今天是:2025年02月02日(星期日)
2020年02月02日 | Ubuntu 安装arm-linux-gcc编译器
2020-02-02 来源:eefocus
* Ubuntu 安装arm-linux-gcc编译器
* 说明:
* Ubuntu下直接安装arm-linux-gcc编译器,省得去配置那些环境。
* 2017-3-21 深圳 南山平山村 曾剑锋
一、参考文档:
Install the ARM cross compiler toolchain on your Linux Ubuntu PC
https://www.acmesystems.it/arm9_toolchain
二、查找支持armhf的软件包名:
zengjf@zengjf:~/zengjf/zengjfos/busybox/busybox-1.26.2$ sudo apt-cache search arm | grep gcc | grep armhf
gcc-arm-linux-gnueabihf - GNU C compiler for the armhf architecture
libgcc-6-dev-armhf-cross - GCC support library (development files)
libgcc1-armhf-cross - GCC support library
gcc-multilib-arm-linux-gnueabihf - GNU C compiler for the armhf architecture
gccgo-arm-linux-gnueabihf - Go compiler (based on GCC) for the armhf architecture
libgcc-4.7-dev-armhf-cross - GCC support library (development files)
libgcc-4.9-dev-armhf-cross - GCC support library (development files)
libgcc-5-dev-armhf-cross - GCC support library (development files)
libgcc1-dbg-armhf-cross - GCC support library (debug symbols)
libsfgcc-4.7-dev-armhf-cross - GCC support library (soft float ABI development files)
libsfgcc-4.9-dev-armhf-cross - GCC support library (soft float ABI development files)
libsfgcc-5-dev-armhf-cross - GCC support library (soft float ABI development files)
libsfgcc-6-dev-armhf-cross - GCC support library (soft float ABI development files)
libsfgcc1-armhf-cross - GCC support library (soft float ABI)
libsfgcc1-dbg-armhf-cross - GCC support library (debug symbols)
三、安装命令:
1. sudo apt-get install gcc-arm-linux-gnueabihf
2. 安装结果:
zengjf@zengjf:~/zengjf/zengjfos/busybox/busybox-1.26.2$ arm
arm2hpdl arm-linux-gnueabihf-gcc arm-linux-gnueabihf-gcov-6 arm-linux-gnueabihf-objdump
arm-linux-gnueabihf-addr2line arm-linux-gnueabihf-gcc-6 arm-linux-gnueabihf-gcov-tool arm-linux-gnueabihf-ranlib
arm-linux-gnueabihf-ar arm-linux-gnueabihf-gcc-ar arm-linux-gnueabihf-gcov-tool-6 arm-linux-gnueabihf-readelf
arm-linux-gnueabihf-as arm-linux-gnueabihf-gcc-ar-6 arm-linux-gnueabihf-gprof arm-linux-gnueabihf-size
arm-linux-gnueabihf-c++filt arm-linux-gnueabihf-gcc-nm arm-linux-gnueabihf-ld arm-linux-gnueabihf-strings
arm-linux-gnueabihf-cpp arm-linux-gnueabihf-gcc-nm-6 arm-linux-gnueabihf-ld.bfd arm-linux-gnueabihf-strip
arm-linux-gnueabihf-cpp-6 arm-linux-gnueabihf-gcc-ranlib arm-linux-gnueabihf-ld.gold
arm-linux-gnueabihf-dwp arm-linux-gnueabihf-gcc-ranlib-6 arm-linux-gnueabihf-nm
arm-linux-gnueabihf-elfedit arm-linux-gnueabihf-gcov arm-linux-gnueabihf-objcopy
上一篇:ARM JTAG 调试原理
下一篇:ARM-Linux中断系统
rt 2410的串口0是完备串口,我们想用它做别的用途 但是它默认是超级终端的调试串口, 我能不能通过修改bootloader来改变它,就是把串口0释放出来,使用串口1作为超级终端的调试串口啊? 多谢… 查看全部问答> |
看了一个多星期的驱动程序开发 然后从网上下了不少资料,看了不少 现在对虚拟串口大概有个了解 但也不是很清楚,希望做过的能给个思路!~~ 注册表和驱动程序之间的联系... 是通过添加注册表实现虚拟串口,还是直接 通过驱动程序虚拟一个串口使用?… 查看全部问答> |
一个DATA FLASH的读写程序找人开发,就是通过COM口吧数据写到板子的闪存(DATAFLASH)上,,要有开发经验 详情:http://www.xinet.com.cn/123/index.html 联系13870920010张先生,QQ:123013020… 查看全部问答> |
ATmega169V驱动段码液晶片,电压5V,取1/3Bias,60Hz, 在静态有部分显示,1/2duty、1/3duty、1/4duty都没有显示,可能是什么原因? 初始化如下: LCDCRB=0x30; LCDFRR=0x66; LCDCCR=0x0F; 。。。。。 LCDCRA=0x80;… 查看全部问答> |
如图,求高手帮分析一下箭头所指的右边电路的工作方式,电容C2是高频信号的正向通路还是反馈网络的一部分?如果是反馈网络,那C2的作用是什么呢? R1,C1是滤波器是肯定的。… 查看全部问答> |
我已经拿到LPC810的板子了 可是在下载程序的时候遇到了一些问题; 我用的是一个232的ISP下载串口板; 软件用的是Flash Magic 读取芯片ID正常; 擦除Flash正常; 但是不能往里写入程序; 总是卡在这里,不能往下进行; 有哪个大虾遇到过这 ...… 查看全部问答> |
得到一个写着MSP-FET430UIF的烧写器,连接到电脑显示驱动安装好了。但是我的ccs中device connection中没有显示这个,只有USB。请问如何安装使用?… 查看全部问答> |
我想问下论坛的大神,我现在在把GPS的经纬度可以定位发送到GSM模块中,在手机显示是经纬度。。我想的是,可以显示当前的所在地址或者是地图的连接。。打算用GSM模块的GPRS,但感觉好像不行,因为还是要电脑操作。。请问大神们,怎么可以发送信息的 ...… 查看全部问答> |
