今天是:2025年10月13日(星期一)
2022年10月13日 | mini2440 简单touch screen驱动程序
2022-10-13 来源:csdn
模块加载后打印出水平和垂直方向的ad转换结果,没有做坐标的转换,只为学习一下touch screen接口的编程方法,代码记录如下:
#include #include #include #include #include #include #include #include #include #include #include #include #include #include #include static struct input_dev *ts_dev; //定时器用于处理长按和滑动 static struct ts_regs_t{ unsigned long adccon; unsigned long adctsc; unsigned long adcdly; unsigned long adcdat0; unsigned long adcdat1; unsigned long adcupdn; }; static volatile struct ts_regs_t *ts_regs; static volatile unsigned long *clkcon; static struct clk *adc_clk; static struct timer_list ts_timer; void enable_adc_clock(void){ (*clkcon) |= (1<<15); } void enter_wait4down_mode(void){ ts_regs->adctsc = 0xd3; //等待中断模式,检测触摸屏按下 } void enter_wait4up_mode(void){ ts_regs->adctsc = 0x1d3; //等待中断模式,检测触摸屏松开 } //进入测量xy坐标的工作模式 void enter_measure_xy_mode(void){ ts_regs->adctsc = (1<<3)|(1<<2); } //启动ac转换 void start_adc(void){ ts_regs->adccon |= (1<<0); } //adc中断处理函数 static irqreturn_t grh_handle_adc_irq(int irq, void *dev_id){ static int adc_count = 0; static int xv=0, yv=0; if(ts_regs->adcdat0 & (1<<15)){ enter_wait4down_mode(); adc_count = 0; xv = yv = 0; } else{ //多次取值取平均值 if(adc_count == 4){ printk(KERN_EMERG"count=%d x=%d y=%dr", adc_count, xv>>2, yv>>2); //上报事件 input_report_abs(ts_dev, ABS_X, xv>>2); input_report_abs(ts_dev, ABS_Y, yv>>2); input_report_abs(ts_dev, ABS_PRESSURE, 1); input_report_key(ts_dev, BTN_TOUCH, 1); input_sync(ts_dev); adc_count = 0; xv = yv = 0; enter_wait4up_mode(); mod_timer(&ts_timer, jiffies+HZ/100); //10ms } else{ adc_count ++; xv += (ts_regs->adcdat0)&0x3ff; yv += (ts_regs->adcdat1)&0x3ff; enter_measure_xy_mode(); start_adc(); } } return IRQ_HANDLED; } //tc中断处理函数 static irqreturn_t grh_handle_tc_irq(int irq, void *dev_id){ if(ts_regs->adcdat0 & (1<<15)){ //printk(KERN_EMERG"pen up!n"); enter_wait4down_mode(); } else{ //printk(KERN_EMERG"pen downn"); //enter_wait4up_mode(); enter_measure_xy_mode(); start_adc(); } return IRQ_HANDLED; } //定时器超时处理函数 static void grh_handle_timer_int(unsigned long num){ if(ts_regs->adcdat0 & (1<<15)){ //上报事件 input_report_abs(ts_dev, ABS_PRESSURE, 0); input_report_key(ts_dev, BTN_TOUCH, 0); input_sync(ts_dev); enter_wait4down_mode(); } else{ enter_measure_xy_mode(); start_adc(); } } static int ts_init(void){ ts_dev = input_allocate_device(); //设置能够产生哪些事件 set_bit(EV_KEY, ts_dev->evbit); set_bit(EV_ABS, ts_dev->evbit); set_bit(BTN_TOUCH, ts_dev->keybit); /*触摸屏按键事件*/ input_set_abs_params(ts_dev, ABS_X, 0, 0x3ff, 0, 0); /*设置绝对位移取值范围*/ input_set_abs_params(ts_dev, ABS_Y, 0, 0x3ff, 0, 0); /*设置绝对位移取值范围*/ input_set_abs_params(ts_dev, ABS_PRESSURE, 0, 1, 0, 0); /*设置压力的取值范围,只有0和1*/ /*注册*/ input_register_device(ts_dev); //ioremap ts_regs = ioremap(0x58000000, sizeof(struct ts_regs_t)); clkcon = ioremap(0x4C00000C, 4); //使能时钟,使得adc可以正常工作 adc_clk = clk_get(NULL, "adc"); if (!adc_clk) { printk(KERN_ERR "failed to get adc clock sourcen"); return -ENOENT; } clk_enable(adc_clk); /* bit[14] PRESCEN=1 使能预分频 bit[13:6] PRESCVL=49 预分频数值为49(pclk=50.625M) adcclk = 50.625M/50=1.0125MHz bit[2] STDBM=0 不进入等待模式 bit[1] READ_START=0 bit[0] ENABLE_START=0 */ ts_regs->adccon = (1<<14)|(49<<6); ts_regs->adcdly = 0xffff; //设定延时,保证数据的准确性 //注册中断 if( request_irq(IRQ_TC, grh_handle_tc_irq, IRQF_SAMPLE_RANDOM, "irq_tc", ts_dev) ){ printk(KERN_EMERG"allocate IRQ_TC error!n"); return -EIO; } if( request_irq(IRQ_ADC, grh_handle_adc_irq, IRQF_SHARED|IRQF_SAMPLE_RANDOM, "irq_adc", ts_dev) ){ printk(KERN_EMERG"allocate IRQ_ADC error!n"); return -EIO; } init_timer(&ts_timer); ts_timer.function = grh_handle_timer_int; add_timer(&ts_timer); enter_wait4down_mode();//等待中断模式,检测触摸屏按下 return 0; } static void ts_exit(void){ iounmap(ts_regs); iounmap(clkcon); free_irq(IRQ_TC, ts_dev); free_irq(IRQ_ADC, ts_dev); input_unregister_device(ts_dev); input_free_device(ts_dev); del_timer(&ts_timer); } module_init(ts_init); module_exit(ts_exit); MODULE_AUTHOR("GRH"); MODULE_VERSION("1.0"); MODULE_DESCRIPTION("TOUCH SCREEN DRIVER"); MODULE_LICENSE("GPL");
“泛在”即“无所不在” ,也有人称之为“普适”即“普遍适用” 。20世纪80年代8位台式电脑开始普及,但有些办公设备的厂商认为计算不应只限于电脑,而是存在于社会的所有方面,也就是说任何电子设备里都应该包含计算技术。本世纪初日本东京工业大 ...… 查看全部问答> |
好几天没有发帖子啦,干别的啦 2010.5.14 测试PWM 功能 , 现发些图片!!使用方面 可以自行按照相关的参数自行设置占空比之类的 , 现在没有用上,制作测试 图片供交流, … 查看全部问答> |
系统上电的时候,cs:ip 指向0xffff0,这个位置应该为ROM地址,这时RAM是不可用的,当ROM bios检测到RAM时,是否执行了代码拷贝?将ROM bios拷到1M高端的64k,如果bios大于64k怎么办呢?或者根本没有什么代码拷贝,只是进行了内存映射? video bios ...… 查看全部问答> |
我现在想使tcpmp能够播放一种新的视频文件(.avs格式),想请教高手怎么才能在里面注册这种格式,使tcpmp能够认识.avs格式呢??… 查看全部问答> |
我的INF是为Realtek 8139网卡写的 我在设备管理器中,用更新驱动的方式想把驱动加载上网卡,但是每次都提示“向导无法为您的硬件找到比您现在已经安装的软件更匹配的软件”,请问这是什么原因啊? 我的INF是用DDK下的GenINF的WIZARD写了一个框架 ...… 查看全部问答> |
完全没有思路。。。。限定是用51系列芯片,手头上只有AT89S52,半屏显示指针如果把所有可能都存在片内ROM 那么64(行数)*8(列字节数)*8bit=512(字节)一屏,需要保存的数据有60时*60分*60秒=216000,即108000KB=108MB。。。晕 所以只能用实时 ...… 查看全部问答> |
