今天是:2025年11月12日(星期三)
2022年11月12日 | MINI2440 按键输入子系统 驱动及测试代码分析
2022-11-12 来源:csdn
按键输入子系统驱动:
#include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include struct pin_desc { int irq; int pin; int pin_state; char *name; int key_val; int pin_val; }; static struct pin_desc buttons_pin[] = { {IRQ_EINT8, S3C2410_GPG(0), S3C2410_GPG0_EINT8, "KEY1", BTN_0}, {IRQ_EINT11, S3C2410_GPG(3), S3C2410_GPG3_EINT11, "KEY3", BTN_1}, {IRQ_EINT13, S3C2410_GPG(5), S3C2410_GPG5_EINT13, "KEY2", BTN_2}, {IRQ_EINT14, S3C2410_GPG(6), S3C2410_GPG6_EINT14, "KEY4", BTN_3}, {IRQ_EINT15, S3C2410_GPG(7), S3C2410_GPG7_EINT15, "KEY5", BTN_4}, {IRQ_EINT19, S3C2410_GPG(11), S3C2410_GPG11_EINT19, "KEY6", BTN_5}, }; static struct input_dev *buttons_input; static irqreturn_t buttons_interrupt(int irq,void *dev_id) { struct pin_desc *pin_desc = (struct pin_desc *)dev_id; int val; val = s3c2410_gpio_getpin(pin_desc->pin); input_event(buttons_input,EV_KEY,pin_desc->key_val, !val); input_sync(buttons_input); return IRQ_HANDLED; } static int __init buttons_init(void) { int error; int i; buttons_input = input_allocate_device(); if(!buttons_input) return -ENOMEM; #if 0 buttons_input->evbit[0] = BIT(EV_KEY); buttons_input->keybit[BITS_TO_LONGS(KEY_L)] = BIT(KEY_L); buttons_input->keybit[BITS_TO_LONGS(KEY_S)] = BIT(KEY_S); buttons_input->keybit[BITS_TO_LONGS(KEY_ENTER)] = BIT(KEY_ENTER); buttons_input->keybit[BITS_TO_LONGS(KEY_LEFTSHIFT)] = BIT(KEY_LEFTSHIFT); #endif set_bit(EV_KEY,buttons_input->evbit); for(i = 0;i set_bit(buttons_pin[i].key_val,buttons_input->keybit); } error = input_register_device(buttons_input); if(error){ input_free_device(buttons_input); return -1; } for(i = 0;i s3c2410_gpio_cfgpin(buttons_pin[i].pin,buttons_pin[i].pin_state); request_irq(buttons_pin[i].irq,buttons_interrupt, IRQF_SHARED | IRQF_TRIGGER_RISING | IRQF_TRIGGER_FALLING,buttons_pin[i].name,(void *)&buttons_pin[i]); } return 0; } static void __exit buttons_exit(void) { int i; for(i = 0; i< sizeof(buttons_pin)/sizeof(buttons_pin[0]); i++) { free_irq(buttons_pin[i].irq, (void *)&buttons_pin[i]); } input_unregister_device(buttons_input); input_free_device(buttons_input); } module_init(buttons_init); module_exit(buttons_exit); MODULE_LICENSE("GPL"); MODULE_AUTHOR("RopenYuan"); 按键输入子系统测试程序 #include #include #include #include #include #include #include #include #include #include #include int main(void) { int buttons_fd; int key_value,i=0,count; struct input_event ev_key; buttons_fd = open("/dev/input/event0", O_RDWR); if (buttons_fd < 0) { perror("open device buttons"); exit(1); } for (;;) { count = read(buttons_fd,&ev_key,sizeof(struct input_event)); for(i=0; i<(int)count/sizeof(struct input_event); i++) if(EV_KEY==ev_key.type) printf("type:%d,code:%d,value:%dn", ev_key.type,ev_key.code,ev_key.value); if(EV_SYN==ev_key.type) printf("syn eventnn"); } close(buttons_fd); return 0; } MAKEFILE ifneq ($(KERNELRELEASE),) obj-m := buttons.o else #KDIR := /home/yuanpengjun/home/linuxeditorkernelfilesystem/kernal/linux-2.6.32/linux-2.6.32.2/ KDIR := /home/yuanpengjun/mini2440/kernel/linux-2.6.32.2/ all: # make -C $(KDIR) M=$(PWD) modules ARCH=arm CROSS_COMPILE=arm-linux- make -C $(KDIR) M=$(PWD) modules /home/yuanpengjun/mini2440/editor/4.4.3/bin/arm-none-linux-gnueabi-gcc -o button button_app.c clean: rm -f *.ko *.o *.mod.o *.mod.c *.symvers modul* endif 以上驱动代码未加入容错处理,只是为了验证是否能成功运行。 在模块加载时出现input: Unspecified device as /devices/virtual/input/input0 原因为没有在驱动中设置struct input_dev 中的成员名name,若有成员名为 XXXX->name = "yyyyyyy",驱动模块加载后会出现如下情况: input: yyyyyyy as /devices/virtual/input/input0 在模块卸载时出现rmmod: chdir(2.6.32.2): No such file or directory,并且不能将模块从系统中卸载掉; 原因为:现在的内核模块在插入卸载时都会要转到/lib/modules/内核版本号/ 这个目录里,格式为/lib/modules/2.6.32.2/ 在这种情况下,不会再出现模块不能卸载情况;
内容:设计一个十字路口的红、绿、黄三色信号交通灯控制电路 设计要求与数据:1. 用红、绿、黄三色发光二极管作信号灯。主干道为东西向,有红、绿、黄三个灯;支干道为南北向,也有红、绿、黄三个灯。红灯亮禁止通行;绿灯亮允许通行;黄灯亮则给 ...… 查看全部问答> |
现在有一个程序是分BANK的,在某一BANK中有一条 printf(\"test0000000000000000000\");编译完后发现 \"test0000000000000000000\"被放到了common bank中,有没有什么办法能让这个字符串被编译到一个指字的地址之后? 比如要把test0000000000000000 ...… 查看全部问答> |
