代码示例_poll的多路复用
2025-02-06 来源:cnblogs
//头文件
#include #include #include #include #include #include #include #include #include #include #include #include #include #include #include //定义一个按键的数据包 struct button_event{ int code; //按键的名称---键值:KEY_DOWN int value; //按键的状态---按下:1,松开:0 }; //设计一个描述按键的结构体类型 struct buttons{ char *name; //名称 unsigned int irqno; //中断号 int gpio; //按键对应的gpio口 int code; //键值 unsigned long flags; //触发方式 }; //定义一个数组来保存多个按键的数据 struct buttons buttons_set[] = { [0] = { .name = 'key1_up', .irqno = IRQ_EINT(0), .gpio = S5PV210_GPH0(0), .code = KEY_UP, .flags = IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING, }, [1] = { .name = 'key2_down', .irqno = IRQ_EINT(1), .gpio = S5PV210_GPH0(1), .code = KEY_DOWN, .flags = IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING, }, [2] = { .name = 'key3_left', .irqno = IRQ_EINT(2), .gpio = S5PV210_GPH0(2), .code = KEY_LEFT, .flags = IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING, }, [3] = { .name = 'key4_right', .irqno = IRQ_EINT(3), .gpio = S5PV210_GPH0(3), .code = KEY_RIGHT, .flags = IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING, }, }; //面向对象编程----设计设备的类型 struct s5pv210_button{ //unsigned int major; dev_t devno; struct class * cls; struct device * dev; struct cdev *cdev; unsigned int irqno; struct button_event event; wait_queue_head_t wq_head; int have_data; //表示当前是否有数据可读,可读--1,不可读--0 }; struct s5pv210_button *button_dev; //实现中断处理函数--------当触发中断时会被执行 irqreturn_t button_irq_svc(int irqno, void *dev) { int value; struct buttons *p; printk('--------^_^ %s------------n',__FUNCTION__); //获取当前触发中断的按键信息 p = (struct buttons *)dev; //获取产生中断的gpio口的值 value = gpio_get_value(p->gpio); //判断是按下还是松开 if(value){ //松开 printk('kernel:%s up!n',p->name); button_dev->event.code = p->code; button_dev->event.value = 0; }else{ //按下 printk('kenel:%s pressed!n',p->name); button_dev->event.code = p->code; button_dev->event.value = 1; } //此时有数据可读 button_dev->have_data = 1; //从等待队列中唤醒阻塞的进程 wake_up_interruptible(&button_dev->wq_head); return IRQ_HANDLED; } //实现设备操作接口 int button_open(struct inode *inode, struct file *filp) { printk('--------^_^ %s------------n',__FUNCTION__); return 0; } ssize_t button_read(struct file *filp , char __user *buf , size_t size, loff_t *flags) { int ret; printk('--------^_^ %s------------n',__FUNCTION__); //判读open时,有没有设置flags为NONBLOCK if(filp->f_flags & O_NONBLOCK && !button_dev->have_data) return -EAGAIN; //判断此时是否有数据可读 wait_event_interruptible(button_dev->wq_head,button_dev->have_data); //将内核数据转换为用户空间数据 ret = copy_to_user(buf,&button_dev->event,size); if(ret > 0){ printk('copy_to_user error!n'); return -EFAULT; } //将数据返回给应用空间后,清空数据包,同时将hava_data置零 memset(&button_dev->event,0,sizeof(button_dev->event)); button_dev->have_data = 0; return size; } ssize_t button_write(struct file *filp, const char __user *buf, size_t size, loff_t *flags) { printk('--------^_^ %s------------n',__FUNCTION__); return size; } long button_ioctl(struct file *filp, unsigned int cmd , unsigned long args) { printk('--------^_^ %s------------n',__FUNCTION__); return 0; } unsigned int button_poll(struct file *filp, struct poll_table_struct *pts) { unsigned int mask = 0; printk('--------^_^ %s------------n',__FUNCTION__); //1,将等待队列头注册到系统中(VFS) poll_wait(filp,&button_dev->wq_head,pts); //2,如果产生按键中断-有数据可读,此时返回POLLIN,如果没有数据返回0 if(button_dev->have_data) mask |= POLLIN; return mask; } int button_close(struct inode *inode, struct file *filp) { printk('--------^_^ %s------------n',__FUNCTION__); return 0; } static struct file_operations fops = { .open = button_open, .read = button_read, .write = button_write, .poll = button_poll, .unlocked_ioctl = button_ioctl, .release = button_close, }; //加载函数和卸载函数 static int __init button_init(void) //加载函数-----在驱动被加载时执行 { int ret,i; printk('--------^_^ %s------------n',__FUNCTION__); //0,实例化设备对象 //参数1 ---- 要申请的空间的大小 //参数2 ---- 申请的空间的标识 button_dev = kzalloc(sizeof(struct s5pv210_button),GFP_KERNEL); if(IS_ERR(button_dev)){ printk('kzalloc error!n'); ret = PTR_ERR(button_dev); return -ENOMEM; } //1,申请设备号-----新方法 #if 0 //静态申请设备号 button_dev->major = 256; ret = register_chrdev_region(MKDEV(button_dev->major,0),1,'button_drv'); if(ret < 0){ printk('register_chrdev_region error!n'); ret = -EINVAL; goto err_kfree; } #else //动态申请设备号 ret = alloc_chrdev_region(&button_dev->devno,0,1,'button_drv'); if(ret < 0){ printk('register_chrdev_region error!n'); ret = -EINVAL; goto err_kfree; } #endif //创建cdev //申请cdev的空间 button_dev->cdev = cdev_alloc(); if(IS_ERR(button_dev->cdev)){ printk('button_dev->cdev error!n'); ret = PTR_ERR(button_dev->cdev); goto err_unregister; } //初始化cdev的成员 cdev_init(button_dev->cdev,&fops); //将cdev加入到内核中----链表 ret = cdev_add(button_dev->cdev,button_dev->devno,1); //2,创建设备文件-----/dev/button button_dev->cls = class_create(THIS_MODULE,'button_cls'); if(IS_ERR(button_dev->cls)){ printk('class_create error!n'); ret = PTR_ERR(button_dev->cls); goto err_cdev_del; } button_dev->dev = device_create(button_dev->cls,NULL,button_dev->devno,NULL,'button'); if(IS_ERR(button_dev->dev)){ printk('device_create error!n'); ret = PTR_ERR(button_dev->dev); goto err_class; } //3,硬件初始化---申请中断 for(i = 0; i < ARRAY_SIZE(buttons_set);i++){ ret = request_irq(buttons_set[i].irqno,button_irq_svc,buttons_set[i].flags,buttons_set[i].name,&buttons_set[i]); if(ret != 0){ printk('request_irq error!n'); ret = -EBUSY; goto err_device; } } //初始化等待队列头 init_waitqueue_head(&button_dev->wq_head); return 0; err_device: device_destroy(button_dev->cls,button_dev->devno); err_class: class_destroy(button_dev->cls); err_cdev_del: cdev_del(button_dev->cdev); err_unregister: unregister_chrdev_region(button_dev->devno,1); err_kfree: kfree(button_dev); return ret; } static void __exit button_exit(void) //卸载函数-----在驱动被卸载时执行 { int i; printk('--------^_^ %s------------n',__FUNCTION__); for(i = 0; i < ARRAY_SIZE(buttons_set);i++){ free_irq(buttons_set[i].irqno,&buttons_set[i]); } device_destroy(button_dev->cls,button_dev->devno); class_destroy(button_dev->cls); cdev_del(button_dev->cdev); unregister_chrdev_region(button_dev->devno,1); kfree(button_dev); } //声明和认证 module_init(button_init); module_exit(button_exit); MODULE_LICENSE('GPL'); #include #include #include #include #include #include #include #include #include #include //定义一个按键的数据包 struct button_event{ int code; //按键的名称---键值:KEY_DOWN int value; //按键的状态---按下:1,松开:0 }; int main(void) { int fd; int ret; struct button_event event; struct pollfd pfds[2]; char buf[128]; fd = open('/dev/button',O_RDWR); if(fd < 0){ perror('open'); exit(1); } pfds[0].fd = 0; //标准输入文件描述符 pfds[0].events = POLLIN; //是否可读 pfds[1].fd = fd; //开发板中的键盘 pfds[1].events = POLLIN; //按键是否触发中断 while(1){ ret = poll(pfds,2,-1); if(ret < 0){ perror('poll'); exit(1); } if(ret > 0){ //标准输入可读 if(pfds[0].revents & POLLIN){ fgets(buf,sizeof(buf),stdin); printf('%s',buf); } //开发板中的按键触发了中断 if(pfds[1].revents & POLLIN){ bzero(&event,sizeof(event)); ret = read(fd,&event,sizeof(event)); if(ret < 0){ perror('read'); exit(1); } switch(event.code){ case KEY_UP: if(event.value) printf('按下了上键!n'); else printf('松开了上键!n'); break; case KEY_DOWN: if(event.value) printf('按下了下键!n'); else printf('松开了下键!n'); break; case KEY_LEFT: if(event.value) printf('按下了左键!n'); else printf('松开了左键!n'); break; case KEY_RIGHT: if(event.value) printf('按下了右键!n'); else printf('松开了右键!n'); break; } } } } close(fd); return 0; } #指定内核源码路径 KERNEL_DIR = /home/farsight/s5pv210/kernel/linux-3.0.8 CUR_DIR = $(shell pwd) MYAPP = test all: #让make进入内核源码编译,同时将当前目录中的c程序作为内核模块一起编译 make -C $(KERNEL_DIR) M=$(CUR_DIR) modules arm-none-linux-gnueabi-gcc -o $(MYAPP) $(MYAPP).c clean: #删除上面编译生成的文件 make -C $(KERNEL_DIR) M=$(CUR_DIR) clean rm -rf $(MYAPP) install: cp *.ko $(MYAPP) /opt/rootfs/drv_module #指定当前目录下哪个文件作为内核模块编 obj-m = button_drv.o Stay hungry, stay foolish 待续。。。
下一篇:ARM—配置交叉编译环境
- 六大全新产品系列推出,MCX A微控制器家族迎来创新
- 意法半导体全新STM32C5系列,重新定义入门级微控制器性能与价值,赋能万千智能设备
- 模组复用与整机重测在SRRC、CCC、CTA/NAL认证中的实践操作指南
- 有源晶振与无源晶振的六大区别详解
- 英飞凌持续巩固全球微控制器市场领导地位
- 使用 Keil Studio for Visual Studio Code开发 STM32 设备
- 从控制到系统:TI利用边缘AI重塑嵌入式MCU的边界
- 蓝牙信道探测技术原理与开发套件实践
- Microchip 推出生产就绪型全栈边缘 AI 解决方案,赋能MCU和MPU实现 智能实时决策
- LoRa、LoRaWAN、NB-IoT与4G DTU技术对比及工业无线方案选型分析
