EDA实验与实践 dac_test
白丁   2013-7-31 19:39 楼主
module dac_test(clock,key,wr_act,wr_data,seg,dig);
input clock;                            //系统时钟(48MHz)
input[4:0] key;                            //按键输入(KEY1~KEY5)
output wr_act;                            //发送数据使能
output[10:0]wr_data;                    //要发送的数据
output[7:0]seg;                            //数码管段码输出
output[7:0]dig;                            //数码管位码输出
//I/O寄存器
reg[10:0]wr_data;
reg wr_act;
reg[7:0]seg;
reg[7:0]dig;
//内部寄存器
reg[16:0]count;                            //时钟分频计数器
reg[4:0]dout1,dout2,dout3;                //消抖寄存器
reg[4:0]buff;                            //边沿检测寄存器
reg[1:0] cnt;                              //数码管扫描计数器
reg[3:0]disp_dat;                        //数码管扫描显存
reg div_clk;                            //分频时钟
wire[4:0] key_edge;
//时钟分频部分
always @(posedge clock)
begin
    if (count < 17'd120000)
    begin
         count <= count + 1'b1;
         div_clk <= 1'b0;
     end
     else
     begin
         count <= 17'd0;
         div_clk <= 1'b1;
     end
end
//按键消抖部分
begin
    if(div_clk)
    begin
        dout1 <= key;
        dout2 <= dout1;
        dout3 <= dout2;
    end
end
//按键边沿检测部分
begin
    buff <= dout1 | dout2 | dout3;
end
assign key_edge = ~(dout1 | dout2 | dout3) & buff;
always @(posedge clock)                            //按键1
begin
    if(key_edge[0])                                //下降沿检测
    wr_data[10:9] <= wr_data[10:9] + 1'b1;
end
always @(posedge clock)                            //按键2
begin
    if(key_edge[1])                                //下降沿检测
    wr_data[7:4] <= wr_data[7:4] + 1'b1;
end
always @(posedge clock)                            //按键3
begin
    if(key_edge[2])                                //下降沿检测
    wr_data[3:0] <= wr_data[3:0] + 1'b1;
end
always @(posedge clock)                            //按键4
begin
    if(key_edge[3])                                //下降沿检测
    wr_data[8] <= ~wr_data[8];
end
always @(posedge clock)                            //按键5
begin
    if(key_edge[4])                                //下降沿检测
        wr_act <= 1'b1;
    else
        wr_act <= 1'b0;
end
//数码管扫描显示部分
always @(posedge clock)                   //定义上升沿触发进程
begin
    if(div_clk)
        cnt <= cnt + 1'b1;
end
begin
    if(div_clk)
    begin
        case(cnt)                                    //选择扫描显示数据
            2'd0:disp_dat = wr_data[10:9] + 4'd1;    //第一个数码管
            2'd1:disp_dat = wr_data[7:4];            //第三个数码管
            2'd2:disp_dat = wr_data[3:0];            //第四个数码管
            2'd3:disp_dat = {3'b0,wr_data[8]};        //第八个数码管
        endcase
        case(cnt)                                    //选择数码管显示位
            2'd0:dig = 8'b01111111;                    //选择第一个数码管显示
            2'd1:dig = 8'b11011111;                    //选择第三个数码管显示
            2'd2:dig = 8'b11101111;                    //选择第四个数码管显示
            2'd3:dig = 8'b11111110;                    //选择第八个数码管显示
        endcase
    end
end
always @(disp_dat)
begin
    case(disp_dat)                        //七段译码
        4'h0:seg = 8'hc0;                //显示0
        4'h1:seg = 8'hf9;                //显示1
        4'h2:seg = 8'ha4;                //显示2
        4'h3:seg = 8'hb0;                //显示3
        4'h4:seg = 8'h99;                //显示4
        4'h5:seg = 8'h92;                //显示5
        4'h6:seg = 8'h82;                //显示6
        4'h7:seg = 8'hf8;                //显示7
        4'h8:seg = 8'h80;                //显示8
        4'h9:seg = 8'h90;                //显示9
        4'ha:seg = 8'h88;                //显示a
        4'hb:seg = 8'h83;                //显示b
        4'hc:seg = 8'hc6;                //显示c
        4'hd:seg = 8'ha1;                //显示d
        4'he:seg = 8'h86;                //显示e
        4'hf:seg = 8'h8e;                //显示f
    endcase
end
endmodule
回复评论
暂无评论,赶紧抢沙发吧
    写回复
