今天是:2025年01月19日(星期日)
2020年01月19日 | STM8 GPIO 学习(驱动LED、Button)
2020-01-19 来源:eefocus
STM8中GPIO寄存器有:输出寄存器(ODR),输入寄存器(IDR),方向寄存器(DDR),控制寄存器1(CR1)和控制寄存器2(CR2).后面三个寄存器组和可以配置为8种GPIO的模式
定义如下:
* @brief General Purpose I/Os (GPIO)
typedef struct GPIO_struct
__IO uint8_t ODR; /*!< Output Data Register */
__IO uint8_t IDR; /*!< Input Data Register */
__IO uint8_t DDR; /*!< Data Direction Register */
__IO uint8_t CR1; /*!< Configuration Register 1 */
__IO uint8_t CR2; /*!< Configuration Register 2 */
GPIO_TypeDef;
相关的配置模式定义如下
* @defgroup GPIO_Modes
* @brief
* Bits definitions:
* - Bit 7: 0 = INPUT mode
* 1 = OUTPUT mode
* 1 = PULL-UP (input) or PUSH-PULL (output)
* - Bit 5: 0 = No external interrupt (input) or No slope control (output)
* 1 = External interrupt (input) or Slow control enabled (output)
* - Bit 4: 0 = Low level (output)
* 1 = High level (output push-pull) or HI-Z (output open-drain)
typedef enum
GPIO_Mode_In_FL_No_IT = (uint8_t)0x00, /*!< Input floating, no external interrupt */
GPIO_Mode_In_PU_No_IT = (uint8_t)0x40, /*!< Input pull-up, no external interrupt */
GPIO_Mode_In_FL_IT = (uint8_t)0x20, /*!< Input floating, external interrupt */
GPIO_Mode_In_PU_IT = (uint8_t)0x60, /*!< Input pull-up, external interrupt */
GPIO_Mode_Out_OD_Low_Fast = (uint8_t)0xA0, /*!< Output open-drain, low level, 10MHz */
GPIO_Mode_Out_PP_Low_Fast = (uint8_t)0xE0, /*!< Output push-pull, low level, 10MHz */
GPIO_Mode_Out_OD_Low_Slow = (uint8_t)0x80, /*!< Output open-drain, low level, 2MHz */
GPIO_Mode_Out_PP_Low_Slow = (uint8_t)0xC0, /*!< Output push-pull, low level, 2MHz */
GPIO_Mode_Out_OD_HiZ_Fast = (uint8_t)0xB0, /*!< Output open-drain, high-impedance level, 10MHz */
GPIO_Mode_Out_PP_High_Fast = (uint8_t)0xF0, /*!< Output push-pull, high level, 10MHz */
GPIO_Mode_Out_OD_HiZ_Slow = (uint8_t)0x90, /*!< Output open-drain, high-impedance level, 2MHz */
GPIO_Mode_Out_PP_High_Slow = (uint8_t)0xD0 /*!< Output push-pull, high level, 2MHz */
}GPIO_Mode_TypeDef;
GPIO_Mode_In_FL_No_IT浮空输入无中断
GPIO_Mode_In_PU_No_I上拉输入无中断
GPIO_Mode_In_FL_IT 浮空输入有中断
GPIO_Mode_In_PU_IT 上拉输入有中断
开漏-输出低-高速
推挽-输出低-高速
开漏-输出低-低速
推挽-输出低-低速
开漏-输出高阻-高速
推挽-输出高-高速
开漏-输出高阻-低速
推挽-输出高-低速
GPIO的固件库函数如下所示:
void GPIO_DeInit (GPIO_TypeDef *GPIOx) Deinitializes the GPIOx peripheral registers to their default reset values.
void GPIO_ExternalPullUpConfig (GPIO_TypeDef *GPIOx,uint8_t GPIO_Pin, FunctionalState NewState) Configures the external pull-up on GPIOx pins.
void GPIO_Init (GPIO_TypeDef *GPIOx,uint8_t GPIO_Pin, GPIO_Mode_TypeDef GPIO_Mode) Initializes the GPIOx according to the specified parameters.
uint8_t GPIO_ReadInputData (GPIO_TypeDef *GPIOx) Reads the specified GPIO input data port.
BitStatus GPIO_ReadInputDataBit (GPIO_TypeDef *GPIOx,GPIO_Pin_TypeDef GPIO_Pin) Reads the specified GPIO input data pin.
uint8_t GPIO_ReadOutputData (GPIO_TypeDef *GPIOx) Reads the specified GPIO output data port.
BitStatus GPIO_ReadOutputDataBit (GPIO_TypeDef *GPIOx,GPIO_Pin_TypeDef GPIO_Pin) Reads the specified GPIO Output data pin.
void GPIO_ResetBits (GPIO_TypeDef *GPIOx,uint8_t GPIO_Pin) Writes low level to the specified GPIO pins.
void GPIO_SetBits (GPIO_TypeDef *GPIOx,uint8_t GPIO_Pin) Writes high level to the specified GPIO pins.
void GPIO_ToggleBits (GPIO_TypeDef *GPIOx,uint8_t GPIO_Pin) Toggles the specified GPIO pins.
void GPIO_Write (GPIO_TypeDef *GPIOx,uint8_t GPIO_PortVal) Writes data to the specified GPIO data port.
void GPIO_WriteBit (GPIO_TypeDef *GPIOx,GPIO_Pin_TypeDef GPIO_Pin, BitAction GPIO_BitVal) Sets or clears the selected data port bit.
下面是GPIO操作的应用,GPIO写操作---板上的两个LED灯闪烁的代码
* @file Project/Template/main.c
* @author MCD Application Team
* @version V1.3.0
* @date 07/14/2010
* @brief Main program body
* @copy
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDIN THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
© COPYRIGHT 2010 STMicroelectronics
/* Includes ------------------------------------------------------------------*/
#include "stm8l15x.h"
/** @addtogroup Template
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* @brief Main program.
* @param None
* @retval None
/*discover_board MACROs for SET, RESET or TOGGLE Output port */
#define GPIO_HIGH(a,b) a->ODR|=b
#define GPIO_LOW(a,b) a->ODR&=~b
#define GPIO_TOGGLE(a,b) a->ODR^=b
#define BUTTON_GPIO_PORT GPIOC
#define USER_GPIO_PIN GPIO_Pin_1
#define LED_GREEN_PORT GPIOE
#define LED_GREEN_PIN GPIO_Pin_7
#define LED_BLUE_PORT GPIOC
#define LED_BLUE_PIN GPIO_Pin_7
#define CTN_GPIO_PORT GPIOC
#define CTN_CNTEN_GPIO_PIN GPIO_Pin_4
#define WAKEUP_GPIO_PORT GPIOE
#define ICC_WAKEUP_GPIO_PIN GPIO_Pin_6
#define ICC_WAKEUP_EXTI_PIN EXTI_Pin_3
void Delay(__IO uint16_t nCount)
/* Decrement nCount value */
while (nCount != 0)
nCount--;
void main(void)
/* Infinite loop */
GPIO_Init(LED_GREEN_PORT, LED_GREEN_PIN, GPIO_Mode_Out_PP_Low_Fast);
GPIO_Init(LED_BLUE_PORT, LED_BLUE_PIN, GPIO_Mode_Out_PP_Low_Fast);
while (1)
GPIO_ToggleBits(LED_GREEN_PORT, LED_GREEN_PIN);
Delay(0xFFFF);
GPIO_ToggleBits(LED_BLUE_PORT, LED_BLUE_PIN);
Delay(0xFFFF);
* @brief Inserts a delay time.
* @param nCount: specifies the delay time length.
* @retval None
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %drn", file, line) */
/* Infinite loop */
while (1)
#endif
/******************* (C) COPYRIGHT 2010 STMicroelectronics *****END OF FILE****/
单片机I/O口控制24伏的继电器 我现在想设计一个用单片机口控制24伏的继电器的通断,我开始试着用三极管驱动(下面有我的三极管驱动电路在继电器我加了个二极管保护三极管没画出来),我查了资料知道我怕下面的电路驱动不了,然后我想用ULN2003驱动, ...… 查看全部问答> |
我知道可以通过.bib文件将快捷方式直接加进NK 然后.dat文件通过例如如下的语句,将快捷方式建立到桌面上,这样建立的快捷方式不会掉电丢失 Directory(\"\\Windows\\LOC_DESKTOP_DIR\"):-File(\"英语.lnk\",\"\\Windows\\CEnglishExp.lnk\") 不过 ...… 查看全部问答> |
TFT屏驱动芯片HX8238的驱动问题,请进来看看,多谢了! 采用的屏是比亚迪的3.5寸TFT屏,下面是TFT屏驱动芯片HX8238的资料: HX8238的时序图 HX8238的时序要求 S3C2440的LCD时序图 我的LCD控制器设置如下: CLKVAL = 6; //因为我用的是FCLK=400MHz HCLK=100MHz PCLK=50MHz的配置 ...… 查看全部问答> |
