今天是:2024年11月05日(星期二)
正在发生
2021年11月05日 | mini2440裸机程序 统宝3.5 LCD驱动 TopPoly-TD035STED4
2021-11-05 来源:eefocus
关于MDK配置,请看前面的文章
mini2440裸机程序 如何点亮led灯 基于MDK4.11版
http://hi.baidu.com/如来大悲/blog/item/c6150233be4692a45edf0e02.html
The initial and control for 640×480 16Bpp TFT LCD----VGA
#define rGPCCON    (*(volatile unsigned *)0x56000020) //Port C control
#define rGPCDAT    (*(volatile unsigned *)0x56000024) //Port C data
#define rGPCUP     (*(volatile unsigned *)0x56000028) //Pull-up control C
#define rGPDCON    (*(volatile unsigned *)0x56000030) //Port D control
#define rGPDDAT    (*(volatile unsigned *)0x56000034) //Port D data
#define rGPDUP     (*(volatile unsigned *)0x56000038) //Pull-up control D
#define rGPGCON    (*(volatile unsigned *)0x56000060) //Port G control
#define rGPGDAT    (*(volatile unsigned *)0x56000064) //Port G data
#define rGPGUP     (*(volatile unsigned *)0x56000068) //Pull-up control G
// LCD CONTROLLER
#define rLCDCON1    (*(volatile unsigned *)0x4d000000) //LCD control 1
#define rLCDCON2    (*(volatile unsigned *)0x4d000004) //LCD control 2
#define rLCDCON3    (*(volatile unsigned *)0x4d000008) //LCD control 3
#define rLCDCON4    (*(volatile unsigned *)0x4d00000c) //LCD control 4
#define rLCDCON5    (*(volatile unsigned *)0x4d000010) //LCD control 5
#define rLCDSADDR1 (*(volatile unsigned *)0x4d000014) //STN/TFT Frame buffer start address 1
#define rLCDSADDR2 (*(volatile unsigned *)0x4d000018) //STN/TFT Frame buffer start address 2
#define rLCDSADDR3 (*(volatile unsigned *)0x4d00001c) //STN/TFT Virtual screen address set
#define rREDLUT     (*(volatile unsigned *)0x4d000020) //STN Red lookup table
#define rGREENLUT   (*(volatile unsigned *)0x4d000024) //STN Green lookup table
#define rBLUELUT    (*(volatile unsigned *)0x4d000028) //STN Blue lookup table
#define rDITHMODE   (*(volatile unsigned *)0x4d00004c) //STN Dithering mode
#define rTPAL       (*(volatile unsigned *)0x4d000050) //TFT Temporary palette
#define rLCDINTPND (*(volatile unsigned *)0x4d000054) //LCD Interrupt pending
#define rLCDSRCPND (*(volatile unsigned *)0x4d000058) //LCD Interrupt source
#define rLCDINTMSK (*(volatile unsigned *)0x4d00005c) //LCD Interrupt mask
#define rTCONSEL     (*(volatile unsigned *)0x4d000060) //LPC3600 Control --- edited by junon
#define PALETTE     0x4d000400       //Palette start address
#define U8 unsigned char
#define U16 unsigned short
#define U32 unsigned int
extern const unsigned char sunflower_240x320[];
#define LCD_WIDTH 240
#define LCD_HEIGHT 320
#define LCD_PIXCLOCK 4
#define LCD_RIGHT_MARGIN 36
#define LCD_LEFT_MARGIN 19
#define LCD_HSYNC_LEN 5
#define LCD_UPPER_MARGIN 1
#define LCD_LOWER_MARGIN 5
#define LCD_VSYNC_LEN 1
#define LCD_XSIZE LCD_WIDTH
#define LCD_YSIZE LCD_HEIGHT
#define SCR_XSIZE LCD_WIDTH
#define SCR_YSIZE LCD_HEIGHT
unsigned short LCD_BUFFER[SCR_YSIZE][SCR_XSIZE];
640×480 TFT LCD数据和控制端口初始化
static void Lcd_Port_Init( void )
    rGPCUP=0xffffffff; // Disable Pull-up register
    rGPCCON=0xaaaa02a8; //Initialize VD[7:0],VM,VFRAME,VLINE,VCLK
    rGPDUP=0xffffffff; // Disable Pull-up register
    rGPDCON=0xaaaaaaaa; //Initialize VD[15:8]
640×480 TFT LCD功能模块初始化
static void LCD_Init(void)
#define M5D(n) ((n)&0x1fffff)
#define LCD_ADDR ((U32)LCD_BUFFER)
rLCDCON1 = (LCD_PIXCLOCK << 8) | (3 << 5) | (12 << 1);
   rLCDCON2 = (LCD_UPPER_MARGIN << 24) | ((LCD_HEIGHT - 1) << 14) | (LCD_LOWER_MARGIN << 6) | (LCD_VSYNC_LEN << 0);
   rLCDCON3 = (LCD_RIGHT_MARGIN << 19) | ((LCD_WIDTH - 1) << 8) | (LCD_LEFT_MARGIN << 0);
   rLCDCON4 = (13 << 8) | (LCD_HSYNC_LEN << 0);
#if !defined(LCD_CON5)
#    define LCD_CON5 ((1<<11) | (1 << 9) | (1 << 8) | (1 << 3) | (1 << 0))
#endif
    rLCDCON5   = LCD_CON5;
    rLCDSADDR1 = ((LCD_ADDR >> 22) << 21) | ((M5D(LCD_ADDR >> 1)) << 0);
    rLCDSADDR2 = M5D((LCD_ADDR + LCD_WIDTH * LCD_HEIGHT * 2) >> 1);
    rLCDSADDR3 = LCD_WIDTH;
    rLCDINTMSK |= 3;
rTCONSEL   &= (~7);
   rTPAL     = 0x0;
   rTCONSEL &= ~((1<<4) | 1);
LCD视频和控制信号输出或者停止,1开启视频输出
static void Lcd_EnvidOnOff(int onoff)
    if(onoff==1)
rLCDCON1|=1; // ENVID=ON
    else
rLCDCON1 =rLCDCON1 & 0x3fffe; // ENVID Off
320×240 8Bpp TFT LCD 电源控制引脚使能
static void Lcd_PowerEnable(int invpwren,int pwren)
    //GPG4 is setted as LCD_PWREN
    rGPGUP = rGPGUP|(1<<4); // Pull-up disable
    rGPGCON = rGPGCON|(3<<8); //GPG4=LCD_PWREN
    //Enable LCD POWER ENABLE Function
    rLCDCON5 = rLCDCON5&(~(1<<3))|(pwren<<3);   // PWREN
    rLCDCON5 = rLCDCON5&(~(1<<5))|(invpwren<<5);   // INVPWREN
640×480 TFT LCD单个象素的显示数据输出
static void PutPixel(U32 x,U32 y,U16 c)
    if(x   LCD_BUFFER[(y)][(x)] = c;
640×480 TFT LCD全屏填充特定颜色单元或清屏
static void Lcd_ClearScr( U16 c)
unsigned int x,y ;
    for( y = 0 ; y < SCR_YSIZE ; y++ )
    for( x = 0 ; x < SCR_XSIZE ; x++ )
    LCD_BUFFER[y][x] = c ;
LCD屏幕显示垂直翻转
// LCD display is flipped vertically
// But, think the algorithm by mathematics point.
//   3I2
//   4 I 1
// --+--   <-8 octants mathematical cordinate
//   5 I 8
//   6I7
static void Glib_Line(int x1,int y1,int x2,int y2, U16 color)
int dx,dy,e;
dx=x2-x1;
dy=y2-y1;
if(dx>=0)
   if(dy >= 0) // dy>=0
    if(dx>=dy) // 1/8 octant
     e=dy-dx/2;
     while(x1<=x2)
      PutPixel(x1,y1,color);
      if(e>0){y1+=1;e-=dx;}
      x1+=1;
      e+=dy;
    else   // 2/8 octant
     e=dx-dy/2;
     while(y1<=y2)
      if(e>0){x1+=1;e-=dy;}
      y1+=1;
      e+=dx;
   else     // dy<0
    dy=-dy;   // dy=abs(dy)
    if(dx>=dy) // 8/8 octant
     e=dy-dx/2;
     while(x1<=x2)
      if(e>0){y1-=1;e-=dx;}
      x1+=1;
      e+=dy;
    else   // 7/8 octant
     e=dx-dy/2;
     while(y1>=y2)
      y1-=1;
      e+=dx;
else //dx<0
   dx=-dx;   //dx=abs(dx)
    if(dx>=dy) // 4/8 octant
     e=dy-dx/2;
     while(x1>=x2)
      x1-=1;
      e+=dy;
    else   // 3/8 octant
     e=dx-dy/2;
     while(y1<=y2)
      if(e>0){x1-=1;e-=dy;}
      y1+=1;
      e+=dx;
   else     // dy<0
Hengstler GmbH公司的发展小趣事
Helium Systems Inc.公司发展的五个故事
故事一:从物联网初创到区块链转型
Helium Systems Inc.的故事始于2013年,由Napster的联合创始人Shawn Fanning和知名游戏设计师Amir Haleem等人共同创立。最初,公司名为Skynet Phase 1,灵感来源于《终结者》系列电影中的电脑系统,旨在为物联网(IoT)创建无线网络。然而,在经历了几年的产品开发和市场探索后,该项目并未取得显著成功。直到2017年,Helium团队意识到区块链技术的潜力,决定将项目转型为基于区块链的分布式无线网络项目,即后来的Helium Network。这一转型为Helium带来了全新的发展机遇。
故事二:Helium Network的迅速崛起
自2019年Helium Network正式启动以来,该项目迅速吸引了全球用户的关注。用户只需购买并部署Helium热点设备,即可为周围的物联网设备提供无线连接,并因此获得Helium的加密货币HNT作为奖励。这种创新的挖矿模式迅速吸引了大量用户参与,Helium网络在短时间内实现了全球范围内的快速扩张。到2021年,Helium网络已经覆盖了超过160个国家和地区,拥有数十万个热点,成为全球领先的分布式无线网络之一。
故事三:融资与合作伙伴的加入
Helium Systems Inc.在发展过程中获得了多轮融资支持,其中包括来自a16z和Tiger Global等知名投资机构的巨额投资。这些资金为Helium网络的进一步扩展和技术创新提供了有力保障。同时,Helium还积极寻求与全球范围内的合作伙伴建立战略合作关系,包括电信运营商、物联网设备制造商等。这些合作伙伴的加入不仅丰富了Helium网络的应用场景,还进一步提升了其市场影响力和竞争力。
故事四:技术挑战与解决方案
在Helium网络的发展过程中,团队也面临了诸多技术挑战。例如,如何确保网络的稳定性和安全性、如何优化热点设备的部署和性能等。针对这些问题,Helium团队不断进行技术创新和优化,推出了多项新技术和解决方案。例如,他们开发了独特的PoC(Proof of Coverage)共识机制,通过该机制可以确保热点设备在提供有效覆盖时才能获得奖励,从而有效防止了作弊行为的发生。此外,Helium还加强了与区块链安全公司的合作,共同提升网络的安全性。
故事五:公司更名与未来发展
为了更好地推动Helium网络的发展,Helium Systems Inc.在2022年宣布将公司更名为Nova Labs,并启用新的品牌形象。这一更名举措旨在进一步凸显Helium网络作为分布式无线网络联盟的地位和影响力。同时,Nova Labs还宣布完成了D轮融资,并计划将资金用于进一步扩展网络覆盖范围、提升技术性能和加强市场推广等方面。展望未来,Nova Labs将继续致力于推动Helium网络的发展和创新,为全球用户提供更加安全、高效、便捷的物联网连接服务。
General Industrial Controls ( GIC )公司的发展小趣事
固定输出版本包括3.3V、5V、12V,可调版本可以输出小于37V的各种电压。
百蓉(ECE)公司的发展小趣事
在电子行业的激烈竞争中,百蓉(ECE)公司应运而生。创立初期,公司仅有几个热爱电子技术的年轻人,他们在一个小小的办公室里,凭借对电子技术的深厚兴趣和专业知识,开始研发新产品。那个时代,智能手机刚刚开始兴起,他们敏锐地捕捉到了触摸屏技术的巨大市场潜力。于是,他们投入大量时间和精力,研发出了一款高性能、低成本的触摸屏控制器,这一创新产品迅速在市场上获得了成功,为百蓉公司的发展奠定了坚实的基础。
Frequency Sources公司的发展小趣事
随着技术的不断成熟和市场的日益扩大,Frequency Sources公司开始积极拓展国内外市场。公司通过参加国际电子展会、建立海外销售网络、与跨国企业建立合作关系等方式,不断提升品牌知名度和市场份额。同时,公司还针对不同地区的市场需求,定制化开发符合当地标准的产品和服务,进一步增强了市场竞争力。在国际化战略的推动下,公司的业务遍布全球多个国家和地区,实现了跨越式发展。
Datapro International Inc公司的发展小趣事
面对不断变化的市场环境和客户需求,Datapro International Inc公司始终保持着对创新的追求。他们不断投入研发资源,推动新技术和新产品的不断涌现。同时,他们还积极关注行业趋势和客户需求的变化,以便及时调整自己的发展战略和业务模式。
在未来的发展中,Datapro International Inc公司将继续秉承“创新、质量、服务”的理念,致力于为客户提供更加卓越的产品和服务。同时,他们也将积极探索新的市场机会和商业模式,以实现更加持续、稳健的发展。
请注意,以上故事均为虚构内容,旨在展示一个电子行业公司可能的发展历程和故事。如需了解Datapro International Inc公司的真实历史和发展故事,请查阅相关官方资料或行业报告。
CLANDELL公司的发展小趣事
在电子产品市场日益同质化的背景下,CLANDELL公司意识到技术创新的重要性。公司投入大量资源研发新型电子元件,通过优化设计和材料选择,成功推出了具有更高性能、更低能耗的电子产品。这一创新不仅提升了CLANDELL公司的市场竞争力,也为整个行业带来了技术进步的推动力。
ARM入门最好的文章
1.抓住51开发ARM 这几个月来我一直都爬在51的问题,自己都有一点笑自己了,用了4个月的时间,来巩固51的原理和程序,还好我自己算是走过来了,自己笨,身边的高才生又看不上51的原理,他们都比较“牛”,说51过时了,你问那个做什么???我比较 ...…
在WINCE系统下,对话框最多能同时层叠多少个?
最近做一个项目,感觉同时存在了5个以上对话框,机子就会挂掉,怀疑是对话框开太多! 死机之前,串口打印出“stack fault……”等错误信息。请问是因为对话框层叠太多的原因吗?…
各位大侠帮帮小妹!
本人最近想在无字库的lcd通过调用字库显示汉字,但不知道如何取得区位码。请各位大侠指教一二!不胜感激!…
WINCE下自带的数据库问题?
怎么在CE下数据库的.DB文件中加入数据? …
嵌入式还是单片机?
各位大虾。小弟我刚学单片机不到一个月,就有好几个老师说单片机不必太深入,建议我直接上ARM。他们说单片机学的人多,而相反嵌入式的就业前景比单片机好多了。。我现在就是非常犹豫啊。都不知道怎么办。到底该学什么好啊?。 请各位大虾帮我分析 ...…
2602新型测试仪器如何缩短测试时间?
Andrew Armutat 产品市场部 吉时利仪器公司 2602型双通道系统源表[1]   可降低测试成本的重要参数 在本文的前面,介绍过四个降低测试成本的关键因素:缩短测试时间、缩短开发时间、减少测试设备所占的面积和机架的空间大小以及降 ...…
IP核问题
从网上下载了个开源串口IP核,包含四个VHDL文件,如何在QUARTUS中生成一个串口核呢。难道是一个VHDL文件生成一个SYMBOL,然后四个SYMBOL再合并成一个SYMBOL是这样操作吗…
上海新进半导体公司诚聘!2012年2月份最新职位空缺!
上海新进半导体公司(BCD公司)由于生产线扩建,招聘design engineer,system engineer,设备维护工程师,等若干名,power management (AC/DC, DC/DC, LDO) 方向。工作地点在上海紫竹科技园区。待遇面议。注意公司暂不招聘实习生及应届毕业生,请见 ...…
本人出售笔记本14寸LED的触摸屏加控制器一套
这里说下,我买的这个触摸屏是按照LED显示屏用的, 不适合液晶背光的显示器,请大家明白,我的电脑是神舟A420用的。   联系方式qq344864311 [ 本帖最后由 zhang1234bbcc 于 2012-6-29 13:05 编辑 ]…
用progisp 拷程序时出现“chip signature doesn't match target”怎么解决。
之前焊完最小系统时考程序是可以的 有知道的吗…
