S5PV210 | 裸机汇编LED流水灯实验
2024-12-05 来源:cnblogs
开发板:
1.原理图
上图中,当按下POWER键后,VDD_5V和VDD_IO会产生5V和3.3V的电压,其中D26无须GPIO控制,为常亮状态,即我们所说的电源指示灯,D[22:25]对应的GPIO口如下:
| LED指示灯 | GPIO口 | 编号 | 动作 |
| D22 | GPJ_3 | LED1 | 1:灭,0:亮 |
| D23 | GPJ0_4 | LED2 | 1:灭,0:亮 |
| D24 | GPJ0_5 | LED3 | 1:灭,0:亮 |
| D25 | GPD0_1 | LED4 | 1:灭,0:亮 |
2.Datasheet相关
1.S5PV210 RISC微处理器用户手册:
S5PV210_UM_REV1.1.pdf
获取方式:可在CSDN搜索下载,也可以@大飞歌获取
2.应用手册(内部ROM启动):
S5PV210_iROM_ApplicationNote_Preliminary_20091126.pdf
获取方式:可网路搜索下载,也可以@大飞歌获取
中文文档地址:https://blog.csdn.net/I_feige/article/details/104848609
3.底板电路原理图:
x210bv3s.pdf
下载链接:https://download.csdn.net/download/i_feige/11877902
控制LED GPIO的寄存器设置详细参见以下章节(S5PV210_UM_REV1.1.pdf):
V210_ Book cover
errata
section 01_ overview
section 02_ system
section 03_ bus
section 04_ interupt
section 05_ memory
section 06_ dma
section 07_ timer
section 08_ connectivity _ storage
section 09_ mutimedia
section 10_ audio _ etc
section 11_ securty
section 12_ etc
2.2.7 PORT GROUP GPD0 CONTROL REGISTER
2.2.7.1 Port Group GPD0 Control Register ( GPD0CON , R / W , Address 0xE020_00A0)
2.2.7.2 Port Group GPD0 Control Register ( GPD0DAT , R / W , Address 0xE020_00A4)
2.2.7.3 Port Group GPD0 Control Register ( GPD0PUD , R / W , Address 0xE020_00A8)
2.2.7.4 Port Group GPD0 Control Register ( GPD0DRV , R / W , Address 0xE020_00AC)
2.2.7.5 Port Group GPD0 Control Register ( GPD0CONPDN , R / W , Address 0xE020_00B0)
2.2.7.6 Port Group GPD0 Control Register ( GPD0PUDPDN , R / W , Address 0xE020_00B4)
2.2.20 PORT GROUP GPJ0 CONTROL REGISTER
2.2.20.1 Port Group GPJ0 Control Register ( GPJ0CON , R / W , Address 0xE020_0240)
2.2.20.2 Port Group GPJ0 Control Register ( GPJ0DAT , R / W , Address 0xE020_0244)
2.2.20.3 Port Group GPJ0 Control Register ( GPJ0PUD , R / W , Address 0xE020_0248)
2.2.20.4 Port Group GPJ0 Control Register ( GPJ0DRV , R / W , Address 0xE020_024C)
2.2.20.5 Port Group GPJ0 Control Register ( GPJ0CONPDN , R / W , Address 0xE020_0250)
2.2.20.6 Port Group GPJ0 Control Register ( GPJ0PUDPDN , R / W , Address 0xE020_0254)
GPD0控制寄存器组的相关信息(部分摘取如下):
有六个控制寄存器,分别是 GPD0CON、GPD0DAT、GPD0PUD、GPD0DRV、GPD0CONPDN 和
端口组 GPD0 控制寄存器中的 GPD0PUDPDN。
2.2.7.1 端口组 GPD0 控制寄存器 (GPD0CON, R/W, Address = 0xE020_00A0)
| GPD0CON | Bit | Description | Initial State |
| GPD0CON[3] | [15:12] | 0000 = Input 0001 = Output 0010 = TOUT_3 0011 ~ 1110 = Reserved 1111 = GPD0_INT[3] | 0000 |
| GPD0CON[2] | [11:8] | 0000 = Input 0001 = Output 0010 = TOUT_2 0011 ~ 1110 = Reserved 1111 = GPD0_INT[2] | 0000 |
| GPD0CON[1] | [7:4] | 0000 = Input 0001 = Output 0010 = TOUT_1 0011 ~ 1110 = Reserved 1111 = GPD0_INT[1] | 0000 |
| GPD0CON[0] | [3:0] | 0000 = Input 0001 = Output 0010 = TOUT_0 0011 ~ 1110 = Reserved 1111 = GPD0_INT[0] | 0000 |
2.2.7.2 端口组 GPD0 数据映射寄存器 (GPD0DAT, R/W, Address = 0xE020_00A4)
| GPD0DAT | Bit | Description | Initial State |
| GPD0DAT[3:0] | [3:0] | 当端口被配置为输入端口时,对应的位是引脚状态。 当端口配置为输出端口时,引脚状态与对应位相同。 当端口被配置为功能引脚时,将读取未定义的值。 | 0000 |
2.2.7.3 端口组 GPD0 上、下拉配置寄存器 (GPD0PUD, R/W, Address = 0xE020_00A8)
| GPD0PUD | Bit | Description | Initial State |
| GPD0PUD[n] | [2n+1:2n] n=0~3 | 00 = 上拉/下拉禁用 01 = 下拉启用 10 = 上拉启用 11 = 保留 | 0x0055 |
2.2.7.4 端口组 GPD0 驱动强度配置寄存器 (GPD0DRV, R/W, Address = 0xE020_00AC)
| GPD0DRV | Bit | Description | Initial State |
| GPD0DRV[n] | [2n+1:2n] n=0~3 | 00 = 1x 10 = 2x 01 = 3x 11 = 4x | 0x0000 |
2.2.7.5 端口组 GPD0 低功耗模式配置寄存器 (GPD0CONPDN, R/W, Address = 0xE020_00B0)
| GPD0CONPDN | Bit | Description | Initial State |
| GPD0[n] | [2n+1:2n] n=0~3 | 00 = Output 0 01 = Output 1 10 = Input 11 = Previous state | 0x00 |
2.2.7.6 端口组 GPD0 低功耗模式上拉/下拉寄存器 (GPD0PUDPDN, R/W, Address = 0xE020_00B4)
| GPD0PUDPDN | Bit | Description | Initial State |
| GPD0[n] | [2n+1:2n] n=0~3 | 00 = 上拉/下拉禁用 01 = 下拉启用 10 = 上拉启用 11 = 保留 | 0x00 |
例如设置GPD0_1 IO口为输出模式,拉高或者拉低(汇编语言实现):
#define GPD0CON 0xE02000A0
#define GPD0DAT 0xE02000A4
/* 初始化GPIO口(配置为输出模式),下面是比较规范的一种写法,也可参考代码实现(流水灯)相关部分 */
ldr r0,=GPD0CON //r0=0xE02000A0
ldr r1,[r0] //将r0地址处的数据读出,保存到r1中(零偏移)
orr r1,r1,#0x0010 //设置r1的第4位(置1),其他位保持不变[7:4]->0001=Output
str r1,[r0] //将r1中的内容传输到r0中数指定的地址内存中去
/* 点亮LED4,GPIO口输出低电平 */
ldr r0,=GPD0DAT //r0=0xE02000A4
bic r1,r1,#0x0002 //清除r1的第1位(置0),其他位保持不变[1]
/* 熄灭LED4,GPIO口输出高电平 */
orr r1,r1,#0x0002 //设置r1的第1位(置1),其他位保持不变[1]
3.代码
3-1.代码实现(流水灯,仅作演示)
* > File Name: start.S
* > Author: fly
* > Create Time: 2020年07月17日 星期五 07时56分19秒
* 汇编点亮led灯:对应GPIO口输出低电平,点亮LED
* D22->GPJ0_3
* D23->GPJ0_4
* D24->GPJ0_5
* D25->PWMOUT1/GPD0_1
#define GPD0PUD 0xE02000A8
#define GPJ0CON 0xE0200240
#define GPJ0DAT 0xE0200244
#define GPJ0PUD 0xE0200248
#define PS_HOLD_CONTORL 0xE010E81C
#define WTCON 0xE2700000
#define SVC_STACK 0xD0037D80
//#define CONFIG_SYS_ICACHE_OFF 1
.global _start
_start:
//给5v电源置锁
//LDR指令:从内存中将1个32位的字读取到目标寄存器中
//STR指令:将1个32位的字数据写入到指令中指定的内存单元中
//ORR指令:逻辑或操作指令
//BIC指令:位清除指令
//MOV指令:数据传送
ldr r0,=PS_HOLD_CONTORL //r0=0xE010E81C
orr r1,r1,#0x300 //设置r1的第8、9位,其他位保持不变
orr r1,r1,#0x1 //设置r1的第1位,其他位保持不变
//关看门狗
ldr r0, =WTCON
mov r1, #0 //将立即数0传输到r1处
str r1, [r0]
//开/关iCache
// MRC指令:从协处理器寄存器传数据到ARM寄存器
// MCR指令:从ARM寄存器传数据到协处理器寄存器
mrc p15, 0, r0, c1, c0, 0
#ifdef CONFIG_SYS_ICACHE_OFF
bic r0, r0, #0x00001000 @ clear bit 12 (I) I-Cache
#else
orr r0, r0, #0x00001000 @ set bit 12 (I) I-Cache
#endif
mcr p15, 0, r0, c1, c0, 0
//设置栈,以便调用c函数
ldr sp, =SVC_STACK
led_init:
/* LED初始化 */
//把GPIO设置输出模式
ldr r0,=0x11111111
ldr r1,=GPJ0CON
str r0, [r1] //把GPJ0所有的IO设置为输出模式
ldr r0,=0x00000010
ldr r1,=GPD0CON
str r0,[r1] //把GPD0_1设置为输出模式
led_run:
/* LED流水灯 */
// 第1步:点亮LED1,其他熄灭
ldr r0, =~(1<<3) //r0=0xFFFFFFF7
ldr r1, =GPJ0DAT //r1=0xE0200244
str r0, [r1]
//熄灭LED4
ldr r0, =~(0<<1) //r0=0xFFFFFFFF
ldr r1, = GPD0DAT
str r0, [r1]
bl delay
// 第2步:点亮LED2,其他熄灭
ldr r0, =~(1<<4) //r0=0xFFFFFFEF
ldr r1, =GPJ0DAT
str r0, [r1]
bl delay
// 第3步:点亮LED3,其他熄灭
ldr r0, =~(1<<5) //r0=0xFFFFFFDF
ldr r1, =GPJ0DAT
str r0, [r1]
bl delay
//熄灭LED3/4/5,点亮LED4
ldr r0, = ((1<<3)|(1<<4)|(1<<5))
ldr r1, =GPJ0DAT
str r0, [r1]
ldr r0, =~(1<<1) //r0=0xFFFFFFFD
ldr r1, = GPD0DAT
str r0, [r1]
bl delay
bl led_run
half:
b half
/* 延时函数:delay*/
delay:
ldr r2,=9000000
ldr r3,=0x0
delay_loop:
//SUB指令:从寄存器Rn中减去shifter_operand表示的数值,
//并将结果保存在目标寄存器Rd中,并根据指令的执行结果
//设置CPSR中的相应标志位
//SUB { sub r2,r2,#1 //r2 = r2 - 1 //CMP指令:使用寄存器Rn的值减去shifter_operand的值, //根据操作的结果更新CPSR中相应的条件标志位,以便后面 //的指令根据相应的条件标志位来判断是否执行 //CMP { cmp r2, r3 bne delay_loop mov pc,lr 配套编译Makefile文件: # 将所有的.o文件链接成.elf文件,“-Ttext 0x0” # 表示程序的运行地址是0x0,由于目前编写的是位置 # 无关码,可以在任一地址运行 # 将elf文件抽取为可在开发板上运行的bin文件 # 将elf文件反汇编保存在dis文件中,调试程序会用 # 添加文件头 # 编译器版本:arm-2009q3 .PHONY: all clean tools CROSS ?= arm-linux- NAME := LED LD := $(CROSS)ld OC := $(CROSS)objcopy OD := $(CROSS)objdump CC := $(CROSS)gcc MK := ../../tools/mk_image/mkv210_image all:$(NAME).bin $(NAME).bin : start.o $(LD) -Ttext 0x0 -o $(NAME).elf $^ $(OC) -O binary $(NAME).elf $(NAME).bin $(OD) -D $(NAME).elf > $(NAME)_elf.dis $(MK) $(NAME).bin # 将当前目录下存在的汇编文件及C文件编译成.o文件 %.o : %.S $(CC) -o $@ $< -c %.o : %.c $(CC) -o $@ $< -c clean: $(RM) *.o *.elf *.bin *.dis *.sd tools: make -C ../../tools/mk_image/ arm-linux-ld:一个链接程序工具,其作用主要是将汇编过的多个二进制文件进行链接,成为一个可执行的二进制文件,这个命令的选项有好多,具体用到的时候大家可以使用--help 选项来查看具体的选项用法。 arm-linux-ld -Ttext 0x0 -o led.elf $^:这句话是将所有的依赖文件连接成ELF格式文件,在连接的过程中,-Ttext 0x0这个选项告诉连接器我的这段程序需要被加载到RAM的0x00000000地址处执行。所以在连接的时候第一条语句的连接地址就是0x00000000,第二条语句就是跟在其后面。有很多人都议论连接地址和运行地址这个怎么说的都有。运行地址可以等于连接地址,还可以认为运行地址是pc指针指向的地址,就是正在执行指令的地址。只要理解了这个概念就可以了。 arm-linux-objcopy:被用来复制一个目标文件的内容到另一个文件中.此选项可以进行格式的转换.在实际编程的,用的最多的就是 将ELF格式的可执行文件转换为二进制文件 arm-linux-objdump:常用来显示二进制文件信息,常用来查看反汇编代码 编译: fly@fly-vm:01-led_s$ make clean rm -f *.o *.elf *.bin *.dis *.sd *.BIN fly@fly-vm:01-led_s$ ls Makefile start.S fly@fly-vm:01-led_s$ make arm-linux-gcc -o start.o start.S -c arm-linux-ld -Ttext 0x0 -o LED.elf start.o arm-linux-objcopy -O binary LED.elf LED.bin arm-linux-objdump -D LED.elf > LED_elf.dis ../../tools/mk_image/mkv210_image LED.bin the checksum 0x000060EB for 228bytes, output: LED.bin.SD.BIN fly@fly-vm:01-led_s$ ls LED.bin LED.bin.SD.BIN LED.elf LED_elf.dis Makefile start.o start.S 3-2.工具mkv210_image代码 /******************************************************************* * > File Name: mkv210_image.c * > Author: fly * > Create Time: 2021-06-17 4/24 12:03:22 +0800 * > Note: 将USB启动时使用的BIN文件制作得到SD启动的Image * 计算校验和,添加16字节文件头,校验和写入第8字节处 *================================================================*/ #include #include #include #include #define ERR_STR strerror(errno) #define SPL_HEADER_SIZE (16) #define SPL_HEADER '@S5PV210$$$$****' #define IMG_SIZE (16*1204) #define FILE_PATH_LEN_MAX (256) char *mk_getCheckSumFile(char *binName) { static char checkSumFileName[FILE_PATH_LEN_MAX] = {0}; //snprintf(checkSumFileName, FILE_PATH_LEN_MAX, '%s%s', 'sd.', binName); snprintf(checkSumFileName, FILE_PATH_LEN_MAX, '%s%s', binName, '.SD.BIN'); return (char*)checkSumFileName; } long mk_getFileLen(FILE* fp) { static long fileLen = 0; fseek(fp, 0L, SEEK_END); fileLen = ftell(fp); fseek(fp, 0L, SEEK_SET); return fileLen; } int main(int argc, char* argv[]) { FILE* fps, *fpd; long nbytes, fileLen; unsigned int checksum, count; char *BUF = NULL, *pBUF = NULL; int i; if(argc != 2){ printf('Usage: %s } /* 打开源BIN文件 */ fps = fopen(argv[1], 'rb'); if (fps == NULL){ printf('fopen %s err: %sn', argv[1], ERR_STR); exit(EXIT_FAILURE); } /* 创建目标BIN文件 */ fpd = fopen(mk_getCheckSumFile(argv[1]), 'w+b'); if (fpd == NULL){ printf('fopen %s err: %sn', mk_getCheckSumFile(argv[1]), ERR_STR); fclose(fps);exit(EXIT_FAILURE); } /* 获取源文件大小 */ fileLen = mk_getFileLen(fps); if(fileLen < (IMG_SIZE - SPL_HEADER_SIZE)){ count = fileLen; }else{ count = IMG_SIZE - SPL_HEADER_SIZE; } BUF = (char *)malloc(IMG_SIZE);/* malloc 16KB BUF */ if (BUF == NULL){ printf('malloc err: %sn', ERR_STR); fclose(fps);fclose(fpd); exit(EXIT_FAILURE); } memcpy(&BUF[0], SPL_HEADER, SPL_HEADER_SIZE); nbytes = fread(BUF+SPL_HEADER_SIZE, 1, count, fps); /* 计算文件检验和 */ pBUF = BUF + SPL_HEADER_SIZE; for(i = 0, checksum = 0; i< IMG_SIZE - SPL_HEADER_SIZE; i++) { checksum += (0x000000FF) & *pBUF++; } pBUF = BUF + 8; *((unsigned int *)pBUF) = checksum; /* 将校验和源文件写入目标文件 */ fwrite(BUF, 1, IMG_SIZE, fpd); printf('the checksum 0x%08X for %ldbytes, output: %sn', checksum, fileLen, mk_getCheckSumFile(argv[1])); free(BUF); fclose(fps); fclose(fpd); return 0; } 配套Makefile .PHONY: all clean CC = gcc SRC = ${wildcard *.c} BIN = ${patsubst %.c, %, $(SRC)} CFLAGS = -g -Wall RM = rm -rf PRJ_PATH= $(shell pwd) all:$(BIN) $(BIN):%:%.c @echo [CC] $@ @$(CC) -o $@ $^ $(CFALGS) -D_PRJ_PATH_=''$(PRJ_PATH)'' clean: $(RM) a.out $(BIN) .*.*.sw? *.sd test: @echo $(PRJ_PATH) .PHONY: clean test 1.OM5开关打到开发板靠下侧(选择启动方式): 2.将BIN文件下载到SD卡 2-1.Windos下使用x210_Fusing_Tool.exe下载(注意使用管理员模式打开) 清理x210_Fusing_Tool.exe文件列表,进入目录:C:UsersflyAppDataRoamingSDFusing,然后删除文件config.ini; 2-2.Linux下载BIN文件到SD卡脚本命令: #!/bin/sh #命令行参数检测 if [ -n '$1' ];then echo 'Source file: $1' else echo 'Usage:$0 exit -1 fi #使用超级用户权限把210.bin读取进来,经过处理再输出到设备sdb上, #跳过该设备的第一个block(每个block的大小为512B) sudo dd iflag=dsync oflag=dsync if=$1 of=/dev/sdb seek=1 另一种更具体的脚本写法: ########################################################### # File Name: s5pv210-irom-sd.sh # Author: fly # Created Time: 2021-06-27 0/25 14:51:59 +0800 ########################################################### #!/bin/bash # s5pv210 irom sd boot fusing tool # display usage message USAGE() { echo Usage: $(basename '$0') ' echo ' device = disk device name of for SD card.' echo ' bootloader = /path/to/*.bin.sd' echo 'e.g. '$(basename '$0')' /dev/sdb boot.bin.sd' } [ `id -u` == 0 ] || { echo 'you must be root user'; exit 1;} [ -z '$1' -o -z '$2' ] && { USAGE; exit 1; } dev='$1' xboot='$2' # validate parameters [ -b '${dev}' ] || { echo '${dev} is not a valid block device'; exit 1; } [ X'${dev}' = X'${dev%%[0-9]}' ] || { echo '${dev} is a partition, please use device, perhaps ${dev%%[0-9]}'; exit 1; } [ -f ${xboot} ] || { echo '${xboot} is not a bootloader binary file.'; exit 1; } # copy the full bootloader image to block device dd if='${xboot}' of='${dev}' bs=512 seek=1 conv=sync sync; sync; sync; echo '^_^ The image is fused successfully' 3.将SD卡插入SD2通道,上电即可查看程序运行状况 接通电源,长按POWER键;可使用串口工具连接UART2,会有打印调试信息输出; 5.参考 1.书籍:ARM嵌入式体系结构与接口技术(Cortex-A8版)(ARM Embedded Architecture and Interface Technology) 2.书籍:嵌入式LinuxC语言程序设计基础教程(C Language Programming of Embedded Linux) 3.使用的交叉编译器1:https://sourcery.mentor.com/public/gnu_toolchain/arm-none-linux-gnueabi/arm-2009q3-67-arm-none-linux-gnueabi-i686-pc-linux-gnu.tar.bz2 4.编译器下载地址2(CSDN):https://download.csdn.net/download/qq_37363920/12333876?utm_medium=distribute.pc_relevant_t0.none-task-download-2%7Edefault%7EBlogCommendFromMachineLearnPai2%7Edefault-1.baidujs&depth_1-utm_source=distribute.pc_relevant_t0.none-task-download-2%7Edefault%7EBlogCommendFromMachineLearnPai2%7Edefault-1.baidujs 5.项目地址:https://gitee.com/x210bv3s/s5pv210-noos-dev 6.S5PV210_UM_REV1.1.pdf:https://download.csdn.net/download/han1202012/8342745?utm_source=iteye_new 7.S5PV210_iROM_ApplicationNote_Preliminary_20091126.pdf:https://download.csdn.net/download/q171884957/8561553 8.S5PV210_iROM_ApplicationNote_Preliminary_20091126.pdf(中文版本):https://blog.csdn.net/I_feige/article/details/104848609 9.x210_Fusing_Tool.exe下载地址:https://download.csdn.net/download/i_feige/11937635
4.运行
SD卡启动
- 六大全新产品系列推出,MCX A微控制器家族迎来创新
- 意法半导体全新STM32C5系列,重新定义入门级微控制器性能与价值,赋能万千智能设备
- 模组复用与整机重测在SRRC、CCC、CTA/NAL认证中的实践操作指南
- 有源晶振与无源晶振的六大区别详解
- 英飞凌持续巩固全球微控制器市场领导地位
- 使用 Keil Studio for Visual Studio Code开发 STM32 设备
- 从控制到系统:TI利用边缘AI重塑嵌入式MCU的边界
- 蓝牙信道探测技术原理与开发套件实践
- Microchip 推出生产就绪型全栈边缘 AI 解决方案,赋能MCU和MPU实现 智能实时决策
- LoRa、LoRaWAN、NB-IoT与4G DTU技术对比及工业无线方案选型分析
