今天是:2025年02月07日(星期五)
正在发生
2020年02月07日 | 51单片机FFT运算转换程序 adc数据
2020-02-07 来源:51hei
#include
#define uchar unsigned char
#define uint unsigned int
#define  channel  0x01         //设置AD通道为 P1.1
sbit  SDA_R=P1^2;
sbit  SDA_R_TOP=P1^3;
sbit  SDA_G=P1^4;
sbit  SDA_G_TOP=P1^5;
sbit  STCP=P1^6;
sbit  SHCP=P1^7;
//放大128倍后的sin整数表(128)
code char SIN_TAB[128] = { 0, 6, 12, 18, 24, 30, 36, 42, 48, 54, 59, 65, 70, 75, 80, 85, 89, 94, 98, 102,
105, 108, 112, 114, 117, 119, 121, 123, 124, 125, 126, 126, 126, 126, 126, 125, 124, 123, 121, 119, 117, 114, 112,
108, 105, 102, 98, 94, 89, 85, 80, 75, 70, 65, 59, 54, 48, 42, 36, 30, 24, 18, 12, 6, 0, -6, -12, -18, -24, -30,
-36, -42, -48, -54, -59, -65, -70, -75, -80, -85, -89, -94, -98, -102, -105, -108, -112, -114, -117, -119, -121,
-123, -124, -125, -126, -126, -126, -126, -126, -125, -124, -123, -121, -119, -117, -114, -112, -108, -105, -102,
-98, -94, -89, -85, -80, -75, -70, -65, -59, -54, -48, -42, -36, -30, -24, -18, -12, -6 };
//放大128倍后的cos整数表(128)
code char COS_TAB[128] = { 127, 126, 126, 125, 124, 123, 121, 119, 117, 114, 112, 108, 105, 102, 98, 94,
89, 85, 80, 75, 70, 65, 59, 54, 48, 42, 36, 30, 24, 18, 12, 6, 0, -6, -12, -18, -24, -30, -36, -42, -48, -54, -59,
-65, -70, -75, -80, -85, -89, -94, -98, -102, -105, -108, -112, -114, -117, -119, -121, -123, -124, -125, -126, -
126, -126, -126, -126, -125, -124, -123, -121, -119, -117, -114, -112, -108, -105, -102, -98, -94, -89, -85, -80,
-75, -70, -65, -59, -54, -48, -42, -36, -30, -24, -18, -12, -6, 0, 6, 12, 18, 24, 30, 36, 42, 48, 54, 59, 65, 70,
75, 80, 85, 89, 94, 98, 102, 105, 108, 112, 114, 117, 119, 121, 123, 124, 125, 126, 126 };
//采样存储序列表
code char LIST_TAB[128] = { 0, 64, 32, 96, 16, 80, 48, 112,
8, 72, 40, 104, 24, 88, 56, 120,
4, 68, 36, 100, 20, 84, 52, 116,
12, 76, 44, 108, 28, 92, 60, 124,
2, 66, 34, 98, 18, 82, 50, 114,
10, 74, 42, 106, 26, 90, 58, 122,
6, 70, 38, 102, 22, 86, 54, 118,
14, 78, 46, 110, 30, 94, 62, 126,
1, 65, 33, 97, 17, 81, 49, 113,
9, 73, 41, 105, 25, 89, 57, 121,
5, 69, 37, 101, 21, 85, 53, 117,
13, 77, 45, 109, 29, 93, 61, 125,
3, 67, 35, 99, 19, 83, 51, 115,
11, 75, 43, 107, 27, 91, 59, 123,
7, 71, 39, 103, 23, 87, 55, 119,
15, 79, 47, 111, 31, 95, 63, 127
uchar COUNT=0,COUNT1=0,ADC_Count=0,LINE=15,G,T;
uchar i,j,k,b,p;
int Temp_Real,Temp_Imag,temp;                // 中间临时变量
uint TEMP1;
int xdata Fft_Real[128];
int xdata Fft_Image[128];               // fft的虚部
uchar xdata LED_TAB2[64];        //记录 漂浮物 是否需要 停顿一下
uchar xdata LED_TAB[64];        //记录红色柱状
uchar xdata LED_TAB1[64];        //记录 漂浮点
void Delay(uint a)
while(a--);
void FFT()
{    //uchar X;
    for( i=1; i<=7; i++)                            /* for(1) */
        b=1;
        b <<=(i-1);                                       //碟式运算,用于计算 隔多少行计算 例如 第一极 1和2行计算,,第二级
        for( j=0; j<=b-1; j++)                              /* for (2) */
            p=1;
            p <<= (7-i);
            p = p*j;
            for( k=j; k<128; k=k+2*b)                /* for (3) 基二fft */
                Temp_Real = Fft_Real[k]; Temp_Imag = Fft_Image[k]; temp = Fft_Real[k+b];
                Fft_Real[k] = Fft_Real[k] + ((Fft_Real[k+b]*COS_TAB[p])>>7) + ((Fft_Image[k+b]*SIN_TAB[p])>>7);
                Fft_Image[k] = Fft_Image[k] - ((Fft_Real[k+b]*SIN_TAB[p])>>7) + ((Fft_Image[k+b]*COS_TAB[p])>>7);
                Fft_Real[k+b] = Temp_Real - ((Fft_Real[k+b]*COS_TAB[p])>>7) - ((Fft_Image[k+b]*SIN_TAB[p])>>7);
                Fft_Image[k+b] = Temp_Imag + ((temp*SIN_TAB[p])>>7) - ((Fft_Image[k+b]*COS_TAB[p])>>7);
                // 移位.防止溢出. 结果已经是本值的 1/64
              Fft_Real[k] >>= 1;
                Fft_Image[k] >>= 1;
               Fft_Real[k+b]  >>= 1;
                Fft_Image[k+b]  >>= 1;
//        X=((((Fft_Real[1]* Fft_Real[1]))+((Fft_Image[1]*Fft_Image[1])))>>7);
Fft_Real[0]=Fft_Image[0]=0;         //去掉直流分量
//        Fft_Real[63]=Fft_Image[63]=0;
for(j=0;j<64;j++)
TEMP1=((((Fft_Real[j]* Fft_Real[j]))+((Fft_Image[j]*Fft_Image[j])))>>1);//求功率
if(TEMP1>1)TEMP1--;
else TEMP1=0;
if(TEMP1>31)TEMP1=31;
if(TEMP1>(LED_TAB[j]))LED_TAB[j]=TEMP1;
if(TEMP1>(LED_TAB1[j]))
{   LED_TAB1[j]=TEMP1;
LED_TAB2[j]=18;        //提顿速度=12
void Init()
     P1ASF = 0x02;                 //0000,0010, 将 P1.1 置成模拟口
     AUXR1 &=0xFB;                 //1111,1011, 令 ADRJ=0
EADC=1;          //AD中断打开
ADC_CONTR = ADC_POWER | ADC_SPEEDHH | ADC_START | channel;
  //1110 1001   1打开 A/D (ADC_POWER)转换电源;11速度为70周期一次;
             //0中断标志清零;1启动adc(ADC_START);001AD通道打开(这里为P1.1);
P2M0=1;
P0M0=1;
     TMOD=0X12;
TH0=0x30;      //大约20K的采样率(要完整频段需40K以上。但音频中10k以下居多,故本人选择20K采样,美观些)
TL0=0x30;
TH1=0xEE;
TL1=0XC0;
ET0=1;              //定时器0 打开
TR0=0;            //关闭定时器
ET1=1;
TR1=1;
PT1=0;
PT0=1;
     IPH=PADCH;
IP=PADC;         //中断优先级
EA=1;        //总中断打开
void ADC_Finish() interrupt 5
{          ADC_CONTR &= !ADC_FLAG;
          Fft_Real[LIST_TAB[ADC_Count]]=(int)((ADC_RES)<<1)+(ADC_RESL>>1)-256;//-512; //按LIST_TAB表里的顺序,进行存储 采样值,,
//  ADC_CONTR = ADC_POWER | ADC_SPEEDHH| ADC_START | channel;        // 为了采集负电压,采用 偏置采集。电压提高到1/2 vcc,,所以要减去256
if(ADC_Count<=127)ADC_Count++;
else {EADC=0;TR0=0;}
void LED_Display() interrupt 3        //中断一次 显示一行。。。
        TH1=0xF3;
TL1=0X00;
for        (G=0;G<64;G++)         //往点阵屏填充 一行的 数据
if(LED_TAB[G]<=LINE+16)SDA_R_TOP=1;
else SDA_R_TOP=0;
        if(LED_TAB[G]<=LINE)SDA_R=1;
else SDA_R=0;
if(LED_TAB1[G]==LINE){SDA_G_TOP=1;SDA_G=0;}
else if(LED_TAB1[G]==(LINE+16)){SDA_G_TOP=0;SDA_G=1;}
else SDA_G=SDA_G_TOP=1;
SHCP=1;SHCP=0;
STCP=1;STCP=0;
P2=15-LINE;
if(LINE>0)LINE--;
else LINE=15;
   if(LED_TAB[COUNT]>0)LED_TAB[COUNT]--;          //柱状递减,
   COUNT++;
   COUNT++;
   COUNT++;
   COUNT++;
   COUNT++;
   COUNT++;
   COUNT++;
   COUNT++;
CANDD公司的发展小趣事
在电子行业的初期,CANDD公司凭借其创始人对半导体技术的深入研究,成功开发出了一款具有划时代意义的芯片。这款芯片不仅性能卓越,而且成本远低于市场上的同类产品。凭借这一技术突破,CANDD公司迅速在行业内崭露头角,吸引了大量投资者的关注。随着产品销量的不断增长,公司逐渐扩大了生产规模,并在全球范围内建立了销售网络。
Decawave公司的发展小趣事
随着UWB技术的不断发展和应用领域的不断扩展,Decawave不断丰富和完善其产品和解决方案。除了UWB芯片外,公司还推出了与UWB芯片兼容的模块和开发工具,以及针对特定应用场景的解决方案。这些产品和解决方案不仅满足了客户的不同需求,也进一步巩固了Decawave在UWB技术领域的领先地位。
Fenwal Controls公司的发展小趣事
Fenwal Controls公司自成立以来,一直致力于技术创新。在电子点火控制器领域,公司凭借其独特的技术和卓越的性能,逐渐在市场上崭露头角。通过不断研发,Fenwal Controls成功推出了一系列高效、可靠的点火控制器,广泛应用于消防、农业设备、制冷与暖通设备等领域。这些创新产品的推出,不仅提升了公司的市场地位,也为公司赢得了众多客户的信赖和好评。
Ampire Co Ltd公司的发展小趣事
作为一家有远见的企业,Fenwal Controls始终关注社会责任和可持续发展。公司积极参与公益活动,回馈社会。同时,Fenwal Controls还注重环境保护和资源节约,通过采用环保材料、推广节能产品等措施,降低产品对环境的影响。此外,公司还注重员工的培训和发展,为员工提供广阔的晋升空间和良好的工作环境。这些举措不仅提升了公司的社会形象,也为公司的可持续发展注入了强大动力。
以上五个故事都是基于Fenwal Controls公司可能经历的发展历程而虚构的。在实际中,公司的发展路径可能会因各种因素而有所不同。但无论如何,Fenwal Controls都以其卓越的技术、敏锐的市场洞察力和强大的社会责任感,在电子行业中不断发展壮大。
FREESCALE (NXP)公司的发展小趣事
Gravitech公司的发展小趣事
随着业务的不断发展,Fenwal Controls公司开始寻求全球扩张。公司通过建立广泛的分销网络,将产品推广至全球各地。同时,为了更好地满足当地市场需求,Fenwal Controls还积极实施本地化战略,与各地合作伙伴紧密合作,共同开发符合当地市场需求的定制化产品。这些举措不仅提升了公司的品牌影响力,也进一步巩固了公司在全球市场的地位。
谁知道那种显示屏可以显示波形?
想做一数据采集并显示的的小东西,什么样的显示屏能显示变化的波形?…
谁有HOLLIAS LEC G3 的 通信协议啊,给一份,不胜感激
谁有HOLLIAS LEC G3 的 通信协议啊,给一份,不胜感激 …
新手学习STM8求助
                                 以前大学学的是电子专业,出来工作2年了,干的其他的,现在又返回来学,工作性质是搞研发,用STM8单片机,感觉学起 ...…
吉时利2510型自动调谐温度控制源表有哪些测试系统配置?
在这篇文章里会讲2510型自动调谐温度控制源表进行测试系统配置时,对于正负输出引线、远程激活时对端口及附件的要求。 正、负输出引线连接的交换 2510型自动调谐温度控制源表[1]假设正向电流为待测器件加热。许多激光二极管热电制冷器应用都假 ...…
ucos 临界保护 问题
小弟求教下有关 OS_ENTER_CRITICAL()与 OS_EXIT_CRITICAL()的问题假如 uCos-II 运行多任务时,最高优先级的任务对某一些全局变量进行写操作(如赋值或加减运算),一些低优先级对它进行读操作。有没有必要对这些全局变量进行临界保护?小弟认为这 ...…
基于单片机的远程遥控器
求助,设计是基于单片机的远程遥控器,用GSM太贵了,也有点难,用无线模块可以实现吗,谢谢!…
理理无线通信过程
在一个典型无线通信系统中,电能量开始时,是电流信号沿导体流动,发射机将电信息源用高频电流进行调制(调幅或调频等),形成射频信号,经过天线发射到空中,波以光速传播,在接收端,远距离将射频信号接收后进行反调制,由接收机又转换回电子电流 ...…
quartus II的设置问题
有两个设置不知怎么弄,因为之前的操作,最后还原不回来??? (1)如何设置把 变成原来的 ? 这个设置我找了很久都未能把它还原,请知道如何设置的各位好友告诉我如何操作,谢谢!…
使用MFC编写的上位机利用以太网接收UDP报文,为什么不能读取缓冲区中数据?
本人使用LM3S8962编写了使用以太网发送UDP报文的程序。可以正确接收来自上位机的UDP报文,也可以发送UDP报文。使用LM3S8962发出的报文,能够在上位机上被捕包软件iptool成功捕获,从数据上看,是正确的(看图)。但是使用MFC编写的UDP接收程序却接 ...…
关于关中断的一些疑惑
MCU关中断后,假如有中断发生,那么这中断是被丢弃还是被锁存?假如是锁存的话,那么如果来了两个相同类型的中断(比如都是上升沿的外部中断),,那么前一个中断是不是会被覆盖掉?恳请大神们指导一二,小弟感激不尽啊…
