今天是:2026年01月13日(星期二)
2023年01月13日 | 用C语言写一个温度测量显示程序
2023-01-13 来源:zhihu
P1ASF = 0x0C; //P1.2 P1.3做ADC
ADC_CONTR = 0xE0; //90T, ADC power on
AUXR = 0x80; //Timer0 set as 1T, 16 bits timer auto-reload,
TH0 = (u8)(Timer0_Reload / 256);
TL0 = (u8)(Timer0_Reload % 256);
ET0 = 1; //Timer0 interrupt enable
TR0 = 1; //Tiner0 run
EA = 1; //打开总中断
for(i=0; i<8; i++) LED8[i] = 0x10; //上电消隐
while(1)
if(B_1ms) //1ms到
B_1ms = 0;
if(++msecond >= 300) //300ms到
msecond = 0;
j = Get_ADC10bitResult(2); //参数0~7,查询方式做一次ADC, 返回值就是结果, == 1024 为错误
if(j < 1024)
LED8[0] = j / 1000; //显示ADC值
LED8[1] = (j % 1000) / 100;
LED8[2] = (j % 100) / 10;
LED8[3] = j % 10;
if(LED8[0] == 0) LED8[0] = DIS_BLACK;
else //错误
for(i=0; i<4; i++) LED8[i] = DIS_;
j = Get_ADC10bitResult(3); //参数0~7,查询方式做一次ADC, 返回值就是结果, == 1024 为错误
j += Get_ADC10bitResult(3);
if(j < 1024*4)
LED8[3] = j % 10;
j = get_temperature(j); //计算温度值
if(j >= 400) F0 = 0, j -= 400; //温度 >= 0度
else F0 = 1, j = 400 - j; //温度 < 0度
LED8[4] = j / 1000; //显示温度值
LED8[5] = (j % 1000) / 100;
LED8[6] = (j % 100) / 10 + DIS_DOT;
LED8[7] = j % 10;
if(LED8[4] == 0) LED8[4] = DIS_BLACK;
if(F0) LED8[4] = DIS_; //显示-
else //错误
for(i=0; i<8; i++) LED8[i] = DIS_;
u16 Get_ADC10bitResult(u8 channel) //channel = 0~7
ADC_RES = 0;
ADC_RESL = 0;
ADC_CONTR = (ADC_CONTR & 0xe0) | 0x08 | channel; //start the ADC
NOP(4);
while((ADC_CONTR & 0x10) == 0) ; //wait for ADC finish
ADC_CONTR &= ~0x10; //清除ADC结束标志
return (((u16)ADC_RES << 2) | (ADC_RESL & 3));
// MF52E 10K at 25, B = 3950, ADC = 12 bits
u16 code temp_table[]={
140, //;-40 0
149, //;-39 1
159, //;-38 2
168, //;-37 3
178, //;-36 4
188, //;-35 5
199, //;-34 6
210, //;-33 7
222, //;-32 8
233, //;-31 9
246, //;-30 10
259, //;-29 11
272, //;-28 12
286, //;-27 13
301, //;-26 14
317, //;-25 15
333, //;-24 16
349, //;-23 17
367, //;-22 18
385, //;-21 19
403, //;-20 20
423, //;-19 21
443, //;-18 22
464, //;-17 23
486, //;-16 24
509, //;-15 25
533, //;-14 26
558, //;-13 27
583, //;-12 28
610, //;-11 29
638, //;-10 30
667, //;-9 31
696, //;-8 32
727, //;-7 33
758, //;-6 34
791, //;-5 35
824, //;-4 36
858, //;-3 37
893, //;-2 38
929, //;-1 39
965, //;0 40
1003, //;1 41
1041, //;2 42
1080, //;3 43
1119, //;4 44
1160, //;5 45
1201, //;6 46
1243, //;7 47
1285, //;8 48
1328, //;9 49
1371, //;10 50
1414, //;11 51
1459, //;12 52
1503, //;13 53
1548, //;14 54
1593, //;15 55
1638, //;16 56
1684, //;17 57
1730, //;18 58
1775, //;19 59
1821, //;20 60
1867, //;21 61
1912, //;22 62
1958, //;23 63
2003, //;24 64
2048, //;25 65
2093, //;26 66
2137, //;27 67
2182, //;28 68
2225, //;29 69
2269, //;30 70
2312, //;31 71
2354, //;32 72
2397, //;33 73
2438, //;34 74
2479, //;35 75
2519, //;36 76
2559, //;37 77
2598, //;38 78
2637, //;39 79
2675, //;40 80
2712, //;41 81
2748, //;42 82
2784, //;43 83
2819, //;44 84
2853, //;45 85
2887, //;46 86
2920, //;47 87
2952, //;48 88
2984, //;49 89
3014, //;50 90
3044, //;51 91
3073, //;52 92
3102, //;53 93
3130, //;54 94
3157, //;55 95
3183, //;56 96
3209, //;57 97
3234, //;58 98
3259, //;59 99
3283, //;60 100
3306, //;61 101
3328, //;62 102
3351, //;63 103
3372, //;64 104
3393, //;65 105
3413, //;66 106
3432, //;67 107
3452, //;68 108
3470, //;69 109
3488, //;70 110
3506, //;71 111
3523, //;72 112
3539, //;73 113
3555, //;74 114
3571, //;75 115
3586, //;76 116
3601, //;77 117
3615, //;78 118
3628, //;79 119
3642, //;80 120
3655, //;81 121
3667, //;82 122
3679, //;83 123
3691, //;84 124
3702, //;85 125
3714, //;86 126
3724, //;87 127
3735, //;88 128
3745, //;89 129
3754, //;90 130
3764, //;91 131
3773, //;92 132
3782, //;93 133
3791, //;94 134
3799, //;95 135
3807, //;96 136
3815, //;97 137
3822, //;98 138
3830, //;99 139
3837, //;100 140
3844, //;101 141
3850, //;102 142
3857, //;103 143
3863, //;104 144
3869, //;105 145
3875, //;106 146
3881, //;107 147
3887, //;108 148
3892, //;109 149
3897, //;110 150
3902, //;111 151
3907, //;112 152
3912, //;113 153
3917, //;114 154
3921, //;115 155
3926, //;116 156
3930, //;117 157
3934, //;118 158
3938, //;119 159
3942 //;120 160
/*** 计算温度 ***/
// 计算结果: 0对应-40.0度, 400对应0度, 625对应25.0度, 最大1600对应120.0度.
// 为了通用, ADC输入为12bit的ADC值.
// 电路和软件算法设计: Coody
#define D_SCALE 10 //结果放大倍数, 放大10倍就是保留一位小数
u16 get_temperature(u16 adc)
u16 code *p;
u16 i;
u8 j,k,min,max;
adc = 4096 - adc; //Rt接地
p = temp_table;
if(adc < p[0]) return (0xfffe);
if(adc > p[160]) return (0xffff);
min = 0; //-40度
max = 160; //120度
for(j=0; j<5; j++) //对分查表
k = min / 2 + max / 2;
if(adc <= p[k]) max = k;
else min = k;
if(adc == p[min]) i = min * D_SCALE;
else if(adc == p[max]) i = max * D_SCALE;
else // min < temp < max
while(min <= max)
min++;
if(adc == p[min]) {i = min * D_SCALE; break;}
else if(adc < p[min])
min--;
i = p[min]; //min
j = (adc - i) * D_SCALE / (p[min+1] - i);
i = min;
i *= D_SCALE;
i += j;
break;
return i;
/***向HC595发送一个字节函数 ***/
void Send_595(u8 dat)
u8 i;
for(i=0; i<8; i++)
dat <<= 1;
P_HC595_SER = CY;
P_HC595_SRCLK = 1;
P_HC595_SRCLK = 0;
/*** 显示扫描函数 ***/
void DisplayScan(void)
Send_595(~T_COM[display_index]); //输出位码
Send_595(t_display[LED8[display_index]]); //输出段码
P_HC595_RCLK = 1;
P_HC595_RCLK = 0; //锁存输出数据
if(++display_index >= 8) display_index = 0; //8位结束回0
/*** Timer0 1ms中断函数 ***/
void timer0 (void) interrupt TIMER0_VECTOR
DisplayScan(); //1ms扫描显示一位
B_1ms = 1; //1ms标志
下一篇:用汇编语言写一个数码时钟程序
作为局域网的主要连接设备,以太网交换机成为应用普及最快的网络设备之一,同时,也是随着这种快速的发展,交换机的功能不断增强,随之而来则是交换机端口的更新换代以及各种特殊设备连接端口不断的添加到交换机上,这也使得交换机的接口类型变得非 ...… 查看全部问答> |
本帖最后由 jameswangsynnex 于 2015-3-3 19:57 编辑 Job description: · Responsible for the creation, implementation and debugging of board level tests for Xbox accessories. · The test engineer must also be able to create d ...… 查看全部问答> |
大家好,68013的GPIO口一般是用8个端口(如P0-P7)接收8位数据,或16个端口(如P0-P15)接收16位数据,也就是第一个端口接收一位数据,现在我有另一个GPIO接口,只有一条线,输出的数据是以b0,b1~b7,这样的顺序,输完一个字节,又接着输第二个字节. 请问怎样才 ...… 查看全部问答> |
