今天是:2024年12月16日(星期一)
正在发生
2019年12月16日 | PIC单片机的读写93XCXX程序
2019-12-16 来源:elecfans
TITLE        "R/W EEPROM"
LIST  P = 16C54
;Serial Eprom interface to PIC16C5X.
;REV 2.0        8/26/92.
;Define Equates:
 PIC54   EQU     1FFH
PAGE
 ORG     0
START
 goto    main            ;run test program
PAGE
TRUE    EQU     1
FALSE   EQU     0
S93C46  EQU     FALSE
S93LC46 EQU     FALSE
S93C56  EQU     FALSE
S93LC56 EQU     FALSE
S93C66  EQU     TRUE
S93LC66 EQU     FALSE
wire3   equ     TRUE
org8    EQU     FALSE
IF      S93LC46
 IF      org8
 LC468   EQU     TRUE
 XC46    EQU     FALSE
 H16     EQU     FALSE
 H8      EQU     FALSE
 ELSE
 LC468   EQU     FALSE
 XC46    EQU     TRUE
 H16     EQU     FALSE
 H8      EQU     FALSE
 ENDIF
ELSE
ENDIF
IF      S93C46
 LC468   EQU     FALSE
 XC46    EQU     TRUE
 H16     EQU     FALSE
 H8      EQU     FALSE
ENDIF
IF      S93C56 + S93C66 + S93LC56 + S93LC66
 IF      org8
 H8      EQU     TRUE
 H16     EQU     FALSE
 LC468   EQU     FALSE
 XC46    EQU     FALSE
 ELSE
 H16     EQU     TRUE
 H8      EQU     FALSE
 LC468   EQU     FALSE
 XC46    EQU     FALSE
 ENDIF
ELSE
ENDIF
;*                      Register Assignments                        *
indir   equ     0       ;Use this register as source/desTInaTIon
   ;for indirect addressing.
pc      equ     2       ;PIC Program Counter.
status  equ     3       ;PIC Status Register.
fsr     equ     4       ;File Select Register.
serial  equ     5       ;Port used for 93CX6 control.
   ;The following four registers must be
   ;located consecuTIvely in memory.
cmd     equ     1a      ;This register contains the 4 bit
   ;command op code for 93CX6 as follows:
   ;bit 7 msb of command op code
   ;bit 6 next bit of op code
   ;bit 5 next bit of op code
   ;bit 4 lsb of op code
   ;bit 3 A8 of address in case of
   ;56/66 in 8 bit mode.
addr    equ     1b      ;memory address of lower 7/8 bits
highb   equ     1c      ;Used in read/write routines to store the
   ;upper byte of a 16 bit data word,
   ;or the data in a 8 bit data word
lowb    equ     1d      ;Used in read/write routines to store the
   ;lower byte of a 16 bit data word,
   ;or not used in 8 bit data word.
cnthi   equ     1e      ;Used as the upper byte of a sixteen bit
   ;loop counter in RDYCHK routine.
cnt     equ     1f      ;Used as the lower byte of a sixteen bit
   ;loop counter in RDYCHK routine, and
   ;elswhere as an eight bit counter.
temp_cmd equ    1e      ;doubles as a temp register for cmd
temp_addr equ   1f      ;doubles as a temp register for addr
;*                      Bit Assignments                             *
carry   equ     0               ;Carry Flag of Status Register.
zflag   equ     2               ;Zero Flag of Status Register.
cs      equ     2               ;Port pin tied to CS on 93CX6.
din     equ     1               ;Port pin tied to DI on 93CX6.
dout    equ     1               ;Port pin tied to DO on 93CX6.
clock   equ     3               ;Port pin tied to CLK on 93CX6.
;*                      General Assignments                         *
no_err  equ     0
error   equ     1
tries   equ     20      ;After issuing a WRITE, ERASE, ERAL, or WRAL
   ;command, the approximate number of machine
   ;cycles X 256 to wait for the RDY status.
   ;This value must be adjusted for operating
   ;frequencies other than 4 MHz.
read    equ     b'10000000'     ;read command op code
write   equ     b'01000000'     ;write command op code
erase   equ     b'11000000'     ;erase command op code
ewen    equ     b'00110000'     ;erase enable command op code
ewds    equ     b'00000000'     ;erase disable command op code
eral    equ     b'00100000'     ;erase all command op code
wral    equ     b'00010000'     ;write all command op code
;*                      Macro Definitions                           *
sel     MACRO                   ;Selects the 93CX6 device.
 bsf     serial,cs       ;Chip Select (CS) = '1' to select
 ENDM                    ;the device
dsel    MACRO                   ;De-select the 93CX6 device.
 bcf     serial,cs       ;Chip Select (CS) = '0' to de-select
    ;the device.
 ENDM
strtbt  MACRO                   ;Issue the Start Bit to the 93CX6.
 bsf     serial,din      ;Start Bit = '1'.
 clkit                   ;Clock it out.
 ENDM
Crowd_Supply__Inc.公司的发展小趣事
与众不同的是,Crowd Supply Inc.采用了一种基于众包和预售的产品研发策略。他们在平台上发布项目概念和初步设计,通过社区的力量进行方案优化和功能迭代。这种模式不仅降低了产品开发成本,还使得产品更贴近用户需求。其中一款基于该策略开发的产品——一款高集成度的开源硬件开发板,在预售阶段就获得了大量订单,为公司带来了可观的收入。
Floeth Electronic Ltd公司的发展小趣事
在电子行业的众多初创公司中,Crowd Supply Inc.以其独特的理念和模式崭露头角。公司成立之初,便聚焦于开放式硬件和社区驱动的产品开发,这在当时的行业环境中还是一个较为新颖的概念。创始人团队由一群富有热情和创新精神的电子工程师和产品开发专家组成,他们通过线上平台汇聚了一群同样对电子硬件感兴趣的爱好者和开发者。初期,公司面临资金短缺、市场认可度低等挑战,但通过不断试错和社区反馈,逐渐找到了自己的发展方向。
汇科公司的发展小趣事
随着市场的不断发展和变化,汇科公司始终将技术创新作为发展的核心驱动力。2012年,汇科第一台球磨机节电柜研发成功,并成功申请国家专利,这标志着公司在节能环保技术领域取得了重要突破。随后,公司又成功研发了柱塞泵节电柜、新一代全智能球磨机节电柜等产品,这些产品不仅提升了公司的市场竞争力,也推动了整个电子行业的发展。
EA Elektro-Automatik公司的发展小趣事
EA Elektro-Automatik深知持续创新是企业发展的重要动力。因此,公司始终将创新作为企业文化的核心价值观之一。公司鼓励员工积极提出创新想法和解决方案,并为他们提供充分的支持和资源。此外,EA Elektro-Automatik还积极参与各类科研项目和行业标准的制定工作,推动整个行业的创新和发展。这种企业文化不仅为公司带来了更多的机会和挑战,也为企业的长期发展奠定了坚实的基础。
以上是关于EA Elektro-Automatik公司在电子行业发展的5个相关故事。这些故事展示了公司从创立到成为全球知名电子测量品牌的发展历程和取得的成就。
德力西(DELIXI)公司的发展小趣事
面对激烈的市场竞争和不断变化的市场需求,德力西始终坚持创新驱动的发展战略。公司投入大量资源进行技术研发和产品创新,推出了多款具有竞争力的新产品。同时,德力西还积极响应绿色发展的号召,致力于打造低碳环保的电子产品。例如,在芜湖基地获得了中国低压电气行业国产品牌首家五星级零碳工厂及碳中和物流园区认证,这标志着德力西在绿色发展方面取得了显著成果。
科达嘉CODACA公司的发展小趣事
随着电子行业的快速发展,科达嘉意识到技术革新是企业持续发展的关键。因此,公司不断增加自动化生产设备,购置先进的质量测试仪器,并筹建了电感元器件分析实验室和标准的AEC-Q200可靠性实验室。这些举措大大增强了公司的研发分析能力,提升了产品质量和生产效率。科达嘉逐渐形成了以材料研发、产品研发、生产、质量及物控为基础的完整产业链。
不错的解密软件(系统上的)
这个解密软件也许会给大家一点方便…
电流采样
我的论文题目是灯泡验光控制器设计,就是测量灯泡的电流来判断灯泡的好坏,电流大小10A左右 工作电压12V,想用电流传感器MAX472来采集电流信号,通过ADC0809显示出来,问题是不知道MAX472跟0809怎么相连,以及采集电流的电路怎么画, 请教。。最好 ...…
接口资料总结
PCI Express标准概述 [ 本帖最后由 天天向上 于 2009-7-6 11:15 编辑 ]…
字符液晶1602和点阵液晶12864 地址的疑惑(初学者提问)
字符液晶1602 确定显示位置的时候  80H 加上地址码 00H-27H  40H-67H。对于80H是如何得出来的? 点阵液晶12864  确定显示位置的时候  B8H 加上页码  40H 加上列码。   对于B8H 40H ...…
音频 PWM 编码问题
如题,在D 类音频功放芯片中要求输入信号是PWM 信号,怎么把音频信号进行PWM 编码呢? 编码规则大致怎样,大致来两张原理图 …
【课程推荐】+ TI C2000无锡研讨会-太阳能微逆变器解决方案
平时没事看看TI的视频,发现有活动,顺便参加一些,希望拿个奖品,先谢谢TI和eeworld 这次我推荐的课程是 TIC2000无锡研讨会-太阳能微逆变器解决方案 主讲是朱桦 新能源是一个比较大的方向,相信有很多人都是从事这一方面。众所周知的是太阳能变 ...…
关于openpilot的问题4
各位高手,小弟正在分析openpilot源代码,分析到了以下代码:OPLinkSettingsData oplinkSettings;    OPLinkSettingsGet(&oplinkSettings);bool is_coordinator = (oplinkSettings.Coordinator == OPLINKSETTINGS_COORDINATOR_TRUE);&nbs ...…
高频放大器布局布线、接地和旁路考虑
我非常喜欢读ADI提供的技术文档比如ADI的大部分数据手册中都会有技术术语或使用技巧的介绍对理解和应用某些产品和技术帮助很大特别是他提供的中文手册翻译的非常全面,通篇都是中文介绍 这次在ADA4817放大器的数据手册里看到了关于布局布线、接地 ...…
keeloq解码
求助keeloq解码,给威信红包,13352990911 …
