今天是:2024年12月20日(星期五)
2018年12月20日 | STM32L1xx的库函数有个Bug(stm32l1xx_gpio.c)
2018-12-20 来源:eefocus
在使用STM32L151的时候遇到 GPIO_PinAFConfig(xx,xx,xx)函数无效,有时候还有导致程序HardFault的问题。之前遇到就使用直接寄存器操作避免了这个问题,这次出现了Hardfault,我想这得找找原因了,不然每次都得修改寄存器操作,麻烦的很。
文件“stm32l1xx_gpio.c”中关于GPIO_PinAFConfig 函数式这么定义的。
当使用的引脚号大于8 的时候会导致hardFault的发生。
void GPIO_PinAFConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_PinSource, uint8_t GPIO_AF)
uint32_t temp = 0x00;
uint32_t temp_2 = 0x00;
/* Check the parameters */
assert_param(IS_GPIO_ALL_PERIPH(GPIOx));
assert_param(IS_GPIO_PIN_SOURCE(GPIO_PinSource));
assert_param(IS_GPIO_AF(GPIO_AF));
// temp = ((uint32_t)(GPIO_AF) << ((uint32_t)((uint32_t)GPIO_PinSource & (uint32_t)0x07) * 4)) ;
// GPIOx->AFR[GPIO_PinSource >> 0x03] &= ~((uint32_t)0xF << ((uint32_t)((uint32_t)GPIO_PinSource & (uint32_t)0x07) * 4)) ;
// temp_2 = GPIOx->AFR[GPIO_PinSource >> 0x03] | temp;
// GPIOx->AFR[GPIO_PinSource >> 0x03] = temp_2;
typedef struct
__IO uint32_t MODER; /*!< GPIO port mode register, Address offset: 0x00 */
__IO uint16_t OTYPER; /*!< GPIO port output type register, Address offset: 0x04 */
uint16_t RESERVED0; /*!< Reserved, 0x06 */
__IO uint32_t OSPEEDR; /*!< GPIO port output speed register, Address offset: 0x08 */
__IO uint32_t PUPDR; /*!< GPIO port pull-up/pull-down register, Address offset: 0x0C */
__IO uint16_t IDR; /*!< GPIO port input data register, Address offset: 0x10 */
uint16_t RESERVED1; /*!< Reserved, 0x12 */
__IO uint16_t ODR; /*!< GPIO port output data register, Address offset: 0x14 */
uint16_t RESERVED2; /*!< Reserved, 0x16 */
__IO uint16_t BSRRL; /*!< GPIO port bit set/reset low registerBSRR, Address offset: 0x18 */
__IO uint16_t BSRRH; /*!< GPIO port bit set/reset high registerBSRR, Address offset: 0x1A */
__IO uint32_t LCKR; /*!< GPIO port configuration lock register, Address offset: 0x1C */
__IO uint32_t AFR[2]; /*!< GPIO alternate function low register, Address offset: 0x20-0x24 */
__IO uint16_t BRR; /*!< GPIO bit reset register, Address offset: 0x28 */
uint16_t RESERVED3; /*!< Reserved, 0x2A */
} GPIO_TypeDef;
我们知道AFR是一个只有两个元素的数组,库中若引脚号大于8,会导致AFR【x】中x的值不在是0、1,而可能是0、1、2、3、4····
所以要你将0-7对应为标号0的数组成员,8-15对应到标号1的成员。
把函数体中实现部分修改下,使得不超过数组界限2个成员。
GPIOx->AFR[(GPIO_PinSource >> 0x03)&0x01] &= ~((uint32_t)0xF << ((uint32_t)((uint32_t)GPIO_PinSource & (uint32_t)0x07) * 4)) ;
temp_2 = GPIOx->AFR[(GPIO_PinSource >> 0x03)&0x01] | temp;
GPIOx->AFR[(GPIO_PinSource >> 0x03)&0x01] = temp_2;
28335片内FLASH插件安装方法 http://www.hellodsp.com/bbs/viewthread.php?tid=7487 28335的ADC_DMA例程 http://www.hellodsp.com/bbs/viewthread.php?tid=7488 SEED_DEC28335用户指南 http://www.hellodsp.com/bbs/viewthread.php?tid=7489 ...… 查看全部问答> |
旁路电容不是理论概念,而是一个经常使用的实用方法,在50 -- 60年代,这个词也就有它特有的含义,现在已不多用。电子管或者晶体管是需要偏置的,就是决定工作点的直流供电条件。例如电子管的栅极相对于阴极往往要求加有负压,为了在一个直流电源下 ...… 查看全部问答> |
eboot 分了 4个分区, 1个binfs 3个fatfs 3个fatfs在pc上都是别出来了, 现在遇到以下问题: 1). 我想隐藏其中2个fatfs分区, 因为 我要放 应用程序 用 所以需要隐藏起来 2). 现在分区的路径名是按默认的名字, 比如默认是 disk, 那么 后面几 ...… 查看全部问答> |
RT,系统是wince4.2,哪位开发过?麻烦发个类似记事本写字板一样的能有输入和存档。以前从未在wince上开发过,新手初来,请各位帮忙!!感谢!! 邮箱:jackbinhao@163.com… 查看全部问答> |
大家好: 谁对UI比较熟,还有就是做菜单的技术,菜单就像是彩屏手机里的菜单或是数字电视里的菜单等,这项技术如何实现,我开发过程中要用到,挺急的,请大家帮忙给我点建议或资料吧。先谢谢了。… 查看全部问答> |
如题, 小弟正在学习mobile开发, 因为以前做asp.net, 所以想请教mobile开发模式与.net开发有什么区别, 比如.net主要是事件,用户触发事件后, 需要编写事件的处理函数,而windowsce是消息机制, 请问这个消息和事件的区别, 总是在源码里 ...… 查看全部问答> |
看了Ti的文档还是不太清楚,最后只能写绝对路径,就是包含盘符的那种,不过还是不太好 现在情况是这样的:在include文件夹下面我定义了A、B、C三个文件夹,用来放置三种.h文件 其中A文件夹中又有A1、A2、A3三个文件夹,如何包含这几个文件夹的头 ...… 查看全部问答> |
