今天是:2025年01月03日(星期五)
2020年01月03日 | MSP432开发板串口调试
2020-01-03 来源:eefocus
拿到MSP432P401R评估板v1.0(这个请注意一下,目前在德州仪器官网上找到的硬件原理图是v2.0,v1.0的串口所在的引脚是RXD,TXD引脚),先将串口调试好,便于下一步工作的展开。首先,查看TI提供的代码例子,这个例子就在TI的MSPWare代码包内。注释如下:
// MSP432P401 Demo - eUSCI_A0 UART echo at 9600 baud using BRCLK = 12MHz
// Description: This demo echoes back characters received via a PC serialport.
// SMCLK/DCO is used as a clock source and the device is put in LPM3
// Theauto-clock enable feature is used by the eUSCI and SMCLK is turned off
// when theUART is idle and turned on when a receive edge is detected.
// Note thatlevel shifter hardware is needed to shift between RS232 and MSP
// voltagelevels.
// Theexample code shows proper initialization of registers
// andinterrupts to receive and transmit data.
// To testcode in LPM3, disconnect the debugger.
// MSP432P401
// --|RST |
// | P1.3/UCA0TXD|----> PC(echo)
// | P1.2/UCA0RXD|<---- PC
// Wei Zhao
// TexasInstruments Inc.
// October2015 (updated) | June 2014 (created)
// Builtwith Code Composer Studio V6.0
从以上信息我们可以看出,此段例程所要做的事情就是将板载串口配置成9600波特率工作的串口,并原样送回我们发送进去的数据。从示意图中我们可以看出,我们只需要一对收发线即可完成本实验。接下来分析其源代码。
#include "msp.h"
int main(void)
WDTCTL =WDTPW | WDTHOLD; // Stopwatchdog timer
CS->KEY= 0x695A; //Unlock CS module for register access
CS->CTL0= 0; // Resettuning parameters
CS->CTL0= CS_CTL0_DCORSEL_3; //Set DCO to 12MHz (nominal, center of 8-16MHz range)
//Select ACLK = REFO, SMCLK = MCLK = DCO
CS->CTL1= CS_CTL1_SELA_2 | CS_CTL1_SELS_3 | CS_CTL1_SELM_3;
CS->KEY= 0; // LockCS module from unintended accesses
//Configure UART pins
P1SEL0 |=BIT2 | BIT3; // set2-UART pin as second function
__enable_interrupt();
NVIC->ISER[0] = 1 << ((EUSCIA0_IRQn) & 31); // EnableeUSCIA0 interrupt in NVIC module
//Configure UART
UCA0CTLW0|= UCSWRST;
UCA0CTLW0|= UCSSEL__SMCLK; // PuteUSCI in reset
// BaudRate calculation
//12000000/(16*9600) = 78.125
//Fractional portion = 0.125
// User'sGuide Table 21-4: UCBRSx = 0x10
// UCBRFx =int ( (78.125-78)*16) = 2
UCA0BR0 =78; //12000000/16/9600
UCA0BR1 =0x00;
UCA0MCTLW= 0x1000 | UCOS16 | 0x0020; //注意这一行的设定
UCA0CTLW0&= ~UCSWRST; //Initialize eUSCI
UCA0IE |=UCRXIE; // EnableUSCI_A0 RX interrupt
__sleep();
__no_operation(); // For debugger
// UART interrupt service routine
void EUSCIA0_IRQHandler(void)
if(UCA0IFG & UCRXIFG)
while(!(UCA0IFG&UCTXIFG));
UCA0TXBUF = UCA0RXBUF;
__no_operation();
我们首先粗略地研究一下这段测试代码,忽略前半部分关于时钟设置的内容,检查我标记的注意行。UCA0MCTLW0寄存器的设定在芯片TechnicalReference Manual的745页,例程中基本是使用默认串口配置。串口通信波特率已经在前面代码中设定为9600。看明白了上述内容,就掌握了这块开发板串口的基本内容,有精力可以继续探索一下芯片手册,尝试串口的其他功能。重要提示,不要使用盗版ghost win7,这样会导致xds110板载调试器的驱动安装失败。
上一篇:MSP430时钟设置及应用总结
敷铜作为PCB设计的一个重要环节,不管是国产的青越锋PCB设计软件,还国外的一些Protel,PowerPCB都提供了智能敷铜功能,那么怎样才能敷好铜,我将自己一些想法与大家一起分享,希望能给同行带来益处。 所谓覆铜,就是将PCB上闲置的空间作为基准面, ...… 查看全部问答> |
最近在做linux+qte 在arm平台上的界面显示,由于周围 几乎没有做 这块的,qt学习起来相当吃力, 这个是qtopia部分一些精华 要点 分析,看后很受启发… 查看全部问答> |
P430颅内出血检测设备的研制策略1 引言 在中国有许多因创伤性颅脑损伤的患者急需抢救,但相当一部分颅内出血患者因未能及时诊断,延误了抢救和治疗时机.因而出现脑血肿或脑疝后压迫脑组织.使脑干和脑实质受到不可逆转的损伤。近红外颅内出血检测 ...… 查看全部问答> |
UBS to RS232 转接线(PL-2303HX)的特性及应用电路 本帖最后由 paulhyde 于 2014-9-15 09:20 编辑 1.USB转串口线: PROLIFIC推出了USB TO 类RS232接口转换芯片PL-2303HX,PL-2303HX可完美的应用于PDA、Modem、GPS、手机、数码相机、读卡机等与PC机的通讯电缆上,实际上很多手机的USB数据线就是 ...… 查看全部问答> |
wince启动信息: Loaded symbols for \'E:\\WINCE420\\PUBLIC\\DIRVERTEST\\RELDIR\\EMULATOR_X86DEBUG\\SCANDLL.DLL\' Unloaded symbols for \'E:\\WINCE420\\PUBLIC\\DIRVERTEST\\RELDIR\\EMULATOR_X86DEBUG\\SCANDLL.DLL\' 可以发现SCANDLL. ...… 查看全部问答> |
在keill中模拟时有时候计算数值哪里出错,纠结很久了,求助 code unsigned int adc[]={228,221,213,204,194,183,172,160,147,135,122,110,99,88,78,69,61,54,48,42,38,33,29,26,23,20,18,16,14,13,11 };code unsigned int tem[]={0,5,10,15,20,25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100,105,1 ...… 查看全部问答> |
