单片机
TQ210搭载Android4.0.3系统构建之LED从驱动到HAL到JNI到应用程序(HAL篇)
2025-02-14 来源:cnblogs
开发板:TQ210
OS:Android 4.0.3
以下所有内容都是在TQ210开发板上实现,并且很多内容也是天嵌公司提供,我将一些内容进行了删减、替换,然后加入了一些自己的理解,同时也是记录自己学习的旅程。
HAL层头文件  放在hardware/libhardware/include/hardware/目录下
led_unders_led_hal.h
#ifndef ANDROID_LED_UNDERS_H    //保证头文件只被加载一次
#define ANDROID_LED_UNDERS_H
#include   //包含hw_module_t hw_device_t hw_module_methods_t...
#include   // 包含int long...
#include //包含__begin_decls
__BEGIN_DECLS  //按照C语言的方式编译和连接
#define LED_UNDERS_HARDWARE_MODULE_ID 'led_unders'  //led_unders模块ID
struct led_module_t   //led模块类型 ,继承hw_module_t
struct hw_module_t common;
struct led_control_device_t  //led设备类型,继承hw_device_t
struct hw_device_t common;
int (*led_on)(struct led_control_device_t *dev,int32_t number);  //打开led
int (*led_off)(struct led_control_device_t *dev,int32_t number);//关闭led
__END_DECLS
#endif
led_unders_led_hal.c
#include
#include
#include //包含malloc memset...
#include //包含__android_log_print
#include
#include
#define DEV_FILE_NAME  '/dev/led_unders'   //设备文件名
#define IOCTL_GPIO_ON 1   //打开LED
#define IOCTL_GPIO_OFF 0 //关闭LED
static int fd=-1;  //文件操作符
static int open_led()  //打开LED
fd=open(DEV_FILE_NAME,O_RDWR);
if(fd<0)
__android_log_print(ANDROID_LOG_DEBUG,'msg','open_led failed.n');
return -1;
__android_log_print(ANDROID_LOG_DEBUG,'msg','open_led success.n');
return 0;
static int close_led(struct hw_device_t *device) //关闭LED
if(fd!=-1)
close(fd);
fd=-1;
if(device) free(device);
return 0;
static int led_on(struct led_control_device_t *dev,int32_t number)  //点亮LED
if(fd==-1) return -1;
return ioctl(fd,IOCTL_GPIO_ON,number);
static int led_off(struct led_control_device_t *dev,int32_t number) //关闭LED
return ioctl(fd,IOCTL_GPIO_OFF,number);
//led初始化函数
static int led_init(const struct hw_module_t *module,const char *name,struct hw_device_t **device)
struct led_control_device_t *dev;  //定义led设备指针
dev=(struct led_control_device_t *)malloc(sizeof(struct led_control_device_t)); //分配内存地址空间
if(dev==NULL)
__android_log_print(ANDROID_LOG_DEBUG,'msg','malloc failed.n');
return 0;
memset(dev,0,sizeof(*dev)); //将内存块初始化为0
dev->common.tag=HARDWARE_DEVICE_TAG;  //设备标志,由HWDT组成
dev->common.version=0;  //设备版本
dev->common.module=module; //指向设备所属于的模块
dev->common.close=(int (*)(struct hw_device_t *))close_led; //关闭函数
*device=(struct hw_device_t *)&dev->common;   //指向设备
dev->led_on=led_on;   //操作函数赋值
dev->led_off=led_off;
if(open_led()==-1) //打开led设备
free(dev);
dev=NULL;
return -1;
return 0;
static struct hw_module_methods_t  led_module_methods= //模块拥有的打开方法
open:led_init
const struct led_module_t HAL_MODULE_INFO_SYM=  //HAL_MODULE_INFO_SYM名称不能修改,用于导出的HMI找到模块,相当于模块的入口
common:
tag:HARDWARE_MODULE_TAG, //在hardware.h中定义的,由HWMT组成
version_major:1,   //模块主版本号
version_minor:0,  //模块次版本号
id:LED_UNDERS_HARDWARE_MODULE_ID,  //模块id,用于构成模块全名
name:'led_unders stub',   //模块名称
author:'undergrowth',   //模块作者
methods:&led_module_methods,   //模块所拥有的方法
Android.mk
LOCAL_PATH :=$(call my-dir)
include $(CLEAR_VARS)
LOCAL_PRELINK_MODULE :=false
LOCAL_SRC_FILES :=led_unders_led_hal.c
LOCAL_SHARED_LIBRARIES :=libutils
LOCAL_MODULE :=led_unders.$(TARGET_BOARD_PLATFORM)
LOCAL_MODULE_TAGS :=optional
LOCAL_MODULE_PATH :=$(LOCAL_PATH)
include $(BUILD_SHARED_LIBRARY)
说说个人对HAL的一些理解:
HAL是GOOGLE2008年I/O大会上提出来的,目的为了硬件厂商保护他们的proprietary,当然也正是这个原因,linux的维护者才将andorid的驱动从内核中删掉,因为linux遵循GPL协议,需要完全开放源代码,而Google遵循Apache 2.0,只需提供驱动的二进制代码即可,很明显,Google没有遵守linux的协议,就被linux干掉了。
       因为之前一直在做linux下的驱动开发,个人感觉HAL和驱动的测试代码很像,不同之处在于,你需要遵循一定的规则编写你的测试代码就形成了HAL层代码,建议最好看看hardware/libhardware/hardware.c和hardware/libhardware/include/hardware/hardware.h两个文件,这个是HAL的基础,对于编写HAL层代码有很大的帮助。
      对于HAL的更多介绍 就不多说了 这位老兄写的还不错 推荐  http://blog.csdn.net/k229650014/article/details/5801397
     可能碰到的错误:
  1.
if(fd<0)
return -1;
  调试的时候 发现open_led failed.  即打开文件失败 但是用驱动测试代码测试 设备文件是没有问题的  而是用HAL打开 就出现问题 无法打开
 原因:权限不够
  解决方法:  添加设备文件的权限   eg: chmod 777 /dev/led_unders   即可解决
2.调试的时候 发现load:countn't find symbol hmi
 查看hardware.c源码发现 是因为hmi为空值  于是查看led_unders_led_hal.c  发现
HAL_MODULE_INFO_SYM写成了HAL_MODULE_INFO_SYS  改过来即可
附:生成的led_unders.tq210.so文件放在/system/lib/hw/目录下
进入单片机查看更多内容>>
相关视频
  • 【TI MSPM0 应用实战】智能小车+工业角度编码器+血氧仪+烟雾探测器!硬核参考设计详解!
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
  • 直播回放: Microchip Timberwolf™ 音频处理器在线研讨会
  • 基于灵动MM32W0系列MCU的指夹血氧仪控制及OTA升级应用方案分享
精选电路图
  • 1瓦线性调频增强器
  • 家用电器遥控器
  • 12V 转 28V DC-DC 变换器(基于 LM2585)
  • 红外开关
  • DS1669数字电位器
  • HA1377 桥式放大器 BCL 电容 17W(汽车音频)
    相关电子头条文章
