今天是:2024年10月27日(星期日)
2021年10月27日 | stm32专题二十四:ADC 标准库函数分析
2021-10-27 来源:eefocus
ADC初始化结构体:
typedef struct
uint32_t ADC_Mode; /*!< Configures the ADC to operate in independent or
dual mode.
This parameter can be a value of @ref ADC_mode */
FunctionalState ADC_ScanConvMode; /*!< Specifies whether the conversion is performed in
Scan (multichannels) or Single (one channel) mode.
This parameter can be set to ENABLE or DISABLE */
FunctionalState ADC_ContinuousConvMode; /*!< Specifies whether the conversion is performed in
Continuous or Single mode.
This parameter can be set to ENABLE or DISABLE. */
uint32_t ADC_ExternalTrigConv; /*!< Defines the external trigger used to start the analog
to digital conversion of regular channels. This parameter
can be a value of @ref ADC_external_trigger_sources_for_regular_channels_conversion */
uint32_t ADC_DataAlign; /*!< Specifies whether the ADC data alignment is left or right.
This parameter can be a value of @ref ADC_data_align */
uint8_t ADC_NbrOfChannel; /*!< Specifies the number of ADC channels that will be converted
using the sequencer for regular channel group.
This parameter must range from 1 to 16. */
}ADC_InitTypeDef;
(1)ADC模式: 一般选择独立模式;
/** @defgroup ADC_mode
// 独立模式,最为常用
#define ADC_Mode_Independent ((uint32_t)0x00000000)
// 剩下的都是双ADC模式,包括同步、交叉、交替、混合等,不常用
#define ADC_Mode_RegInjecSimult ((uint32_t)0x00010000)
#define ADC_Mode_RegSimult_AlterTrig ((uint32_t)0x00020000)
#define ADC_Mode_InjecSimult_FastInterl ((uint32_t)0x00030000)
#define ADC_Mode_InjecSimult_SlowInterl ((uint32_t)0x00040000)
#define ADC_Mode_InjecSimult ((uint32_t)0x00050000)
#define ADC_Mode_RegSimult ((uint32_t)0x00060000)
#define ADC_Mode_FastInterl ((uint32_t)0x00070000)
#define ADC_Mode_SlowInterl ((uint32_t)0x00080000)
#define ADC_Mode_AlterTrig ((uint32_t)0x00090000)
(2)ADC扫描模式:单通道 AD转换使用 DISABLE,多通道 AD转换使用 ENABLE;
(3)ADC连续转换:一般都会启用;
(4)外部触发选择:一般选择软件触发,也可以使用定时器触发 or 外部中断事件触发;
(5)ADC数据对齐:右对齐;
(6)ADC转换通道数量;
常用的标准固件库函数:
(1)ADC初始化函数
// 初始化ADC
void ADC_Init(ADC_TypeDef* ADCx, ADC_InitTypeDef* ADC_InitStruct);
(2)ADC时钟设置函数(设置分频系数),通常设置为6分频,ADCCLK = 12MHz
* @brief Configures the ADC clock (ADCCLK).
* @param RCC_PCLK2: defines the ADC clock divider. This clock is derived from
* the APB2 clock (PCLK2).
* This parameter can be one of the following values:
* @arg RCC_PCLK2_Div2: ADC clock = PCLK2/2
* @arg RCC_PCLK2_Div4: ADC clock = PCLK2/4
* @arg RCC_PCLK2_Div6: ADC clock = PCLK2/6
* @arg RCC_PCLK2_Div8: ADC clock = PCLK2/8
* @retval None
void RCC_ADCCLKConfig(uint32_t RCC_PCLK2)
uint32_t tmpreg = 0;
/* Check the parameters */
assert_param(IS_RCC_ADCCLK(RCC_PCLK2));
tmpreg = RCC->CFGR;
/* Clear ADCPRE[1:0] bits */
tmpreg &= CFGR_ADCPRE_Reset_Mask;
/* Set ADCPRE[1:0] bits according to RCC_PCLK2 value */
tmpreg |= RCC_PCLK2;
/* Store the new value */
RCC->CFGR = tmpreg;
(3)ADC规则通道配置函数(配置通道、转换顺序、采样周期)
* @brief Configures for the selected ADC regular channel its corresponding
* rank in the sequencer and its sample time.
* @param ADCx: where x can be 1, 2 or 3 to select the ADC peripheral.
* @param ADC_Channel: the ADC channel to configure.
* @arg ADC_Channel_0: ADC Channel0 selected
* @arg ADC_Channel_1: ADC Channel1 selected
* @arg ADC_Channel_2: ADC Channel2 selected
* @arg ADC_Channel_3: ADC Channel3 selected
* @arg ADC_Channel_4: ADC Channel4 selected
* @arg ADC_Channel_5: ADC Channel5 selected
* @arg ADC_Channel_6: ADC Channel6 selected
* @arg ADC_Channel_7: ADC Channel7 selected
* @arg ADC_Channel_8: ADC Channel8 selected
* @arg ADC_Channel_9: ADC Channel9 selected
* @arg ADC_Channel_10: ADC Channel10 selected
* @arg ADC_Channel_11: ADC Channel11 selected
* @arg ADC_Channel_12: ADC Channel12 selected
* @arg ADC_Channel_13: ADC Channel13 selected
* @arg ADC_Channel_14: ADC Channel14 selected
* @arg ADC_Channel_15: ADC Channel15 selected
* @arg ADC_Channel_16: ADC Channel16 selected
* @arg ADC_Channel_17: ADC Channel17 selected
* @param Rank: The rank in the regular group sequencer. This parameter must be between 1 to 16.
* @param ADC_SampleTime: The sample time value to be set for the selected channel.
* @arg ADC_SampleTime_1Cycles5: Sample time equal to 1.5 cycles
* @arg ADC_SampleTime_7Cycles5: Sample time equal to 7.5 cycles
* @arg ADC_SampleTime_13Cycles5: Sample time equal to 13.5 cycles
* @arg ADC_SampleTime_28Cycles5: Sample time equal to 28.5 cycles
* @arg ADC_SampleTime_41Cycles5: Sample time equal to 41.5 cycles
* @arg ADC_SampleTime_55Cycles5: Sample time equal to 55.5 cycles
* @arg ADC_SampleTime_71Cycles5: Sample time equal to 71.5 cycles
* @arg ADC_SampleTime_239Cycles5: Sample time equal to 239.5 cycles
* @retval None
void ADC_RegularChannelConfig(ADC_TypeDef* ADCx, uint8_t ADC_Channel, uint8_t Rank, uint8_t ADC_SampleTime)
uint32_t tmpreg1 = 0, tmpreg2 = 0;
assert_param(IS_ADC_ALL_PERIPH(ADCx));
assert_param(IS_ADC_CHANNEL(ADC_Channel));
assert_param(IS_ADC_REGULAR_RANK(Rank));
assert_param(IS_ADC_SAMPLE_TIME(ADC_SampleTime));
/* if ADC_Channel_10 ... ADC_Channel_17 is selected */
if (ADC_Channel > ADC_Channel_9)
/* Get the old register value */
tmpreg1 = ADCx->SMPR1;
/* Calculate the mask to clear */
tmpreg2 = SMPR1_SMP_Set << (3 * (ADC_Channel - 10));
/* Clear the old channel sample time */
tmpreg1 &= ~tmpreg2;
/* Calculate the mask to set */
tmpreg2 = (uint32_t)ADC_SampleTime << (3 * (ADC_Channel - 10));
/* Set the new channel sample time */
tmpreg1 |= tmpreg2;
/* Store the new register value */
ADCx->SMPR1 = tmpreg1;
else /* ADC_Channel include in ADC_Channel_[0..9] */
tmpreg1 = ADCx->SMPR2;
tmpreg2 = SMPR2_SMP_Set << (3 * ADC_Channel);
该开发实验板采用PCI-E x1接口,为方便用户进行自主开发,提供了80个可用的FPGA IO输入输出,用户可以自行设计应用接插板,如外部A/D数据采集,图象数据处理等系统应用,而不需要对PCI-E接口有过多的了解。 PCI-E接口芯 ...… 查看全部问答> |
大虾: 小弟一直想做FPGA。书是看了不少,可是还是很迷茫。因为大部分就是一些简单的实例,也有一些稍微复杂一点的。可是我总是感觉没有长进。 比如:我看到好多设计中都用到FIFO,可是异 ...… 查看全部问答> |
各位高人 本人被这两个指令搞得头昏脑胀了 请指教 这两个指令中的数据时怎样变换的 我的理解:BIN: 例如键盘输入528400 要把这个输入数计入到数据寄存器里 用BIN指令 过程是不是把这个BCD码当作 十进制然后才成相应的二进制 0000 0000 0000 1000 0 ...… 查看全部问答> |
求高人解惑!我用OP07设计的3倍输出电路运放,输出只能在1.69-4.33V之间,为什么? 第一次发图 不知道大家能看到不。 ------------------------------------ 我是用5V单电源供电,运放为OP07,便于实验,两个输入,U2接地,U1为0-4.5V的一个可调输入,参数设计为输出3倍的电压, 但是试验中,当我输入电压的3倍低于1 ...… 查看全部问答> |
我先有MULIICESERVER连的板子。BIOS已经烧到了板子的NORFLASH里面。 在用AXD调试。用LOAD把调试镜象.AXF文件下到板子里面.怎么只能在main函数设置断点.而且就能设置2次.设置2次以后清楚断点继续设置断点运行后.就不停止了. 这是为什么.… 查看全部问答> |
我目前使用的是freescale m31+ce5.0系统,通过修改hive注册表后,512m的nandflash现在已经有fat分区,并且在系统启动后能现在nand flash的磁盘。 我现在想改成两个fat的分区,一个用与存放system.hv等注册表和系统的一些应用程序,另一个提供用户 ...… 查看全部问答> |
w5100是自带网络协议的芯片,具体我不讲了,我就讲下中断方式应用,这个应用是采用TCP/IP网络协议,单片机是客户端跟服务器进行相连的。 这里先讲两种寄存器,W5100_IR和W5100_S0_IR,后面这个这个芯片总共 ...… 查看全部问答> |
