单片机
字符设备驱动(1)驱动代码完整源码:charButtons.c
2025-01-09 来源:cnblogs
内核版本:Linux3.0.8
开发板:基于三星S5PV210处理器的Tiny210开发板
驱动名称:charButtons.c
驱动描述:按键触发中断,中断处理程序执行相应的简单LED点亮操作
方案1注册字符设备使用新的接口实现(需要好几个函数来实现。貌似更复杂)
方案2注册字符设备使用老的接口实现(貌似老接口更简单)
简    述:简单字符型驱动程序,手动静态分配设备号,手动创建设备节点
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#define DEVICE_NAME        'buttons'
struct button_desc {
    int gpio;
    int number;
    char *name;
struct led_desc {
    int gpio;
    int number;
    char *name;
static struct button_desc buttons[] = {
    { S5PV210_GPH2(0), 0, 'KEY0' },
    { S5PV210_GPH2(1), 1, 'KEY1' },
    { S5PV210_GPH2(2), 2, 'KEY2' },
    { S5PV210_GPH2(3), 3, 'KEY3' },
    { S5PV210_GPH3(0), 4, 'KEY4' },
    { S5PV210_GPH3(1), 5, 'KEY5' },
    { S5PV210_GPH3(2), 6, 'KEY6' },
    { S5PV210_GPH3(3), 7, 'KEY7' },
static struct led_desc leds[] = {
    {S5PV210_GPJ2(0),1,'LED1'},
    {S5PV210_GPJ2(1),2,'LED2'},
    {S5PV210_GPJ2(2),3,'LED3'},
    {S5PV210_GPJ2(3),4,'LED4'},
#define OK            (0)
#define ERROR         (-1)
struct gpio_chip *chip;
struct cdev *gDev;
struct file_operations *gFile;
dev_t  devNum;
unsigned int subDevNum = 1;//要申请的次设备号个数
int reg_major  =  234;
int reg_minor =   0;
static irqreturn_t button_interrupt(int irq, void *dev_id)
    struct button_desc *bdata = (struct button_desc *)dev_id;
    int down;
    unsigned tmp;
    tmp = gpio_get_value(bdata->gpio);
    /* active low */
    down = !tmp;
    printk('KEY %d: %08xn', bdata->number, down);
    if(bdata->number < 4)
        gpio_set_value(leds[bdata->number].gpio,0);
        printk('LED %d: On n',leds[bdata->number].number);
    else
        gpio_set_value(leds[(bdata->number) - 4].gpio,1);
        printk('LED %d: OFF n',leds[(bdata->number)-4].number);
    return IRQ_HANDLED;
int butsOpen(struct inode *p, struct file *f)
        int irq;
    int i;
    int err = 0;
    printk(KERN_EMERG'butsOpenrn');
    for (i = 0; i < ARRAY_SIZE(buttons); i++) {
        if (!buttons[i].gpio)
            continue;
        irq = gpio_to_irq(buttons[i].gpio);
        // irq = IRQ_EINT(16)+i =160+i 'S5PV210_GPH2(i)'
        //irq = IRQ_EINT(24)+i =168+i  'S5PV210_GPH3(i)'
        err = request_irq(irq, button_interrupt, IRQ_TYPE_EDGE_BOTH,
                buttons[i].name, (void *)&buttons[i]);
        if (err)
            break;
    for(i = 0; i    {
        if(!leds[i].gpio)
            continue;
        gpio_direction_output(leds[i].gpio,1);
    if (err) {
        i--;
        for (; i >= 0; i--) {
                continue;
            disable_irq(irq);
            free_irq(irq, (void *)&buttons[i]);
        return -EBUSY;
    return 0;
int charDrvInit(void)
    devNum = MKDEV(reg_major, reg_minor);
    printk(KERN_EMERG'devNum is %drn', devNum);
    if(OK == register_chrdev_region(devNum, subDevNum, DEVICE_NAME))
        printk(KERN_EMERG'register_chrdev_region okrn');
    else
        printk(KERN_EMERG'register_chrdev_region errorrn');
        return ERROR;
    /*if(OK == alloc_chrdev_region(&devNum, subDevNum, subDevNum,'test'))
    else
        return ERROR;
    gDev = kzalloc(sizeof(struct cdev), GFP_KERNEL);
    gFile = kzalloc(sizeof(struct file_operations), GFP_KERNEL);
    gFile->open = butsOpen;
//注册设备函数到file_operations结构体gFile
   //gDev->owner = THIS_MODULE;
    gFile->owner = THIS_MODULE;
    cdev_init(gDev, gFile);
//在cdev结构体中添加指针指向file_operations结构体gFile
    cdev_add(gDev, devNum, 3);
//建立设备号与cdev结构体联系
    printk(KERN_EMERG'button driver initial done...rn');
    return 0;
void __exit charDrvExit(void)
    int i,irq;
    cdev_del(gDev);
    unregister_chrdev_region(devNum, subDevNum);
                continue;
            disable_irq(irq);
    return;
module_init(charDrvInit);//执行insmod时会执行此行代码并调用charDrvInit,驱动开始
module_exit(charDrvExit);//执行rmmod时,结束
MODULE_LICENSE('GPL');
#include
#include
#include
#include
#include
#include
#include
#define DEVICE_NAME        'leds'
    int gpio;
    int number;
    char *name;
struct led_desc {
    int gpio;
    int number;
    char *name;
#define OK            (0)
#define ERROR         (-1)
dev_t  devNum;
int reg_minor =   0;
    int down;
    unsigned tmp;
    /* active low */
    down = !tmp;
    else
    return IRQ_HANDLED;
        int irq;
    int i;
    int err = 0;
            continue;
        err = request_irq(irq, button_interrupt, IRQ_TYPE_EDGE_FALLING,
        if (err)
            break;
    for(i = 0; i    {
        if(!leds[i].gpio)
            continue;
    if (err) {
        i--;
                continue;
            disable_irq(irq);
        return -EBUSY;
    return 0;
static const struct file_operations gFile =
    .owner = THIS_MODULE,
    .open  =  butsOpen,
    if(OK == register_chrdev(reg_major, DEVICE_NAME, &gFile))
        printk(KERN_EMERG 'register_chrdev_region okrn');
    else
        return ERROR;
    printk(KERN_EMERG 'button driver initial done...rn');
    return 0;
    int i,irq;
    unregister_chrdev(reg_major, DEVICE_NAME);
                continue;
            disable_irq(irq);
    return;
MODULE_AUTHOR('LiuB');
函数修饰符
__init,本质上是一个宏定义,在内核源代码中定义:#define __init __section(.init.text) __cold notrace
作用就是,将被它修饰的函数放入.init.text段中去。所以所有的内核模块的__init修饰的函数被放在一起。内核启动时统一加载,加载完后统一释放以节省内存。
__exit,同上:#define __exit __section(.exit.text) __exitused __cold notrace
printk()函数:内核封装出来的打印函数。格式:
printk( 打印级别 “打印信息”) //printk的打印级别是用来控制printk打印的信息是否在终端显示
#define KERN_EMERG    '<0>'    /* system is unusable            */
#define KERN_ALERT    '<1>'    /* action must be taken immediately    */
#define KERN_CRIT    '<2>'    /* critical conditions            */
#define KERN_ERR    '<3>'    /* error conditions            */
#define KERN_WARNING    '<4>'    /* warning conditions            */
#define KERN_NOTICE    '<5>'    /* normal but significant condition    */
#define KERN_INFO    '<6>'    /* informational            */
#define KERN_DEBUG    '<7>'    /* debug-level messages            */
/* Use the default kernel loglevel */
#define KERN_DEFAULT    ''
如果定义了模块,即这一驱动被动态编译为模块时
驱动代码中的module_init、module_exit的内核定义(/include/linux/init.h)
/* Each module must use one module_init(). */
#define module_init(initfn)
static inline initcall_t __inittest(void)    { return initfn; }
int init_module(void) __attribute__((alias(#initfn)));
typedef int (*initcall_t)(void);
//static inline initcall_t __inittest(void)    { return initfn; }
//inittest这个函数返回值为一个initcall_t类型的initfn
//而initcall_t是一个函数指针,返回值为整型,输入参数为空
/* This is only required if you want to be unloadable. */
#define module_exit(exitfn)
static inline exitcall_t __exittest(void)    { return exitfn; }
void cleanup_module(void) __attribute__((alias(#exitfn)));
typedef void (*exitcall_t)(void);
如果未定义模块,这一驱动被静态编译进内核
 * module_init() - driver initialization entry point
 * @x: function to be run at kernel boot time or module insertion
 * module_init() will either be called during do_initcalls() (if
 * builtin) or at module insertion time (if a module).  There can only
 * be one per module.
#define module_init(x)    __initcall(x);
#define __initcall(fn) device_initcall(fn)
#define device_initcall(fn)    __define_initcall('6',fn,6)
/* initcalls are now grouped by functionality into separate
 * subsections. Ordering inside the subsections is determined
 * by link order.
 * For backwards compatibility, initcall() puts the call in
 * the device init subsection.
 * The `id' arg to __define_initcall() is needed so that multiple initcalls
 * can point at the same handler without causing duplicate-symbol build errors.
#define __define_initcall(level,fn,id)
    static initcall_t __initcall_##fn##id __used
    __attribute__((__section__('.initcall' level '.init'))) = fn
通过这些段代码,我们能够看出最终的结果是将我们使用module_init修饰的函数指针链接到一个叫.initcall的段里,也就是说最终所有使用module_init修饰的函数指针都被链接在这个段里,内核在启动的时候顺序调用所有链接在这个段里的函数,实现设备的初始化
进入单片机查看更多内容>>
相关视频
  • 【TI MSPM0 应用实战】智能小车+工业角度编码器+血氧仪+烟雾探测器!硬核参考设计详解!
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
  • 直播回放: Microchip Timberwolf™ 音频处理器在线研讨会
  • 基于灵动MM32W0系列MCU的指夹血氧仪控制及OTA升级应用方案分享
精选电路图
  • 锂离子/锂聚合物USB电池充电器
  • 6晶体管H桥
  • AVR LCD温度计—LM35
  • AVR PC步进电机驱动器
  • AVR温度计TCN75
  • JDM2 PIC 18F 编程器
    相关电子头条文章
