今天是:2025年01月14日(星期二)
2021年01月14日 | MSP430F249 IIC write and Uart send
2021-01-14 来源:eefocus
#include
//注意:两次发送间隔必须要有延时,否则不能再次发送,串口发送格式:
unsigned char PTxData[250]; // Pointer to TX data
unsigned char pHead;
unsigned char pTail;
unsigned char TXByteCtr;
const unsigned char TxData[] = // Table of data to transmit
0x01,
0x02,
0x03,
0x04,
0x05
void UartInit(void)
if (CALBC1_1MHZ==0xFF) // If calibration constant erased
while(1); // do not load, trap CPU!!
DCOCTL = 0; // Select lowest DCOx and MODx settings
BCSCTL1 = CALBC1_1MHZ; // Set DCO
DCOCTL = CALDCO_1MHZ;
P3SEL |= 0x30; // P3.4,5 = USCI_A0 TXD/RXD
UCA0CTL1 |= UCSSEL_2; // SMCLK
UCA0BR0 = 104; // 1MHz 9600; (104)decimal = 0x068h
UCA0BR1 = 0; // 1MHz 9600
UCA0MCTL = UCBRS0; // Modulation UCBRSx = 1
UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
void UartSend( unsigned char Data )
UCA0TXBUF = Data; // TX -> RXed character
while (!(IFG2&UCA0TXIFG)); // USCI_A0 TX buffer ready?,发送缓冲区空
void IICInit(void)
UCB0CTL1 |= UCSWRST; // Enable SW reset
UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode
UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset
UCB0BR0 = 12; // fSCL = SMCLK/12 = ~100kHz
UCB0BR1 = 0;
UCB0I2CSA = 0xA0>>1; // Slave Address is ,注意地址需要右移一位,24C02地址为0XA0,故要写入0X50
// 7位地址模式,器件会发送一位读写位,正好8位。
UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation
IE2 |= UCB0TXIE; // Enable TX interrupt
void IICSend( void )
int i;
for(i=3000;i>0;i--); //两次发送间隔必须要有延时,否则不能再次发送
while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent
UCB0CTL1 |= UCTR + UCTXSTT; // I2C TX, start condition
__bis_SR_register(CPUOFF + GIE); // Enter LPM0 w/ interrupts
int main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
P3SEL |= 0x06; // Assign I2C pins to USCI_B0
IICInit();
UartInit();
while (1)
UartSend('A');
PTxData[0] = 0;
PTxData[1] = 2;
PTxData[2] = 3;
PTxData[3] = 4;
PTxData[4] = 5;
pTail = 5;
IICSend();
PTxData[0] = 0X10;
PTxData[1] = 2;
PTxData[2] = 3;
PTxData[3] = 4;
PTxData[4] = 5;
pTail = 5;
IICSend();
PTxData[0] = 0x20;
PTxData[1] = 2;
PTxData[2] = 3;
PTxData[3] = 4;
PTxData[4] = 5;
pTail = 5;
IICSend();
PTxData[0] = 0X30;
PTxData[1] = 2;
PTxData[2] = 3;
PTxData[3] = 4;
PTxData[4] = 5;
pTail = 5;
IICSend();
while(1);
// The USCIAB0TX_ISR is structured such that it can be used to transmit any
// number of bytes by pre-loading TXByteCtr with the byte count. Also, TXData
// points to the next byte to transmit.
#pragma vector = USCIAB0TX_VECTOR
__interrupt void USCIAB0TX_ISR(void)
if ( pHead < pTail ) // Check TX byte counter
UCB0TXBUF = PTxData [pHead++ ]; // Load TX buffer
else
pHead = 0;
UCB0CTL1 |= UCTXSTP; // I2C stop condition
IFG2 &= ~UCB0TXIFG; // Clear USCI_B0 TX int flag
__bic_SR_register_on_exit(CPUOFF); // Exit LPM0
在我对U盘做过滤的时候,得到当我在访问U盘的时候, 用到的是SCSIOP_READ命令,也就是说我是通过他来 访问U盘的,但是我U盘是通过什么方式或者说是哪个 命令把我要访问的内容返回给我的呀.??? 请大家给解释一下.^_^… 查看全部问答> |
紧急招聘DSP人才(欢迎来电咨询15812809535曹先生) 工作地点:广州 招聘通讯行业DSP工程师, 任职要求:本科或硕士研究生,电子、通信、信号处理、计算机或相关专业,2年以上相关工作经验; 熟悉通信信号处理常用算法和理论基础; &n ...… 查看全部问答> |
一直以来都想写点什么,关于 FPGA 设计,因为有点不太服气。为什么同样是设计,有些人可以好像玩一样的摆弄,photoshop,很时尚,很跩。有些人可以用所谓的广告创意玩弄人们的智商。而硬件工程师则一律的被人以为呆板没有创意。我是说,为什么我们 ...… 查看全部问答> |
#include <msp430x14x.h>#define keyin (P3IN&BIT4)void led_flash(void);char key(void){ if(keyin==0) return 1; else return 0; }void main(void){ &nb ...… 查看全部问答> |
转 三菱的电池问题,算是告一段落了,在这里总结一下这次的事情。 1.事件的开端 Mitsubishi reports fire in i-MiEV battery pack, melting in Outlander PHEV pack Mitsubishi Motors reported two separate incidents with ...… 查看全部问答> |
在飞凌S5PV210开发板上移植U-Boot 的过程主要包括以下四个步骤:1.下载U-Boot源码2.修改相应的文件代码 3.编译U-Boot4.烧写到开发板上,运行U-Boot是universal bootloader,也就是通用的bootloader。它存在于nandflash或者SD卡中,它是在开机上点 ...… 查看全部问答> |
