keyboard
2025-02-07 来源:cnblogs
一 按键驱动程序的简单实现
下面是基于中断和消息的按键驱动程序,其工作原理是:当应用程序读取键值时,会调用按键驱动程序的read函数,而我们实现的read函数检测完读取长度后没有直接读取键值而是等待按键消息,如果没有按键,程序会进入休眠状态,这样可以节省大量的CPU,而当我们按键时硬件会产生中断,程序自动进入中断处理函数,在中断处理函数中,驱动程序读取键值存入全局变量并激活read函数中等待的消息,应用程序被迅速唤醒并通过read函数读取键值,如此,完成了获取键值的工作。下面是源码,比较简单,也就不多说了。
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
static dev_t devno;
static struct cdev cdev;
static struct class* buttons_class;
static struct device* buttons_device;
static wait_queue_head_t button_waitq;
static volatile int pressed = 0;
static unsigned char key_val;
struct key_desc{
unsigned int pin;
unsigned char value;
static struct key_desc key_descs[8] = {
[0] = {
.pin = S5PV210_GPH0(0),
.value = 0x00,
[1] = {
.pin = S5PV210_GPH0(1),
.value = 0x01,
[2] = {
.pin = S5PV210_GPH0(2),
.value = 0x02,
[3] = {
.pin = S5PV210_GPH0(3),
.value = 0x03,
[4] = {
.pin = S5PV210_GPH0(4),
.value = 0x04,
[5] = {
.pin = S5PV210_GPH0(5),
.value = 0x05,
[6] = {
.pin = S5PV210_GPH2(6),
.value = 0x06,
[7] = {
.pin = S5PV210_GPH2(7),
.value = 0x07,
static irqreturn_t buttons_irq(int irq, void *dev_id){
volatile struct key_desc *key = (volatile struct key_desc *)dev_id;
if(gpio_get_value(key->pin)){
key_val = key->value|0x80;
else{
key_val = key->value;
pressed = 1;
wake_up_interruptible(&button_waitq);
return IRQ_RETVAL(IRQ_HANDLED);
static int buttons_open(struct inode *inode, struct file *file){
int ret;
ret = request_irq(IRQ_EINT(0), buttons_irq, IRQ_TYPE_EDGE_BOTH, 'key1', &key_descs[0]);
if(ret)
return ret;
ret = request_irq(IRQ_EINT(1), buttons_irq, IRQ_TYPE_EDGE_BOTH, 'key2', &key_descs[1]);
if(ret)
return ret;
ret = request_irq(IRQ_EINT(2), buttons_irq, IRQ_TYPE_EDGE_BOTH, 'key3', &key_descs[2]);
if(ret)
return ret;
ret = request_irq(IRQ_EINT(3), buttons_irq, IRQ_TYPE_EDGE_BOTH, 'key4', &key_descs[3]);
if(ret)
return ret;
ret = request_irq(IRQ_EINT(4), buttons_irq, IRQ_TYPE_EDGE_BOTH, 'key5', &key_descs[4]);
if(ret)
return ret;
ret = request_irq(IRQ_EINT(5), buttons_irq, IRQ_TYPE_EDGE_BOTH, 'key6', &key_descs[5]);
if(ret)
return ret;
ret = request_irq(IRQ_EINT(22), buttons_irq, IRQ_TYPE_EDGE_BOTH, 'key7', &key_descs[6]);
if(ret)
return ret;
ret = request_irq(IRQ_EINT(23), buttons_irq, IRQ_TYPE_EDGE_BOTH, 'key8', &key_descs[7]);
if(ret)
return ret;
return 0;
static ssize_t buttons_read(struct file * file, char __user *data, size_t count, loff_t *loff){
if(count != 1){
printk(KERN_ERR 'The driver can only give one key value once!n');
return -ENOMEM;
wait_event_interruptible(button_waitq, pressed);
pressed = 0;
if(copy_to_user(data, &key_val, 1)){
printk(KERN_ERR 'The driver can not copy the data to user area!n');
return -ENOMEM;
return 0;
static int buttons_close(struct inode *inode, struct file *file){
free_irq(IRQ_EINT(0), &key_descs[0]);
free_irq(IRQ_EINT(1), &key_descs[1]);
free_irq(IRQ_EINT(2), &key_descs[2]);
free_irq(IRQ_EINT(3), &key_descs[3]);
free_irq(IRQ_EINT(4), &key_descs[4]);
free_irq(IRQ_EINT(5), &key_descs[5]);
free_irq(IRQ_EINT(22), &key_descs[6]);
free_irq(IRQ_EINT(23), &key_descs[7]);
return 0;
struct file_operations buttons_ops = {
.open = buttons_open,
.read = buttons_read,
.release = buttons_close,
int buttons_init(void){
int ret;
cdev_init(&cdev, &buttons_ops);
cdev.owner = THIS_MODULE;
ret = alloc_chrdev_region(&devno, 0, 1, 'buttons');
if(ret){
printk(KERN_ERR 'alloc char device region faild!n');
return ret;
ret = cdev_add(&cdev, devno, 1);
if(ret){
printk(KERN_ERR 'add char device faild!n');
goto add_error;
buttons_class = class_create(THIS_MODULE, 'buttonsdrv');
if(IS_ERR(buttons_class)){
printk(KERN_ERR 'create class error!n');
goto class_error;
buttons_device = device_create(buttons_class, NULL, devno, NULL, 'buttons');
if(IS_ERR(buttons_device)){
printk(KERN_ERR 'create buttons device error!n');
goto device_error;
init_waitqueue_head(&button_waitq);
return 0;
device_error:
class_destroy(buttons_class);
class_error:
cdev_del(&cdev);
add_error:
unregister_chrdev_region(devno,1);
return -ENODEV;
void buttons_exit(void){
device_destroy(buttons_class, devno);
cdev_del(&cdev);
unregister_chrdev_region(devno, 1);
module_init(buttons_init);
module_exit(buttons_exit);
MODULE_LICENSE('GPL');
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
static dev_t devno;
struct key_desc{
unsigned int pin;
[0] = {
.value = 0x00,
[1] = {
.value = 0x01,
[2] = {
.value = 0x02,
[3] = {
.value = 0x03,
[4] = {
.value = 0x04,
[5] = {
.value = 0x05,
[6] = {
.value = 0x06,
[7] = {
.value = 0x07,
else{
pressed = 1;
int ret;
if(ret)
return ret;
if(ret)
return ret;
if(ret)
return ret;
if(ret)
return ret;
if(ret)
return ret;
if(ret)
return ret;
if(ret)
return ret;
if(ret)
return ret;
return 0;
if(count != 1){
return -ENOMEM;
pressed = 0;
return -ENOMEM;
return 0;
return 0;
int ret;
if(ret){
return ret;
if(ret){
goto add_error;
goto class_error;
goto device_error;
return 0;
device_error:
class_error:
cdev_del(&cdev);
add_error:
return -ENODEV;
cdev_del(&cdev);
测试程序代码:
[cpp]
#include
#include
int main(){
int fd = open('/dev/buttons', O_RDWR);
if(fd < 0){
printf('open error');;
return 0;
unsigned char key;
while(1){
read(fd, &key, 1);
printf('The key = %xn', key);
close(fd);
#include
#include
int main(){
if(fd < 0){
return 0;
unsigned char key;
while(1){
read(fd, &key, 1);
close(fd);
}相比轮询方式的按键驱动程序,中断方式编写的按键驱动程序可以很大程度上节省CPU资源,因此,推荐使用中断方式。
二 支持POLL机制
上面这种方式实现的按键驱动程序有个弊端,如果我们不按键,应用程序将会永远阻塞在这里,幸运的是,linux内核提供了poll机制,可以设置超时等待时间,如果在这个时间内读取到键值则正常返回,反之则超时退出。使内核支持poll非常简单,为file_operations的poll成员提供poll处理函数即可。
使内核支持poll还需要以下几步:
添加poll头文件
[cpp]
#include
#include
编写poll处理函数:
[cpp]
static unsigned buttons_poll(struct file *file, poll_table *wait){
unsigned int mask = 0;
poll_wait(file, &button_waitq, wait);
if (pressed)
mask |= POLLIN | POLLRDNORM;
return mask;
if (pressed)
return mask;
}将poll处理函数添加给file_operations:
[cpp]
.poll = buttons_poll,
.poll = buttons_poll,这样,驱动程序就支持poll机制了。下面是poll方式的测试程序:
[cpp]
#include
#include
#include
#include
#include
int main(int argc, char **argv){
int fd;
int ret;
struct pollfd fds[1];
if (fd < 0){
printf('can't open!n');
fds[0].fd = fd;
fds[0].events = POLLIN;
while (1){
ret = poll(fds, 1, 5000);
if (ret == 0){
printf('time outn');
else{
read(fd, &key_val, 1);
printf('key_val = 0x%xn', key_val);
return 0;
#include
#include
#include
#include
#include
int fd;
int ret;
if (fd < 0){
fds[0].fd = fd;
while (1){
if (ret == 0){
else{
return 0;
}这样,应用程序可以限制时间,如果在一定时间内读取不到键值就可以做特殊处理,这种思想在网络通信中应用广泛。
三 支持异步机制
很多情况下,我们的程序在等待按键期间需要处理其它任务而不是在这里空等,这时,就需要采用异步模式了。所谓异步模式,实际上是采用消息机制(以本文的按键程序为例),即当驱动程序检测到按键后发送消息给应用程序,应用程序接收到消息后再去读取键值。与前面的两种模式相比,最大的不同在于异步方式是驱动告诉应用程序来读而不是应用程序主动去读。添加异步支持更加简单,首先是为file_operations注册fasync函数,函数内容如下:
[cpp]
static int buttons_fasync(int fd, struct file * file, int on){
return fasync_helper(fd, file, on, &button_async);
}然后再buttons_read函数中添加一行代码,修改后的代码如下:[cpp] view plaincopyprint?static ssize_t buttons_read(struct file * file, char __user *data, size_t count, loff_t *loff){
if(count != 1){
return -ENOMEM;
pressed = 0;
return -ENOMEM;
return 0;
if(count != 1){
return -ENOMEM;
pressed = 0;
return -ENOMEM;
return 0;
}这样,驱动程序就支持异步获取键值了,为了测试效果,测试程序也需要修改,代码如下:[cpp] view plaincopyprint?#include
#include
#include
#include
#include
#include
#include
/* sixthdrvtest
int fd;
void my_signal_fun(int signum)
printf('key_val: 0x%xn', key_val);
int ret;
int Oflags;
signal(SIGIO, my_signal_fun);
fd = open('/dev/buttons', O_RDWR | O_NONBLOCK);
if (fd < 0){
return -1;
fcntl(fd, F_SETOWN, getpid());
Oflags = fcntl(fd, F_GETFL);
fcntl(fd, F_SETFL, Oflags | FASYNC);
int rest;
while (1){
printf('Hellon');
while(rest = sleep(50)){
sleep(rest);
return 0;
#include
#include
#include
#include
#include
#include
#include
/* sixthdrvtest
int fd;
int ret;
int Oflags;
if (fd < 0){
return -1;
int rest;
while (1){
printf('Hellon');
sleep(rest);
return 0;
}这里需要注意的是,应用程序接收到消息会打断sleep,比如执行sleep(5)之后程序接收到了一个消息,这时,应用程序就被唤醒了,虽然是去执行的消息处理函数。如果程序接收到消息时仅睡眠了2秒,那么sleep被中断时会返回5-2=3,所以代码中采用while循环方式进行sleep,这样,即使接收到了消息也能完整的休眠5秒,当然,sleep函数本身是不够精确的,不过相差无几。
到这里,这个驱动程序基本上就算可以了,当然,还有对阻塞和非阻塞的支持,同步与互斥的支持,而阻塞与非阻塞无非是加上个逻辑判断,同步与互斥根应用程序的同步控制也差不多,无非就是信号量或者原子操作,这里就不多说了
上一篇:libnfc移植到ARM上
下一篇:SDRAM初始化
- 爆料:iPhone AR眼镜后年问世,Magic Keyboard明年见
- 外设一个一个学 for_ARM interrupt keyboard
- iPad Pro键盘拆解:全身导电 可修复度0
- ARM64架构硬件中断处理流程深度剖析
- ARM64硬件中断处理机制深度解析
- 51单片机的中断系统扫盲行动
- 《逗比小憨憨51单片机Proteus仿真系列》第4期单片机的外部中断实验仿真
- 【菜鸟必看】STM32 串口接收不定长数据中断检测相关问题
- 基于STM32CUBEMX驱动低压步进器电机驱动器STSPIN220(3)----定时器中断产生指定数量脉
- STM32中中断标志位与中断挂起位详解:TIM_ClearFlag与TIM_ClearITPendingBit函数应用指南
- 六大全新产品系列推出,MCX A微控制器家族迎来创新
- 意法半导体全新STM32C5系列,重新定义入门级微控制器性能与价值,赋能万千智能设备
- 从控制到系统:TI利用边缘AI重塑嵌入式MCU的边界
- 模组复用与整机重测在SRRC、CCC、CTA/NAL认证中的实践操作指南
- 有源晶振与无源晶振的六大区别详解
- 英飞凌持续巩固全球微控制器市场领导地位
- 使用 Keil Studio for Visual Studio Code开发 STM32 设备
- 蓝牙信道探测技术原理与开发套件实践
- LoRa、LoRaWAN、NB-IoT与4G DTU技术对比及工业无线方案选型分析
- Microchip 推出生产就绪型全栈边缘 AI 解决方案,赋能MCU和MPU实现 智能实时决策
