单片机
内核启动后,lcd显示logo失败
2025-01-06 来源:cnblogs
针对-s5pv210,但对其他平台也使用
lcd显示logo失败,若显示成功默认的logo是一只企鹅,但是串口打印“Start display and show logo”,但是LCD屏没有显示
[    0.833071] s3cfb s3cfb: [fb2] dma: 0x465ab000, cpu: 0xe1000000, size: 0x005dc000
[    0.845112] FIMD src sclk = 166750000
[    0.965701] s3cfb s3cfb: registered successfully
[    0.965744] Start display and show logo
原因:LCD驱动有问题。
第一步:在arch/arm/mach-s5pv210/mach-smdkc110.c当中,约712行,将之前的LCD初始化删掉,并修改如下:
#ifdef CONFIG_FB_S3C_LTE480WV
static struct s3cfb_lcd wvga_s70 = {
        .width = 800,
        .height = 480,
        .p_width = 154,
        .p_height = 96,
        .bpp = 32,
        .freq = 65,
        .timing = {
                .h_fp = 80,
                .h_bp = 36,
                .h_sw = 10,
                .v_fp = 22,
                .v_fpe = 1,
                .v_bp = 15,
                .v_bpe = 1,
                .v_sw = 8,
        .polarity = {
                .rise_vclk = 0,
                .inv_hsync = 1,
                .inv_vsync = 1,
                .inv_vden = 0,
static void lcd_cfg_gpio(struct platform_device *pdev)
    int i;
    for (i = 0; i < 8; i++) {
        s3c_gpio_cfgpin(S5PV210_GPF0(i), S3C_GPIO_SFN(2));
        s3c_gpio_setpull(S5PV210_GPF0(i), S3C_GPIO_PULL_NONE);
        s3c_gpio_cfgpin(S5PV210_GPF1(i), S3C_GPIO_SFN(2));
        s3c_gpio_setpull(S5PV210_GPF1(i), S3C_GPIO_PULL_NONE);
        s3c_gpio_cfgpin(S5PV210_GPF2(i), S3C_GPIO_SFN(2));
        s3c_gpio_setpull(S5PV210_GPF2(i), S3C_GPIO_PULL_NONE);
    for (i = 0; i < 4; i++) {
        s3c_gpio_cfgpin(S5PV210_GPF3(i), S3C_GPIO_SFN(2));
        s3c_gpio_setpull(S5PV210_GPF3(i), S3C_GPIO_PULL_NONE);
    /* mDNIe SEL: why we shall write 0x2 ? */
    writel(0x2, S5P_MDNIE_SEL);
    /* drive strength to max */
    writel(0xaaaaaaaa, S5PV210_GPF0_BASE + 0xc);
    writel(0xaaaaaaaa, S5PV210_GPF1_BASE + 0xc);
    writel(0xaaaaaaaa, S5PV210_GPF2_BASE + 0xc);
    writel(0x000000aa, S5PV210_GPF3_BASE + 0xc);
#define S5PV210_GPD_0_0_TOUT_0  (0x2)
#define S5PV210_GPD_0_1_TOUT_1  (0x2 << 4)
#define S5PV210_GPD_0_2_TOUT_2  (0x2 << 8)
#define S5PV210_GPD_0_3_TOUT_3  (0x2 << 12)
static int lcd_backlight_on(struct platform_device *pdev)
    int err;
    err = gpio_request(S5PV210_GPD0(3), 'GPD0');
    if (err) {
        printk(KERN_ERR 'failed to request GPD0 for '
            'lcd backlight controln');
        return err;
    gpio_direction_output(S5PV210_GPD0(3), 1);
    s3c_gpio_cfgpin(S5PV210_GPD0(3), S5PV210_GPD_0_3_TOUT_3);
    gpio_free(S5PV210_GPD0(3));
    return 0;
static int lcd_backlight_off(struct platform_device *pdev, int onoff)
    int err;
    if (err) {
        return err;
    gpio_direction_output(S5PV210_GPD0(3), 0);
    return 0;
static int lcd_reset_lcd(struct platform_device *pdev)
    int err;
    err = gpio_request(S5PV210_GPH0(6), 'GPH0');
    if (err) {
        printk(KERN_ERR 'failed to request GPH0 for '
                'lcd reset controln');
        return err;
    gpio_direction_output(S5PV210_GPH0(6), 1);
    mdelay(100);
    gpio_set_value(S5PV210_GPH0(6), 0);
    mdelay(10);
    gpio_set_value(S5PV210_GPH0(6), 1);
    mdelay(10);
    gpio_free(S5PV210_GPH0(6));
    return 0;
static struct s3c_platform_fb lte480wv_fb_data __initdata = {
    .hw_ver    = 0x62,
    .nr_wins = 5,
    .default_win = CONFIG_FB_S3C_DEFAULT_WINDOW,
    .swap = FB_SWAP_WORD | FB_SWAP_HWORD,
       .lcd = &wvga_s70,
    .cfg_gpio    = lcd_cfg_gpio,
    .backlight_on    = lcd_backlight_on,
    .backlight_onoff    = lcd_backlight_off,
    .reset_lcd    = lcd_reset_lcd,
#endif
第二步:使用make menuconfig,去配置当前显示的windows,请配置为windows0
Device Drivers
  -->Graphics support
     --> Support for frame buffer devices
        --> (2)     Default Window (0-4)
修改为
Device Drivers
  -->Graphics support
         --> (0)     Default Window (0-4)
进入单片机查看更多内容>>
相关视频
  • 【TI MSPM0 应用实战】智能小车+工业角度编码器+血氧仪+烟雾探测器!硬核参考设计详解!
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
  • 直播回放: Microchip Timberwolf™ 音频处理器在线研讨会
  • 基于灵动MM32W0系列MCU的指夹血氧仪控制及OTA升级应用方案分享
精选电路图
  • 1瓦线性调频增强器
  • 家用电器遥控器
  • 12V 转 28V DC-DC 变换器(基于 LM2585)
  • 红外开关
  • DS1669数字电位器
  • HA1377 桥式放大器 BCL 电容 17W(汽车音频)
    相关电子头条文章
