今天是:2024年10月29日(星期二)
2019年10月29日 | (C与汇编语言)ARM9之LPC2132控制LCD1602显示字符串
2019-10-29 来源:51hei
GPADIR EQU 0xE0028008
GPASET EQU 0xE0028004
GPACLR EQU 0xE002800C
EXPORT xmain
AREA Init,CODE,READONLY
ENTRY
xmain
ldr r0,=GPADIR
ldr r1,=0x3ff
str r1,[r0] ;A=out
;===========init1602=================
mov r4,#0x38
BL w1602C
mov r4,#0x06
BL w1602C
mov r4,#0x0c
BL w1602C
mov r4,#0x01
BL w1602C
;============main=================
loop mov r4,#0x80
bl w1602C
ldr r9,=dat
mov r6,#0
loop1 ldr r4,[r9,r6]
bl w1602D
ADD r6,r6,#1
BL delay
cmp r6,#15
bne loop1
mov r4,#0xc0
bl w1602C
ldr r9,=ttt
mov r6,#0
loop2 ldr r4,[r9,r6]
bl w1602D
ADD r6,r6,#1
BL delay
cmp r6,#15
bne loop2
B loop
w1602C ldr r1,=0x3ff
ldr r0,=GPACLR
str r1,[r0]
mov r1,#0
ORR r1,r1,r4
ldr r0,=GPASET
str r1,[r0]
nop
nop
orr r1,r1,#0x200
str r1,[r0]
nop
nop
ldr r0,=GPACLR
mov r1,#0x200
str r1,[r0]
mov pc,lr
w1602D ldr r1,=0x3ff
ldr r0,=GPACLR
str r1,[r0]
mov r1,#0x100
ORR r1,r1,r4
ldr r0,=GPASET
str r1,[r0]
nop
nop
orr r1,r1,#0x200
str r1,[r0]
nop
nop
ldr r0,=GPACLR
mov r1,#0x200
str r1,[r0]
mov pc,lr
delay mov r5,#0xff00
delay1 sub r5,r5,#1
cmp r5,#0
bne delay1
mov pc,lr
dat DCB " China Dianzi"
ttt DCB " Keji Xueyuan"
end
#define rGPACON (*(volatile unsigned *)0xE0028008) //Port A in/out0x56000000
#define rGPADAT1 (*(volatile unsigned *)0xE0028004) //Port A =10x56000004
#define rGPADAT0 (*(volatile unsigned *)0xE002800C) //Port A =0 0x56000008
const unsigned char dd[]="Shanxi Dianzi";
const unsigned char tt[]="gongchengxueyuan";
void xmain()
unsigned int i,k;
rGPACON = 0x7ff; //A11-A0=out
rGPADAT1 |= 0x38;
k=4;
while(k--);
rGPADAT1 |= 0x100;
k=7;
while(k--);
rGPADAT0 |= 0x100;
k=10;
while(k--);
rGPADAT0 |= 0x7ff;
rGPADAT1 |= 0x06;
k=4;
while(k--);
rGPADAT1 |= 0x100;
k=7;
while(k--);
rGPADAT0 |= 0x100;
k=10;
while(k--);
rGPADAT0 |= 0x7ff;
下一篇:ARM读取DS1302汇编程序
memory-mapped registers 的具体含义? RT TI DSP中memory-mapped registers是指实际在DSP中存在的寄存器还是仅在存储器中存在的呢? 小弟很菜,望各位大哥多多指教!… 查看全部问答> |
我用PB编译好了winCE内核后,已经把镜像下载到了目标平台上,跑起来了。现在下一步是开发应用程序,就是把evc下的应用程序也下载到目标平台上。我不想使用把应用程序编译到内核然后一起下载到目标板上的的方法,觉得那样不够灵活。请问内核下载到目 ...… 查看全部问答> |
当波特率为19200,38400或者57600时,电脑接收到的数据正常,当用9600时,电脑接收到的数据有时候被分成两部分。 这会是什么原因,请指点。 图片.pdf (36.88 KB) 下载次数:63 2009-12-7 17: ...… 查看全部问答> |
