PIC16F877A DS1302芯片驱动
2016-11-04 来源:eefocus
- #include
- typedef unsigned char uchar;
- typedef unsigned int uint;
- #define rs_h PORTC|=0x01
- #define rs_l PORTC&=0xfe
- #define rw_h PORTC|=0x02
- #define rw_l PORTC&=0xfd
- #define en_h PORTC|=0x04
- #define en_l PORTC&=0xfb
- #define rst_h PORTC|=0x08
- #define rst_l PORTC&=0xf7
- #define sck_h PORTC|=0x10
- #define sck_l PORTC&=0xef
- #define io_h PORTC|=0x20
- #define io_l PORTC&=0xdf
- #define SECADD 0X80//秒寄存器地址
- #define MINADD 0x82
- #define HRADD 0x84
- #define DATEADD 0x86
- #define MONTHADD 0x88
- #define DAYADD 0x8a
- #define YEARADD 0x8c
- #define CONTROLADD 0x8e
- #define PORT (PORTB)
- void delayms(uint x);
- void lcd_com(uchar com);
- void lcd_dat(uchar dat);
- void lcd_write(uchar c,uchar r,uchar dat);
- void lcd_init(void);
- void Ds1302Init(void);
- void WriteByte(uchar dat);
- uchar ReadByte(void);
- uchar BCDtoDex(uchar dat);
- uchar DextoBCD(uchar dat);
- void Ds1302Write(uchar add,uchar dat);
- uchar Ds1302Read(uchar add);
- void main(void)
- uchar sec,min,hr,date,month,day,year;
- TRISB=0x00;
- TRISC&=0xc0;
- lcd_init();
- Ds1302Init();
- while(1)
- sec=Ds1302Read(SECADD);
- min=Ds1302Read(MINADD);
- hr=Ds1302Read(HRADD);
- date=Ds1302Read(DATEADD);
- month=Ds1302Read(MONTHADD);
- day=Ds1302Read(DAYADD);
- year=Ds1302Read(YEARADD);
- sec=BCDtoDex(sec);
- min=BCDtoDex(min);
- hr=BCDtoDex(hr);
- date=BCDtoDex(date);
- month=BCDtoDex(month);
- day=BCDtoDex(day);
- year=BCDtoDex(year);
- lcd_write(0,1,0x32);
- lcd_write(0,2,0x30);
- lcd_write(0,3,0x30+year/10);
- lcd_write(0,4,0x30+year%10);
- lcd_write(0,6,0x30+month/10);
- lcd_write(0,7,0x30+month%10);
- lcd_write(0,9,0x30+date/10);
- lcd_write(0,10,0x30+date%10);
- lcd_write(0,14,0x30+day);
- lcd_write(1,4,0x30+hr/10);
- lcd_write(1,5,0x30+hr%10);
- lcd_write(1,7,0x30+min/10);
- lcd_write(1,8,0x30+min%10);
- lcd_write(1,10,0x30+sec/10);
- lcd_write(1,11,0x30+sec%10);
- delayms(1005);//1ms
- rst_l;
- sck_l;
- Ds1302Write(CONTROLADD,0);//关闭写保护
- Ds1302Write(MINADD,DextoBCD(06));
- Ds1302Write(HRADD,DextoBCD(19));
- Ds1302Write(DATEADD,DextoBCD(20));
- Ds1302Write(MONTHADD,DextoBCD(5));
- Ds1302Write(DAYADD,DextoBCD(7));
- Ds1302Write(YEARADD,DextoBCD(12));
- Ds1302Write(SECADD,DextoBCD(30));//写秒,同时启动时钟
- void WriteByte(uchar dat)//上升沿输出
- uchar i;
- TRISC&=0xdf;
- for(i=8;i>0;i--)
- sck_l;//低电平时数据线可变
- if(dat&0x01)
- io_h;
- else
- io_l;
- sck_h;
- dat>>=1;
- uchar BCDtoDex(uchar dat)//BCD码转十进制
- uchar i;
- i=dat/16;
- dat%=16;
- i=i*10+dat;
- return i;
- uchar DextoBCD(uchar dat)//十进制转BCD码
- uchar i;
- i=dat/10;
- dat%=10;
- i=i*16+dat;
- return i;
- uchar ReadByte(void)//下降沿输出
- uchar i;
- uchar dat;
- TRISC|=0x20;
- for(i=8;i>0;i--)//要考虑之前写完后的状态,第一次进入此循环体即有下降沿
- dat>>=1;
- sck_l;
- if(PORTC&0x20)
- dat|=0x80;
- sck_h;
- return dat;
- rst_l;
- sck_l;
- rst_h;
- WriteByte(add);//最低位置0表示写
- WriteByte(dat);
- rst_l;
- uchar dat;
- rst_l;
- sck_l;
- rst_h;
- WriteByte(add+1);//地址最低位置1表示读
- dat=ReadByte();
- rst_l;
- return dat;
- void delayms(uint x) //8M晶振下,延时1ms
- uint y,z;
- for(y=x;y>0;y--)
- for(z=220;z>0;z--);
- void lcd_init(void)//LCD1602初始化
- lcd_com(0x38);
- lcd_com(0x0c);
- lcd_com(0x06);
- lcd_write(0,5,0xb0);
- lcd_write(0,8,0xb0);
- lcd_write(1,6,0x3a);
- lcd_write(1,9,0x3a);
- void lcd_com(uchar com)//向LCD1602写命令
- rs_l;
- rw_l;
- PORT=com;
- delayms(1);
- en_h;
- delayms(1);
- en_l;
- void lcd_dat(uchar dat)//向LCD1602写数据
- rs_h;
- rw_l;
- PORT=dat;
- delayms(1);
- en_h;
- delayms(1);
- en_l;
- void lcd_write(uchar c,uchar r,uchar dat)//向LCD1602指定行、指定列、写数据
- lcd_com(0x80+0x40*c+r);
- lcd_dat(dat);
- delayms(1);
相关文章
