今天是:2026年01月13日(星期二)
2023年01月13日 | 用C语言写一个驱动数码管程序
2023-01-13 来源:zhihu
/****** 本程序功能说明 *****用STC的MCU的IO方式控制74HC595驱动8位数码管。显示效果为: 数码时钟。使用Timer0的16位自动重装来产生1ms节拍,程序运行于这个节拍下, 用户修改MCU主时钟频率时,自动定时于1ms.*****/
#define MAIN_Fosc 22118400L //定义主时钟
#include "STC15Fxxxx.H"
#define Timer0_Reload (65536UL -(MAIN_Fosc / 1000)) //Timer 0 中断频率, 1000次/秒
#define DIS_DOT 0x20
#define DIS_BLACK 0x10
#define DIS_ 0x11
u8 code t_display[]={ //标准字库
// 0 1 2 3 4 5 6 7 8 9 A B C D E F
0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71,
//black - H J K L N o P U t G Q r M y
0x00,0x40,0x76,0x1E,0x70,0x38,0x37,0x5C,0x73,0x3E,0x78,0x3d,0x67,0x50,0x37,0x6e,
0xBF,0x86,0xDB,0xCF,0xE6,0xED,0xFD,0x87,0xFF,0xEF,0x46}; //0. 1. 2. 3. 4. 5. 6. 7. 8. 9. -1
u8 code T_COM[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80}; //位码
sbit P_HC595_SER = P4^0; //pin 14 SER data input
sbit P_HC595_RCLK = P5^4; //pin 12 RCLk store (latch) clock
sbit P_HC595_SRCLK = P4^3; //pin 11 SRCLK Shift data clock
u8 LED8[8]; //显示缓冲
u8 display_index; //显示位索引
bit B_1ms; //1ms标志
u8 hour,minute,second;
u16 msecond;
/******* 显示时钟函数 ********/
void DisplayRTC(void)
if(hour >= 10) LED8[0] = hour / 10;
else LED8[0] = DIS_BLACK;
LED8[1] = hour % 10;
LED8[2] = DIS_;
LED8[3] = minute / 10;
LED8[4] = minute % 10;
LED8[5] = DIS_;
LED8[6] = second / 10;
LED8[7] = second % 10;
/***** RTC演示函数 *****/
void RTC(void)
if(++second >= 60)
second = 0;
if(++minute >= 60)
minute = 0;
if(++hour >= 24) hour = 0;
/**** 主函数 *******/
void main(void)
u8 i,k;
P0M1 = 0; P0M0 = 0; //设置为准双向口
P1M1 = 0; P1M0 = 0; //设置为准双向口
P2M1 = 0; P2M0 = 0; //设置为准双向口
P3M1 = 0; P3M0 = 0; //设置为准双向口
P4M1 = 0; P4M0 = 0; //设置为准双向口
P5M1 = 0; P5M0 = 0; //设置为准双向口
P6M1 = 0; P6M0 = 0; //设置为准双向口
P7M1 = 0; P7M0 = 0; //设置为准双向口
AUXR = 0x80; //Timer0 set as 1T, 16 bits timer auto-reload,
TH0 = (u8)(Timer0_Reload / 256);
TL0 = (u8)(Timer0_Reload % 256);
ET0 = 1; //Timer0 interrupt enable
TR0 = 1; //Tiner0 run
EA = 1; //打开总中断
display_index = 0;
hour = 11; //初始化时间值
minute = 59;
second = 58;
RTC();
DisplayRTC();
// for(i=0; i<8; i++) LED8[i] = DIS_BLACK; //上电消隐
for(i=0; i<8; i++) LED8[i] = i; //显示01234567
k = 0;
while(1)
if(B_1ms) //1ms到
B_1ms = 0;
if(++msecond >= 1000) //1秒到
msecond = 0;
RTC();
DisplayRTC();
/*** 向HC595发送一个字节函数 *******/
void Send_595(u8 dat)
u8 i;
for(i=0; i<8; i++)
dat <<= 1;
P_HC595_SER = CY;
P_HC595_SRCLK = 1;
P_HC595_SRCLK = 0;
/******** 显示扫描函数 **********/
void DisplayScan(void)
Send_595(~T_COM[display_index]); //输出位码
Send_595(t_display[LED8[display_index]]); //输出段码
P_HC595_RCLK = 1;
P_HC595_RCLK = 0; //锁存输出数据
if(++display_index >= 8) display_index = 0; //8位结束回0
/***** Timer0 1ms中断函数 ********/
void timer0 (void) interrupt TIMER0_VECTOR
DisplayScan(); //1ms扫描显示一位
B_1ms = 1; //1ms标志
上一篇:用汇编语言写一个数码时钟程序
下一篇:用汇编语言写个流水灯程序
一直想通过wince上的程序连接pc上的数据库如sql server,mysql等,一直没搞定。不知有没有大侠能够指导一下啊? 这几天看了下sqlite数据库的东西,简单小程序能写了,但是发现sqlite有个问题就是好像不支持c/s结构,只能在本地进行sq ...… 查看全部问答> |
终于收到力源申请的套件了,哈哈哈哈还以为与她无缘,现在开始,晚上的"夜生活"开始丰富了也开始倒塌STM32~~~~~~~~~~~~~~~~~~~… 查看全部问答> |
(写得很认真,先留着,等板子来了就可以耍了!感谢作者) 故事的起因是这样滴。。。LaunchPad包装盒中并没有附带资料光盘(至少我收到的是这样的),只有一张纸的简单介绍,即TI网站上的文档MSP-EXP430G2 LaunchPa ...… 查看全部问答> |
转自:deyisupport 前面有两篇关于仪表放大器 (INA) 电源及共模抑制比 (PSRR & CMRR) 的极好博客文章。(参见“处理抑制问题:仪表放大器 PSRR 与 CMRR”第 I 部分 和 第 II 部分)。 准确指出了大多数 INA 器件的 CMRR 与 PSRR 性能会随增益变化 ...… 查看全部问答> |
转自deyisupport 你看没看到过汽车向前行驶,而车的轮子实际上是向后转呢?如果不是在表演高难度特技的话,我打赌你一定在汽车广告中看到过。你想没想过这是为什么呢?真实的生活如流水般不可中断,而视频摄像头每秒钟只记录了有限数量的画面。每 ...… 查看全部问答> |
