今天是:2024年10月15日(星期二)
2021年10月15日 | stm32专题五:时钟树(二)系统配置时钟函数分析
2021-10-15 来源:eefocus
分析stm32的系统时钟函数,对于我们实现自定义时钟配置非常重要,以下是标准库函数中的时钟配置函数。
static void SetSysClockTo72(void)
__IO uint32_t StartUpCounter = 0, HSEStatus = 0;
/* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
/* Enable HSE */
// 使能HSE
RCC->CR |= ((uint32_t)RCC_CR_HSEON);
/* Wait till HSE is ready and if Time out is reached exit */
// 等待HSE就绪并做超时处理
do
HSEStatus = RCC->CR & RCC_CR_HSERDY;
StartUpCounter++;
} while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
/* 分析:当不超过超时时间时,后面这部分一直为1;因此,只要HSERDY了,立马跳出循环
如果HSE故障,则会一直等到设定的超时时间,然后跳出 */
// 上面只是跳出循环,这里判断HSE是否真正启动成功
if ((RCC->CR & RCC_CR_HSERDY) != RESET)
HSEStatus = (uint32_t)0x01;
else
HSEStatus = (uint32_t)0x00;
// HSE启动成功,程序继续往下执行
if (HSEStatus == (uint32_t)0x01)
/* Enable Prefetch Buffer */
// 使能预取指,CPU运行过程:取指令-执行指令-取指令-执行指令
// 预取指类似于8086的指令队列,会取出当前和接下来要执行的多条指令,送入指令队列缓冲
FLASH->ACR |= FLASH_ACR_PRFTBE;
/* Flash 2 wait state */
/* CPU从Flash取指令的时间间隔,72MHz时要等待两个时钟周期
等待的原因时,flash运行速度慢,CPU如果一直等待flash就绪,则会浪费很多时间效率低下
因此等待两个时钟周期,待flash就绪然后读取指令到预取指缓存 */
FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
// 配置AHB APB1 APB2总线的分频因子
/* HCLK = SYSCLK = 72M*/
RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
/* PCLK2 = HCLK = 72M */
RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
/* PCLK1 = HCLK = 36M */
RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
/* PLL configuration: PLLCLK = HSE * 9 = 72 MHz */
// 配置锁相环输入为HSE不分频
RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
RCC_CFGR_PLLMULL));
// 配置PLL倍频因子为9
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);
/* Enable PLL */
// 使能PLL锁相环
RCC->CR |= RCC_CR_PLLON;
/* Wait till PLL is ready */
// 等待锁相环准备就绪
while((RCC->CR & RCC_CR_PLLRDY) == 0)
/* Select PLL as system clock source */
// 选择PLLCLK作为系统时钟
RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
/* Wait till PLL is used as system clock source */
// 等待PLLCLK切换成功
while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
// 如果HSE启动失败,在这里填入错误处理代码
else
{ /* If HSE fails to start-up, the application will have wrong clock
configuration. User can add here some code to deal with this error */
上一篇:STM32时钟树解析
下一篇:STM32系统时钟树分析
FlexRay实现的初期功能是迈向全自动无人驾驶(或近乎全自动驾驶)的第一步。虽然最早的设想是实现汽车线控(X-by-wire)(线控驱动、线控驾驶等),然而其他发展趋势也在推动FlexRay技术的发展和应用。主要表现在生产效率、安全法规要求愈来愈高,各种舒 ...… 查看全部问答> |
小弟论文涉及CMOS图像传感器的原理以及应用,哪位有开发过CMOS传感器经验的大哥指点一二!或是能够提供资料,感激不尽!此前,研究方向与此无关,想尽快进入角色! 补充一下:是线阵CMOS传感器的.主要希望能够指点CMOS图像采集及数据处理的过程… 查看全部问答> |
ARMSYS2440随盘提供的“WINCE应用程序实例”加入了摄像头应用程序 谁有这个应用程序,能否提供给我。 我的邮箱:5iminimao@163.com… 查看全部问答> |
make -C /lib/modules/2.6.25-14.fc9.i686/build SUBDIRS=/opt/driver/RT73_Linux_STA_Drv1.0.4.0/Module modules make[1]: Entering directory `/usr/src/kernels/2.6.25-14.fc9.i686\' CC [M] /opt/driver/RT73_Linux_S ...… 查看全部问答> |
另: 1.深圳哪里有PB的盘买啊?在网上下不到啊! 2.我买了个mini2440玩,想练习写CE驱动,该怎么做?系统是买来的光盘中自带的,怎么将我的驱动加到系统中?怎么测试驱动啊? 谢谢各位!… 查看全部问答> |
三星的系列NandFlash有什么区别?K9F1G08/2G08/4G08/8G08.他们都是大块(2KB每页)的NAND FLASH?他们的驱动可以完全公用? 三星的系列NandFlash有什么区别?K9F1G08/K9F2G08/K9F4G08/K9F8G08.他们都是大块(2KB每页)的NAND FLASH?他们的驱动可以完全公用?还是不同芯片驱动要进行不同的修改?… 查看全部问答> |
请问大家,我在一秒钟之内检测到的下降沿次数就是频率对不对? 我将比较器的输出端接到P3^2口 程序如下 /******************中断函数***********************/void int0() interrupt 0{ count++; //每来个低电平进入中断,计 ...… 查看全部问答> |
1.什么是ADI DSP,有什么特点,有些什么型号? ADI公司的嵌入式处理器和DSP产品组合由Blackfin、SHARC、SigmaDSP、TigerSHARC、ADSP-21xx及模拟微控制器组成,提供高速、多DSP信号处理、融合信号/控制处理 ...… 查看全部问答> |
