buffer[j] = temp;
temp1 = 0;
for(i=5; i<25; i++)
temp1 += buffer[i];
return(temp);
void main(void)
EUART_init();
GPIO_Init();
ADC_Init();
timer0_init();
while(1)
temp=receive_udata();
if (temp==0x01)
temp=0;
port_check();
multi_convertor();
uchar num1, num2;
num1=PORTD;
num2=PORTB&0X03;
transmit_udata(num2);
transmit_udata(num1);
uchar data1,data2,i;
uint adc[30]={0};
// ADC_channel++;
for (ADC_channel=0; ADC_channel<10; ADC_channel++)
switch(ADC_channel)
case 0: ADCON0=0x01;break;//AN0 channel;
case 1: ADCON0=0x05;break;//AN1 channel;
case 2: ADCON0=0x09;break;//AN2 channel;
case 3: ADCON0=0x0D;break;//AN3 channel;
case 4: ADCON0=0x11;break;//AN4 channel;
case 5: ADCON0=0x15;break;//AN5 channel;
case 6: ADCON0=0x19;break;//AN6 channel;
case 7: ADCON0=0x1D;break;//AN7 channel;
case 8: ADCON0=0x21;break;//AN8 channel;
case 9: ADCON0=0x25;break;//AN9 channel;
default:break;
for(i=0;i<30;i++)
ADCON0 |=0x01;
asm("NOP");
asm("NOP");
GODONE=1;
while(GODONE);
adc[i]=(ADRESH*256)+ADRESL;
ADbuf[ADC_channel]=data_average(adc);
data1=ADbuf[ADC_channel]/255;
data2=ADbuf[ADC_channel]%255;
transmit_udata(data1);
transmit_udata(data2);
下一篇:avr单片机双通信C程序
适合 DIY显存8M的单片机显卡的开源操作系统RT-THREAD 网址:http://www.rt-thread.org 内核及组件 实时线程操作系统(RT-Thread) 是一款主要由中国开源社区主导开发的开源实时操作系统(许可证GPLv2)。实时线程操作系统不仅仅是一个单一的实时操作系统内核,它也是一个完整的应用 系统,包含了 ...… 查看全部问答> |
本人初学nand flash,有几个问题不太明白, 1.nand flash中chip,die, bank ,zone,block,page等概念之间什么关系,以及它们的具体含义! 2.nand flash spec资料一般那里找。 … 查看全部问答> |
XDS510 USB2.0 , CCS2.2连接f2812出错 前一段时间用ccs连接该DSP开发板一直都没有什么问题, 但是最近怎么都连不上同一块开发板了, 报错为Can\'t Initialize target cpu: 1. Target initialization failed< -1294>; 2. Check target power, and JTAG connection 重装了系统, 重新 ...… 查看全部问答> |
北京时间6月25日消息,据国外媒体报道,Google官方近日公布了数张Project Loon项目的动态图片。 上周,Google宣布了高空热气球项目Project Loon,该项目旨在为难以构建高速互联网的偏远地区提供价格低廉的网络服务。Project Loon官方网站称,高空热 ...… 查看全部问答> |
ADI设计问答:为什么我精心设计的有源滤波器未能达到其技术指标要求? 回答:这是因为许多有源滤波器软件忽略了“实际的”放大器特性。 最近,我度假去红海潜水。临行之前,我把自己的手机和计算机都留在了家里,并把所有的工作都暂时抛在一边。但是,我却犯了一个愚蠢的错误,那就是用带有\"Analog Devices\"字样的帆 ...… 查看全部问答> |
[PCB] 关于PCB设计要点分析 当前社会,大量的电子产品广泛的应用在我们的日常工作、生活当中,所以他们的可靠性需要保证,而绝大多数通过印制电路板的电子系统、设备,必须要有合理的设计原理图,正确的印制电路板,才可以从根本上提高他们的可靠 ...… 查看全部问答> |
去年淘宝买来做毕业设计,现闲置无用,九成九新,附送所有资料,以及关于视频图像的研究生论文。有意者QQ:471293219! 淘宝店家资料:http://item.taobao.com/item.htm? ... 4034&_u=u2b1kmce065 … 查看全部问答> |
