今天是:2025年01月31日(星期五)
2020年01月31日 | apache+sqlite+php for Arm Linux
2020-01-31 来源:eefocus
经过几天的努力终于在arm-linux平台上搭建了apache+sqlite+php平台.
apche与sqlite网上有不少资料,而php for arm-linux很少.为了在arm平台上安装php发了不少时间.所以将搭建过程发表在此,希望对大家有所帮助.
Sqlite for Arm Linux安装
1、 下载sqlite3.3.8:请到http://www.sqlite.org/download.html,将下载的代码包解开,将生成sqlite3.3.8目录
2、 修改configure文件,将下面语句注释掉
#if test "$cross_compiling" = "yes"; then
# { { echo "$as_me:$LINENO:: error: unable to find a compiler for building build tools" >&5#echo "$as_me: error: unable to find a compiler for building build tools" >&2;}
# { (exit 1); exit 1; }; }
#fi
#else
# test "$cross_compiling" = yes &&
# { { echo "$as_me:$LINENO:: error: cannot check for file existence when cross compiling" >&5
#echo "$as_me: error: cannot check for file existence when cross compiling" >&2;}
#else
3、配置
./configure –prefix=/data0/sqlite --disable-tcl --host=arm-linux
4、 修改Makefile文件
将BCC = arm-linux-gcc -g -O2改成BCC = gcc -g -O2
5、 修改Makefile文件,将sqlite3程序以静态键接库方式编译
先需增加libsqlite3.a的编译
再将sqlite3$(TEXE): $(TOP)/src/shell.c .libs/libsqlite3.la sqlite3.h
改成lite3$(TEXE): $(TOP)/src/shell.c .libs/libsqlite3.a sqlite3.h
将 -o $@ $(TOP)/src/shell.c .libs/libsqlite3.la
改成 -o $@ $(TOP)/src/shell.c .libs/libsqlite3.a
6、 Make
7、 #arm-linux-strip sqlite3
8、 将sqlite3上传至终端
9、 Sqlite3程序测试
sqlite3 test
,if you see the following messages:
SQLite version 3.3.8
Enter ".help" for instructions
sqlite>
input some commands to do something,
sqlite> create table tbl(one varchar(10),two smallint);
sqlite> insert into tbl values('hello',10);
sqlite> insert into tbl values('goodbye',20);
sqlite> .quit
10、 测试C程序
make a 'test.c' file in 'build' directory, content as showed:
#include
#include "sqlite3.h" /* orignal is */
static int callback(void *NotUsed, int argc, char **argv, char **azColName){
int i;
for(i=0; iprintf("%s = %sn", azColName[i], argv[i] ? argv[i] : "NULL");
printf("n");
return 0;
int main(int argc, char **argv){
sqlite3 *db;
char *zErrMsg = 0;
int rc;
if( argc!=3 ){
fprintf(stderr, "Usage: %s DATABASE SQL-STATEMENTn", argv[0]);
exit(1);
rc = sqlite3_open(argv[1], &db);
if( rc ){
fprintf(stderr, "Can't open database: %sn", sqlite3_errmsg(db));
sqlite3_close(db);
exit(1);
rc = sqlite3_exec(db, argv[2], callback, 0, &zErrMsg);
if( rc!=SQLITE_OK ){
fprintf(stderr, "SQL error: %sn", zErrMsg);
sqlite3_free(zErrMsg);
sqlite3_close(db);
return 0;
#arm-linux-gcc test.c -L.libs -lsqlite3 –static
#arm-linux-strip a.out
将a.out程序上传至终端,并执行
#a.out test "select * from tbl"
one = hello
two = 10
one = goodbye
two = 20
apache服务器for ARM Linux
1. 从http://www.apache.org/ 上下载apache_1.3.39.tar.gz,然后解压缩的一个目录,然后转到apache_1.3.39目录。
2. 使用本地的gcc编译这个版本,运行:
./ configure
make 完成后,不需要make install
3. 然后创建一个新的编译arm版本的目录,然后在那个目录下解压缩apache_1.3.39.tar.gz,转到该目录下的apache_1.3.39,运行:
export CC="arm-linux-gcc"
./configure --prefix=/data0/apache/ --without-execstrip --enable-module=so
然后运行make 命令,这时编译会在apache_1.3.39/src/main/gen_test_char处失败,因为arm版本该程序无法在本地机器运行,你需要把前面编译的本地版本的apache_1.3.39/src/main/gen_test_char覆盖这个arm版本,然后转到arm版本的apache_1.3.39下继续make,随后编译到另一个程序apache_1.3.39/src/main/gen_uri_delims也出现相同的问题,也使用本地版本覆盖掉它,继续make,直到最后编译成功。
4. --prefix=/data0/apache /指定了安装的目录为/data0/apache/,运行make install,所有编译好的arm版本的apache程序都安装到了/data0/apache/目录下,你把这个目录压缩后,上传至终端上,然后修改conf/httpd.conf配置文件。
5.注意要修改conf/httpd.conf,增加ServerName www.willfar-ertu.com:80,否则在启动服务时会报一个警告httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1 for ServerName
6 .执行如下命令判断apache是否安装成功 http://IP:80 如果显示了apache说明页面,则说明安装成功.如果出现403的错误提示,请确认apache的目录权限是否为755,包括apache的上级目录.
PHP for ARM Linux
1. 从http://www.php.net 上下载php-4.4.8.tar.gz,然后解压缩的一个目录,然后转到php-4.4.8目录
2. export CC=”arm-linux-gcc”
3. 修改configure文件,将其中交叉编译错误处理注释掉,例:
#if test "$cross_compiling" = yes; then
#   { echo "configure: error 7: can not run test program while cross compiling" 1>&2; exit 1; }
#else
4 ./configure --prefix=/data0/php --with-apxs=/data0/apache/bin/apxs --enable-pdo=shared --with-sqlite=shared  --with-pdo-sqlite=shared --with-zlib --host=arm-linux --enable-track-vars --with-xml
5. 执行./configure会报一些错误,根据错误提示,修改configure文件注释掉错误处理,直到成功
6.修改Makefile文件,将其中
EXTRA_LIBS = -lcrypt -l -lcrypt -lz -lm -lcrypt –lcrypt
替换为
http://ip/index.php,能看到php信息,则说明php安装成功
PHP Version 4.4.8
System
Linux localhost 2.4.18-rmk7-pxa1 #2 四 12月 27 12:28:52 CST 2007 armv4l
Build Date
Feb 3 2008 11:58:44
Configure Command
'./configure' '--prefix=/data0/php' '--with-apxs=/data0/apache/bin/apxs' '--enable-pdo=shared' '--with-sqlite=shared' '--with-pdo-sqlite=shared' '--with-zlib' '--host=arm-linux' '--enable-track-vars' '--with-xml'
Server API
Apache
Virtual Directory Support
disabled
Configuration File (php.ini) Path
/data0/php/lib
PHP API
20020918
PHP Extension
20020429
Zend Extension
20050606
Debug Build
no
Zend Memory Manager
enabled
Thread Safety
disabled
Registered PHP Streams
php, http, ftp, compress.zlib
php与sqlite3结合
先从php网站上下载php-sqlite3压缩包
1.把压缩包,解压缩到一个目录.
2.进入该目录,运行/data0/php/bin/phpize
3../configure --with-php-config=/data0/php/bin/php-config --with-sqlite3=你的sqlite3安装目录
4.make
5.make install
6.把生成的sqlite3.so放到php扩展目录下.
7.在php.ini加载一下sqlite3.so模块
铨力(ALLPOWER)公司的发展小趣事
为了进一步提升综合竞争力,铨力公司开始着手深化产业链整合。通过收购、合作等方式,公司逐渐掌握了从原材料供应、产品生产到销售终端的完整产业链。这一举措不仅降低了生产成本,提高了生产效率,还为公司带来了更多的利润增长点。
BEI Sensors公司的发展小趣事
Beckhoff Automation GmbH公司成立于1953年,总部设立在德国Verl市。公司自创立之初,便致力于工业自动化产品的研发与生产。在创始人的领导下,公司逐步建立起一套完整的工业自动化产品体系,包括工业PC、现场总线模块、驱动产品等。凭借卓越的产品质量和创新的技术理念,Beckhoff在行业内逐渐崭露头角,赢得了客户的广泛认可。
AUSTIN公司的发展小趣事
AUSTIN公司的创始人是赫伯特·奥斯汀(Herbert Austin)。在1905年,他制造了第一辆奥斯汀汽车,这标志着奥斯汀品牌的诞生。随着产品的推出,奥斯汀汽车很快获得了市场的认可,销量逐年攀升。直到1914年左右,奥斯汀始终是英国汽车工业的领导者,其汽车产品以高质量和可靠性而闻名。
EVERLIGHT公司的发展小趣事
随着全球环保意识的不断提高,EVERLIGHT也积极响应环保号召,致力于研发和生产环保型LED产品。公司采用环保材料和节能技术,不断降低产品的能耗和废弃物排放。同时,公司还积极推广绿色照明理念,为客户提供环保、节能的照明解决方案。这种对环保的关注和实践让EVERLIGHT在电子行业中树立了良好的形象。
台湾肯尼威(CANNYWELL)公司的发展小趣事
在品质保障的基础上,肯尼威开始积极拓展市场。公司不仅在台湾本地建立了完善的销售网络,还成功进军国际市场。通过与多家国际知名企业的合作,肯尼威的产品逐渐打入电子、机械、医疗器械等多个领域。同时,公司还积极参加国际展会,展示最新的技术和产品,吸引了众多海外客户的关注。
Astec [Astec America, Inc]公司的发展小趣事
面对数字化转型的大趋势,Astec也积极拥抱变革。公司加大了对信息技术和智能制造的投入,通过引入先进的生产管理系统和数据分析工具,提高了生产效率和产品质量。同时,Astec还积极探索新的商业模式和销售渠道,以适应数字化时代的市场需求。展望未来,Astec将继续坚持创新驱动的发展理念,不断推动公司在电子行业中的持续发展。
这五个故事基于Astec America, Inc在电子行业发展的主要阶段和事件进行编写,旨在客观描述公司的发展历程和重要成就。请注意,这些故事可能无法涵盖公司发展的所有细节,但能够提供一个大致的框架。
2009年电子大赛比赛中常用的模块
本帖最后由 paulhyde 于 2014-9-15 03:38 编辑 比赛中常用的模块有: 运算放大器模块 滤波器模块 AGC模块 DDS信号源模块 电机驱动模块 A/D模块 D/A模块 欢迎大家把资料共享,查找资料!  …
arm知识
本帖最后由 paulhyde 于 2014-9-15 09:28 编辑 大家看看..  …
关于总线的问题?
比如wishbone总线到AMBA总线的用Verilog写的转换协议; AMBA对NAND flash控制器的操作程序…
关于ARM CPU异常中断的问题?
各位大虾,本人使用的s3c2410的芯片,在裸机下编程时出现了一个问题,我写了一段程序用于触发CPU的异常中断,但是CPU中断时没有进入中断服务函数中,不知道各位大虾有没有碰到过这种情况,如何才能够让CPU异常中断进入我的中断服务函数中?…
请大虾们给我点MFC蓝牙编程方面的资料!
我要用MFC编写PC端蓝牙软件,有搜索、连接、加密和传输文件的功能,希望大虾们能给我点MFC关于蓝牙编程的资料,如果有源代码参考的话就更好了。我能给的分不多,还请大虾们能无私的帮小弟个忙。感激,感激! …
触摸屏校准程序!
现在是直接调用系统自带的校准程序,方法如下: 首先在头文件里加入函数指针定义: typedef  BOOL  (WINAPI *_TouchCalibrate)(); 然后使用如下代码,就会出现屏幕校准画面了。 HINSTANCE  hinstance = LoadLi ...…
wince 读取xml 问题
我是用Visual Studio C#建的解决方案 我想读与exe文件同目录下的XML,怎么读取? 之前没接触过WINCE,请各位多指教…
键盘 scancodetovirtualkey
scancodetovirtualkey,我看了源码是调用*puiVk = MapVirtualKey(*puiSc, MAP_SC_TO_VK); 但这个函数我没找到。有谁知道的,帮忙解答下```…
求助:udp协议网络通信的实现
根据udp的协议,编写了服务器端和客户机端的程序,想验证一下收发数据是否正确,可以将收发的程序都下载到目标机下,通过自发自收来实现?vxworks下本机的ip还是:127.0.0.1吗??不知道这种方法是否可以实现??…
委托开发GPS接收存储终端
我司开发一个gps的接收终端,要求 1)通过电池/直流电供电 2)定时(如每5秒钟)接收一次gps位置信息,然后保存到终端内的存储卡中 3)终端有一个小屏幕显示一些基本信息,工作状态、时间等 4)终端可以通过usb接入电脑,按fat文件格式,由电脑 ...…
