今天是:2025年02月07日(星期五)
2020年02月07日 | 基于STM32单片机对HCSR04超声波的控制
2020-02-07 来源:elecfans
注意:定义GPIOB2为超声输出;GPIOB10为输入,定时器用tim2
#include “HCSR04.h”
#include “delay.h”
#include “sys.h”
int overcount;
float length=0;
void HCSR04_init()
GPIO_InitTypeDef GPIO_InitStructure;
TIM_TImeBaseInitTypeDef TIM_TImeBaseInitStructer;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB , ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
TIM_DeInit(TIM2);
TIM_TimeBaseInitStructer.TIM_Period=4999;
TIM_TimeBaseInitStructer.TIM_Prescaler=7199;
TIM_TimeBaseInitStructer.TIM_ClockDivision=TIM_CKD_DIV1;
TIM_TimeBaseInitStructer.TIM_CounterMode=TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2,&TIM_TimeBaseInitStructer);
TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
TIM_ITConfig(
TIM2,
TIM_IT_Update |
TIM_IT_Trigger,
ENABLE
TIM_ClearFlag(TIM2,TIM_FLAG_Update);
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
TIM_Cmd(TIM2,DISABLE);
float HCSR04_Read()
float sum=0,length1=0;
u8 i=0,j=0;
u16 tim;
// while(i!=5)
for(i=0;i《5;i++)
PBout(2)=1;
delay_us(20);
PBout(2)=0;
while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_10)==RESET);
TIM_SetCounter(TIM2,0);
TIM_Cmd(TIM2,ENABLE);
while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_10)==SET);
tim=TIM2-》CNT;
length1=tim/58.0*100;
TIM2-》CNT=0;
sum+=length1;
length=sum/5;
sum=0;
return length;
///////////////////////////////////////////////////.h文件//////////////////////////////////////////////////////////////////
#include “stm32f10x_lib.h”
#define PBout(n) BIT_ADDR(GPIOB_ODR_Addr,n) //ê?3?
#define PBin(n) BIT_ADDR(GPIOB_IDR_Addr,n) //ê?è?
extern float HCSR04_Read();
extern void HCSR04_init();
//extern void HC_RS04_Init();
1. Warning 280:’i’:unreferenced local variable 说明 局部变量 i 在函数中未作任何的存取操作 解决方法 消除函数中 i变量的宣告 2 Warning 206:’Music3’:missing function-prototype 说明 Music3( )函数未作宣告 或未作外部宣告 ...… 查看全部问答> |
最近调试u-boot 下 lcd显示,由于原配的lcd为320*240的TFT,现在我要改为640*480,修改参数后发现显示是稳定的,但是显示3块错开的相同的内容(分别在屏幕的上中下的位置),不知是什么原因。有人碰到过吗;请问是什么原因呢?… 查看全部问答> |
按照PB帮助文档作的BLDR,NK.bin也可以通过网络或者在终端运行,PB是5.0的版本. 以下是错误信息: Microsoft Windows CE BIOS Bootloader Version 2.2 (Built Mar 13 2004) WARNING: code=0x7. WARNING: code=0x13. WARNING: code=0x7. WARNING: ...… 查看全部问答> |
我现在程序启动定时器,定时器到达后进入待机模式,主程序在循环将一个LED闪烁。发现进入待机模式后,LED灯是亮的不再闪烁了,功耗确实降了下来。我是IO口接LED接R接地,设置的推挽方式。进入待机模式发现IO还是3.3V的高电平,而不是高阻状态 ...… 查看全部问答> |
一、引言 Linux本身为分时操作系统,其系统目标为较好的平均响应时间和较高的吞吐量,而实时系统则主要考虑任务的按时完成、尽量减少进程运行的不可预测性等。但与商业嵌入式操作系统相比Linux遵循GPL,具有源代码开放、定制方便、支持广泛的计算 ...… 查看全部问答> |
1/1.I/O, ASDO 在AS 模式下是专用输出脚,在PS 和JTAG 模式下可以当I/O 脚来用。在AS 模式下,这个脚是CII 向串行配置芯片发送控制信号的脚。也是用来从配置芯片中读配置数据的脚。在AS 模式下,ASDO 有一个内部的上拉电阻,一直有效,配置完成后 ...… 查看全部问答> |
