今天是:2025年04月25日(星期五)
2020年04月25日 | 《韦东山视频第二期》——LCD驱动
2020-04-25 来源:eefocus
一、LCD驱动程序框架分析
app: open("/dev/fb0", ...) 主设备号:29, 次设备号:0
kernel:(核心文件/drivers/video/fbmem.c)
fb_open
int fbidx = iminor(inode);
struct fb_info *info;
info = registered_fb[fbidx]; //根据次设备号获得从底层注册的struct fb_info结构体中
file->private_data = info;
if (info->fbops->fb_open) { //调用底层struct fb_info结构体中的fb_open函数
res = info->fbops->fb_open(info,1);
if (res)
module_put(info->fbops->owner);
app: read()
_____________________________________________________________________________________
kernel:
fb_read
struct inode *inode = file->f_path.dentry->d_inode;
struct fb_info *info = registered_fb[fbidx];
if (info->fbops->fb_read)
return info->fbops->fb_read(info, buf, count, ppos);
src = (u32 __iomem *) (info->screen_base + p);
dst = buffer;
*dst++ = fb_readl(src++);
copy_to_user(buf, buffer, c)
怎么写LCD驱动程序?
1.分配一个fb_info结构体:framebuffer_alloc()
2.设置
3.注册:register_framebuffer
4.硬件相关的操作
#include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include struct lcd_regs { unsigned long lcdcon1; unsigned long lcdcon2; unsigned long lcdcon3; unsigned long lcdcon4; unsigned long lcdcon5; unsigned long lcdsaddr1; unsigned long lcdsaddr2; unsigned long lcdsaddr3; unsigned long redlut; unsigned long greenlut; unsigned long bluelut; unsigned long reserved[9]; unsigned long dithmode; unsigned long tpal; unsigned long lcdintpnd; unsigned long lcdsrcpnd; unsigned long lcdintmsk; unsigned long lpcsel; }; static struct fb_ops* s3c_lcdfb_ops = { .owner = THIS_MODULE, // .fb_setcplreg = atmel_lcdfb_setolreg, .fb_fillrect = cfb_fillrect, .fb_copyarea = cfb_copyarea, .fb_imageblit = cfb_imageblit, }; static struct fb_info* s3c_lcd; static volatile unsigned long *gpbcon; static volatile unsigned long *gpbdat; static volatile unsigned long *gpccon; static volatile unsigned long *gpdcon; static volatile unsigned long *gpgcon; static volatile struct lcd_regs* lcd_regs; static u32 pseudo_palette[16]; //为了兼容,设置假的调色板 /* from pxafb.c */ static inline unsigned int chan_to_field(unsigned int chan, struct fb_bitfield *bf) { chan &= 0xffff; chan >>= 16 - bf->length; return chan << bf->offset; } static int s3c_lcdfb_setcolreg(unsigned int regno, unsigned int red, unsigned int green, unsigned int blue, unsigned int transp, struct fb_info *info) { unsigned int val; if (regno > 16) return 1; /* 用red,green,blue三原色构造出val */ val = chan_to_field(red, &info->var.red); val |= chan_to_field(green, &info->var.green); val |= chan_to_field(blue, &info->var.blue); //((u32 *)(info->pseudo_palette))[regno] = val; pseudo_palette[regno] = val; return 0; } static int lcd_init(void) { /* 1. 分配一个fb_info结构体 */ s3c_lcd = framebuffer_alloc(0, NULL); /* 2. 设置 */ /* 2.1 设置固定的参数 */ strcpy(s3c_lcd->fix.id, "mylcd"); s3c_lcd->fix.smem_len = 320*240*32/8; /* MINI2440的LCD位宽是24,但是2440里会分配4字节即32位(浪费1字节) */ s3c_lcd->fix.type = FB_TYPE_PACKED_PIXELS; s3c_lcd->fix.visual = FB_VISUAL_TRUECOLOR; /* 真彩色 */ s3c_lcd->fix.line_length = 320 * 4; /* 1行的字节数 */ /* 2.2 设置可变的参数 */ s3c_lcd->var.xres = 320; s3c_lcd->var.yres = 240; s3c_lcd->var.xres_virtual = 320; s3c_lcd->var.yres_virtual = 240; s3c_lcd->var.bits_per_pixel = 32; /* 每个像素所占的位数 */ /* RGB: 565 */ s3c_lcd->var.red.offset = 16; s3c_lcd->var.red.length = 8; s3c_lcd->var.green.offset = 8; s3c_lcd->var.green.length = 8; s3c_lcd->var.blue.offset = 0; s3c_lcd->var.blue.length = 0; s3c_lcd->var.activate = FB_ACTIVATE_NOW; /* 2.3 设置操作函数 */ s3c_lcd->fops = &s3c_lcdfb_ops; /* 2.4 其他设置 */ //s3c_lcd->pseudo_palette =; // //s3c_lcd->screen_base = ; /* 显存的虚拟地址 */ s3c_lcd->screen_size = 320*240*32/8; /* 3. 硬件相关的操作 */ /* 3.1 配置GPIO用于LCD */ gpbcon = ioremap(0x56000010, 8); gpbdat = gpbcon+1; gpccon = ioremap(0x56000020, 4); gpdcon = ioremap(0x56000030, 4); gpgcon = ioremap(0x56000060, 4); *gpccon = 0xaaaaaaaa; /* GPIO管脚用于VD[7:0],LCDVF[2:0],VM,VFRAME,VLINE,VCLK,LEND */ *gpdcon = 0xaaaaaaaa; /* GPIO管脚用于VD[23:8] */ // *gpbcon &= ~(3); /* GPB0设置为输出引脚 */ // *gpbcon |= 1; // *gpbdat &= ~1; /* 输出低电平 */ *gpgcon |= (3<<8); /* GPG4用作LCD_PWREN */ /* 3.2 根据LCD手册设置LCD控制器,比如VCLK的频率等 */ lcd_regs = ioremap(0x4D000000, sizeof(struct lcd_regs)); /* * MINI2440 LCD 3.5英寸 ZQ3506_V0 SPEC.pdf 第11、12页 * * LCD手册11,12页和2440手册"Figure 15-6. TFT LCD Timing Example"一对比就知道参数含义了 */ /* bit[17:8]: VCLK = HCLK / [(CLKVAL+1) x 2], LCD手册11 (Dclk=6.4MHz~11MHz) * 7.1MHz = 100MHz / [(CLKVAL+1) x 2] * CLKVAL = 6 * bit[6:5]: 0b11, TFT LCD * bit[4:1]: 0b1101, 24 bpp for TFT * bit[0] : 0 = Disable the video output and the LCD control signal. */ lcd_regs->lcdcon1 = (6<<8) | (3<<5) | (0x0d<<1); /* 垂直方向的时间参数 * 根据数据手册 * bit[31:24]: VBPD, VSYNC之后再过多长时间才能发出第1行数据
我想做一个方波到三角波的信号发生器,但在从方波到三角波的过程中。如果从周期NT开始转换刚输出都是正的。如果从T/2开始转换则输出的是正负对称的波形。我现在想要一个正负对称的波形。但是怎么样才能保证一定会是正负对称的呢。望高人指教一下!… 查看全部问答> |
LM的官方网站发布了新的手册,新版本的LM3S芯片引脚能够承受5V电压。 什么时间生产的芯片才算新版本的呢?B版本或以上就可承受5VLM3S单片机B版本或以上的IO口就可承受5V。版本号在单片机的第二行文字内,如B版本为“1RN20B4X”中的B,C版本为“1RN20C0X”中的C。… 查看全部问答> |
上次发的帖子,大家可能以为我放弃了或者已经不在弄了~~~~~ 非常感谢大家的帮助~~~因为一直很忙也没结贴~~感谢googleman ,咸蛋超人,and wangxin_801115,还有其他进来回帖的大家~~~ 呵呵~~~但是现在还没弄出来啊~~~中断还是进不了,但是比之前有 ...… 查看全部问答> |
前面问题详见:http://blog.ednchina.com/huoyumutou/解决问题的办法主要是通过改CY68013A的固件来完成的,在CYPRESS/USB/Applicatoin目录下会有个例子叫SlaveFIFO,但是这个例子是异步传输,可以通过以下几个改动来实现同步传输。1. 对照寄存器表 ...… 查看全部问答> |
本人学生,学习单片机有2.3月了,有下面俩问题: 1、单片机应用广不广泛 2、出去后能不能在工作中应用 本人学习51的,用的是MedWinV3.0来编程的,期望大家回答下我的问题… 查看全部问答> |
allegro pcb中画封装时以芯片第一脚为坐标原点还是芯片物理中心为坐标原点? 1.两者在贴片时有什么区别? 2.能不能在同一块PCB板上使用这两种不同方式的封装? 3.是否可以很方便地互改(坐标原点在封装画成后改动)?… 查看全部问答> |
目前demo 板上已经移植好了 QP, LWIP, UIP, UCGUI 以及用串口中断接收的两个中断下半部模型例子。 demo 板同时支持mini 2440 和tq 2440 的开发板。… 查看全部问答> |
本帖最后由 paulhyde 于 2014-9-15 03:23 编辑 今年D题基础和发挥有个题目条件是有同学总是纠结于这个条件,要做高通滤波之类的,其实我认为不要做什么滤波,可以说是画蛇添足,下限频率小于0.3MHZ,表示要比这个值小,小到多少?0当然最好了,也 ...… 查看全部问答> |
