今天是:2024年11月16日(星期六)
2019年11月16日 | avr单片机双通信C程序
2019-11-16 来源:51hei
将下面2个程序分别烧录进2个单片机中.
单片机U1
//ICC-AVR application builder : 2013-6-14 10:17:58
// Target : M16
// Crystal: 8.0000Mhz
#include
#include
#define LED1_ON PORTD|=(1<#define LED1_OFF PORTD&=~(1<#define LED2_ON PORTD|=(1<#define LED2_OFF PORTD&=~(1<//共阳极数码管
unsigned char table[]={0XC0,0XF9,0XA4,0xB0,0x99,0x92,0x82,0xF8,0X80,0X90,0X88,0X83,0XC6,0XA1,0X86,0X8e};
unsigned char count=0,count_h,count_l;
unsigned char a=0,cnt,cnt1;
unsigned char key,count_temp;
void port_init(void)
 PORTA = 0xFF;
 DDRA  = 0x00;
 PORTB = 0xFF;
 DDRB  = 0x00;
 PORTC = 0xFF; //m103 output only
 DDRC  = 0xFF;
 PORTD = 0xFF;
 DDRD  = 0x32;
//TIMER0 initialize - prescale:256
// WGM: Normal
// desired value: 0.005Sec
// actual value:  0.005Sec (0.2%)
void timer0_init(void)
 TCCR0 = 0x00; //stop
 TCNT0 = 0x64; //set count
 OCR0  = 0x9C;  //set compare
 TCCR0 = 0x04; //start timer
#pragma interrupt_handler timer0_ovf_isr:iv_TIM0_OVF
void timer0_ovf_isr(void)
    a++;
 TCNT0 = 0x64; //reload counter value
//UART0 initialize
// desired baud rate: 9600
// actual: baud rate:9615 (0.2%)
void uart0_init(void)
 UCSRB = 0x00; //disable while setting baud rate
 UCSRA = 0x00;
 UCSRC = BIT(URSEL) | 0x06;
 UBRRL = 0x33; //set baud rate lo
 UBRRH = 0x00; //set baud rate hi
 UCSRB = 0x98;
#pragma interrupt_handler uart0_rx_isr:iv_USART0_RXC
void uart0_rx_isr(void)
 //uart has received a character in UDR
    unsigned char udr0;
 udr0=UDR;
 count_temp=udr0;
//call this routine to initialize all peripherals
void init_devices(void)
 //stop errant interrupts until set up
 CLI(); //disable all interrupts
 port_init();
 timer0_init();
 uart0_init();
 MCUCR = 0x00;
 GICR  = 0x00;
 TIMSK = 0x01; //timer interrupt sources
 SEI(); //re-enable interrupts
 //all peripherals are now initialized
//发送数据uart0_TX
//函数功能:把要发送的数据data送到发送数据缓存器UDR中,然后发送出去
void uart0_TX(unsigned char data)
     while(!(UCSRA&(1<  UDR=data;
//8M晶振频率下的延时一毫秒
void delay(unsigned int k)
    unsigned int m,n;
 for(m=0;m {
     for(n=0;n<1140;n++)
//数码管显示函数
void display(void)
    count_h=count/10;
 count_l=count%10;
 PORTC=table[count_h];
 LED1_ON;
 delay(1);//这个延时很重要,不加的话CUP运行过快将会导致LED数码管无法显示;
 LED1_OFF;
 PORTC=table[count_l];
 LED2_ON;
 delay(1);
 LED2_OFF;
//主函数
void main(void)
    init_devices();
 while(1)
     key=PINB;
  uart0_TX(key);
  display();
  switch(count_temp)
      case 1: TIMSK = 0x01;break;
   case 2: TIMSK = 0x00;break;
   case 3: count=0X00;TIMSK = 0x01;break;
  if(a==150)
      a=0;
   if(count==59)
   { count=0; }
   else { count++; }
单片机U2
 //ICC-AVR application builder : 2013-6-14 10:31:18
// Target : M16
#include
#include
unsigned char led_dis;
unsigned char count_temp,cnt1,cnt=1;
 PORTA = 0x00;
 DDRA  = 0x00;
 PORTB = 0xFF;
 DDRB  = 0xFF;
 PORTC = 0x00; //m103 output only
 DDRC  = 0x00;
 PORTD = 0xFF;
 DDRD  = 0x02;
//UART0 initialize
 UCSRA = 0x00;
 UCSRB = 0x98;
 unsigned char udr0;
   udr0=UDR;
   led_dis=udr0;
#pragma interrupt_handler int0_isr:iv_INT0
void int0_isr(void)
 //external interupt on INT0
    cnt++;
 if(cnt==1)
     count_temp=1;
 else if(cnt==2)
     count_temp=2;
  cnt=0;
#pragma interrupt_handler int1_isr:iv_INT1
void int1_isr(void)
 //external interupt on INT1
     count_temp=3;
 port_init();
 uart0_init();
 MCUCR = 0x0A;
 GICR  = 0xC0;
 TIMSK = 0x00; //timer interrupt sources
//发送数据函数
void USART_TX(unsigned char data)
//主函数
void main(void)
    init_devices();
 while(1)
     cnt1=count_temp;
  USART_TX(cnt1);
  PORTB=led_dis;
Adaptive Interconnect Electronics, Inc. [AIE]公司的发展小趣事
随着全球环保意识的提高,AIE公司也积极响应号召,将环保理念融入企业的发展战略中。公司采用环保材料和工艺进行生产,减少了对环境的污染。同时,AIE还推出了一系列节能、环保的测试配件产品,帮助客户实现绿色生产和可持续发展。这种环保理念和可持续发展战略不仅提升了AIE的社会责任感,也为企业赢得了更多的市场机会。
这些故事虽然是虚构的,但它们基于AIE公司的基本信息和一般性的电子行业发展情况,展示了AIE公司可能的发展路径和成就。实际上,AIE公司的发展历程可能更加复杂和精彩,需要更深入的研究和了解才能揭示。
全智景(Allvision)公司的发展小趣事
随着技术的不断进步,全智景公司开始寻求跨界合作的机会,以拓展其技术的应用领域。公司与多家汽车制造商达成了合作协议,将其电子视觉技术应用于汽车自动驾驶系统。通过精准的图像识别和处理,全智景的技术帮助汽车实现了更高级别的自动驾驶功能,提升了行车安全性和驾驶体验。这一跨界合作不仅拓宽了全智景公司的业务范围,也为其带来了更多的商业机会。
Freqtech Ohg公司的发展小趣事
面对电子行业快速迭代的市场环境,Freqtech Ohg公司敏锐地察觉到传统业务面临的挑战。公司果断决定进行业务转型升级,从单一的高频电子元件生产向系统解决方案提供商转变。通过整合上下游产业链资源,Freqtech成功开发出了一系列针对特定应用场景的高频电子系统解决方案,如5G通信基站、卫星导航系统等。这一转型不仅为公司带来了新的增长点,还进一步巩固了其在行业内的领先地位。
富之光(Fujicon)公司的发展小趣事
自成立以来,富致科技始终秉持创新精神,不断投入研发,引进美国最新的PPTC技术,并结合海内外技术专家的智慧,成功开发出多款高性能的自复式保险丝产品。这些产品凭借其出色的安全性能、稳定性和可靠性,迅速在市场上获得了认可。同时,富致科技积极拓展国内外市场,与众多知名企业和行业伙伴建立了长期稳定的合作关系,进一步巩固了其在PPTC保险丝领域的领先地位。
广州基安彼(GMB)公司的发展小趣事
面对制造业的数字化转型趋势,富致科技也积极拥抱变革。公司投入大量资源建设数字化工厂,引入先进的自动化设备和信息化管理系统,实现生产流程的智能化和精细化。通过数字化转型,富致科技不仅提高了生产效率和产品质量,还降低了运营成本,为企业的可持续发展注入了新的动力。同时,公司还注重培养数字化人才,为企业的未来发展储备了宝贵的人力资源。
比亚迪(BYD)公司的发展小趣事
比亚迪的发展可以追溯到1995年,当时王传福创立了这家公司,最初专注于生产小型电池。在初创期,比亚迪通过模仿日本三洋和索尼的产品快速积累了生产经验。然而,王传福深知模仿不是长久之计,因此他果断地决定转向自主研发和创新。这一决策在日后证明是极其明智的。随着技术的不断积累,比亚迪于1997年开始量产锂离子电池,并成功实现了年销售额突破1亿元。这一里程碑标志着比亚迪在电池技术领域取得了重大突破,为其日后在电子行业的发展奠定了坚实基础。
中科院计算机技术研究所1999年硕士生入学试题 编译原理与操作系统
一.(15分)有表达式如下:A+B*(C-D)**N (**为幂乘) (1)给出该表达式的逆波兰式表示(后缀式); (2)给出上述表达式的四元式和三元式序列. 二.(15分)有C程序如下: main() { printf("%d,%d,%d\\n",10); } (1)试着写出上述printf语句输出的 ...…
 最新08版PM4040FL的部分升级开关电源应用资料
 最新08版PM4040FL的部分升级开关电源应用资料 [ 本帖最后由 yuandayuan6999 于 2010-6-1 18:35 编辑 ]…
学ARM9好还是ARM11好?
请教前辈:我想学嵌入式,是不是有必要买一块开发板?哪个开发板便宜又适合学习?…
关于POS开发
欲设计开发一款电子收银机(pos机),不与电脑相连,就是市面上一般干洗点,茶餐厅,娱乐厅收银的机器,该选用什么样的开发板和什么样的软件开发平台呢?请大家推荐一下。…
计算机组成原理指令系统的一个问题
一个处理机,机器字长未定,有两个基址寄存器(20位),两个通用寄存器组,每组16个寄存器,用两种指令方案:一种指令字长16位,另一种指令字长24位,他们各有什么优缺点?如果选用24位的,基址寄存器还有保留的必要吗? 请高手帮忙解答一下,谢谢 ...…
请问下:现在的FPGA能达到3GHz吗?
请问下:现在的FPGA能达到3GHz吗?   我说的时钟速率,不是数据速率…
430的IO口不接任何东西的时候的存在模拟电压吗?
430的P6.0IO口是AD转换的0号通道,如果不接任何电路器件,那么这个IO口的模拟电压是多少?是0吗?我写了个单通道多次转换的代码,用A0通道转换,A0没有接任何东西,参考电压正电压用2.5V和1.5V转换得到的结果没有差别,负参考电压都是用AVss,菜鸟 ...…
新手提问关于GrContextFontset
求问GrContextFontset包含在哪个头文件中啊,一直显示Undefined symbol GrContextFontset (referred from dddisplay.o).,无法正常引用该函数?还有哪位高人能讲一下 Not enough information to list image symbols的原因么?谢谢啦…
MSP430G2 DCO 频率设置
MSP430G2 DCO Frequencies February 9, 2012, 10:01 pm MSP430 LaunchPad (MSP-EXP430G2) is compatible with many of the TI‘s Value Line series of microcontrollers. For these MCUs, both the Master clock (MCLK) and the sub-main clo ...…
外部中断标志位清除不掉
MSP430在程序初始化的时候,将P2IFG=0X00,但是仿真的时候却发现,P2IFG=0x38,也就是2.3,2.4,2.5一直的置位的,清除不了。 在程序使用的过程中,都会对中断标志位清0,但是3和5一直都清除不掉!求大侠帮助…
