今天是:2024年10月29日(星期二)
2020年10月29日 | STM32 USB SD卡读卡器和NAND FLASH模拟U盘
2020-10-29 来源:eefocus
本次工程是要同时实现SD卡读卡器和NAND Flash模拟U盘的功能。结合之前的两个工程,稍稍修改下就可以了。
既然要实现两个盘,当然在usb_prop.c中的Max_Lun变量赋值为1,在USB_User组中同时添加fsmc_nand.c和sdio_sdcard.c这两个文件,在外设库中挺尸添加stm32f10x_sdio.c和stm32f10x_fsmc.c两个文件。
添加完之后,可能会有些许的错误,解决完后,我们就要修改下mass_mal.c文件了,这个文件本次要同时实现SD卡和NAND Flash的相关驱动代码的挂接,代码如下:
uint32_t Mass_Memory_Size[2];
uint32_t Mass_Block_Size[2];
uint32_t Mass_Block_Count[2];
__IO uint32_t Status = 0;
uint16_t MAL_Init(uint8_t lun)
u16 status = MAL_OK;
switch (lun)
case 0:
Status = SD_Init(); //调用SD初始化函数
break;
case 1:
FlashInit();
break;
default:
return MAL_FAIL;
return status;
uint16_t MAL_Write(uint8_t lun, uint32_t Memory_Offset, uint32_t *Writebuff, uint16_t Transfer_Length)
switch (lun)
case 0:
Status = SD_WriteBlock((uint8_t*)Writebuff, Memory_Offset, Transfer_Length);
SD_WaitWriteOperation(); //等待dma传输结束
while(SD_GetStatus() != SD_TRANSFER_OK); //等待sdio到sd卡传输结束
if ( Status != SD_OK )
return MAL_FAIL;
break;
case 1:
FlashWriteOneSector(Memory_Offset,(u8*)Writebuff, Transfer_Length);
break;
default:
return MAL_FAIL;
return MAL_OK;
uint16_t MAL_Read(uint8_t lun, uint32_t Memory_Offset, uint32_t *Readbuff, uint16_t Transfer_Length)
switch (lun)
case 0:
Status = SD_ReadBlock((uint8_t*)Readbuff, Memory_Offset, Transfer_Length);
SD_WaitReadOperation(); //等待dma传输结束
return MAL_FAIL;
break;
case 1:
FlashReadOneSector(Memory_Offset, (u8*)Readbuff, Transfer_Length);
break;
default:
return MAL_FAIL;
return MAL_OK;
uint16_t MAL_GetStatus (uint8_t lun)
uint32_t DeviceSizeMul = 0, NumberOfBlocks = 0;
if (lun == 0)
if (SD_Init() == SD_OK)
SD_GetCardInfo(&SDCardInfo);
SD_SelectDeselect((uint32_t) (SDCardInfo.RCA << 16));
DeviceSizeMul = (SDCardInfo.SD_csd.DeviceSizeMul + 2);
if(SDCardInfo.CardType == SDIO_HIGH_CAPACITY_SD_CARD)
Mass_Block_Count[0] = (SDCardInfo.SD_csd.DeviceSize + 1) * 1024;
else
NumberOfBlocks = ((1 << (SDCardInfo.SD_csd.RdBlockLen)) / 512);
Mass_Block_Count[0] = ((SDCardInfo.SD_csd.DeviceSize + 1) * (1 << DeviceSizeMul) << (NumberOfBlocks/2));
Mass_Block_Size[0] = 512;
Status = SD_SelectDeselect((uint32_t) (SDCardInfo.RCA << 16));
Status = SD_EnableWideBusOperation(SDIO_BusWide_4b);
return MAL_FAIL;
LED2_ON();
return MAL_OK;
else
LED2_OFF();
else
Mass_Block_Count[1] = FLASH_MAX_SECTOR_ADDR/FLASH_SECTOR_SIZE; //NAND_ZONE_SIZE * NAND_BLOCK_SIZE * NAND_MAX_ZONE ;
Mass_Block_Size[1] = FLASH_SECTOR_SIZE; //NAND_PAGE_SIZE;
Mass_Memory_Size[1] = (Mass_Block_Count[1] * Mass_Block_Size[1]);//这里的NAND要选择Mass_Block_Count[1]和Mass_Block_Size[1]
LED4_ON(); //因为SD的的是Mass_Block_Count[0]和Mass_Block_Size[0]
return MAL_OK;
return MAL_FAIL;
这样就可以在电脑上同时出现两个盘,分别是SD卡和NAND模拟出来的。
在调是这个代码之前,曾经粗心,把MAL_GetStatus()l里的NAND相关代码的下成如下:
Mass_Block_Count[0] = FLASH_MAX_SECTOR_ADDR/FLASH_SECTOR_SIZE;
Mass_Block_Size[0] = FLASH_SECTOR_SIZE;
Mass_Memory_Size[0] = (Mass_Block_Count[0] * Mass_Block_Size[0]);
数组元素都是0,与SD卡冲突,导致两个盘都显示不出来,但是你屏蔽掉SD相关的代码是可以的,或则屏蔽掉NAND相关代码也是可以的,偏偏两个代码一起的时候不行,检查了半天,才发现问题出在这里。
各位大虾,我刚开始做vxworks 在broadcom上开发,急需tornado for mips版本,先行谢过!!! QQ: 510765226 谢谢! … 查看全部问答> |
北京港震机电技术有限公司是注册于北京市中关村科技园中的一家高新技术企业,由中国地震局地震预测研究所的下属企业与香港企业共同合资建立。作为集产品研发、制造和提供系统解决方案的高科技实体,北京港震公司致力于数字化地震台网(台站)系统以及 ...… 查看全部问答> |
我用的HP的Pocket PC,型号是hx2400,如何定制合适的SDK,高手请教教我。困扰了2天了。 我是个菜鸟,现在用EVC4.0开发PDA上的程序,目前有设备,但是没有相应的SDK,这就导致写好的程序无法在合适的环境下编译,我试着自己用PB建立SDK,但还是不行。从网上下载了微软的Pocket PC2003的SDK,但是装上后在EVC下的平台选择中没有该项。在网 ...… 查看全部问答> |
现在有一个bluez植入uclinux的课题,本人能力有限,想请大家帮帮忙,当然是有偿帮忙的。哪位有兴趣可以与我联系。vonsavant@163.com… 查看全部问答> |
请见各位 stm32f103vbt6芯片如何读取usb摄像头的图像信息 如何打包再发送出去啊 有相关程序吗 谢谢 可以发我邮箱ahlbzy@126.com… 查看全部问答> |
Windows Embedded CE 6.0 R3 Product Update Rollup, December 31, 2012 How to install this updateAll updates for Windows Embedded CE 6.0 R3 require the following: 1) Platform Builder 6.0 is installed on the machine.2) Upon install ...… 查看全部问答> |
