单片机
STM32串口3 映射和完全重映射 PB10 PB11 / PD8 PD9 / PC10 PC11
2024-09-30 来源:cnblogs
STM32F103共有五个串口,有时候在项目中,其他的引脚已经配置用了,重新改太麻烦
STM32串口3 映射和完全重映射 PB10 PB11 PD8 PD9  PC10 PC11
所有本次实验 使用了串口3的映射端口,配置和普通的类似
只是注意要使用映射使能说明
GPIO_PinRemapConfig(GPIO_FullRemap_USART3  , ENABLE);
点击(此处)折叠或打开
void USART3_Configuration(u32 bound)
  //GPIO端口设置
  GPIO_InitTypeDef GPIO_InitStructure;
    USART_InitTypeDef USART_InitStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
 #if 1
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //remap时钟|RCC_APB2Periph_AFIO //开启GPIOB时钟
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);//这里要分开打开 //USART3时钟 来自APB1
#endif
#if 0
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);//开启GPIOB和USART3时钟
        //USART3_TX GPIOB.10
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //PB.10
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;    //复用推挽输出
    GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIOA.10
    //USART3_RX     GPIOB.11初始化
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;//PB11
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
    GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIOB.11
#endif
#if 0    //重映射
    //GPIO_PartialRemap_USART3 部分重映射 GPIOC_10 GPIOC_11
    GPIO_PinRemapConfig(GPIO_PartialRemap_USART3,ENABLE);
    //USART3_TX GPIOC.10
  GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化
  //USART3_RX     GPIOC.11初始化
#endif
#if 1
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //remap时钟|RCC_APB2Periph_AFIO //开启GPIOB时钟
     //GPIO_FullRemap_USART3 完全重映射 D8 D9
     GPIO_PinRemapConfig(GPIO_FullRemap_USART3,ENABLE);
    //USART3_TX GPIOD8
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //
  GPIO_Init(GPIOD, &GPIO_InitStructure);//初始化
  //USART3_RX     GPIOD9
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;//
#endif
  //Usart3 NVIC 配置
  NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=1 ;//抢占优先级3
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;        //子优先级3
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;            //IRQ通道使能
    NVIC_Init(&NVIC_InitStructure);    //根据指定的参数初始化VIC寄存器
   //USART 初始化设置
    USART_InitStructure.USART_BaudRate = bound;//串口波特率
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
    USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
    USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;    //收发模式
  USART_Init(USART3, &USART_InitStructure); //初始化串口3
  USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);//开启串口接受中断
  USART_Cmd(USART3, ENABLE); //使能串口3
点击(此处)折叠或打开
#include 'sys.h'
#include 'usart.h'
#include 'timer.h'
#include 'stdint.h'
 u8     checkdata[8];        //检测串口1接收的特定数据数据
//发送上位机的数据
uint32_t crc16_data1[] = { 0x00,0x00, 0x00 };//饮水机数据
uint32_t crc16_data2[] = { 0x00,0x00, 0x00 };//
uint32_t crc16_data3[] = { 0x00,0x00, 0x00 };//
uint32_t crc16_data4[] = { 0x00,0x00, 0x00 };//
uint32_t crc16_data5[] = { 0x00,0x00, 0x00 };//
uint32_t crc16_data6[] = { 0x00,0x00, 0x00 };//
uint32_t crc16_data7[] = { 0x00,0x00, 0x00 };//
uint32_t crc16_data8[] = { 0x00,0x00, 0x00 };//
uint32_t crc16_data9[] = { 0x00,0x00, 0x00 };//
uint32_t crc16_data10[]= { 0x00,0x00, 0x00 };//
//串口1队列定义
u8     UART1SendBuff[UART1BuffSize];        //发送数据
u8     UART1ReceBuff[UART1BuffSize];        //接收数据?
u16 UART1ReceIn = 0;//接收状态标记数据位
u8 UART1ReceFullFlag = 0;//接收完数据标志位
//串口3队列定义
u8     UART3SendBuff[UART3BuffSize];        //发送数据
u8     UART3ReceBuff[UART3BuffSize];        //接收数据?
u16 UART3ReceIn = 0;//接收状态标记数据位
u8 UART3ReceFullFlag = 0;//接收完数据标志位
void USART1_Configuration(u32 bound){
  //GPIO端口设置
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA, ENABLE);    //使能USART1,GPIOA时钟
    //USART1_TX GPIOA.9
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
  GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.9
  //USART1_RX     GPIOA.10初始化
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//PA10
  GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.10
  //Usart1 NVIC 配置
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2 ;//抢占优先级3
   //USART 初始化设置
  USART_Init(USART1, &USART_InitStructure); //初始化串口1
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启串口接受中断
  USART_Cmd(USART1, ENABLE); //使能串口1
  //GPIO端口设置
 #if 1
#endif
#if 0
#endif
#if 0    //重映射
#endif
#if 1
    //USART3_TX GPIOD8
  //USART3_RX     GPIOD9
#endif
  //Usart3 NVIC 配置
   //USART 初始化设置
//串口1发送一帧数据
void USART1_SendOneData(uint32_t SendOneData)
    USART_SendData(USART1, SendOneData);
    while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)
//串口2发送一帧数据
void USART2_SendOneData(uint32_t SendOneData)
    USART_SendData(USART2, SendOneData);
    while (USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET)
//串口3发送一帧数据
void USART3_SendOneData(uint32_t SendOneData)
    USART_SendData(USART3, SendOneData);
    while (USART_GetFlagStatus(USART3, USART_FLAG_TC) == RESET)
//串口1发送一列数据
void USART1_SendUnfixedData(uint32_t *Buffer, uint8_t Length)
    uint8_t i;
    for(i=0;i    {
        USART1_SendOneData(*Buffer++);
//串口2发送一列数据
void USART2_SendUnfixedData(uint32_t *Buffer, uint8_t Length)
    uint8_t i;
    for(i=0;i    {
        USART2_SendOneData(*Buffer++);
//串口3发送一列数据
void USART3_SendUnfixedData(uint32_t *Buffer, uint8_t Length)
    uint8_t i;
    for(i=0;i    {
        USART3_SendOneData(*Buffer++);
//串口1中断服务函数
void USART1_IRQHandler(void)
    u8 Res;//数据暂存
    if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //接收中断
        Res =USART_ReceiveData(USART1);    //读取接收到的数据
        switch(UART1ReceIn)//读取接收到的数据有几位 每一位对应的数据协议校验
            case 0:
                if(Res==0xFE)
                    UART1ReceBuff[UART1ReceIn++] = Res;
                else
                    UART1ReceIn = 0;
                break;
            case 1:
                if(Res==0xFE)
                else
                    UART1ReceIn = 0;
                break;
            case 2://此处为判断数据的位置 正反转
//                if(Res==0x02)//在其他位置判断数据
//                {UART1ReceBuff[UART1ReceIn++] = Res;
//                    checkdata[0]=UART1ReceBuff[2];}
            break;
            case 3://此处为判断数据的位置 旋转角度
            checkdata[1]=UART1ReceBuff[3];    //接收到的角度数据和实际齿轮数据不一致
            break;
            case 4:
                if(Res==0xFD)
                else
                    UART1ReceIn = 0;
                break;
            case 5:
                if(Res==0xFD)
                else
                    UART1ReceIn = 0;
                break;
            default:
                break;
        if(UART1ReceIn >= 5)
            UART1ReceFullFlag = 1;    //数据完整接受完
                UART1ReceIn = 0;
             timer8flag=0;
//        USART_ClearFlag(USART1, USART_IT_RXNE);//清除相对应的中断位 清除中断预处理位USART_ClearITPendingBit左移八位是USART_ClearFlag
        USART_ClearITPendingBit(USART1, USART_IT_RXNE);//清除相对应的中断位 清除中断预处理位USART_ClearITPendingBit左移八位是USART_ClearFlag
     if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET)    // 发送中断 USART_GetITStatus
    //    USART_ClearFlag(USART1, USART_IT_TXE);                    // clear interrupt 清除中断预处理位
        USART_ClearITPendingBit(USART1, USART_IT_TXE);                    // clear interrupt 清除中断预处理位
//    if(USART_GetFlagStatus(USART1, USART_FLAG_ORE) != RESET)
//        USART_ClearFlag(USART1, USART_FLAG_ORE);
//串口3中断服务函数
void USART3_IRQHandler(void)
    u8 Res;//数据暂存
    if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET) //接收中断
        Res =USART_ReceiveData(USART3);    //读取接收到的数据 USART_ReceiveData
            USART_SendData(USART1,Res);//将读取到的数据通过串口1发送
        switch(UART3ReceIn)//读取接收到的数据有几位 每一位对应的数据协议校验
            case 0:
                if(Res==0XFE)
                    UART3ReceBuff[UART3ReceIn++] = Res;
                else
                    UART3ReceIn = 0;
                break;
            case 10:
                if(Res==0xFF)
                else
                    UART3ReceIn = 0;
                break;
            default:
                break;
        if(UART3ReceIn >= 11)
            UART3ReceFullFlag = 1;    //数据完整接受完
        USART_ClearITPendingBit(USART3, USART_IT_RXNE);//清除相对应的中断位 清除中断预处理位USART_ClearITPendingBit左移八位是USART_ClearFlag
    else if(USART_GetITStatus(USART3, USART_IT_TXE) != RESET)    // 发送中断 USART_GetITStatus
        USART_ClearITPendingBit(USART3, USART_IT_TXE);                    // clear interrupt 清除中断预处理位
void send_data()
    //刷新位置信息
if(timer8flag100ms==1)
timer8flag100ms=0;
            //发送协议头 FE FE D1
            USART_SendData(USART1,0xFA);//向串口1发送数据
            while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束
            USART_SendData(USART1,0xFC);
            //发送数据内容1
            USART1_SendUnfixedData(crc16_data1,1);//空开1
            //发送数据内容2
                USART1_SendUnfixedData(crc16_data2,1);//空开2
            //发送数据内容3
                USART1_SendUnfixedData(crc16_data3,1);//空开3
            //发送数据内容4
                USART1_SendUnfixedData(crc16_data4,1);//空开4
            //发送数据内容5
            USART1_SendUnfixedData(crc16_data5,2);//饮水机 空烧数据
            //发送数据内容设备接地的数据 (过载实验)(1111 1111)(八个设备)
                USART1_SendUnfixedData(crc16_data6,1);
            //发送数据内容7     接地触电 crc16_data7[0] 湿手触电 crc16_data7[1]
                USART1_SendUnfixedData(crc16_data7,1);
            //发送数据内容8        发送给串口的数据
                USART1_SendUnfixedData(crc16_data8,1);
            //发送协议尾 FD FD
            USART_SendData(USART1,0xFD);//向串口1发送数据
void send_data_usart3(void)
    //刷新位置信息
if(timer8flag200ms==1)
timer8flag200ms=0;
            //发送协议头 FE FE D1
            USART_SendData(USART3,0xFA);//向串口1发送数据
            while(USART_GetFlagStatus(USART3,USART_FLAG_TC)!=SET);//等待发送结束
            USART_SendData(USART3,0xFC);
            //发送数据内容1
            USART3_SendUnfixedData(crc16_data1,1);//空开1
            //发送数据内容2
                USART3_SendUnfixedData(crc16_data2,1);//空开2
            //发送数据内容3
                USART3_SendUnfixedData(crc16_data3,1);//空开3
            //发送数据内容4
                USART3_SendUnfixedData(crc16_data4,1);//空开4
            //发送数据内容5
             USART3_SendUnfixedData(crc16_data5,2);//饮水机 空烧数据
                USART3_SendUnfixedData(crc16_data6,1);
                USART3_SendUnfixedData(crc16_data7,1);
            //发送数据内容8        发送给串口的数据
                USART3_SendUnfixedData(crc16_data8,1);
            //发送协议尾 FD FD
            USART_SendData(USART3,0xFD);//向串口1发送数据
进入单片机查看更多内容>>
相关视频
  • 【TI MSPM0 应用实战】智能小车+工业角度编码器+血氧仪+烟雾探测器!硬核参考设计详解!
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
  • 直播回放: Microchip Timberwolf™ 音频处理器在线研讨会
  • 基于灵动MM32W0系列MCU的指夹血氧仪控制及OTA升级应用方案分享
精选电路图
  • 1瓦线性调频增强器
  • 家用电器遥控器
  • 12V 转 28V DC-DC 变换器(基于 LM2585)
  • 红外开关
  • DS1669数字电位器
  • HA1377 桥式放大器 BCL 电容 17W(汽车音频)
    相关电子头条文章
