用内核定时器来实现的按键驱动代码分析以及测试代码
2025-02-06 来源:cnblogs
驱动代码:
#include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include #include struct class *key_class; static int key_major = 0; struct key_desc_t { int pin; //which gpio pin int pin_dir;//input or output int number; char *name; }; /*设备结构体*/ static struct key_dev { struct cdev cdev; struct timer_list key_timer;/*内核定时器*/ }; struct key_dev *key_devp;//设备结构体指针 #define MAX_KEYS 5 /* 用来指定按键所用gpio的编号,方向和名字 */ static struct key_desc_t key_desc [] = { {S5PV210_GPH0(3), S3C_GPIO_INPUT, 0, 'KEY1'}, /* K1 */ {S5PV210_GPH0(4), S3C_GPIO_INPUT, 1, 'KEY2'}, /* K2 */ {S5PV210_GPH0(5), S3C_GPIO_INPUT, 2, 'KEY3'}, /* K3 */ {S5PV210_GPH0(6), S3C_GPIO_INPUT, 3, 'KEY4'}, /* K4 */ {S5PV210_GPH0(7), S3C_GPIO_INPUT, 4, 'KEY5'}, /* K5 */ }; /* 按键被按下的次数*/ static volatile int key_values [MAX_KEYS] = {0, 0, 0, 0, 0}; /* 等待队列: * 当没有按键被按下时,如果有进程调用key_read函数, * 它将休眠 */ static DECLARE_WAIT_QUEUE_HEAD(key_waitq); #define KEY_TIMER_DELAY HZ/50 /*20ms*/ /* 事件标志, 有键按下时将它置1,key_read将它清0 */ static volatile int ev_press = 0; static void key_timer_handle(unsigned long data) { struct key_desc_t *key_p = (struct key_desc_t *)data; int down; static unsigned char pressed[MAX_KEYS] = {0}; int i; for(i=0;i down = gpio_get_value(key_p->pin); if(!down) //key pressed { pressed[i] ++; if(pressed[i] > 2) pressed[i] = 3; } if((!down) && (2 == pressed[i]))//要等待20ms再检查一下该按键确实是被按下,而不是抖动 { printk('pressedn'); key_values[i] = i + 1; ev_press = 1; /* 表示按键被按下了 */ wake_up_interruptible(&key_waitq); /* 唤醒休眠的进程 */ } if(down && pressed[i]) //如果该键被释放 { pressed[i] = 0; } } /*调度定时器再次执行*/ key_devp->key_timer.expires = jiffies + KEY_TIMER_DELAY; add_timer(&key_devp->key_timer); } /* 应用程序对设备文件/dev/key执行open(...)时, * 就会调用key_open函数 */ static int key_open(struct inode *inode, struct file *file) { return 0; } /* 应用程序对设备文件/dev/key执行close(...)时, * 就会调用key_close函数 */ static int key_close(struct inode *inode, struct file *file) { int i=0; for(i=0;i return 0; } /* 应用程序对设备文件/dev/key执行read(...)时, * 就会调用key_read函数 */ static int key_read(struct file *filp, char __user *buff, size_t count, loff_t *offp) { unsigned long err; if (!ev_press) { if (filp->f_flags & O_NONBLOCK) return -EAGAIN; else /* 如果ev_press等于0,休眠 */ wait_event_interruptible(key_waitq, ev_press); } /* 执行到这里时,ev_press等于1,将它清0 */ ev_press = 0; /* 将按键状态复制给用户,并清0 */ err = copy_to_user(buff, (const void *)key_values, min(sizeof(key_values), count)); memset((void *)key_values, 0, sizeof(key_values)); return err ? -EFAULT : min(sizeof(key_values), count); } /************************************************** * 当用户程序调用select函数时,本函数被调用 * 如果有按键数据,则select函数会立刻返回 * 如果没有按键数据,本函数使用poll_wait等待 **************************************************/ static unsigned int key_poll(struct file *file, struct poll_table_struct *wait) { unsigned int mask = 0; poll_wait(file, &key_waitq, wait); if (ev_press) mask |= POLLIN | POLLRDNORM; return mask; } /* 这个结构是字符设备驱动程序的核心 * 当应用程序操作设备文件时所调用的open、read、write等函数, * 最终会调用这个结构中的对应函数 */ static struct file_operations key_fops = { .owner = THIS_MODULE, /* 这是一个宏,指向编译模块时自动创建的__this_module变量 */ .open = key_open, .release = key_close, .read = key_read, .poll = key_poll, }; void set_gpio_mode_for_key(struct key_desc_t * key) { int i; for(i = 0; i < MAX_KEYS; i ++,key ++) { //s3c_gpio_pullup(key->pin, 1); s3c_gpio_cfgpin(key->pin, key->pin_dir); } } /* * Set up the cdev structure for a device. */ static void key_setup_cdev(struct key_dev *dev, int minor) { printk('in the key_setup_cdev!!n'); int err, devno = MKDEV(key_major, minor); cdev_init(&dev->cdev, &key_fops); //dev->cdev.owner = THIS_MODULE; //dev->cdev.ops = &key_fops; printk('cdev_init success!!n'); err = cdev_add (&dev->cdev, devno, 1); /* Fail gracefully if need be */ if (err) printk (KERN_NOTICE 'Error %d adding key%d', err, minor); printk('key_setup_cdev success!!n'); } /* * We export one key device. There's no need for us to maintain any * special housekeeping info, so we just deal with raw cdev. */ //static struct cdev key_cdev; /* * 执行“insmod *.ko”命令时就会调用这个函数 */ static int __init button_init(void) { int result; dev_t dev = MKDEV(key_major, 0); char dev_name[]='key'; /*申请gpio*/ int ret; int i=0; for(i=0;i ret=gpio_request(key_desc[i].pin,'KEY'); if(ret) { printk('fail to request gpio %d !!n',key_desc[i].pin); return 0; } } printk('request gpio success!!n'); /* Figure out our device number. */ if (key_major) result = register_chrdev_region(dev, 1, dev_name); else { result = alloc_chrdev_region(&dev, 0, 1, dev_name); key_major = MAJOR(dev); } if (result < 0) { printk(KERN_WARNING 'key: unable to get major %dn', key_major); return result; } if (key_major == 0) key_major = result; printk('alloc_chrdev_region success !!n'); /* 动态申请设备结构体的内存*/ key_devp = kmalloc(sizeof(struct key_dev), GFP_KERNEL);//kmalloc()内核空间;malloc()用户空间。返回起始地址 if (!key_devp) /*申请失败*/ { result = - ENOMEM; printk('key_devp kmalloc failed!!n'); } memset(key_devp, 0, sizeof(struct key_dev));//把此内存空间清零 /* Now set up cdev. */ key_setup_cdev(key_devp, 0); printk('key device installed, with major %dn', key_major); printk('The device name is: /dev/%sn', dev_name); /*set gpio mode*/ //set_gpio_mode_for_key(key_desc); /*init kernel timer*/ init_timer(&key_devp->key_timer); key_devp->key_timer.function = &key_timer_handle; key_devp->key_timer.data = (unsigned long)key_desc; key_devp->key_timer.expires = jiffies + KEY_TIMER_DELAY; add_timer(&key_devp->key_timer); /*用udev机制自动添加设备结点*/ key_class=class_create(THIS_MODULE,'key_class'); device_create(key_class,NULL,key_devp->cdev.dev,NULL,dev_name); return 0; } /* * 执行rmmod key_drv.ko”命令时就会调用这个函数 */ static void __exit button_cleanup(void) { cdev_del(&key_devp->cdev); unregister_chrdev_region(MKDEV(key_major, 0), 1); del_timer_sync(&key_devp->key_timer); printk('key device uninstalledn'); } /* 这两行指定驱动程序的初始化函数和卸载函数 */ module_init(button_init); module_exit(button_cleanup); /* 描述驱动程序的一些信息,不是必须的 */ MODULE_AUTHOR('mhb@SEU'); // 驱动程序的作者 MODULE_DESCRIPTION('KEY Driver'); // 一些描述信息 MODULE_LICENSE('GPL'); // 遵循的协议 测试代码: #include #include #include #include #include #include #include #include #include #include int main(void) { int i; int key_fd; int key_value[5]; /*打开键盘设备文件*/ key_fd = open('/dev/key', 0); if (key_fd < 0) { perror('open device key'); exit(1); } for (;;) { fd_set rds; int ret; FD_ZERO(&rds); FD_SET(key_fd, &rds); /*使用系统调用select检查是否能够从/dev/key设备读取数据*/ ret = select(key_fd + 1, &rds, NULL, NULL, NULL); /*读取出错则退出程序*/ if (ret < 0) { perror('select'); exit(1); } if (ret == 0) { printf('Timeout.n'); } /*能够读取到数据*/ else if (FD_ISSET(key_fd, &rds)) { /*开始读取键盘驱动发出的数据,注意key_value和键盘驱动中定义为一致的类型*/ int ret = read(key_fd, key_value, sizeof key_value); if (ret != sizeof key_value) { if (errno != EAGAIN) perror('read keyn'); continue; } else { /*打印键值*/ for (i = 0; i < 5; i++) printf('K%d %s, key value = 0x%02xn', i+1, (key_value[i] & 0x80) ? 'released': key_value[i] ? 'pressed down' : '', key_value[i]); } } } /*关闭设备文件句柄*/ close(key_fd); return 0; }
- 六大全新产品系列推出,MCX A微控制器家族迎来创新
- 意法半导体全新STM32C5系列,重新定义入门级微控制器性能与价值,赋能万千智能设备
- 从控制到系统:TI利用边缘AI重塑嵌入式MCU的边界
- 模组复用与整机重测在SRRC、CCC、CTA/NAL认证中的实践操作指南
- 有源晶振与无源晶振的六大区别详解
- 英飞凌持续巩固全球微控制器市场领导地位
- 使用 Keil Studio for Visual Studio Code开发 STM32 设备
- 蓝牙信道探测技术原理与开发套件实践
- LoRa、LoRaWAN、NB-IoT与4G DTU技术对比及工业无线方案选型分析
- Microchip 推出生产就绪型全栈边缘 AI 解决方案,赋能MCU和MPU实现 智能实时决策
