今天是:2024年12月12日(星期四)
正在发生
2019年12月12日 | PIC单片机的BCD码处理程序
2019-12-12 来源:elecfans
#define PAGE    EJECT
TITLE   "BCD ArithmeTIc RouTInes : Ver 1.0"
;                      BCD ArithmeTIc Routines
 LIST     columns=120, WRAP, L=0
 include "17c42.h"
 CBLOCK   0x20
  Lbyte, Hbyte
  R2, R1, R0             ;must maintain R2, R1, R0 sequence
  count
  Num1, Num2
 ENDC
BCD     equ      Num1
Htemp   equ      Num1
Ltemp   equ      Num2
 PAGE
 ORG     0x0000
;                      BCD Arithmetic Test Program
main
 setf     Hbyte
 setf     Lbyte
;                               ; 16 bit binary num = 0xffff
 call    B2_BCD_Looped   ; after conversion the Decimal Num
;                               ; in R0, R1, R2 = 06,55,35
 setf     Hbyte
 setf     Lbyte
 call    B2_BCD_Straight ; same as above, but straight line code
 movlw    0x06
 movwf     R0
 movlw    0x55
 movwf     R1
 movlw    0x35
 movwf     R2              ; setf R0R1R2 = 65535
 call    BCDtoB          ; after conversion Hbyte = 0xff
;                               ; and Lbyte = 0xff
 movlw    0x99
 movwf     Num1
 movlw    0x99
 movwf     Num2            ; setf Num1 = Num2 = 0x99 (max BCD)
 call    BCDAdd          ; after addition, Num2 = 98
;                               ; and Num1 = 01 ( 99+99 = 198)
 movlw    0x63            ; setf Wreg = 63 hex
 call    BinBCD          ; after conversion, BCD = 99
;                               ; 63 hex = 99 decimal.
self    goto    self
 PAGE
;                  Binary To BCD Conversion Routine (8 bit)
;       This routine converts the 8 bit binary number in the W Reg
; to a 2 digit BCD number in location BCD( compacted BCD Code)
;       The least significant digit is returned in location LSD and
; the most significant digit is returned in location MSD.
;   Performance :
;               Program Memory  :  10
;               Clock Cycles    :  62  (worst case when W = 63 Hex )
;                                      ( i.e max Decimal number 99 )
BinBCD
 clrf     BCD
again
 addlw    -10
 btfss      _carry
 goto    swapBCD
 incf     BCD
 goto    again
swapBCD
 addlw    10
 swapf    BCD
 iorwf     BCD
 return
 PAGE
;                Binary To BCD Conversion Routine (16 Bit)
;                       (LOOPED Version)
;      This routine converts a 16 Bit binary Number to a 5 Digit
; BCD Number.
;       The 16 bit binary number is input in locations Hbyte and
; Lbyte with the high byte in Hbyte.
;       The 5 digit BCD number is returned in R0, R1 and R2 with R0
; containing the MSD in its right most nibble.
;   Performance :
;               Program Memory  :  32
;               Clock Cycles    :  750
B2_BCD_Looped
 bsf      _fs0
 bsf      _fs1            ; set fsr0 for no auto increment
 bcf      _carry
 clrf     count
 bsf      count,4         ; set count = 16
 clrf     R0
 clrf     R1
 clrf     R2
loop16a
 rlcf     Lbyte
 rlcf     Hbyte
 rlcf     R2
 rlcf     R1
 rlcf     R0
 dcfsnz   count
 return
adjDEC
 movlw    R2              ; load R2 as indirect address ptr
 movwf     fsr0
 call    adjBCD
 incf     fsr0
 call    adjBCD
 incf     fsr0
 call    adjBCD
 goto    loop16a
adjBCD
 movfp    indf0,wreg
 addlw    0x03
 btfsc      wreg,3          ; test if result > 7
 movwf     indf0
 movfp    indf0,wreg
 addlw    0x30
 btfsc      wreg,7          ; test if result > 7
 movwf     indf0           ; save as MSD
 return
;                       (Partial Straight Line Version)
; BCD Number.
;   Performance :
;               Program Memory  :  44
;               Clock Cycles    :  572
B2_BCD_Straight
 bsf      _fs0
 bcf      _carry
 clrf     count
 clrf     R0
 clrf     R1
 clrf     R2
loop16b
 rlcf     Lbyte
 rlcf     Hbyte
 rlcf     R2
 rlcf     R1
 rlcf     R0
 dcfsnz   count
 return                   ; DONE
 movwf    fsr0
; adjustBCD
 movfp    indf0,wreg
 addlw    0x03
 movwf    indf0
 movfp    indf0,wreg
 addlw    0x30
 incf     fsr0
; adjustBCD
 movfp    indf0,wreg
 addlw    0x03
 movwf    indf0
 movfp    indf0,wreg
 addlw    0x30
 incf     fsr0
; adjustBCD
 movfp    indf0,wreg
 addlw    0x03
 movwf    indf0
 movfp    indf0,wreg
 addlw    0x30
 goto    loop16b
 PAGE
;               BCD To Binary Conversion
;       This routine converts a 5 digit BCD number to a 16 bit binary
; number.
;       The input 5 digit BCD numbers are asumed to be in locations
; R0, R1 & R2 with R0 containing the MSD in its right most nibble.
;       The 16 bit binary number is output in registers Hbyte & Lbyte
; ( high byte & low byte repectively ).
;       The method used for conversion is :
;               input number X = abcde ( the 5 digit BCD number )
;       X = (R0,R1,R2) = abcde = 10[10[10[10a+b]+c]+d]+e
;   Performance :
;               Program Memory  :  30
;               Clock Cycles    :  112
mpy10b
 andlw    0x0f
 addwf     Lbyte
 btfsc      _carry
 incf     Hbyte
mpy10a
 bcf      _carry          ; multiply by 2
 rlcf     Lbyte,w
 movwf     Ltemp
 rlcf     Hbyte,w         ; (Htemp,Ltemp) = 2*N
 movwf     Htemp
 rlcf     Lbyte
 rlcf     Hbyte
 rlcf     Lbyte
 rlcf     Hbyte
 rlcf     Lbyte
 rlcf     Hbyte     ; (Hbyte,Lbyte) = 8*N
 movfp    Ltemp,wreg
 addwf     Lbyte
 movfp    Htemp,wreg
 addwfc    Hbyte
 return                     ; (Hbyte,Lbyte) = 10*N
BCDtoB
 clrf     Hbyte
 movfp    R0,wreg
 andlw    0x0f
 movwf     Lbyte
 call    mpy10a          ; result = 10a+b
 swapf    R1,w
 call    mpy10b          ; result = 10[10a+b]
 movfp    R1,wreg
 call    mpy10b          ; result = 10[10[10a+b]+c]
 swapf    R2,w
 call    mpy10b          ; result = 10[10[10[10a+b]+c]+d]
 movfp    R2,wreg
 andlw    0x0f
 addwf     Lbyte
 btfsc      _carry
 incf     Hbyte           ; result = 10[10[10[10a+b]+c]+d]+e
 return                  ; BCD to binary conversion done
 PAGE
;                 Unsigned BCD Addition
;       This routine performs a 2 Digit Unsigned BCD Addition
; It is assumed that the two BCD numbers to be added are in
; locations Num1 & Num2. The result is the sum of Num1+Num2
; and is stored in location Num2 and the overflow carry is returned
; in location Num1
;   Performance :
;               Program Memory  :       5
;               Clock Cycles    :       5
BCDAdd
 movfp    Num1,wreg
 addwf     Num2,w          ; perform binary addition
 daw     Num2      ; adjust for BCD addition
 clrf     Num1
 rlcf     Num1      ; set Num1 = carry bit
 return
 END
ES Systems公司的发展小趣事
ES Systems自创立之初就专注于电子系统技术的研发。公司创始人是一位资深的电子工程师,他带领团队不断突破技术瓶颈,开发出了一系列高性能的电子系统产品。随着技术的不断成熟和产品线的丰富,ES Systems逐渐在市场中树立了技术领先的形象,吸引了大量客户的青睐。公司通过技术驱动实现了快速成长,并在电子行业中占据了重要地位。
Frequency Electronics Inc公司的发展小趣事
高频电子的业务范围广泛且多元化,主要包括FEI-NY、Gillam-FEI和FEI-Zyfer三个部门。FEI-NY部门主要负责纽约总部设施和子公司FEI-Asia与FEI-Elcom的运营;Gillam-FEI部门则负责比利时与法国的业务,并专注于电缆网络同步产品的设计、研发和生产;FEI-Zyfer部门则主要经营公司加州业务,并设计生产附带GPS技术的产品。这种多元化业务布局不仅降低了公司的经营风险,还实现了各业务之间的战略协同和资源共享。
Doodle Labs公司的发展小趣事
随着技术的不断进步和市场的不断变化,Doodle Labs意识到单一产品无法满足多样化的客户需求。因此,公司开始加大研发投入,不断推出新的产品线。其中,最为引人注目的是一款名为Helix的六波段智能无线电产品,它能够在1625-2500MHz的频率范围内工作,为无人机提供全方位的通信支持。这款产品一经推出就受到了市场的热烈欢迎,Doodle Labs也因此获得了更多的关注和认可。
AMOTECH(阿莫泰克)公司的发展小趣事
进入21世纪,AMOTECH继续深耕电子领域,特别是在压敏电阻技术上取得了重大突破。2003年,公司的压敏电阻产品被产业资源部评为世界一流产品,这一成就不仅提升了AMOTECH在全球电子行业中的地位,也为其后续发展奠定了坚实基础。同年,公司还成功在韩国安全商协会自动报价首次公开募股,为公司的进一步扩张提供了资金支持。
Custom Electronics Inc公司的发展小趣事
在电子行业的早期阶段,CEI凭借其卓越的研发团队和创新能力,成功开发出一款具有革命性的新型电容器。这款电容器以其高效能、长寿命和稳定性强的特点,迅速在市场中获得认可。CEI借此机会,进一步扩大了生产规模,提高了产品质量,逐渐确立了其在电子行业中的领先地位。
DMEL Inc公司的发展小趣事
为了提升产品质量和用户体验,DMEL Inc不断加大对生产过程的管控力度。公司引进了先进的生产设备和管理系统,建立了严格的质量检测体系。同时,DMEL Inc还加强了与供应商的合作,确保原材料的质量和供应的稳定性。这些措施的实施,使得DMEL Inc的产品质量得到了显著提升,赢得了消费者的信赖和好评。
菜鸟请教 谁能帮我解释下这小段延时子程序
跪求高手 大致解释下每一行是干什么可以么? 万分感谢!! :( ------------------------------------------------- DELAY:                          ...…
台湾IC设计上半年大爆发,模拟IC最抢眼
2010年由于电子产品逐渐进入需求高峰之后的淡季,PC、Notebook、小笔电等成长率趋缓,手机芯片、模拟IC、驱动IC、内存IC等需求处于回升。2010年台湾IC设计业产值突破新台币2300亿元,比去年同期成长35%。这显示2010年初景气复苏渐露曙光,终端 ...…
wince 6.0 按键中断 一直存在
wince 6.0 pxa270 再进行了初始化,和中断的设置后,按键一直有中断。而且是在没有按下按键的情况下。 这样的问题会是什么原因造成的呢? kpc设置问题?还是中断触发的设置问题,或是中断设置问题?一直没有搞明白,为什么还没有操作按键就一直 ...…
转载:各个版本的tornado及其他软件的密码
个版本的tornado及其他软件的密码,经验证,在笔记本上安装Tornado成功。 转载: 共分三个类别:嵌入式系统开发软件,PCB、FPGA、IC开发软件,射频以及其他EDA软件 嵌入式系统开发软件 一、WINDRIVER.TORNADO.V2.2.FOR.COLDFIRE CD1 ...…
帮帮小弟吧,NDIS驱动安装问题,雪地打滚了
头写了一个防火墙程序,现在本人手里有sys和两个inf,一个是过滤器的inf,一个是虚拟设备的驱动,跟passthru的差不多,手动安装没有问题,可是跟据bindview的例子写的程序自动安装就是不起作用,网络组件已经显示出来了,可是就是不起作用,弄了一个 ...…
有没有卖24个交换口主板的厂家?
介绍一下24个交换口的厂家?为什么多网口主板大多数是个4,6个口的…
2011年LED照明市场与技术概览
绿色照明应用热潮已经到来,LED照明则成为不可逆转的趋势。2012年,日本将全面禁用白炽灯,东芝照明技术更是决定在2012年之前停产普通白炽灯泡,关闭全部生产线。台湾地区相关部门也宣布,截至2012年底全面禁止高能耗的白炽灯泡的使用。而欧盟早在2 ...…
关于STM32的实际速度。
这两天测试了STM32的速度。在72M的时钟下,我得到的数据大概如下:整数加减乘除     大概  4千万/S浮点运算就慢慢了       20万/S  左右。我是自己编写的测 ...…
【挖电源】最小开关电源,谁都能做
这个非常简单大家看下,原理不说了,无话可说         上PDF   [ 本帖最后由 ddllxxrr 于 2011-7-22 09:11 编辑 ]…
ADC 硬件过采样和软件过采样有什么区别?
ADC 硬件过采样和软件过采样有什么区别? 之前对 M3 ADC 采样过程中,发现值比较飘,所以想采用过采样,不知道这两种有什么区别。…
