第七章之S5PV210移植到Nandflash
2024-12-20 来源:cnblogs
1,之前的操作都是基于SD卡进行运行的,如今在Nandfalsh中运行u-boot.因为s5p_goni.h配置文件没有配置Nand相关文件,所以先配置Nand文件.
在include/configs/s5p_goni.h中添加一个:#define CONFIG_CMD_NAND
2,根据board_init_r函数中nand_init()如下图:
3,进行nand_init();
4,所以配置文件还需要添加#defnie CONFIG_SYS_MAX_NAND_DEVICE 1,及其 nand基地址#define CONFIG_SYS_NAND_BASE 0xB0E00000
5,查看common/Makefie如图:先把环境变量设成nand
6,在nand_init()中,发现drives/mtd/nand/没有相关的board_nand_init()函数.根据s3c2410修改成s5pv210nand.c:
> File Name: s5pv210_nand.c
> Author:
> Mail:
> Created Time: Wed 09 Aug 2017 03:34:27 PM CST
/* name:Sourcelink
* (C) Copyright 2006 OpenMoko, Inc.
* Author: Harald Welte * * SPDX-License-Identifier: GPL-2.0+ */ #include #include #include #include #define MP0_1CON (*(volatile unsigned long *)0xE02002E0) #define MP0_3CON (*(volatile unsigned long *)0xE0200320) #define MP0_6CON (*(volatile unsigned long *)0xE0200380) /* Nand Flash Configuration Register */ #define AddrCycle 1 /* 5 address cycle */ #define PageSize 0 /* 2KBytes/Page */ #define MLCFlash 0 /* SLC NAND Flash */ #define TWRPH1 1 /* (0+1) * 7.5 > 5ns (tCLH/tALH) */ #define TWRPH0 2 /* (1+1) * 7.5ns > 12ns (tWP) */ #define TACLS 1 /* 7.5ns * 2 > 12ns tALS tCLS */ /* Control Register */ #define MODE 1 /* ENABLE NAND Flash Controller */ #define Reg_nCE0 1 /* Disable chip select */ /* modied by Sourcelink */ static void s5pv210_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) { struct nand_chip *chip = mtd->priv; struct s5pv210_nand *nand = (struct s5pv210_nand *)s5pv210_get_base_nand(); debug('hwcontrol(): 0x%02x 0x%02xn', cmd, ctrl); ulong IO_ADDR_W = (ulong)nand; if (ctrl & NAND_CTRL_CHANGE) { if (ctrl & NAND_CLE) IO_ADDR_W = IO_ADDR_W | 0x8; /* Command Register */ else if (ctrl & NAND_ALE) IO_ADDR_W = IO_ADDR_W | 0xC; /* Address Register */ chip->IO_ADDR_W = (void *)IO_ADDR_W; if (ctrl & NAND_NCE) /* select */ writel(readl(&nand->nfcont) & ~(1 << 1), &nand->nfcont); else /* deselect */ writel(readl(&nand->nfcont) | (1 << 1), &nand->nfcont); } if (cmd != NAND_CMD_NONE) writeb(cmd, chip->IO_ADDR_W); else chip->IO_ADDR_W = &nand->nfdata; } static int s5pv210_dev_ready(struct mtd_info *mtd) { struct s5pv210_nand *nand = (struct s5pv210_nand *)s5pv210_get_base_nand(); debug('dev_readyn'); return readl(&nand->nfstat) & 0x01; } #ifdef CONFIG_S3C2410_NAND_HWECC void s5pv210_nand_enable_hwecc(struct mtd_info *mtd, int mode) { struct s5pv210_nand *nand = (struct s5pv210_nand *)s5pv210_get_base_nand(); debug('s5pv210_nand_enable_hwecc(%p, %d)n', mtd, mode); writel(readl(&nand->nfconf) | S3C2410_NFCONF_INITECC, &nand->nfconf); } static int s5pv210_nand_calculate_ecc(struct mtd_info *mtd, const u_char *dat, u_char *ecc_code) { struct s5pv210_nand *nand = (struct s5pv210_nand *)s5pv210_get_base_nand(); ecc_code[0] = readb(&nand->nfecc); ecc_code[1] = readb(&nand->nfecc + 1); ecc_code[2] = readb(&nand->nfecc + 2); debug('s5pv210_nand_calculate_hwecc(%p,): 0x%02x 0x%02x 0x%02xn', mtd , ecc_code[0], ecc_code[1], ecc_code[2]); return 0; } static int s5pv210_nand_correct_data(struct mtd_info *mtd, u_char *dat, u_char *read_ecc, u_char *calc_ecc) { if (read_ecc[0] == calc_ecc[0] && read_ecc[1] == calc_ecc[1] && read_ecc[2] == calc_ecc[2]) return 0; printf('s5pv210_nand_correct_data: not implementedn'); return -1; } #endif /* * add by Sourcelink * nand_select_chip * @mtd: MTD device structure * @ctl: 0 to select, -1 for deselect * * Default select function for 1 chip devices. */ static void s5pv210_nand_select_chip(struct mtd_info *mtd, int ctl) { struct nand_chip *chip = mtd->priv; switch (ctl) { case -1: /* deselect the chip */ chip->cmd_ctrl(mtd, NAND_CMD_NONE, 0 | NAND_CTRL_CHANGE); break; case 0: /* Select the chip */ chip->cmd_ctrl(mtd, NAND_CMD_NONE, NAND_NCE | NAND_CTRL_CHANGE); break; default: BUG(); } } /* modied by Sourcelink */ int board_nand_init(struct nand_chip *nand) { u32 cfg; struct s5pv210_nand *nand_reg = (struct s5pv210_nand *)(struct s5pv210_nand *)s5pv210_get_base_nand(); debug('board_nand_init()n'); /* initialize hardware */ /* HCLK_PSYS=133MHz(7.5ns) */ cfg = ((AddrCycle << 1) | (PageSize << 2) | (MLCFlash << 3) | (TWRPH1 << 4) | (TWRPH0 << 8) | (TACLS << 12)); writel(cfg, &nand_reg->nfconf); writel((Reg_nCE0 << 1) | (MODE << 0), &nand_reg->nfcont); /* Disable chip select and Enable NAND Flash Controller */ /* * port map * CE1-> Xm0CSn2 -> MP01_2 * CLE-> Xm0FCLE -> MP03_0 * ALE-> Xm0FALE -> MP03_1 * WE -> Xm0FWEn -> MP03_2 * RE -> Xm0FREn -> MP03_3 * R/B1->Xm0FRnB0-> MP03_4 * IO[7:0]->Xm0DATA[7:0]->MP0_6[7:0] * */ /* 设置片选引脚 CSN[0] */ MP0_1CON &= ~(0x00000F00); MP0_1CON |= (3 << 8); /* CLE,ALE,WE,RE,R/B1 */ MP0_3CON &= ~(0x000FFFFF); MP0_3CON |= 0x00022222; /* DATA */ MP0_6CON = 0x22222222; /* initialize nand_chip data structure */ nand->IO_ADDR_R = (void *)&nand_reg->nfdata; nand->IO_ADDR_W = (void *)&nand_reg->nfdata; nand->select_chip = s5pv210_nand_select_chip; /* read_buf and write_buf are default */ /* read_byte and write_byte are default */ /* hwcontrol always must be implemented */ nand->cmd_ctrl = s5pv210_hwcontrol; nand->dev_ready = s5pv210_dev_ready; #ifdef CONFIG_S3C2410_NAND_HWECC nand->ecc.hwctl = s5pv210_nand_enable_hwecc; nand->ecc.calculate = s5pv210_nand_calculate_ecc; nand->ecc.correct = s5pv210_nand_correct_data; nand->ecc.mode = NAND_ECC_HW; nand->ecc.size = CONFIG_SYS_NAND_ECCSIZE; nand->ecc.bytes = CONFIG_SYS_NAND_ECCBYTES; nand->ecc.strength = 1; #else nand->ecc.mode = NAND_ECC_SOFT; #endif #ifdef CONFIG_S3C2410_NAND_BBT nand->bbt_options |= NAND_BBT_USE_FLASH; #endif debug('end of nand_initn'); return 0; } 在62行添加#define S5PV210_NAND_BASE 0xB0E00000 8,然后在arch/arm/include/asm/arch-s5pc1xx/下创建文件nand_reg.h,定义 NAND 的寄存器结构体 /************************************************************************* > File Name: nand_reg.h > Author: > Mail: > Created Time: Wed 09 Aug 2017 04:11:49 PM CST ************************************************************************/ #ifndef _NAND_REG_H #define _NAND_REG_H #ifndef __ASSEMBLY__ static inline struct s5pv210_nand *s5pv210_get_base_nand(void) { return (struct s5pv210_nand *)S5PV210_NAND_BASE; } struct s5pv210_nand { unsigned int nfconf; unsigned int nfcont; unsigned int nfcmmd; unsigned int nfaddr; unsigned int nfdata; unsigned int nfmeccd0; unsigned int nfmeccd1; unsigned int nfseccd; unsigned int nfsblk; unsigned int nfeblk; unsigned int nfstat; unsigned int nfeccerr0; unsigned int nfeccerr1; unsigned int nfmecc0; unsigned int nfmecc1; unsigned int nfsecc; unsigned int nfmlcbitpt; }; #endif #endif 9,修改drivers/mtd/nand/Makefile,将s5pv210_nand.c编译进uboot 10,添加环境变量偏移量,在配置文件里添加:#define CONFIG_ENV_OFFSET,移植NAND,必需要OFFSET 11,然后,再make,生成可以移值到Nand falsh的u-boot.7,在vim arch/arm/include/asm/arch-s5pc1xx/cpu.h 下添加:
- 六大全新产品系列推出,MCX A微控制器家族迎来创新
- 意法半导体全新STM32C5系列,重新定义入门级微控制器性能与价值,赋能万千智能设备
- 模组复用与整机重测在SRRC、CCC、CTA/NAL认证中的实践操作指南
- 有源晶振与无源晶振的六大区别详解
- 英飞凌持续巩固全球微控制器市场领导地位
- 使用 Keil Studio for Visual Studio Code开发 STM32 设备
- 从控制到系统:TI利用边缘AI重塑嵌入式MCU的边界
- 蓝牙信道探测技术原理与开发套件实践
- Microchip 推出生产就绪型全栈边缘 AI 解决方案,赋能MCU和MPU实现 智能实时决策
- LoRa、LoRaWAN、NB-IoT与4G DTU技术对比及工业无线方案选型分析
