单片机
[smart210] firstled.s 代码分析及编译分析
2024-12-12 来源:cnblogs
平台:smart210(tiny210v2)
CPU:S5PV210
目标:led灯按照一定频率闪烁
1.代码如下(如果不能编译,请去掉注释):
.globl _start
_start:
    ldr r1, =0xE0200280     //config the GPJ2CON[0to15] as output
    ldr r0, =0x00001111
    str r0, [r1]
    mov r2, #0x1000          //r2=8
led_blink:
     ldr r1, =0xE0200284    //set the GPJ2DAT[0to3] as 0,4 leds would light on!
     mov r0, #0xa
     str r0, [r1]
     bl delay
     ldr r1, =0xE0200284    //set the GPJ2DAT[0to3] as 1,4 leds would light off!
     mov r0, #0x5
     str r0, [r1]
     bl delay
     sub r2,r2,#1        //r2=r2-1
     cmp r2,#0            //if r2!=0 jump to led_blink
     bne led_blink        //then the led_blink will turn 8 times
halt:
    b halt            //while(1)
delay:
    mov r0,#0xf000000        //r0=0xf000000
delay_loop:
    cmp r0,#0            //if r0=0
    sub r0,r0,#1        //r0=r0-1
    bne delay_loop        //after 'cmp r0,#0' ,if r0!=0 jump to delay_loop
                //then the delay_loop will turn 32 times
    mov pc,lr            //come back the main
2.使用以下命令编译链接与反汇编
arm-linux-gcc -c -o firstled.o firstled.s    //对.s文件进行预处理,编译,汇编,生成.o文件
arm-linux-ld -Ttext 0x0 -o led.elf firstled.o    //链接.o文件,并设置代码段起始运行地址为0x0 ,生成.elf
arm-linux-objcopy -O binary led.elf led.bin    //将.elf文件复制一份,并以二进制.bin形式保存,该形式可在开发板上使用
arm-linux-objdump -D led.elf > led_elf.dis    //将.elf文件反汇编成.dis文件,方便调试程序
3.使用以下命令给led.bin添加头部
./mkmini210 led.bin led210.bin
其中,mkmini210由程序mkv210_image.c编译而来,mkv210_image.c内容如下
/* 在BL0阶段,Irom内固化的代码读取nandflash或SD卡前16K的内容,
 * 并比对前16字节中的校验和是否正确,正确则继续,错误则停止。*/
#include
#include
#include
#define BUFSIZE                 (16*1024)
#define IMG_SIZE                (16*1024)
#define SPL_HEADER_SIZE         16
#define SPL_HEADER              'S5PC110 HEADER  '
int main (int argc, char *argv[])
    FILE        *fp;
    char        *Buf, *a;
    int        BufLen;
    int        nbytes, fileLen;
    unsigned int    checksum, count;
    int        i;
    // 1. 3个参数
    if (argc != 3)
        printf('Usage: mkbl1 n');
        return -1;
    // 2. 分配16K的buffer
    BufLen = BUFSIZE;
    Buf = (char *)malloc(BufLen);
    if (!Buf)
        printf('Alloc buffer failed!n');
        return -1;
    memset(Buf, 0x00, BufLen);
    // 3. 读源bin到buffer
    // 3.1 打开源bin
    fp = fopen(argv[1], 'rb');
    if( fp == NULL)
        printf('source file open errorn');
        free(Buf);
        return -1;
    // 3.2 获取源bin长度
    fseek(fp, 0L, SEEK_END);
    fileLen = ftell(fp);
    fseek(fp, 0L, SEEK_SET);
    // 3.3 源bin长度不得超过16K-16byte
    count = (fileLen < (IMG_SIZE - SPL_HEADER_SIZE))
        ? fileLen : (IMG_SIZE - SPL_HEADER_SIZE);
    // 3.4 buffer[0~15]存放'S5PC110 HEADER  '
    memcpy(&Buf[0], SPL_HEADER, SPL_HEADER_SIZE);
    // 3.5 读源bin到buffer[16]
    nbytes = fread(Buf + SPL_HEADER_SIZE, 1, count, fp);
    if ( nbytes != count )
        printf('source file read errorn');
        free(Buf);
        fclose(fp);
        return -1;
    fclose(fp);
    // 4. 计算校验和
     // 4.1 从第16byte开始统计buffer中共有几个1
    a = Buf + SPL_HEADER_SIZE;
    for(i = 0, checksum = 0; i < IMG_SIZE - SPL_HEADER_SIZE; i++)
        checksum += (0x000000FF) & *a++;
    // 4.2 将校验和保存在buffer[8~15]
    a = Buf + 8;
    *( (unsigned int *)a ) = checksum;
    // 5. 拷贝buffer中的内容到目的bin
    // 5.1 打开目的bin
    fp = fopen(argv[2], 'wb');
    if (fp == NULL)
        printf('destination file open errorn');
        free(Buf);
        return -1;
    // 5.2 将16k的buffer拷贝到目的bin中
    a = Buf;
    nbytes    = fwrite( a, 1, BufLen, fp);
    if ( nbytes != BufLen )
        printf('destination file write errorn');
        free(Buf);
        fclose(fp);
        return -1;
    free(Buf);
    fclose(fp);
    return 0;
这段代码完成的工作是:
第一步 分配16k 的buffer;
第二步 将led.bin 读到buffer的第16byte开始的地方;
第三步 计算校验和,并将校验和保存在buffer第8~11byte中;
第四步 将16k 的buffer拷贝到led210.bin 中;
4.下载led210.bin到smart210
这里使用minitools下载.bin文件,操作过程比较简单就不再赘述了
5.运行效果是4个LED交替闪烁,频率约为0.8s左右
进入单片机查看更多内容>>
相关视频
  • 【TI MSPM0 应用实战】智能小车+工业角度编码器+血氧仪+烟雾探测器!硬核参考设计详解!
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
  • 直播回放: Microchip Timberwolf™ 音频处理器在线研讨会
  • 基于灵动MM32W0系列MCU的指夹血氧仪控制及OTA升级应用方案分享
精选电路图
  • 1瓦线性调频增强器
  • 家用电器遥控器
  • 12V 转 28V DC-DC 变换器(基于 LM2585)
  • 红外开关
  • DS1669数字电位器
  • HA1377 桥式放大器 BCL 电容 17W(汽车音频)
    相关电子头条文章
